[U-Boot-Users] My 3 patches
Hi.
Here is my 3 patches.
sbc2410x.patch is for the new board -- SBC-2410X. I write this new hardware-specific configurations refer to smdk2410 configurations in U-Boot. File list: MAKEALL Makefile board/sbc2410x/Makefile board/sbc2410x/config.mk board/sbc2410x/flash.c board/sbc2410x/lowlevel_init.S board/sbc2410x/sbc2410x.c board/sbc2410x/u-boot.lds cpu/arm920t/s3c24x0/interrupts.c include/configs/sbc2410x.h This patch adds a new configuration option -- CONFIG_SBC2410X.
cmdline_editing.patch implements cmdline-editing extension of readline. I pick codes heavily borrowed from vivi bootloader and integrate them into U-Boot. File list: common/main.c This patch adds a new configuration option -- CONFIG_CMDLINE_EDITING.
nand_for_sbc2410x.patch adds nand support for SBC-2410X board. It do that by taking nand controller specific codes (from VCMA9 board) in place. File list: common/cmd_nand.c include/linux/mtd/nand.h include/linux/mtd/nand_ids.h
more detail please review: http://sourceforge.net/mailarchive/forum.php?thread_id=8089177&forum_id=...
CHANGELOG item: * Add support for friendly-arm SBC-2410X board Patch by JinHua Luo, 1 Sep 2005 * Add to readline cmdline-editing extension Patch by JinHua Luo, 1 Sep 2005 * Add nand support for SBC-2410X Patch by JinHua Luo, 1 Sep 2005
CREDIT item (if proper): N: JinHua Luo E: luo.jinhua@gd-linux.com home_king@163.com D: Support for friendly-arm SBC-2410X board D: Add to readline cmdline-editing extension D: Add nand support for SBC-2410X W: www.gd-linux.com
luo.jinhua
-- JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com
Hi:
I applied your patch my U-Boot. But I found one bug in this patch in cread_line() function, you should return the number of read characters. You return the "rc" at the end of the function, but rc always equals 0. The u-boot command will NOT be executed.
I modified the to return (eol_num). It is ok.
You can check it.
Bryan Wu from China.
----- Original Message ----- From: "luo.jinhua" luo.jinhua@gd-linux.com To: "u-boot-users" u-boot-users@lists.sourceforge.net Sent: Friday, September 02, 2005 10:02 AM Subject: [U-Boot-Users] My 3 patches
Hi.
CHANGELOG item:
- Add support for friendly-arm SBC-2410X board
- Add to readline cmdline-editing extension
- Add nand support for SBC-2410X
luo.jinhua
On Fri, 16 Sep 2005 18:36:09 +0800, Bryan Wu wrote
Hi:
You can check it.
Thank you.
It is indeed a bug. However, while I always use CFG_HUSH_PARSER, the hush engine ignores the "rc" retval and recalculates the console_buffer length, which make me miss the bug.
luo.jinhua ---------- JinHua Luo, GuangDong Linux Center, luo.jinhua@gd-linux.com
Dear JinHua Luo,
Thanks a lot for your contribution.
Applied, thanks.
Applied, thanks a lot!
...which should have been documented in the README (I did this for you).
I did not add this patch, though. I think you will have to adapt it to the current (new) NAND code first. Can you please do this, and then resubmit this part? Thanks!
Bryan Wu
luo.jinhua
