[U-Boot] [PATCH v1] common: Fix a typo abnove -> above
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- common/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/Kconfig b/common/Kconfig index c759952b80..af66496e75 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -560,7 +560,7 @@ config LOG_DEFAULT_LEVEL help This is the default logging level set when U-Boot starts. It can be adjusted later using the 'log level' command. Note that setting - this to a value abnove LOG_MAX_LEVEL will be ineffective, since the + this to a value above LOG_MAX_LEVEL will be ineffective, since the higher levels are not compiled in to U-Boot.
0 - emergency
Andy Shevchenko
