[U-Boot] [PATCH] spl: mmc: Fix indentation in spl_mmc.c file
This fixes a wrongly indented block of code.
Signed-off-by: Mans Rullgard mans@mansr.com [lukma: Make the commit message more verbose] Signed-off-by: Lukasz Majewski lukma@denx.de
common/spl/spl_mmc.c | 40 ++++++++++++++++++++-------------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b3619889f7..2caceb5186 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -334,28 +334,28 @@ int spl_mmc_load(struct spl_image_info *spl_image, err = -EINVAL; switch (boot_mode) { case MMCSD_MODE_EMMCBOOT: - /* - * We need to check what the partition is configured to. - * 1 and 2 match up to boot0 / boot1 and 7 is user data - * which is the first physical partition (0). - */ - part = (mmc->part_config >> 3) & PART_ACCESS_MASK; - - if (part == 7) - part = 0; - - if (CONFIG_IS_ENABLED(MMC_TINY)) - err = mmc_switch_part(mmc, part); - else - err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); - - if (err) { + /* + * We need to check what the partition is configured to. + * 1 and 2 match up to boot0 / boot1 and 7 is user data + * which is the first physical partition (0). + */ + part = (mmc->part_config >> 3) & PART_ACCESS_MASK; + + if (part == 7) + part = 0; + + if (CONFIG_IS_ENABLED(MMC_TINY)) + err = mmc_switch_part(mmc, part); + else + err = blk_dselect_hwpart(mmc_get_blk_desc(mmc), part); + + if (err) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT - puts("spl: mmc partition switch failed\n"); + puts("spl: mmc partition switch failed\n"); #endif - return err; - } - /* Fall through */ + return err; + } + /* Fall through */ case MMCSD_MODE_RAW: debug("spl: mmc boot mode: raw\n");
Dear Tom,
Tom, are there any issues preventing this patch from being applied to -master?
configured to.
is user data
PART_ACCESS_MASK; -
if (part == 7)
part = 0;
else
err =
if (err) {
to.
data
if (part == 7)
part = 0;
else
err =
if (err) {
failed\n");
#endif
return err;
/* Fall through */
return err;
case MMCSD_MODE_RAW: debug("spl: mmc boot mode: raw\n");/* Fall through */
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Lukasz Majewski
