[U-Boot] [PATCH 0/1] sun7i: Set ARMV7_BOOT_SEC_DEFAULT when OLD_SUNXI_KERNEL_COMPAT is set
Hi Ian,
Thanks for the quick review on the 2 display fixes. With Albert's pull-req of today the dependencies for this fix are going upstream as soon as Tom merges the pull-req.
Can you review this one too please ?
Thanks & Regards,
Hans
Old kernels cannot handle booting in non-secure (hyp) mode, so when OLD_SUNXI_KERNEL_COMPAT is set, also set ARMV7_BOOT_SEC_DEFAULT.
Note that whether to booting secure or non-secure can always be overriden using the bootm_boot_mode environment variable.
Signed-off-by: Hans de Goede hdegoede@redhat.com -- Changes in v2: -Use Kconfig rather the a hard-define in include/configs/sun7i.h --- board/sunxi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index e20ea1b..246cd9a 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -24,6 +24,7 @@ config MACH_SUN7I select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select SUPPORT_SPL + select ARMV7_BOOT_SEC_DEFAULT if OLD_SUNXI_KERNEL_COMPAT
config MACH_SUN8I bool "sun8i (Allwinner A23)"
Acked-by: Ian Campbell ijc@hellion.org.uk
Hans de Goede
Ian Campbell
