[U-Boot] [PATCH V2 2/2] USB-CDC: called handle_interrupts inside usb_eth_send
The patch removes an endless loop in the usb_eth_send if the tx_complete is not called before going in the loop. The driver interrupt routine is called allowing the driver to check if the TX is completed.
Signed-off-by: Stefano Babic sbabic@denx.de ---
Changes from V1: - Comments by Remy Bohmer: moved usb_ep_queue inside timeout to not break at91 code
drivers/usb/gadget/ether.c | 12 ++++++++++-- 1 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/gadget/ether.c b/drivers/usb/gadget/ether.c index 0b4ed18..f082c03 100644 --- a/drivers/usb/gadget/ether.c +++ b/drivers/usb/gadget/ether.c @@ -1808,6 +1808,8 @@ static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int le struct usb_request *req = NULL;
struct eth_dev *dev = &l_ethdev; + unsigned long ts; + unsigned long timeout = USB_CONNECT_TIMEOUT; dprintf("%s:...\n",__func__);
req = dev->tx_req; @@ -1833,13 +1835,19 @@ static int usb_eth_send(struct eth_device* netdev, volatile void* packet, int le #endif dev->tx_qlen=1;
+ ts = get_timer(0); + packet_sent=0; retval = usb_ep_queue (dev->in_ep, req, GFP_ATOMIC);
if (!retval) - dprintf("%s: packet queued\n",__func__); + debug("%s: packet queued\n",__func__); while(!packet_sent) { - packet_sent=0; + if (get_timer(ts) > timeout) { + printf ("timeout sending packets to usb ethernet\n"); + return -1; + } + usb_gadget_handle_interrupts(); }
- unsigned long ts;
- unsigned long timeout = USB_CONNECT_TIMEOUT;
Please keep an empty line after the declaration block.
- ts = get_timer(0);
- packet_sent=0;
Please keep the style consistent and add spaces before/after =.
if (!retval)
while(!packet_sent) {debug("%s: packet queued\n",__func__);
packet_sent=0;
Please be consistent and remove space before paren. U-Boot nwo seems to follow the Linux coding style...
WBR, Sergei
2010/8/14 Stefano Babic sbabic@denx.de:
Changes from V1:
Sorry, patch does not apply any more after applying the series from Vitaly yesterday. please rebase.
Kind regards,
Remy
Changes from V1:
No problem, I rebase it.
Best regards, Stefano
Remy Bohmer
Sergei Shtylyov
Stefano Babic
