Re: [U-Boot] [PATCH V2 06/12] lcd: replace CONSOLE_(ROWS|COLS) with variables
Hi Simon,
On 11/30/2014 09:25 PM, Simon Glass wrote:
On 30 November 2014 at 05:29, Nikita Kiryanov nikita@compulab.co.il wrote:
Replace CONSOLE_(ROWS|COLS) macros with variables, and assign the original macro values.
This is a preparatory step for extracting lcd console code into its own file.
Signed-off-by: Nikita Kiryanov nikita@compulab.co.il Cc: Anatolij Gustschin agust@denx.de Cc: Simon Glass sjg@chromium.org
Changes in V2: - New patch.
Are you intended to want to support multiple displays, or just to change the resolution after start?
This did cross my mind as possible future work, but for this patch set the change was driven by the goal of decoupling lcd_console stuff as much as possible from the rest of the code, which meant that I did not want to bring panel_info references into lcd_console.c (there's actually one use of panel_info still remaining in console_scrollup() but I'll get rid of it if/when this series is applied).
In the case of console_cols and console_rows, the idea was that the use of panel_info can be avoided if lcd.c would pass the values as parameters to lcd_init_console() (introduced in a later patch), which meant that the macros had to be replaced with variables.
Tested on pit, LCD works fine.
Tested-by: Simon Glass sjg@chromium.org
This mail did not reach mainline, so I'm Cc-ing the mailing list. I don't know if patchworks will register the Ack and Tested-by though, can you maybe resend them in a separate reply?
Nikita Kiryanov
