[U-Boot] [PATCH] dlmalloc: remove manual reloc alias warning
The avr32 architecture (and some others) require manual relocation. Due to the previous error all avr32 boards gave warnings in MAKEALL wich makes it hard to find new warnings.
This patch fixes following warning: ---8<--- dlmalloc.c: In function 'malloc_bin_reloc': dlmalloc.c:1493: warning: dereferencing pointer 'p' does break strict-aliasing rules dlmalloc.c:1493: warning: dereferencing pointer 'p' does break strict-aliasing rules dlmalloc.c:1490: note: initialized from here dlmalloc.c:1493: note: initialized from here --->8---
Signed-off-by: Andreas Bießmann biessmann@corscience.de --- A question to all the other related arches, namely m68k, mips, nds32 and sparc: Do you encounter the same warnings or is this warning due to my outdated compiler (4.4.3 currently, unfortunately atmel do not bother to send their patches mainline)?
common/dlmalloc.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index c645d73..78b1885 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -1485,9 +1485,10 @@ static mbinptr av_[NAV * 2 + 2] = { };
#ifdef CONFIG_NEEDS_MANUAL_RELOC +typedef unsigned long __attribute__((__may_alias__)) ulong_aliased; void malloc_bin_reloc (void) { - unsigned long *p = (unsigned long *)(&av_[2]); + ulong_aliased *p = (ulong_aliased *)(&av_[2]); int i; for (i=2; i<(sizeof(av_)/sizeof(mbinptr)); ++i) { *p++ += gd->reloc_off;
previous thread (and i think there was one before this): http://patchwork.ozlabs.org/patch/134597/ -mike
Dear Mike Frysinger,
thank you for the hint. I think this is a better solution so I will test it and try to force the other patch as the correct solution.
Best regards
Andreas Bießmann
well, looks nice but is broken at runtime ;(
Best regards
Andreas Bießmann
Dear all,
- ulong_aliased *p = (ulong_aliased *)(&av_[2]); int i; for (i=2; i<(sizeof(av_)/sizeof(mbinptr)); ++i) { *p++ += gd->reloc_off;
this seems to be related to http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/121848/focus=121849 can you Wolfgang and/or Simon please comment.
best regards
Andreas Bießmann
On Tue, Aug 14, 2012 at 1:50 AM, Andreas Bießmann andreas.devel@googlemail.com wrote:
Dear all,
My only comment is that I created that patch due to errors I saw at the time, and still see with the toolchain I use for avr32.
best regards
Andreas Bießmann
Dear Simon Glass,
Dear all,
So you also want to remove this annoying warning. Sorry that I didn't test your patch from January earlier, but it is broken at runtime.
I would really like to remove the alias warning in 2012.10. My patch is straight forward, maybe there are better solutions. However I would like to see tested by from other affected arches (m68k, mips, nds32 and sparc).
Best regards
Andreas Bießmann
Dear =?UTF-8?q?Andreas=20Bie=C3=9Fmann?=,
In message 1344848523-20359-1-git-send-email-andreas.devel@googlemail.com you wrote:
I dislike this typedef, especially as it's used only a single time. But even so - why cannot we avoid the __may_alias__ thing alltogether?
You wrote in http://article.gmane.org/gmane.comp.boot-loaders.u-boot/137770 that Simon's patch breaks avr32 boards at runtime.
The implementation is indeed broken. I wonder if it ever worked:
mbinptr *p = &av_[2]; int i;
for (i = 2; i < ARRAY_SIZE(av_); ++i) *p = (mbinptr)((ulong)*p + gd->reloc_off);
i. e. this has the offset 2 added twice, so it is missing the first two real entries, env writing beyond the end of the array.
Can you please test this code instead:
mbinptr *p = &av_; int i;
Dear Andreas,
Please ignore me. Seems my brain is still in vacation mode.
However, I really wonder why you say this code would be causing runtime errors for you:
It looks good to me.
Can you please add some debug printf()s to find out how the old code and this one differ in their results?
Dera Wolfgang Denk,
On 01.09.2012 14:02, Wolfgang Denk wrote:
Dear Andreas,
Well, I did not investigate it further, but I can do this weekend (after merging/testing/pull request the atmel arm stuff). Hopefully we get a solution for the annoying alias warning in upcoming release.
Best regards
Andreas Bießmann
participants (5)
Andreas Bießmann
Andreas Bießmann
Mike Frysinger
