[U-Boot] [PATCH] mx6ul_14x14_evk: Fix DDR calibration values
When running NXP 4.1 kernel with U-Boot mainline we observe a hang when going into the lowest operational point of cpufreq.
Comparing the DDR calibration values against NXP U-Boot showed that the values were incorrect.
Adjust the calibration values so that we can avoid such system hang.
Reported-by: Eric Nelson eric@nelint.com Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index c213861..77c561d 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -784,10 +784,10 @@ static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { };
static struct mx6_mmdc_calibration mx6_mmcd_calib = { - .p0_mpwldectrl0 = 0x00070007, - .p0_mpdgctrl0 = 0x41490145, - .p0_mprddlctl = 0x40404546, - .p0_mpwrdlctl = 0x4040524D, + .p0_mpwldectrl0 = 0x00000000, + .p0_mpdgctrl0 = 0x41570155, + .p0_mprddlctl = 0x4040474A, + .p0_mpwrdlctl = 0x40405550, };
struct mx6_ddr_sysinfo ddr_sysinfo = {
Acked-by: Peng Fan peng.fan@nxp.com
Thanks, Peng.
- .p0_mpwldectrl0 = 0x00000000,
- .p0_mpdgctrl0 = 0x41570155,
- .p0_mprddlctl = 0x4040474A,
- .p0_mpwrdlctl = 0x40405550,
2.7.4
Hi Eric,
After running more tests I still get the hang sometimes, so we still need to review the DDR SPL settings.
Regards,
Fabio Estevam
Hi Fabio,
On 08/29/2016 04:58 AM, Fabio Estevam wrote:
Hi Eric,
Regards,
Fabio Estevam
I just test this patch against imx/master and I'm still seeing the issue:
root@imx6ulevk:~# Bus freq set to 24000000 start...
Do you have kernel debug messages enabled so you can see the bus frequency change?
Hi Fabio,
Regards,
Fabio Estevam
Things are working well using your config patch: http://pastebin.com/crAe1Yr1
root@imx6ulevk:~# Bus freq set to 24000000 start... Bus freq set to 24000000 done!
root@imx6ulevk:~# root@imx6ulevk:~# Bus freq set to 400000000 start... Bus freq set to 400000000 done!
Hi Eric,
Please test this one: http://lists.denx.de/pipermail/u-boot/2016-August/265131.html
Thanks
Thanks very much for your efforts Fabio,
On 08/29/2016 11:06 AM, Fabio Estevam wrote:
Hi Eric,
I did and it fixes the problem.
I sent a review with some concerns about why and how, but patch 1/3 confirmed that the problem doesn't stem from calibration.
This is good, because I originally found the problem on a custom board that had pristine calibration values which survived multiple overnight stress tests (using the stress tool and Linux).
Regards,
Eric
Eric Nelson
Fabio Estevam
Peng Fan
