[U-Boot-Users] [PATCH 01/30] common/cmd_[af]*: Remove obsolete references to CONFIG_COMMANDS.
Signed-off-by: Jon Loeliger jdl@freescale.com --- common/bedbug.c | 4 ++-- common/cmd_autoscript.c | 9 ++++----- common/cmd_bdinfo.c | 2 +- common/cmd_bedbug.c | 2 +- common/cmd_bmp.c | 4 ++-- common/cmd_bootm.c | 22 +++++++++++----------- common/cmd_cache.c | 2 +- common/cmd_console.c | 2 +- common/cmd_date.c | 2 +- common/cmd_dcr.c | 2 +- common/cmd_diag.c | 2 +- common/cmd_display.c | 2 +- common/cmd_doc.c | 4 ++-- common/cmd_dtt.c | 4 ++-- common/cmd_eeprom.c | 8 ++++---- common/cmd_elf.c | 4 ++-- common/cmd_ext2.c | 6 +++--- common/cmd_fat.c | 2 +- common/cmd_fdc.c | 17 ++++++++--------- common/cmd_fdos.c | 4 ++-- common/cmd_flash.c | 14 +++++++------- common/cmd_fpga.c | 6 +++--- 22 files changed, 61 insertions(+), 63 deletions(-)
diff --git a/common/bedbug.c b/common/bedbug.c index 1a793f8..3bf1fc3 100644 --- a/common/bedbug.c +++ b/common/bedbug.c @@ -2,7 +2,7 @@
#include <common.h>
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG)
#include <linux/ctype.h> #include <bedbug/bedbug.h> @@ -1253,4 +1253,4 @@ int find_next_address (unsigned char *nextaddr, int step_over, * purpose. */
-#endif /* CONFIG_COMMANDS & CFG_CMD_BEDBUG */ +#endif diff --git a/common/cmd_autoscript.c b/common/cmd_autoscript.c index aaca362..606fb9a 100644 --- a/common/cmd_autoscript.c +++ b/common/cmd_autoscript.c @@ -47,8 +47,7 @@ #include <hush.h> #endif
-#if defined(CONFIG_AUTOSCRIPT) || \ - (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT) +#if defined(CONFIG_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
extern image_header_t header; /* from cmd_bootm.c */ int @@ -152,7 +151,7 @@ autoscript (ulong addr)
#endif /* CONFIG_AUTOSCRIPT || CFG_CMD_AUTOSCRIPT */ /**************************************************/ -#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT) +#if defined(CONFIG_CMD_AUTOSCRIPT) int do_autoscript (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -170,7 +169,7 @@ do_autoscript (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return rcode; }
-#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT) +#if defined(CONFIG_CMD_AUTOSCRIPT) U_BOOT_CMD( autoscr, 2, 0, do_autoscript, "autoscr - run script from memory\n", @@ -179,4 +178,4 @@ U_BOOT_CMD( ); #endif /* CFG_CMD_AUTOSCRIPT */
-#endif /* CONFIG_AUTOSCRIPT || CFG_CMD_AUTOSCRIPT */ +#endif /* CFG_CMD_AUTOSCRIPT */ diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index b5ba2a0..55cb100 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -30,7 +30,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if (CONFIG_COMMANDS & CFG_CMD_BDI) || defined(CONFIG_CMD_BDI) +#if defined(CONFIG_CMD_BDI) static void print_num(const char *, ulong);
#ifndef CONFIG_ARM /* PowerPC and other */ diff --git a/common/cmd_bedbug.c b/common/cmd_bedbug.c index 4c309f9..0bd622b 100644 --- a/common/cmd_bedbug.c +++ b/common/cmd_bedbug.c @@ -13,7 +13,7 @@
#ifndef MAX #define MAX(a,b) ((a) > (b) ? (a) : (b)) diff --git a/common/cmd_bmp.c b/common/cmd_bmp.c index d5c5bda..241aa83 100644 --- a/common/cmd_bmp.c +++ b/common/cmd_bmp.c @@ -31,7 +31,7 @@ #include <asm/byteorder.h> #include <malloc.h>
-#if (CONFIG_COMMANDS & CFG_CMD_BMP) || defined(CONFIG_CMD_BMP) +#if defined(CONFIG_CMD_BMP)
static int bmp_info (ulong addr); static int bmp_display (ulong addr, int x, int y); @@ -188,4 +188,4 @@ static int bmp_display(ulong addr, int x, int y) #endif }
-#endif /* (CONFIG_COMMANDS & CFG_CMD_BMP) || defined(CONFIG_CMD_BMP) */ +#endif /* defined(CONFIG_CMD_BMP) */ diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 950e160..90de6b1 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -48,7 +48,7 @@ DECLARE_GLOBAL_DATA_PTR; /*cmd_boot.c*/ extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
-#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) +#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) #include <rtc.h> #endif
@@ -89,11 +89,11 @@ int gunzip (void *, int, unsigned char *, unsigned long *); static void *zalloc(void *, unsigned, unsigned); static void zfree(void *, void *, unsigned);
-#if (CONFIG_COMMANDS & CFG_CMD_IMI) || defined(CONFIG_CMD_IMI) +#if defined(CONFIG_CMD_IMI) static int image_info (unsigned long addr); #endif
-#if (CONFIG_COMMANDS & CFG_CMD_IMLS) || defined(CONFIG_CMD_IMLS) +#if defined(CONFIG_CMD_IMLS) #include <flash.h> extern flash_info_t flash_info[]; /* info for FLASH chips */ static int do_imls (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); @@ -133,7 +133,7 @@ static void fixup_silent_linux (void); #endif static boot_os_Fcn do_bootm_netbsd; static boot_os_Fcn do_bootm_rtems; -#if (CONFIG_COMMANDS & CFG_CMD_ELF) || defined(CONFIG_CMD_ELF) +#if defined(CONFIG_CMD_ELF) static boot_os_Fcn do_bootm_vxworks; static boot_os_Fcn do_bootm_qnxelf; int do_bootvx ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[] ); @@ -440,7 +440,7 @@ int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) addr, len_ptr, verify); break;
-#if (CONFIG_COMMANDS & CFG_CMD_ELF) || defined(CONFIG_CMD_ELF) +#if defined(CONFIG_CMD_ELF) case IH_OS_VXWORKS: do_bootm_vxworks (cmdtp, flag, argc, argv, addr, len_ptr, verify); @@ -1219,7 +1219,7 @@ do_bootm_artos (cmd_tbl_t *cmdtp, int flag, #endif
-#if (CONFIG_COMMANDS & CFG_CMD_BOOTD) || defined(CONFIG_CMD_BOOTD) +#if defined(CONFIG_CMD_BOOTD) int do_bootd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { int rcode = 0; @@ -1247,7 +1247,7 @@ U_BOOT_CMD(
#endif
-#if (CONFIG_COMMANDS & CFG_CMD_IMI) || defined(CONFIG_CMD_IMI) +#if defined(CONFIG_CMD_IMI) int do_iminfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { int arg; @@ -1317,7 +1317,7 @@ U_BOOT_CMD(
#endif /* CFG_CMD_IMI */
-#if (CONFIG_COMMANDS & CFG_CMD_IMLS) || defined(CONFIG_CMD_IMLS) +#if defined(CONFIG_CMD_IMLS) /*----------------------------------------------------------------------- * List all images found in flash. */ @@ -1378,13 +1378,13 @@ U_BOOT_CMD( void print_image_hdr (image_header_t *hdr) { -#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) +#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) time_t timestamp = (time_t)ntohl(hdr->ih_time); struct rtc_time tm; #endif
printf (" Image Name: %.*s\n", IH_NMLEN, hdr->ih_name); -#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) +#if defined(CONFIG_TIMESTAMP) || defined(CONFIG_CMD_DATE) to_tm (timestamp, &tm); printf (" Created: %4d-%02d-%02d %2d:%02d:%02d UTC\n", tm.tm_year, tm.tm_mon, tm.tm_mday, @@ -1588,7 +1588,7 @@ do_bootm_rtems (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], (*entry_point ) ( gd->bd ); }
-#if (CONFIG_COMMANDS & CFG_CMD_ELF) || defined(CONFIG_CMD_ELF) +#if defined(CONFIG_CMD_ELF) static void do_bootm_vxworks (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], ulong addr, ulong *len_ptr, int verify) diff --git a/common/cmd_cache.c b/common/cmd_cache.c index 29ca621..6890faf 100644 --- a/common/cmd_cache.c +++ b/common/cmd_cache.c @@ -27,7 +27,7 @@ #include <common.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_CACHE) || defined(CONFIG_CMD_CACHE) +#if defined(CONFIG_CMD_CACHE)
static int on_off (const char *);
diff --git a/common/cmd_console.c b/common/cmd_console.c index 70f8a20..530e345 100644 --- a/common/cmd_console.c +++ b/common/cmd_console.c @@ -28,7 +28,7 @@ #include <command.h> #include <devices.h>
-#if (CONFIG_COMMANDS & CFG_CMD_CONSOLE) || defined(CONFIG_CMD_CONSOLE) +#if defined(CONFIG_CMD_CONSOLE)
extern void _do_coninfo (void); int do_coninfo (cmd_tbl_t * cmd, int flag, int argc, char *argv[]) diff --git a/common/cmd_date.c b/common/cmd_date.c index 7b7f547..93c2ca4 100644 --- a/common/cmd_date.c +++ b/common/cmd_date.c @@ -31,7 +31,7 @@
-#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE) +#if defined(CONFIG_CMD_DATE)
const char *weekdays[] = { "Sun", "Mon", "Tues", "Wednes", "Thurs", "Fri", "Satur", diff --git a/common/cmd_dcr.c b/common/cmd_dcr.c index 31c732e..e79280c 100644 --- a/common/cmd_dcr.c +++ b/common/cmd_dcr.c @@ -29,7 +29,7 @@ #include <config.h> #include <command.h>
-#if defined(CONFIG_4xx) && ((CONFIG_COMMANDS & CFG_CMD_SETGETDCR) || defined(CONFIG_CMD_SETGETDCR)) +#if defined(CONFIG_4xx) && defined(CONFIG_CMD_SETGETDCR)
unsigned long get_dcr (unsigned short); unsigned long set_dcr (unsigned short, unsigned long); diff --git a/common/cmd_diag.c b/common/cmd_diag.c index 7293457..091e3c8 100644 --- a/common/cmd_diag.c +++ b/common/cmd_diag.c @@ -28,7 +28,7 @@ #include <command.h> #include <post.h>
-#if ((CONFIG_COMMANDS & CFG_CMD_DIAG) || defined(CONFIG_CMD_DIAG)) && defined(CONFIG_POST) +#if defined(CONFIG_CMD_DIAG) && defined(CONFIG_POST)
int do_diag (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { diff --git a/common/cmd_display.c b/common/cmd_display.c index f2e7e88..47ef35a 100644 --- a/common/cmd_display.c +++ b/common/cmd_display.c @@ -24,7 +24,7 @@ #include <common.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_DISPLAY) || defined(CONFIG_CMD_DISPLAY) +#if defined(CONFIG_CMD_DISPLAY)
#undef DEBUG_DISP
diff --git a/common/cmd_doc.c b/common/cmd_doc.c index 4293aa1..9af625a 100644 --- a/common/cmd_doc.c +++ b/common/cmd_doc.c @@ -19,7 +19,7 @@ # define SHOW_BOOT_PROGRESS(arg) #endif
-#if (CONFIG_COMMANDS & CFG_CMD_DOC) || defined(CONFIG_CMD_DOC) +#if defined(CONFIG_CMD_DOC)
#include <linux/mtd/nftl.h> #include <linux/mtd/doc2000.h> @@ -1608,4 +1608,4 @@ void doc_probe(unsigned long physadr) } }
-#endif /* (CONFIG_COMMANDS & CFG_CMD_DOC) */ +#endif diff --git a/common/cmd_dtt.c b/common/cmd_dtt.c index b220ecb..8da95bf 100644 --- a/common/cmd_dtt.c +++ b/common/cmd_dtt.c @@ -25,7 +25,7 @@ #include <config.h> #include <command.h>
-#if (CONFIG_COMMANDS & CFG_CMD_DTT) || defined(CONFIG_CMD_DTT) +#if defined(CONFIG_CMD_DTT)
#include <dtt.h> #include <i2c.h> @@ -61,4 +61,4 @@ U_BOOT_CMD( " - Read temperature from digital thermometer and thermostat.\n" );
-#endif /* CONFIG_COMMANDS & CFG_CMD_DTT */ +#endif diff --git a/common/cmd_eeprom.c b/common/cmd_eeprom.c index b4467e8..d6fb9ab 100644 --- a/common/cmd_eeprom.c +++ b/common/cmd_eeprom.c @@ -42,7 +42,7 @@ #include <command.h> #include <i2c.h>
-#if (CONFIG_COMMANDS & CFG_CMD_EEPROM) || defined(CFG_ENV_IS_IN_EEPROM) || defined(CONFIG_CMD_EEPROM) +#if defined(CFG_ENV_IS_IN_EEPROM) || defined(CONFIG_CMD_EEPROM)
extern void eeprom_init (void); extern int eeprom_read (unsigned dev_addr, unsigned offset, @@ -62,7 +62,7 @@ extern int eeprom_write_enable (unsigned dev_addr, int state);
-#if (CONFIG_COMMANDS & CFG_CMD_EEPROM) || defined(CONFIG_CMD_EEPROM) +#if defined(CONFIG_CMD_EEPROM) int do_eeprom ( cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { const char *const fmt = @@ -121,7 +121,7 @@ int do_eeprom ( cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) * 0x00000nxx for EEPROM address selectors and page number at n. */
#ifndef CONFIG_SPI #if !defined(CFG_I2C_EEPROM_ADDR_LEN) || CFG_I2C_EEPROM_ADDR_LEN < 1 || CFG_I2C_EEPROM_ADDR_LEN > 2 @@ -425,7 +425,7 @@ void eeprom_init (void) #endif /* CFG_CMD_EEPROM */ /***************************************************/
#ifdef CFG_I2C_MULTI_EEPROMS U_BOOT_CMD( diff --git a/common/cmd_elf.c b/common/cmd_elf.c index cc8a8da..6d72619 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -23,7 +23,7 @@ DECLARE_GLOBAL_DATA_PTR; #endif
#ifndef MAX #define MAX(a,b) ((a) > (b) ? (a) : (b)) @@ -101,7 +101,7 @@ int do_bootvx (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) else addr = simple_strtoul (argv[1], NULL, 16);
-#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) /* Check to see if we need to tftp the image ourselves before starting */
if ((argc == 2) && (strcmp (argv[1], "tftp") == 0)) { diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index d0999ac..8bd2b47 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -35,14 +35,14 @@ #include <common.h> #include <part.h>
-#if (CONFIG_COMMANDS & CFG_CMD_EXT2) || defined(CONFIG_CMD_EXT2) +#if defined(CONFIG_CMD_EXT2) #include <config.h> #include <command.h> #include <image.h> #include <linux/ctype.h> #include <asm/byteorder.h> #include <ext2fs.h> -#if (((CONFIG_COMMANDS & CFG_CMD_USB) || defined(CONFIG_CMD_USB)) && defined(CONFIG_USB_STORAGE)) +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) #include <usb.h> #endif
@@ -260,4 +260,4 @@ U_BOOT_CMD( " to address 'addr' from ext2 filesystem\n" );
-#endif /* CONFIG_COMMANDS & CFG_CMD_EXT2 */ +#endif diff --git a/common/cmd_fat.c b/common/cmd_fat.c index f7e6c86..0f0ff4a 100644 --- a/common/cmd_fat.c +++ b/common/cmd_fat.c @@ -31,7 +31,7 @@ #include <ata.h> #include <part.h>
-#if (CONFIG_COMMANDS & CFG_CMD_FAT) || defined(CONFIG_CMD_FAT) +#if defined(CONFIG_CMD_FAT)
#undef DEBUG
diff --git a/common/cmd_fdc.c b/common/cmd_fdc.c index 3c2ba56..7349412 100644 --- a/common/cmd_fdc.c +++ b/common/cmd_fdc.c @@ -47,12 +47,11 @@ #endif
-/*#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE) */ +/*#if defined(CONFIG_CMD_DATE) */ /*#include <rtc.h> */ /*#endif */
-#if (CONFIG_COMMANDS & CFG_CMD_FDC) || defined(CONFIG_CMD_FDC) \ - || (CONFIG_COMMANDS & CFG_CMD_FDOS) || defined(CONFIG_CMD_FDOS) +#if defined(CONFIG_CMD_FDC) || defined(CONFIG_CMD_FDOS)
typedef struct { @@ -708,9 +707,9 @@ int fdc_setup(int drive, FDC_COMMAND_STRUCT *pCMD, FD_GEO_STRUCT *pFG)
return TRUE; } -#endif /* ((CONFIG_COMMANDS & CFG_CMD_FDC)||(CONFIG_COMMANDS & CFG_CMD_FDOS))*/ +#endif
-#if (CONFIG_COMMANDS & CFG_CMD_FDOS) || defined(CONFIG_CMD_FDOS) +#if defined(CONFIG_CMD_FDOS)
/* Low level functions for the Floppy-DOS layer */
@@ -773,9 +772,9 @@ int fdc_fdos_read (void *buffer, int len)
return (fdc_read_data (buffer, len, pCMD, pFG)); } -#endif /* (CONFIG_COMMANDS & CFG_CMD_FDOS) */ +#endif
-#if (CONFIG_COMMANDS & CFG_CMD_FDC) || defined(CONFIG_CMD_FDC) +#if defined(CONFIG_CMD_FDC) /**************************************************************************** * main routine do_fdcboot */ @@ -881,13 +880,13 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
-#endif /* CONFIG_COMMANDS & CFG_CMD_FDC */ +#endif
U_BOOT_CMD( fdcboot, 3, 1, do_fdcboot, diff --git a/common/cmd_fdos.c b/common/cmd_fdos.c index 8208d7b..f9da98d 100644 --- a/common/cmd_fdos.c +++ b/common/cmd_fdos.c @@ -31,7 +31,7 @@ #include <command.h> #include <fdc.h>
/*----------------------------------------------------------------------------- * do_fdosboot -- @@ -154,4 +154,4 @@ U_BOOT_CMD( "[directory]\n" );
-#endif /* CONFIG_COMMANDS & CFG_CMD_FDOS */ +#endif diff --git a/common/cmd_flash.c b/common/cmd_flash.c index 4744e97..e191f9c 100644 --- a/common/cmd_flash.c +++ b/common/cmd_flash.c @@ -31,9 +31,9 @@ #include <dataflash.h> #endif
-#if (CONFIG_COMMANDS & CFG_CMD_FLASH) || defined(CONFIG_CMD_FLASH) +#if defined(CONFIG_CMD_FLASH)
-#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) && defined(CONFIG_JFFS2_CMDLINE) +#if (defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) #include <jffs2/jffs2.h>
/* parition handling routines */ @@ -311,7 +311,7 @@ int do_flerase (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) flash_info_t *info; ulong bank, addr_first, addr_last; int n, sect_first, sect_last; -#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) struct mtd_device *dev; struct part_info *part; u8 dev_type, dev_num, pnum; @@ -343,7 +343,7 @@ int do_flerase (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return rcode; }
-#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) /* erase <part-id> - erase partition */ if ((argc == 2) && (id_parse(argv[1], NULL, &dev_type, &dev_num) == 0)) { mtdparts_init(); @@ -447,7 +447,7 @@ int do_protect (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) flash_info_t *info; ulong bank, addr_first, addr_last; int i, p, n, sect_first, sect_last; -#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) struct mtd_device *dev; struct part_info *part; u8 dev_type, dev_num, pnum; @@ -539,7 +539,7 @@ int do_protect (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return rcode; }
-#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) /* protect on/off <part-id> */ if ((argc == 3) && (id_parse(argv[2], NULL, &dev_type, &dev_num) == 0)) { mtdparts_init(); @@ -672,7 +672,7 @@ int flash_sect_protect (int p, ulong addr_first, ulong addr_last)
/**************************************************/ -#if ((CONFIG_COMMANDS & CFG_CMD_JFFS2) || defined(CONFIG_CMD_JFFS2)) && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) # define TMP_ERASE "erase <part-id>\n - erase partition\n" # define TMP_PROT_ON "protect on <part-id>\n - protect partition\n" # define TMP_PROT_OFF "protect off <part-id>\n - make partition writable\n" diff --git a/common/cmd_fpga.c b/common/cmd_fpga.c index e32b29a..3fc4fca 100644 --- a/common/cmd_fpga.c +++ b/common/cmd_fpga.c @@ -27,7 +27,7 @@ */ #include <common.h> #include <command.h> -#if (CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET) +#if defined(CONFIG_CMD_NET) #include <net.h> #endif #include <fpga.h> @@ -43,7 +43,7 @@ #define PRINTF(fmt,args...) #endif
-#if defined (CONFIG_FPGA) && ((CONFIG_COMMANDS & CFG_CMD_FPGA ) || defined(CONFIG_CMD_FPGA)) +#if defined (CONFIG_FPGA) && defined(CONFIG_CMD_FPGA)
/* Local functions */ static void fpga_usage (cmd_tbl_t * cmdtp); @@ -321,4 +321,4 @@ U_BOOT_CMD (fpga, 6, 1, do_fpga, "\tloadb\tLoad device from bitstream buffer (Xilinx devices only)\n" "\tloadmk\tLoad device generated with mkimage\n" "\tdump\tLoad device to memory buffer\n"); -#endif /* CONFIG_FPGA && CONFIG_COMMANDS & CFG_CMD_FPGA */ +#endif
Jon Loeliger
