[U-Boot] [PATCH] License cleanup: Fix license header for some esd display configurations
These files were autogenerated by EPSON configuration tools. This patch replaces the autogenerated file headers by the GPL license notice.
This change is done with the explicit permission of Epson Research & Development / IC Software Development.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- board/esd/common/s1d13704_320_240_4bpp.h | 27 +++++++++++++++++---------- board/esd/common/s1d13705_320_240_8bpp.h | 27 +++++++++++++++++---------- board/esd/common/s1d13806_1024_768_8bpp.h | 23 +++++++++++++++++------ board/esd/common/s1d13806_320_240_4bpp.h | 23 +++++++++++++++++------ board/esd/common/s1d13806_640_480_16bpp.h | 23 +++++++++++++++++------ board/esd/common/s1d13806_640_480_8bpp.h | 23 +++++++++++++++++------ 6 files changed, 102 insertions(+), 44 deletions(-)
diff --git a/board/esd/common/s1d13704_320_240_4bpp.h b/board/esd/common/s1d13704_320_240_4bpp.h index 77c8a46..57cf5f7 100644 --- a/board/esd/common/s1d13704_320_240_4bpp.h +++ b/board/esd/common/s1d13704_320_240_4bpp.h @@ -1,19 +1,26 @@ /* + * Copyright (c) 2000,2001 Epson Research and Development, Inc. * - * Generic Header information generated by 13704CFG.EXE (Build 10) + * See file CREDITS for list of people who contributed to this + * project. * - * Copyright (c) 2000,2001 Epson Research and Development, Inc. - * All rights reserved. + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * - * Panel: 320x240x4bpp 78Hz Mono 4-Bit STN, Disabled (PCLK=6.666MHz) + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. * - * This file defines the configuration environment and registers, - * which can be used by any software, such as display drivers. - * - * PLEASE NOTE: If you FTP this file to a non-Windows platform, make - * sure you transfer this file using ASCII, not BINARY - * mode. + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA * + * Generic Header information generated by 13704CFG.EXE (Build 10) + * Panel: 320x240x4bpp 78Hz Mono 4-Bit STN, Disabled (PCLK=6.666MHz) */
static S1D_REGS regs_13704_320_240_4bpp[] = diff --git a/board/esd/common/s1d13705_320_240_8bpp.h b/board/esd/common/s1d13705_320_240_8bpp.h index 60843ac..634889a 100644 --- a/board/esd/common/s1d13705_320_240_8bpp.h +++ b/board/esd/common/s1d13705_320_240_8bpp.h @@ -1,19 +1,26 @@ /* + * Copyright (c) 2000,2001 Epson Research and Development, Inc. * - * Generic Header information generated by 13704CFG.EXE (Build 10) + * See file CREDITS for list of people who contributed to this + * project. * - * Copyright (c) 2000,2001 Epson Research and Development, Inc. - * All rights reserved. + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * - * Panel: 320x240x8bpp 78Hz Mono 8-Bit STN, Disabled (PCLK=6.666MHz) + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. * - * This file defines the configuration environment and registers, - * which can be used by any software, such as display drivers. - * - * PLEASE NOTE: If you FTP this file to a non-Windows platform, make - * sure you transfer this file using ASCII, not BINARY - * mode. + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA * + * Generic Header information generated by 13704CFG.EXE (Build 10) + * Panel: 320x240x8bpp 78Hz Mono 8-Bit STN, Disabled (PCLK=6.666MHz) */
static S1D_REGS regs_13705_320_240_8bpp[] = diff --git a/board/esd/common/s1d13806_1024_768_8bpp.h b/board/esd/common/s1d13806_1024_768_8bpp.h index 68801bf..0b420b2 100644 --- a/board/esd/common/s1d13806_1024_768_8bpp.h +++ b/board/esd/common/s1d13806_1024_768_8bpp.h @@ -1,16 +1,27 @@ /* + * Copyright (c) 2000,2001 Epson Research and Development, Inc. * - * File generated by S1D13806CFG.EXE + * See file CREDITS for list of people who contributed to this + * project. * - * Copyright (c) 2000,2001 Epson Research and Development, Inc. - * All rights reserved. + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * - * PLEASE NOTE: If you FTP this file to a non-Windows platform, make - * sure you transfer this file using ASCII, not BINARY mode. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * File generated by S1D13806CFG.EXE * Panel: (active) 1024x768 34Hz TFT Single 12-bit (PCLK=BUSCLK=33.333MHz) * Memory: Embedded SDRAM (MCLK=CLKI=49.100MHz) (BUSCLK=33.333MHz) - * */
static S1D_REGS regs_13806_1024_768_8bpp[] = diff --git a/board/esd/common/s1d13806_320_240_4bpp.h b/board/esd/common/s1d13806_320_240_4bpp.h index 24d7350..5aab2c1 100644 --- a/board/esd/common/s1d13806_320_240_4bpp.h +++ b/board/esd/common/s1d13806_320_240_4bpp.h @@ -1,16 +1,27 @@ /* + * Copyright (c) 2000,2001 Epson Research and Development, Inc. * - * File generated by S1D13806CFG.EXE + * See file CREDITS for list of people who contributed to this + * project. * - * Copyright (c) 2000,2001 Epson Research and Development, Inc. - * All rights reserved. + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * - * PLEASE NOTE: If you FTP this file to a non-Windows platform, make - * sure you transfer this file using ASCII, not BINARY mode. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * File generated by S1D13806CFG.EXE * Panel: (active) 320x240 62Hz STN Single 4-bit (PCLK=CLKI2/4=6.250MHz) * Memory: Embedded SDRAM (MCLK=CLKI=49.500MHz) (BUSCLK=33.333MHz) - * */
static S1D_REGS regs_13806_320_240_4bpp[] = diff --git a/board/esd/common/s1d13806_640_480_16bpp.h b/board/esd/common/s1d13806_640_480_16bpp.h index 178f1a9..f851278 100644 --- a/board/esd/common/s1d13806_640_480_16bpp.h +++ b/board/esd/common/s1d13806_640_480_16bpp.h @@ -1,16 +1,27 @@ /* + * Copyright (c) 2000,2001 Epson Research and Development, Inc. * - * File generated by S1D13806CFG.EXE + * See file CREDITS for list of people who contributed to this + * project. * - * Copyright (c) 2000,2001 Epson Research and Development, Inc. - * All rights reserved. + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * - * PLEASE NOTE: If you FTP this file to a non-Windows platform, make - * sure you transfer this file using ASCII, not BINARY mode. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * File generated by S1D13806CFG.EXE * Panel: (active) 640x480 59Hz TFT Single 18-bit (PCLK=CLKI2=25.000MHz) * Memory: Embedded SDRAM (MCLK=CLKI=49.152MHz) (BUSCLK=33.333MHz) - * */
static S1D_REGS regs_13806_640_480_16bpp[] = diff --git a/board/esd/common/s1d13806_640_480_8bpp.h b/board/esd/common/s1d13806_640_480_8bpp.h index c1f5b2b..17fa1d3 100644 --- a/board/esd/common/s1d13806_640_480_8bpp.h +++ b/board/esd/common/s1d13806_640_480_8bpp.h @@ -1,16 +1,27 @@ /* + * Copyright (c) 2000,2001 Epson Research and Development, Inc. * - * File generated by S1D13806CFG.EXE + * See file CREDITS for list of people who contributed to this + * project. * - * Copyright (c) 2000,2001 Epson Research and Development, Inc. - * All rights reserved. + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * - * PLEASE NOTE: If you FTP this file to a non-Windows platform, make - * sure you transfer this file using ASCII, not BINARY mode. + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * File generated by S1D13806CFG.EXE * Panel: (active) 640x480 59Hz TFT Single 18-bit (PCLK=CLKI2=25.000MHz) * Memory: Embedded SDRAM (MCLK=CLKI=49.152MHz) (BUSCLK=33.333MHz) - * */
static S1D_REGS regs_13806_640_320_16bpp[] =
Hi Wolfgang,
Thanks.
Wolfgang, will you pull this patch directly? Or should I run it through the 4xx repository?
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Dear Stefan Roese,
Thanks.
I can do it.
Dear Matthias Fuchs,
Applied, thanks.
Matthias Fuchs
Stefan Roese
