RE: [PATCH 3/4] clk: add clock driver for SCMI agents
Subject: [PATCH 3/4] clk: add clock driver for SCMI agents
This change introduces a clock driver for SCMI agent devices. When SCMI agent and SCMI clock drivers are enabled, SCMI agent binds a clock device for each SCMI clock protocol devices enabled in the FDT.
SCMI clock driver is embedded upon CONFIG_CLK_SCMI=y. If enabled, CONFIG_SCMI_AGENT is also enabled.
SCMI Clock protocol is defined in the SCMI specification [1].
Links: [1] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdevelo per.arm.com%2Farchitectures%2Fsystem-architectures%2Fsoftware-standar ds%2Fscmi&data=02%7C01%7Cpeng.fan%40nxp.com%7C6a1c6d1e102 94e81e47708d82a6777b9%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0% 7C0%7C637305971176347870&sdata=4pKZGL17y7QUY%2Bi9XRutLOCe 5jBs1y9gMW7vNoUIcC0%3D&reserved=0 Signed-off-by: Etienne Carriere etienne.carriere@linaro.org
drivers/clk/Kconfig | 8 +++ drivers/clk/Makefile | 1 + drivers/clk/clk_scmi.c | 152 ++++++++++++++++++++++++++++++++++++++++ drivers/firmware/scmi.c | 3 + 4 files changed, 164 insertions(+) create mode 100644 drivers/clk/clk_scmi.c
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 82cb1874e19..234d6035202 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -152,6 +152,14 @@ config CLK_CDCE9XX Enable the clock synthesizer driver for CDCE913/925/937/949 series of chips.
+config CLK_SCMI
- bool "Enable SCMI clock driver"
- select SCMI_FIRMWARE
- help
Enable this option if you want to support clock devices exposed
by a SCMI agent based on SCMI clock protocol communication
with a SCMI server.
source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index d9119545810..76bba77d1f0 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -31,6 +31,7 @@ obj-$(CONFIG_CLK_K210) += kendryte/ obj-$(CONFIG_CLK_MPC83XX) += mpc83xx_clk.o obj-$(CONFIG_CLK_OWL) += owl/ obj-$(CONFIG_CLK_RENESAS) += renesas/ +obj-$(CONFIG_CLK_SCMI) += clk_scmi.o obj-$(CONFIG_CLK_SIFIVE) += sifive/ obj-$(CONFIG_ARCH_SUNXI) += sunxi/ obj-$(CONFIG_CLK_STM32F) += clk_stm32f.o diff --git a/drivers/clk/clk_scmi.c b/drivers/clk/clk_scmi.c new file mode 100644 index 00000000000..efe64a6a38f --- /dev/null +++ b/drivers/clk/clk_scmi.c @@ -0,0 +1,152 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2019-2020 Linaro Limited */ #include <common.h>
+#include <clk-uclass.h> #include <dm.h> #include <scmi.h> #include +<asm/types.h>
+enum scmi_clock_message_id {
- SCMI_CLOCK_RATE_SET = 0x5,
- SCMI_CLOCK_RATE_GET = 0x6,
- SCMI_CLOCK_CONFIG_SET = 0x7,
+#define SCMI_CLK_RATE_ASYNC_NOTIFY BIT(0) +#define SCMI_CLK_RATE_ASYNC_NORESP (BIT(0) | BIT(1)) +#define SCMI_CLK_RATE_ROUND_DOWN 0 +#define SCMI_CLK_RATE_ROUND_UP BIT(2) +#define SCMI_CLK_RATE_ROUND_CLOSEST BIT(3)
+struct scmi_clk_state_in {
- u32 clock_id;
- u32 attributes;
+struct scmi_clk_state_out {
- s32 status;
+static int scmi_clk_gate(struct clk *clk, int enable) {
- struct scmi_clk_state_in in = {
.clock_id = clk->id,
.attributes = enable,
- struct scmi_clk_state_out out;
- struct scmi_msg scmi_msg = {
.protocol_id = SCMI_PROTOCOL_ID_CLOCK,
.message_id = SCMI_CLOCK_CONFIG_SET,
.in_msg = (u8 *)&in,
.in_msg_sz = sizeof(in),
.out_msg = (u8 *)&out,
.out_msg_sz = sizeof(out),
- int rc;
- rc = scmi_send_and_process_msg(clk->dev->parent, &scmi_msg);
- if (rc)
return rc;
- return scmi_to_linux_errno(out.status); }
+static int scmi_clk_enable(struct clk *clk) {
- return scmi_clk_gate(clk, 1);
+static int scmi_clk_disable(struct clk *clk) {
- return scmi_clk_gate(clk, 0);
+struct scmi_clk_rate_get_in {
- u32 clock_id;
+struct scmi_clk_rate_get_out {
- s32 status;
- u32 rate_lsb;
- u32 rate_msb;
+static ulong scmi_clk_get_rate(struct clk *clk) {
- struct scmi_clk_rate_get_in in = {
- struct scmi_clk_rate_get_out out;
.message_id = SCMI_CLOCK_RATE_GET,
- int rc;
- if (rc)
- rc = scmi_to_linux_errno(out.status);
- if (rc)
- return (ulong)(((u64)out.rate_msb << 32) | out.rate_lsb); }
+struct scmi_clk_rate_set_in {
- u32 clock_id;
- u32 flags;
- u32 rate_lsb;
- u32 rate_msb;
+struct scmi_clk_rate_set_out {
- s32 status;
+static ulong scmi_clk_set_rate(struct clk *clk, ulong rate) {
- struct scmi_clk_rate_set_in in = {
.flags = SCMI_CLK_RATE_ASYNC_NORESP |
This will use async, but how if sync?
Thanks, Peng.
SCMI_CLK_RATE_ROUND_CLOSEST,
.rate_lsb = (u32)rate,
.rate_msb = (u32)((u64)rate >> 32),
- struct scmi_clk_rate_set_out out;
.message_id = SCMI_CLOCK_RATE_SET,
- int rc;
- if (rc)
+static const struct clk_ops scmi_clk_ops = {
- .enable = scmi_clk_enable,
- .disable = scmi_clk_disable,
- .get_rate = scmi_clk_get_rate,
- .set_rate = scmi_clk_set_rate,
+U_BOOT_DRIVER(scmi_clock) = {
- .name = "scmi_clk",
- .id = UCLASS_CLK,
- .ops = &scmi_clk_ops,
+}; diff --git a/drivers/firmware/scmi.c b/drivers/firmware/scmi.c index fa8a91c3f3d..9f06718df51 100644 --- a/drivers/firmware/scmi.c +++ b/drivers/firmware/scmi.c @@ -399,6 +399,9 @@ static int scmi_bind(struct udevice *dev) continue;
switch (protocol_id) {
case SCMI_PROTOCOL_ID_CLOCK:
drv = DM_GET_DRIVER(scmi_clock);
default: dev_info(dev, "Ignore unsupported SCMI protocol %u\n", protocol_id);break;
-- 2.17.1
Hi Peng,
Thanks, you're right, i made it wrong. Considering u-boot sequential execution, synchronous rate setting is prefered. I'll remove SCMI_CLK_RATE_ASYNC_NORESP from .flags value.
Etienne
Thanks, Peng.
Etienne Carriere
Peng Fan
