[PATCH v<9>] arm: add initial support for the Phytium Pomelo Board
This adds platform code and the device tree for the Phytium Pomelo Board. The initial support comprises the UART and the PCIE.
Signed-off-by: weichangzheng nicholas_zheng@outlook.com Changes since v1: updated to DT Changes since v2: Modify some explicit types and macro Changes since v3: Modify some SDRAM related macro definitions and distro_bootcmd Changes since v4: Modify distro_bootcmd Changes since v5: Modify the CPU node description of the DT Changes since v6: Modify DT Changes since v7: Modify DT Changes since v8: Temporarily remove the CPU node description of the DT --- arch/arm/Kconfig | 20 ++++ arch/arm/dts/Makefile | 1 + arch/arm/dts/phytium-pomelo.dts | 50 ++++++++++ board/phytium/pomelo/Kconfig | 12 +++ board/phytium/pomelo/MAINTAINERS | 8 ++ board/phytium/pomelo/Makefile | 14 +++ board/phytium/pomelo/cpu.h | 73 ++++++++++++++ board/phytium/pomelo/ddr.c | 161 +++++++++++++++++++++++++++++++ board/phytium/pomelo/pcie.c | 60 ++++++++++++ board/phytium/pomelo/pll.c | 73 ++++++++++++++ board/phytium/pomelo/pomelo.c | 118 ++++++++++++++++++++++ board/phytium/pomelo/sec.c | 37 +++++++ configs/pomelo_defconfig | 18 ++++ include/configs/pomelo.h | 44 +++++++++ 14 files changed, 689 insertions(+) create mode 100644 arch/arm/dts/phytium-pomelo.dts create mode 100644 board/phytium/pomelo/Kconfig create mode 100644 board/phytium/pomelo/MAINTAINERS create mode 100644 board/phytium/pomelo/Makefile create mode 100644 board/phytium/pomelo/cpu.h create mode 100644 board/phytium/pomelo/ddr.c create mode 100644 board/phytium/pomelo/pcie.c create mode 100644 board/phytium/pomelo/pll.c create mode 100644 board/phytium/pomelo/pomelo.c create mode 100644 board/phytium/pomelo/sec.c create mode 100644 configs/pomelo_defconfig create mode 100644 include/configs/pomelo.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0448787b8b..029af85fcb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1818,6 +1818,25 @@ config TARGET_DURIAN Support for durian platform. It has 2GB Sdram, uart and pcie.
+config TARGET_POMELO + bool "Support Phytium Pomelo Platform" + select ARM64 + select DM + select AHCI + select SCSI_AHCI + select AHCI_PCI + select BLK + select PCI + select DM_PCI + select SCSI + select DM_SCSI + select DM_SERIAL + select DM_ETH if NET + imply CMD_PCI + help + Support for pomelo platform. + It has 8GB Sdram, uart and pcie. + config TARGET_PRESIDIO_ASIC bool "Support Cortina Presidio ASIC Platform" select ARM64 @@ -2038,6 +2057,7 @@ source "board/toradex/colibri_pxa270/Kconfig" source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" source "board/phytium/durian/Kconfig" +source "board/phytium/pomelo/Kconfig" source "board/xen/xenguest_arm64/Kconfig" source "board/keymile/Kconfig"
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9fb38682e6..45d0340bd3 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1107,6 +1107,7 @@ dtb-$(CONFIG_TARGET_MX53PPD) += imx53-ppd.dtb dtb-$(CONFIG_TARGET_TOTAL_COMPUTE) += total_compute.dtb
dtb-$(CONFIG_TARGET_DURIAN) += phytium-durian.dtb +dtb-$(CONFIG_TARGET_POMELO) += phytium-pomelo.dtb
dtb-$(CONFIG_TARGET_PRESIDIO_ASIC) += ca-presidio-engboard.dtb
diff --git a/arch/arm/dts/phytium-pomelo.dts b/arch/arm/dts/phytium-pomelo.dts new file mode 100644 index 0000000000..3f809c0dbb --- /dev/null +++ b/arch/arm/dts/phytium-pomelo.dts @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * dts file for Phytium Pomelo board + * Copyright (C) 2021, Phytium Ltd. + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ +/dts-v1/; + +/ { + model = "Phytium Pomelo Board"; + compatible = "phytium,d2000-pomelo", "phytium,d2000"; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + serial0 = &uart0; + }; + + sysclk_48mhz: clk48mhz { + compatible = "fixed-clock"; + #clock-cells = <0x0>; + clock-frequency = <48000000>; + clock-output-names = "sysclk_48mhz"; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + uart0: serial@28001000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0 0x28001000 0x0 0x1000>; + clocks = <&sysclk_48mhz>; + }; + + pcie@40000000 { + compatible = "pci-host-ecam-generic"; + device_type = "pci"; + #address-cells = <3>; + #size-cells = <2>; + reg = <0x0 0x40000000 0x0 0x10000000>; + ranges = <0x01000000 0x00 0x00000000 0x0 0x50000000 0x0 0x00F00000>, + <0x02000000 0x00 0x58000000 0x0 0x58000000 0x0 0x28000000>, + <0x43000000 0x10 0x00000000 0x10 0x00000000 0x10 0x00000000>; + }; + }; +}; diff --git a/board/phytium/pomelo/Kconfig b/board/phytium/pomelo/Kconfig new file mode 100644 index 0000000000..281aa8feff --- /dev/null +++ b/board/phytium/pomelo/Kconfig @@ -0,0 +1,12 @@ +if TARGET_POMELO + +config SYS_BOARD + default "pomelo" + +config SYS_VENDOR + default "phytium" + +config SYS_CONFIG_NAME + default "pomelo" + +endif diff --git a/board/phytium/pomelo/MAINTAINERS b/board/phytium/pomelo/MAINTAINERS new file mode 100644 index 0000000000..d76a4a026e --- /dev/null +++ b/board/phytium/pomelo/MAINTAINERS @@ -0,0 +1,8 @@ +POMELO BOARD +M: lixinde lixinde@phytium.com.cn +M: weichangzheng weichangzheng@phytium.com.cn +S: Maintained +F: board/phytium/pomelo/* +F: include/configs/pomelo.h +F: configs/pomelo_defconfig +F: arch/arm/dts/phytium-pomelo.dts diff --git a/board/phytium/pomelo/Makefile b/board/phytium/pomelo/Makefile new file mode 100644 index 0000000000..b9cb3609bd --- /dev/null +++ b/board/phytium/pomelo/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2021 +# lixinde lixinde@phytium.com.cn +# weichangzheng weichangzheng@phytium.com.cn +# + +obj-y += pomelo.o +obj-y += pll.o +obj-y += pcie.o +obj-y += ddr.o +obj-y += sec.o + + diff --git a/board/phytium/pomelo/cpu.h b/board/phytium/pomelo/cpu.h new file mode 100644 index 0000000000..005ea5982b --- /dev/null +++ b/board/phytium/pomelo/cpu.h @@ -0,0 +1,73 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2021 + * Phytium Technology Ltd <www.phytium.com> + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#ifndef _FT_POMELO_H +#define _FT_POMELO_H + +/* SMCCC ID */ +#define CPU_SVC_VERSION 0xC2000F00 +#define CPU_GET_RST_SOURCE 0xC2000F01 +#define CPU_INIT_PLL 0xC2000F02 +#define CPU_INIT_PCIE 0xC2000F03 +#define CPU_INIT_MEM 0xC2000F04 +#define CPU_INIT_SEC_SVC 0xC2000F05 + +/*CPU RESET*/ +#define CPU_RESET_POWER_ON 0x1 +#define CPU_RESET_PLL 0x4 +#define CPU_RESET_WATCH_DOG 0x8 + +/* PLL */ +#define PARAMETER_PLL_MAGIC 0x54460010 + +/* PCIE */ +#define PARAMETER_PCIE_MAGIC 0x54460011 +#define CFG_INDEPENDENT_TREE 0x0 +#define PCI_PEU0 0x1 +#define PCI_PEU1 0x1 +#define PEU1_OFFSET 16 +#define PEU_C_OFFSET_MODE 16 +#define PEU_C_OFFSET_SPEED 0 +#define RC_MODE 0x1 +#define X8X8 0x1 +#define GEN3 3 + +/* DDR */ +#define PARAMETER_MCU_MAGIC 0x54460014 +#define PARAM_MCU_VERSION 0x1 +#define PARAM_MCU_SIZE 0x100 +#define PARAM_CH_ENABLE 0x3 +#define PARAM_ECC_ENABLE 0x3 +#define PARAM_FORCE_SPD_DISABLE 0x0 +#define PARAM_MCU_MISC_ENABLE 0x0 + +#define UDIMM_TYPE 0x2 +#define DIMM_X8 0x1 +#define NO_MIRROR 0x0 +#define NO_ECC_TYPE 0 +#define DDR4_TYPE 0xC + +/* SEC */ +#define PARAMETER_COMMON_MAGIC 0x54460013 + +/* FLUSH L3 CASHE */ +#define HNF_COUNT 0x8 +#define HNF_PSTATE_REQ (HNF_BASE + 0x10) +#define HNF_PSTATE_STAT (HNF_BASE + 0x18) +#define HNF_PSTATE_OFF 0x0 +#define HNF_PSTATE_SFONLY 0x1 +#define HNF_PSTATE_HALF 0x2 +#define HNF_PSTATE_FULL 0x3 +#define HNF_STRIDE 0x10000 +#define HNF_BASE (unsigned long)(0x3A200000) +void ddr_init(void); +void sec_init(void); +void check_reset(void); +void pcie_init(void); + +#endif /* _FT_POMELO_H */ diff --git a/board/phytium/pomelo/ddr.c b/board/phytium/pomelo/ddr.c new file mode 100644 index 0000000000..c6dbed9639 --- /dev/null +++ b/board/phytium/pomelo/ddr.c @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct ddr_spd { + /******************* read from spd *****************/ + u8 dimm_type; /* 1: RDIMM;2: UDIMM;3: SODIMM;4: LRDIMM */ + u8 data_width; /* 0: x4; 1: x8; 2: x16 */ + u8 mirror_type;/* 0: stardard; 1: mirror */ + u8 ecc_type; /* 0: no-ecc; 1:ecc */ + u8 dram_type; /* 0xB: DDR3; 0xC: DDR4 */ + u8 rank_num; + u8 row_num; + u8 col_num; + + u8 bg_num; /*only DDR4*/ + u8 bank_num; + u16 module_manufacturer_id; + u16 taamin; + u16 trcdmin; + + u16 trpmin; + u16 trasmin; + u16 trcmin; + u16 tfawmin; + + u16 trrd_smin; /*only DDR4*/ + u16 trrd_lmin; /*only DDR4*/ + u16 tccd_lmin; /*only DDR4*/ + u16 twrmin; + + u16 twtr_smin; /*only DDR4*/ + u16 twtr_lmin; /*only DDR4*/ + u16 twtrmin; /*only DDR3*/ + u16 trrdmin; /*only DDR3*/ + + /******************* RCD control words *****************/ + u8 f0rc03; /*bit[3:2]:CS bit[1:0]:CA */ + u8 f0rc04; /*bit[3:2]:ODT bit[1:0]:CKE */ + u8 f0rc05; /*bit[3:2]:CLK-A side bit[1:0]:CLK-B side */ + u8 bc00; + u8 bc01; + u8 bc02; + u8 bc03; + u8 bc04; + + u8 bc05; + u8 f5bc5x; + u8 f5bc6x; + /******************* LRDIMM special *****************/ + u8 vrefdq_pr0; + u8 vrefdq_mdram; + u8 rtt_mdram_1866; + u8 rtt_mdram_2400; + u8 rtt_mdram_3200; + + u8 drive_dram; + u8 odt_dram_1866; + u8 odt_dram_2400; + u8 odt_dram_3200; + u8 park_dram_1866; + u8 park_dram_2400; + u8 park_dram_3200; + u8 rcd_num; +} __attribute((aligned(4))); + +struct mcu_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + + u8 ch_enable; + u8 misc1_enable; + u8 misc2_enable; + u8 force_spd_enable; + u8 misc3_enable; + u8 train_debug; + u8 train_recover; + u8 rev2[9]; + + struct ddr_spd ddr_spd_info[2]; +} __attribute((aligned(4))); + +static void get_mcu_up_info_default(struct mcu_config *pm) +{ + pm->magic = PARAMETER_MCU_MAGIC; + pm->version = PARAM_MCU_VERSION; + pm->size = PARAM_MCU_SIZE; + pm->ch_enable = PARAM_CH_ENABLE; + pm->misc1_enable = PARAM_ECC_ENABLE; + pm->force_spd_enable = PARAM_FORCE_SPD_DISABLE; + pm->misc3_enable = PARAM_MCU_MISC_ENABLE; + pm->train_recover = 0x0; +} + +static u8 init_dimm_param(u8 ch, struct mcu_config *pm) +{ + debug("manual config dimm info...\n"); + pm->ddr_spd_info[ch].dimm_type = UDIMM_TYPE; + pm->ddr_spd_info[ch].data_width = DIMM_X8; + pm->ddr_spd_info[ch].mirror_type = NO_MIRROR; + pm->ddr_spd_info[ch].ecc_type = NO_ECC_TYPE; + pm->ddr_spd_info[ch].dram_type = DDR4_TYPE; + pm->ddr_spd_info[ch].rank_num = 1; + pm->ddr_spd_info[ch].row_num = 16; + pm->ddr_spd_info[ch].col_num = 10; + pm->ddr_spd_info[ch].bg_num = 4; + pm->ddr_spd_info[ch].bank_num = 4; + pm->ddr_spd_info[ch].taamin = 13750; + pm->ddr_spd_info[ch].trcdmin = 13750; + + pm->ddr_spd_info[ch].trpmin = 13750; + pm->ddr_spd_info[ch].trasmin = 32000; + pm->ddr_spd_info[ch].trcmin = 45750; + pm->ddr_spd_info[ch].tfawmin = 21000; + + pm->ddr_spd_info[ch].trrd_smin = 3000; + pm->ddr_spd_info[ch].trrd_lmin = 4900; + pm->ddr_spd_info[ch].tccd_lmin = 5000; + pm->ddr_spd_info[ch].twrmin = 15000; + + pm->ddr_spd_info[ch].twtr_smin = 2500; + pm->ddr_spd_info[ch].twtr_lmin = 7500; + + return 0; +} + +void get_default_mcu_info(u8 *data) +{ + get_mcu_up_info_default((struct mcu_config *)data); +} + +void fix_mcu_info(u8 *data) +{ + struct mcu_config *mcu_info = (struct mcu_config *)data; + + for (int ch = 0; ch < 2; ch++) + init_dimm_param(ch, mcu_info); +} + +void ddr_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + get_default_mcu_info(buffer); + fix_mcu_info(buffer); + + arm_smccc_smc(CPU_INIT_MEM, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("DRAM init failed :0x%lx\n", res.a0); +} diff --git a/board/phytium/pomelo/pcie.c b/board/phytium/pomelo/pcie.c new file mode 100644 index 0000000000..698d82fd8d --- /dev/null +++ b/board/phytium/pomelo/pcie.c @@ -0,0 +1,60 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct pcu_ctr { + u32 base_config[3]; + u32 equalization[3]; + u8 rev[80]; +} __attribute((aligned(4))); + +struct pcu_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + u32 independent_tree; + u32 base_cfg; + u8 rev2[16]; + struct pcu_ctr ctr_cfg[2]; +} __attribute((aligned(4))); + +struct pcu_config const peu_base_info = { + .magic = PARAMETER_PCIE_MAGIC, + .version = 0x2, + .size = 0x100, + .independent_tree = CFG_INDEPENDENT_TREE, + .base_cfg = ((PCI_PEU1 | (X8X8 << 1)) << PEU1_OFFSET | (PCI_PEU0 | (X8X8 << 1))), + .ctr_cfg[0].base_config[0] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].base_config[1] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].base_config[2] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[0] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[1] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[1].base_config[2] = (RC_MODE << PEU_C_OFFSET_MODE) | (GEN3 << PEU_C_OFFSET_SPEED), + .ctr_cfg[0].equalization[0] = 0x7, + .ctr_cfg[0].equalization[1] = 0x7, + .ctr_cfg[0].equalization[2] = 0x7, + .ctr_cfg[1].equalization[0] = 0x7, + .ctr_cfg[1].equalization[1] = 0x7, + .ctr_cfg[1].equalization[2] = 0x7, +}; + +void pcie_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &peu_base_info, sizeof(peu_base_info)); + arm_smccc_smc(CPU_INIT_PCIE, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("PCIE init failed :0x%lx\n", res.a0); +} diff --git a/board/phytium/pomelo/pll.c b/board/phytium/pomelo/pll.c new file mode 100644 index 0000000000..a66ffddf09 --- /dev/null +++ b/board/phytium/pomelo/pll.c @@ -0,0 +1,73 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct pll_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + u32 core_pll; + u32 res1; + u32 lmu_pll; + u32 res2; + u32 res3; + u32 res4; + u32 res5; +} __attribute((aligned(4))); + +struct pll_config const pll_base_info = { + .magic = PARAMETER_PLL_MAGIC, + .version = 0x1, + .size = 0x30, + .core_pll = 2300, /*MHz*/ + .lmu_pll = 667, /*MHz*/ +}; + +u32 get_reset_source(void) +{ + struct arm_smccc_res res; + + arm_smccc_smc(CPU_GET_RST_SOURCE, 0, 0, 0, 0, 0, 0, 0, &res); + return res.a0; +} + +void pll_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &pll_base_info, sizeof(pll_base_info)); + arm_smccc_smc(CPU_INIT_PLL, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("PLL init failed :0x%lx\n", res.a0); +} + +void check_reset(void) +{ + u32 rst; + + rst = get_reset_source(); + + switch (rst) { + case CPU_RESET_POWER_ON: + pll_init(); + break; + case CPU_RESET_PLL: + break; + case CPU_RESET_WATCH_DOG: + break; + default: + panic("other reset source\n"); + } +} diff --git a/board/phytium/pomelo/pomelo.c b/board/phytium/pomelo/pomelo.c new file mode 100644 index 0000000000..4fbe1e5835 --- /dev/null +++ b/board/phytium/pomelo/pomelo.c @@ -0,0 +1,118 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <command.h> +#include <init.h> +#include <asm/armv8/mmu.h> +#include <asm/io.h> +#include <linux/arm-smccc.h> +#include <scsi.h> +#include <init.h> +#include <asm/u-boot.h> +#include "cpu.h" + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + debug("Phytium ddr init\n"); + ddr_init(); + + gd->mem_clk = 0; + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, 0x7b000000); + + sec_init(); + debug("PBF relocate done\n"); + + return 0; +} + +int board_init(void) +{ + return 0; +} + +void reset_cpu(void) +{ + struct arm_smccc_res res; + + debug("run in reset cpu\n"); + arm_smccc_smc(0x84000009, 0, 0, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("reset cpu error, %lx\n", res.a0); +} + +int mach_cpu_init(void) +{ + check_reset(); + return 0; +} + +int board_early_init_f(void) +{ + pcie_init(); + return 0; +} + +static struct mm_region pomelo_mem_map[] = { + { + .virt = 0x0UL, + .phys = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | + PTE_BLOCK_UXN + }, + { + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0x7b000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_NS | + PTE_BLOCK_INNER_SHARE + }, + { + 0, + } +}; + +struct mm_region *mem_map = pomelo_mem_map; + +int __asm_flush_l3_dcache(void) +{ + int i, pstate; + + for (i = 0; i < HNF_COUNT; i++) + writeq(HNF_PSTATE_SFONLY, HNF_PSTATE_REQ + i * HNF_STRIDE); + for (i = 0; i < HNF_COUNT; i++) { + do { + pstate = readq(HNF_PSTATE_STAT + i * HNF_STRIDE); + } while ((pstate & 0xf) != (HNF_PSTATE_SFONLY << 2)); + } + + for (i = 0; i < HNF_COUNT; i++) + writeq(HNF_PSTATE_FULL, HNF_PSTATE_REQ + i * HNF_STRIDE); + + return 0; +} + +int last_stage_init(void) +{ + int ret; + + /* pci e */ + pci_init(); + /* scsi scan */ + ret = scsi_scan(true); + if (ret) { + printf("scsi scan failed\n"); + return CMD_RET_FAILURE; + } + return ret; +} diff --git a/board/phytium/pomelo/sec.c b/board/phytium/pomelo/sec.c new file mode 100644 index 0000000000..aeb3983f01 --- /dev/null +++ b/board/phytium/pomelo/sec.c @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#include <stdio.h> +#include <string.h> +#include <linux/arm-smccc.h> +#include <init.h> +#include "cpu.h" + +struct common_config { + u32 magic; + u32 version; + u32 size; + u8 rev1[4]; + u64 core_bit_map; +} __attribute((aligned(4))); + +struct common_config const common_base_info = { + .magic = PARAMETER_COMMON_MAGIC, + .version = 0x1, + .core_bit_map = 0x3333, +}; + +void sec_init(void) +{ + u8 buffer[0x100]; + struct arm_smccc_res res; + + memcpy(buffer, &common_base_info, sizeof(common_base_info)); + arm_smccc_smc(CPU_INIT_SEC_SVC, 0, (u64)buffer, 0, 0, 0, 0, 0, &res); + if (res.a0 != 0) + panic("SEC init failed :0x%lx\n", res.a0); +} diff --git a/configs/pomelo_defconfig b/configs/pomelo_defconfig new file mode 100644 index 0000000000..a963d85fbb --- /dev/null +++ b/configs/pomelo_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARM_SMCCC=y +CONFIG_TARGET_POMELO=y +CONFIG_SYS_TEXT_BASE=0x180000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_DEVICE_TREE="phytium-pomelo" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyAMA0,115200 earlycon=pl011,0x28001000 root=/dev/sda2 rw" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_LAST_STAGE_INIT=y +CONFIG_SYS_PROMPT="pomelo#" +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCI_PHYTIUM=y +CONFIG_PCIE_ECAM_GENERIC=y +CONFIG_PL01X_SERIAL=y diff --git a/include/configs/pomelo.h b/include/configs/pomelo.h new file mode 100644 index 0000000000..d9fc03ada7 --- /dev/null +++ b/include/configs/pomelo.h @@ -0,0 +1,44 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2021 + * lixinde lixinde@phytium.com.cn + * weichangzheng weichangzheng@phytium.com.cn + */ + +#ifndef __POMELO_CONFIG_H__ +#define __POMELO_CONFIG_H__ + +/* SDRAM Bank #1 start address */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR (0x80000000 + 0x10000000) + +/* SIZE of malloc pool */ +#define CONFIG_SYS_MALLOC_LEN (0x100000 + 0x1000) +#define CONFIG_SYS_INIT_SP_ADDR (0x29800000 + 0x1a000) + +/* PCI CONFIG */ +#define CONFIG_SYS_PCI_64BIT 1 + +/*BOOT*/ +#define CONFIG_SYS_BOOTM_LEN 0x3c00000 +#define CONFIG_BOARD_EARLY_INIT_F + +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(SCSI, scsi, 0) \ + +#include <config_distro_bootcmd.h> +#endif + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "image=Image\0" \ + BOOTENV \ + "scriptaddr=0x90100000\0" \ + "kernel_addr_r=0x90200000\0" \ + "fdt_addr_r=0x95000000\0" \ + "boot_fit=no\0" \ + "fdtfile=phytium-pomelo.dtb\0" \ + +#endif +
