[U-Boot] [PATCH] 83xx: Added a weak board_reset function to allow custom reset.
From 2b9f89f5d0538e44ebbe66236cd9b6be4ee902e3 Mon Sep 17 00:00:00 2001 From: Richard Retanubun RichardRetanubun@RuggedCom.com Date: Mon, 26 Oct 2009 14:16:03 -0400 Subject: [PATCH] Added a weak board_reset function to allow custom reset.
This patch adds a board_reset function to allow boards to specify their own custom reset sequence (e.g. resetting by timing out watchdog).
Signed-off-by: Richard Retanubun RichardRetanubun@RuggedCom.com ---
Based on Mike Frysinger's suggestion on: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/70304
cpu/mpc83xx/cpu.c | 6 ++++++ cpu/mpc83xx/cpu.h | 33 +++++++++++++++++++++++++++++++++ 2 files changed, 39 insertions(+), 0 deletions(-) create mode 100644 cpu/mpc83xx/cpu.h
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index e38a372..ebda4b0 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -39,6 +39,7 @@ #include <asm/immap_qe.h> #include <asm/io.h> #endif +#include "cpu.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -199,6 +200,11 @@ do_reset (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[])
volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR;
+ /* Call the board specific reset actions first. */ + if(board_reset) { + board_reset(); + } + #ifdef MPC83xx_RESET /* Interrupts and MMU off */ __asm__ __volatile__ ("mfmsr %0":"=r" (msr):); diff --git a/cpu/mpc83xx/cpu.h b/cpu/mpc83xx/cpu.h new file mode 100644 index 0000000..c1227eb --- /dev/null +++ b/cpu/mpc83xx/cpu.h @@ -0,0 +1,33 @@ +/* + * cpu.h + * + * Copyright (c) 2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CPU_H_ +#define _CPU_H_ + +#include <command.h> + +/* Use this to create board specific reset functions */ +void board_reset(void) __attribute__((__weak__)); + +#endif /* _CPU_H_ */ -- 1.6.2.4
Dear Richard Retanubun,
Instead of adding yet another implementation of the same code I would like to see at least common code being used within an architecture; for PowerPC, we already have different implementations in "cpu/ppc4xx/cpu.c" and in "cpu/mpc86xx/cpu.c".
Not to mention that "cpu/arm920t/at91rm9200/reset.c" and "cpu/blackfin/cpu.h" / "cpu/blackfin/reset.c" have such code, too.
Can we please come up with one common implementation?
Thanks.
Richard Retanubun
