[U-Boot] u-boot-sunxi/master: Buildman issues
Full Log: ---------- boards.cfg is up to date. Nothing to do. Summary of 36 commits for 1275 boards (12 threads, 1 job per thread) 01: sunxi: fix ACTLR.SMP assembly routine aarch64: + orangepi_pc2 blackfin: + cm-bf561 blackstamp bf527-ezkit-v2 br4 cm-bf527 bf506f-ezkit ip04 bf527-sdp bf527-ad7160-eval bf609-ezkit tcm-bf518 bf527-ezkit bf533-ezkit ibf-dsp561 bf537-minotaur bf537-pnav bf537-srv1 cm-bf548 bf548-ezkit bf525-ucr2 blackvme pr1 bf518f-ezbrd bf526-ezbrd x86: + galileo conga-qeval20-qa3-e3845-internal-uart qemu-x86_64 conga-qeval20-qa3-e3845 bayleybay theadorable-x86-dfi-bt700 qemu-x86_efi_payload64 minnowmax dfi-bt700-q7x-151 som-db5800-som-6867 chromebook_link64 arm: + CHIP_pro sun8i_a23_evb nanopi_neo_air Sunchip_CX-A99 mx6sxsabreauto +/bin/sh: 1: bfin-uclinux-ldr: not found +make[1]: *** [u-boot.ldr] Error 127 +make: *** [sub-make] Error 2 +make[1]: bfin-uclinux-ldr: Command not found +/bin/sh: 1: iasl: not found +mv: cannot stat '../board/intel/galileo/dsdt.hex': No such file or directory +make[2]: *** [board/intel/galileo/dsdt.c] Error 1 +make[1]: *** [board/intel/galileo] Error 2 + if (i2c_read(chip, addr, 1, &valb, 1)) + ^ + return i2c_write(chip, addr, 1, &valb, 1); +cc1: error: -mcpu=bf506-0.0 is not valid +cc1: error: unrecognized command line option '-mcpu=bf506-0.0' +make[2]: *** [u-boot.cfg] Error 1 +make[1]: *** No rule to make target `include/config/auto.conf', needed by `include/config/uboot.release'. Stop. +cc1: error: -mcpu=bf609-0.0 is not valid +cc1: error: unrecognized command line option '-mcpu=bf609-0.0' +mv: cannot stat '../board/congatec/conga-qeval20-qa3-e3845/dsdt.hex': No such file or directory +make[2]: *** [board/congatec/conga-qeval20-qa3-e3845/dsdt.c] Error 1 +make[1]: *** [board/congatec/conga-qeval20-qa3-e3845] Error 2 +make[2]: *** [orangepi_pc2_defconfig] Error 1 +make[1]: *** [orangepi_pc2_defconfig] Error 2 +make[2]: *** [CHIP_pro_defconfig] Error 1 +make[1]: *** [CHIP_pro_defconfig] Error 2 +mv: cannot stat '../board/dfi/dfi-bt700/dsdt.hex': No such file or directory +make[2]: *** [board/dfi/dfi-bt700/dsdt.c] Error 1 +make[1]: *** [board/dfi/dfi-bt700] Error 2 +In file included from ../arch/x86/include/asm/bitops.h:18:0, + from ../include/linux/bitops.h:123, + from ../include/common.h:25, + from ../lib/asm-offsets.c:15: + if (!(word & (~0ul << 32))) { + ^ + word <<= 32; + if (!(word & (~0ul << (BITS_PER_LONG-16)))) { + if (!(word & (~0ul << (BITS_PER_LONG-8)))) { + if (!(word & (~0ul << (BITS_PER_LONG-4)))) { + if (!(word & (~0ul << (BITS_PER_LONG-2)))) { + if (!(word & (~0ul << (BITS_PER_LONG-1)))) + from ../arch/x86/lib/asm-offsets.c:15: + from ../arch/x86/cpu/cpu.c:22: + from ../arch/x86/cpu/cpu_x86.c:7: + from ../arch/x86/cpu/intel_common/cpu.c:7: + from ../arch/x86/cpu/intel_common/lpc.c:7: + from ../arch/x86/cpu/intel_common/microcode.c:10: +../arch/x86/cpu/intel_common/microcode.c: In function 'microcode_read_rev': +../arch/x86/cpu/intel_common/microcode.c:79:2: error: PIC register clobbered by 'ebx' in 'asm' + asm volatile ( +make[3]: *** [arch/x86/cpu/intel_common/microcode.o] Error 1 +make[2]: *** [arch/x86/cpu/intel_common] Error 2 +make[1]: *** [arch/x86/cpu] Error 2 +mv: cannot stat '../board/intel/bayleybay/dsdt.hex': No such file or directory +make[2]: *** [board/intel/bayleybay/dsdt.c] Error 1 +make[1]: *** [board/intel/bayleybay] Error 2 +make[2]: *** [sun8i_a23_evb_defconfig] Error 1 +make[1]: *** [sun8i_a23_evb_defconfig] Error 2 +../arch/x86/lib/crt0_x86_64_efi.S: Assembler messages: +../arch/x86/lib/crt0_x86_64_efi.S:16: Error: bad register name `%rsp' +../arch/x86/lib/crt0_x86_64_efi.S:17: Error: bad register name `%rcx' +../arch/x86/lib/crt0_x86_64_efi.S:18: Error: bad register name `%rdx' +../arch/x86/lib/crt0_x86_64_efi.S:21: Error: bad register name `%rip)' +../arch/x86/lib/crt0_x86_64_efi.S:22: Error: bad register name `%rip)' +../arch/x86/lib/crt0_x86_64_efi.S:24: Error: bad register name `%rcx' +../arch/x86/lib/crt0_x86_64_efi.S:25: Error: bad register name `%rdx' +../arch/x86/lib/crt0_x86_64_efi.S:26: Error: bad register name `%rcx' +../arch/x86/lib/crt0_x86_64_efi.S:27: Error: bad register name `%rdx' +../arch/x86/lib/crt0_x86_64_efi.S:30: Error: bad register name `%rdi' +../arch/x86/lib/crt0_x86_64_efi.S:31: Error: bad register name `%rsi' +../arch/x86/lib/crt0_x86_64_efi.S:34: Error: bad register name `%rsp' +../arch/x86/lib/crt0_x86_64_efi.S:47: Warning: setting incorrect section attributes for .reloc +make[2]: *** [arch/x86/lib/crt0_x86_64_efi.o] Error 1 +make[1]: *** [arch/x86/lib] Error 2 +make[2]: *** [Sunchip_CX-A99_defconfig] Error 1 +make[1]: *** [Sunchip_CX-A99_defconfig] Error 2 +make[2]: *** [nanopi_neo_air_defconfig] Error 1 +make[1]: *** [nanopi_neo_air_defconfig] Error 2 +mv: cannot stat '../board/intel/minnowmax/dsdt.hex': No such file or directory +make[2]: *** [board/intel/minnowmax/dsdt.c] Error 1 +make[1]: *** [board/intel/minnowmax] Error 2 +mv: cannot stat '../board/advantech/som-db5800-som-6867/dsdt.hex': No such file or directory +make[2]: *** [board/advantech/som-db5800-som-6867/dsdt.c] Error 1 +make[1]: *** [board/advantech/som-db5800-som-6867] Error 2 w+../drivers/gpio/pca953x.c: In function 'pca953x_reg_write': w+../drivers/gpio/pca953x.c:68:3: warning: implicit declaration of function 'i2c_read' [-Wimplicit-function-declaration] w+../drivers/gpio/pca953x.c:74:3: warning: implicit declaration of function 'i2c_write' [-Wimplicit-function-declaration] w+../drivers/usb/musb/musb_hcd.c: In function 'config_hub_port': w+../drivers/usb/musb/musb_hcd.c:405:5: warning: variable 'hub' set but not used [-Wunused-but-set-variable] w+../drivers/usb/musb/musb_core.c: In function 'musb_configure_ep': w+../drivers/usb/musb/musb_core.c:71:6: warning: variable 'idx' set but not used [-Wunused-but-set-variable] w+../board/bf533-ezkit/flash.c: In function 'read_data': w+../board/bf533-ezkit/flash.c:241:6: warning: variable 'iShift' set but not used [-Wunused-but-set-variable] w+../drivers/net/ax88180.c: In function 'ax88180_mac_reset': w+../drivers/net/ax88180.c:132:16: warning: variable 'tmpval' set but not used [-Wunused-but-set-variable] w+../drivers/net/ax88180.c: In function 'ax88180_recv': w+../drivers/net/ax88180.c:577:17: warning: variable 'tmp_regval' set but not used [-Wunused-but-set-variable] w+../include/asm-generic/bitops/__fls.h: In function '__fls': w+../include/asm-generic/bitops/__fls.h:17:2: warning: left shift count >= width of type w+../include/asm-generic/bitops/__fls.h:19:3: warning: left shift count >= width of type w+../include/asm-generic/bitops/__fls.h:22:2: warning: left shift count >= width of type w+../include/asm-generic/bitops/__fls.h:26:2: warning: left shift count >= width of type w+../include/asm-generic/bitops/__fls.h:30:2: warning: left shift count >= width of type w+../include/asm-generic/bitops/__fls.h:34:2: warning: left shift count >= width of type w+../include/asm-generic/bitops/__fls.h:38:2: warning: left shift count >= width of type 02: ARM: rename CONFIG_TIMER_CLK_FREQ to COUNTER_FREQUENCY 03: fsl: ls102x: remove redundant GENERIC_TIMER_CLK 04: sunxi: simplify ACTLR.SMP bit set #ifdef 05: sunxi: configs: merge sun9i and sun50i SPL memory definitions 06: sunxi: Kconfig: introduce CONFIG_SUNXI_HIGH_SRAM 07: sunxi: provide ARMv8 mem_map for every ARM64 board 08: SPI: SPL: sunxi: fix 64-bit build 09: sunxi: DRAM: add Allwinner H5 support 10: sunxi: prepare for sharing MACH_SUN8I_H3 config symbol 11: sunxi: introduce Allwinner H5 config option 12: sunxi: Add OrangePi PC 2 initial support -make[2]: *** [orangepi_pc2_defconfig] Error 1 -make[1]: *** [orangepi_pc2_defconfig] Error 2 +ERROR: File too large! +make[2]: *** [spl/sunxi-spl.bin] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 13: sunxi: add NanoPi NEO Air defconfig arm: nanopi_neo_air -make[2]: *** [nanopi_neo_air_defconfig] Error 1 -make[1]: *** [nanopi_neo_air_defconfig] Error 2 14: nand: sunxi: Fix modulo by zero error 15: bch: Allow to build for the host 16: tools: sunxi: Add spl image builder 17: common: Move environment choice to Kconfig arm: + Nintendo_NES_Classic_Edition CHIP +In file included from ../include/common.h:987:0, +../include/environment.h:154:19: error: 'CONFIG_ENV_SIZE' undeclared here (not in a function) + #define ENV_SIZE (CONFIG_ENV_SIZE - ENV_HEADER_SIZE) + ^ +../include/environment.h:162:21: note: in expansion of macro 'ENV_SIZE' + unsigned char data[ENV_SIZE]; /* Environment data */ + ^ +make[2]: *** [lib/asm-offsets.s] Error 1 +make[1]: *** [prepare0] Error 2 18: cmd: Add Kconfig option for CMD_MTDPARTS and related options 19: mtd: ubi: Select RBTREE option from MTD_UBI Kconfig entry 20: cmd: Expose a Kconfig option to enable UBIFS commands 21: cmd: nand: Expose optional suboptions in Kconfig 22: mtd: sunxi: Select the U-Boot location config option 23: mtd: sunxi: Change U-Boot offset 24: sunxi: Enable UBI and NAND support -In file included from ../include/common.h:987:0, -../include/environment.h:154:19: error: 'CONFIG_ENV_SIZE' undeclared here (not in a function) - #define ENV_SIZE (CONFIG_ENV_SIZE - ENV_HEADER_SIZE) -../include/environment.h:162:21: note: in expansion of macro 'ENV_SIZE' - unsigned char data[ENV_SIZE]; /* Environment data */ - ^ -make[2]: *** [lib/asm-offsets.s] Error 1 -make[1]: *** [prepare0] Error 2 -ERROR: File too large! -make[2]: *** [spl/sunxi-spl.bin] Error 1 -make[1]: *** [spl/u-boot-spl] Error 2 +../cmd/nand.c: In function 'set_dev': +../cmd/nand.c:118:24: error: 'CONFIG_SYS_MAX_NAND_DEVICE' undeclared (first use in this function) + if (dev < 0 || dev >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[dev]) { + ^ +../cmd/nand.c:118:24: note: each undeclared identifier is reported only once for each function it appears in +../cmd/nand.c: In function 'do_nand': +../cmd/nand.c:400:19: error: 'CONFIG_SYS_MAX_NAND_DEVICE' undeclared (first use in this function) + for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) { +../cmd/nand.c: In function 'do_nandboot': +../cmd/nand.c:994:24: error: 'CONFIG_SYS_MAX_NAND_DEVICE' undeclared (first use in this function) + if (idx < 0 || idx >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[idx]) { +make[2]: *** [cmd/nand.o] Error 1 +make[1]: *** [cmd] Error 2 25: sunxi: Add the default mtdids and mtdparts to our env 26: nand: sunxi: Add options for the SPL NAND configuration 27: scripts: sunxi: Build an raw SPL image 28: sunxi: Sync GR8 DTS and AXP209 with the kernel 29: sunxi: Add support for the CHIP Pro arm: CHIP_pro -make[2]: *** [CHIP_pro_defconfig] Error 1 -make[1]: *** [CHIP_pro_defconfig] Error 2 30: ARM: dts: sun9i: Add mmc1 pinmux setting 31: arm: sunxi: Add Sunchip CX-A99 initial support -make[2]: *** [Sunchip_CX-A99_defconfig] Error 1 -make[1]: *** [Sunchip_CX-A99_defconfig] Error 2 32: sunxi: Add boards/sunxi and arch/arm/mach-sunxi to sunxi MAINTAINERS entry 33: cmd: ubifs: Add a dependency on CMD_UBI 34: cmd: nand: Make the NAND options default to NAND_SUNXI arm: Sunchip_CX-A99 -../cmd/nand.c: In function 'set_dev': -../cmd/nand.c:118:24: error: 'CONFIG_SYS_MAX_NAND_DEVICE' undeclared (first use in this function) - if (dev < 0 || dev >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[dev]) { - ^ -../cmd/nand.c:118:24: note: each undeclared identifier is reported only once for each function it appears in -../cmd/nand.c: In function 'do_nand': -../cmd/nand.c:400:19: error: 'CONFIG_SYS_MAX_NAND_DEVICE' undeclared (first use in this function) - for (i = 0; i < CONFIG_SYS_MAX_NAND_DEVICE; i++) { -../cmd/nand.c: In function 'do_nandboot': -../cmd/nand.c:994:24: error: 'CONFIG_SYS_MAX_NAND_DEVICE' undeclared (first use in this function) - if (idx < 0 || idx >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[idx]) { -make[2]: *** [cmd/nand.o] Error 1 -make[1]: *** [cmd] Error 2 +In file included from ../include/common.h:987:0, +../include/environment.h:154:19: error: 'CONFIG_ENV_SIZE' undeclared here (not in a function) + #define ENV_SIZE (CONFIG_ENV_SIZE - ENV_HEADER_SIZE) +../include/environment.h:162:21: note: in expansion of macro 'ENV_SIZE' + unsigned char data[ENV_SIZE]; /* Environment data */ + ^ +make[2]: *** [lib/asm-offsets.s] Error 1 +make[1]: *** [prepare0] Error 2 +ERROR: File too large! +make[2]: *** [spl/sunxi-spl.bin] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 35: sunxi: Add default environment size arm: Nintendo_NES_Classic_Edition CHIP -In file included from ../include/common.h:987:0, -../include/environment.h:154:19: error: 'CONFIG_ENV_SIZE' undeclared here (not in a function) - #define ENV_SIZE (CONFIG_ENV_SIZE - ENV_HEADER_SIZE) - ^ -../include/environment.h:162:21: note: in expansion of macro 'ENV_SIZE' - unsigned char data[ENV_SIZE]; /* Environment data */ - ^ -make[2]: *** [lib/asm-offsets.s] Error 1 -make[1]: *** [prepare0] Error 2 36: sunxi: Add defconfig for Allwinner A23 EVB arm: sun8i_a23_evb -make[2]: *** [sun8i_a23_evb_defconfig] Error 1 -make[1]: *** [sun8i_a23_evb_defconfig] Error 2
On Tue, Apr 4, 2017 at 1:43 PM, Jagan Teki jagannadh.teki@gmail.com wrote:
Full Log:
- if (i2c_read(chip, addr, 1, &valb, 1))
- return i2c_write(chip, addr, 1, &valb, 1);
Toolchain issues?
New boards introduced not available at the start of the series.
- if (!(word & (~0ul << 32))) {
- word <<= 32;
- if (!(word & (~0ul << (BITS_PER_LONG-16)))) {
- if (!(word & (~0ul << (BITS_PER_LONG-8)))) {
- if (!(word & (~0ul << (BITS_PER_LONG-4)))) {
- if (!(word & (~0ul << (BITS_PER_LONG-2)))) {
- if (!(word & (~0ul << (BITS_PER_LONG-1))))
- asm volatile (
The above seem like existing errors completely unrelated that are completely unrelated to the series you're testing, especially since the first patch here is sunxi specific.
Same here.
Known breakage, fixed by "sunxi: Add default environment size", the second last patch in the current sunxi/master-pr branch.
Known breakage, fixed by "cmd: nand: Make the NAND options default to NAND_SUNXI", the third last patch in the current sunxi/master-pr branch.
At the end the sunxi targets are all buildable. You could squash the fix patches into the original patches if the intermediate build failures are of concern.
Regards ChenYu
Chen-Yu Tsai
Jagan Teki
