[U-Boot] [PATCH 2/3] mmc: s5p_mmc: fixed wrong function argument
Useless code is removed, and get buswidth value.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- arch/arm/include/asm/arch-exynos/mmc.h | 4 ++-- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 4 ++-- drivers/mmc/s5p_sdhci.c | 9 ++++----- 3 files changed, 8 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 0f701c9..afdfcf0 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -64,11 +64,11 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
-int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks); +int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline unsigned int s5p_mmc_init(int index, int bus_width) { unsigned int base = samsung_get_base_mmc() + (0x10000 * index); - return s5p_sdhci_init(base, 52000000, 400000, index); + return s5p_sdhci_init(base, index, bus_width); } #endif diff --git a/arch/arm/include/asm/arch-s5pc1xx/mmc.h b/arch/arm/include/asm/arch-s5pc1xx/mmc.h index 0f701c9..afdfcf0 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/mmc.h +++ b/arch/arm/include/asm/arch-s5pc1xx/mmc.h @@ -64,11 +64,11 @@ #define SDHCI_CTRL4_DRIVE_MASK(_x) ((_x) << 16) #define SDHCI_CTRL4_DRIVE_SHIFT (16)
static inline unsigned int s5p_mmc_init(int index, int bus_width) { unsigned int base = samsung_get_base_mmc() + (0x10000 * index); - return s5p_sdhci_init(base, 52000000, 400000, index); + return s5p_sdhci_init(base, index, bus_width); } #endif diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 12b28dd..d7e92a4 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -69,7 +69,7 @@ static void s5p_sdhci_set_control_reg(struct sdhci_host *host) sdhci_writel(host, ctrl, SDHCI_CONTROL2); }
-int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks) +int s5p_sdhci_init(u32 regbase, int index, int bus_width) { struct sdhci_host *host = NULL; host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); @@ -80,12 +80,11 @@ int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks)
host->name = S5P_NAME; host->ioaddr = (void *)regbase; - host->quirks = quirks;
- host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; - if (quirks & SDHCI_QUIRK_REG32_RW) + if (host->quirks & SDHCI_QUIRK_REG32_RW) host->version = sdhci_readl(host, SDHCI_HOST_VERSION - 2) >> 16; else host->version = sdhci_readw(host, SDHCI_HOST_VERSION); @@ -94,6 +93,6 @@ int s5p_sdhci_init(u32 regbase, u32 max_clk, u32 min_clk, u32 quirks)
host->host_caps = MMC_MODE_HC;
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 52000000, 400000); return 0; }
Jaehoon Chung
