[U-Boot] [PATCH] power: tps65910: replace error() by pr_err()
The patch replaces the former error() by the new pr_err(). This makes the TPS65910 driver conform to Masahiro's patch 'treewide:replace with error() with pr_err()' introduced October 2017.
Signed-off-by: Felix Brack fb@ltec.ch ---
drivers/power/pmic/pmic_tps65910_dm.c | 4 ++-- drivers/power/regulator/tps65910_regulator.c | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/power/pmic/pmic_tps65910_dm.c b/drivers/power/pmic/pmic_tps65910_dm.c index 0127ce3..c65f38f 100644 --- a/drivers/power/pmic/pmic_tps65910_dm.c +++ b/drivers/power/pmic/pmic_tps65910_dm.c @@ -32,7 +32,7 @@ static int pmic_tps65910_write(struct udevice *dev, uint reg, const u8 *buffer,
ret = dm_i2c_write(dev, reg, buffer, len); if (ret) - error("%s write error on register %02x\n", dev->name, reg); + pr_err("%s write error on register %02x\n", dev->name, reg);
return ret; } @@ -44,7 +44,7 @@ static int pmic_tps65910_read(struct udevice *dev, uint reg, u8 *buffer,
ret = dm_i2c_read(dev, reg, buffer, len); if (ret) - error("%s read error on register %02x\n", dev->name, reg); + pr_err("%s read error on register %02x\n", dev->name, reg);
return ret; } diff --git a/drivers/power/regulator/tps65910_regulator.c b/drivers/power/regulator/tps65910_regulator.c index 5e2ec8f..ad952e5 100644 --- a/drivers/power/regulator/tps65910_regulator.c +++ b/drivers/power/regulator/tps65910_regulator.c @@ -340,11 +340,11 @@ static int buck_set_vdd1_vdd2_value(struct udevice *dev, int uV)
/* check setpoint is within limits */ if (uV < uc_pdata->min_uV) { - error("voltage %duV for %s too low\n", uV, dev->name); + pr_err("voltage %duV for %s too low\n", uV, dev->name); return -EINVAL; } if (uV > uc_pdata->max_uV) { - error("voltage %duV for %s too high\n", uV, dev->name); + pr_err("voltage %duV for %s too high\n", uV, dev->name); return -EINVAL; }
Signed-off-by: Felix Brack fb@ltec.ch Reviewed-by: Simon Glass sjg@chromium.org
Felix Brack
