[U-Boot-Users] pcmcia support for at91rm9200dk
hello david,
I have a patch to boot on a cf card for at91rm9200dk It's just for doing some tests so it is not a "proper" patch : some defines to put in a correct file...
regards,
Yann
David A. Peters a écrit :
Does U-Boot have PCMCIA support for the AT91RM9200?
This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170 Project Admins to receive an Apple iPod Mini FREE for your judgement on who ports your project to Linux PPC the best. Sponsored by IBM. Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php
diff -uNrp u-boot-1.1.1-ori/board/at91rm9200dk/at91rm9200dk.c u-boot-1.1.1/board/at91rm9200dk/at91rm9200dk.c --- u-boot-1.1.1-ori/board/at91rm9200dk/at91rm9200dk.c Thu Sep 11 21:49:01 2003 +++ u-boot-1.1.1/board/at91rm9200dk/at91rm9200dk.c Tue Sep 7 10:29:49 2004 @@ -112,3 +115,69 @@ void nand_init (void) printf ("%4lu MB\n", nand_probe(AT91_SMARTMEDIA_BASE) >> 20); } #endif + + + + +/* YD Pcmcia initialization. + * Todo: ajouter les define dans un .h propre.... + */ +#if (CONFIG_COMMANDS & CFG_CMD_PCMCIA) +#define AT91C_ID_PIOB ( 3) +#define AT91C_ID_PIOC ( 4) +#define AT91C_PIO_PC6 (1 << 6) +#define AT91C_PC6_NWAIT (AT91C_PIO_PC6) +#define AT91C_PIO_PC7 (1 << 7) +#define AT91C_PC7_A23 (AT91C_PIO_PC7) +#define AT91C_PIO_PC9 (1 << 9) +#define AT91C_PC9_A25_CFRNW (AT91C_PIO_PC9) +#define AT91C_PIO_PC10 (1 << 10) +#define AT91C_PC10_NCS4_CFCS (AT91C_PIO_PC10) +#define AT91C_PIO_PC11 (1 << 11) +#define AT91C_PC11_NCS5_CFCE1 (AT91C_PIO_PC11) +#define AT91C_PIO_PC12 (1 << 12) +#define AT91C_PC12_NCS6_CFCE2 (AT91C_PIO_PC12) +#define AT91C_PIO_PB0 (1 << 0) +#define AT91C_CF_PB0_CD1 AT91C_PIO_PB0 +#define AT91C_PIO_PC5 (1 << 5) +#define AT91C_CF_PC5_RESET AT91C_PIO_PC5 +#define AT91C_EBI_CS4A_SMC_COMPACTFLASH (0x1 << 4) +#define AT91C_SMC2_DBW_16 (0x1 << 13) +#define AT91C_SMC2_BAT (0x1 << 12) +#define AT91C_BASE_PIOB ((AT91PS_PIO) 0xFFFFF600) + +int at91_pcmcia_low_level_init() +{ + + *AT91C_PMC_PCER = 1 << AT91C_ID_PIOB; + *AT91C_PMC_PCER = 1 << AT91C_ID_PIOC; + + /* Set up pio */ + *AT91C_PIOC_PDR = AT91C_PC6_NWAIT | AT91C_PC7_A23 | AT91C_PC9_A25_CFRNW | AT91C_PC10_NCS4_CFCS | AT91C_PC11_NCS5_CFCE1 | AT91C_PC12_NCS6_CFCE2; + *AT91C_PIOC_ASR = AT91C_PC6_NWAIT | AT91C_PC7_A23 | AT91C_PC9_A25_CFRNW | AT91C_PC10_NCS4_CFCS | AT91C_PC11_NCS5_CFCE1 | AT91C_PC12_NCS6_CFCE2; + + *AT91C_PIOB_PER = AT91C_CF_PB0_CD1; + *AT91C_PIOB_ODR = AT91C_CF_PB0_CD1; + *AT91C_PIOC_PER = AT91C_CF_PC5_RESET; + ((AT91PS_PIO)AT91C_BASE_PIOB)->PIO_OER = AT91C_CF_PC5_RESET; + ((AT91PS_PIO)AT91C_BASE_PIOB)->PIO_CODR = AT91C_CF_PC5_RESET; + + + /* Setup Compact Flash, enable the address range of CS4 */ + *AT91C_EBI_CSA |= AT91C_EBI_CS4A_SMC_COMPACTFLASH; + +#define SM_RWH (4 << 28) /* hold time, was 2 */ +#define SM_RWS (6 << 24) /* setup time, was 6 */ +#define SM_TDF (1 << 8) /* data float time, */ +#define SM_NWS (32) /* wait states, NOTE: 0=1.5, 1=2.5, etc */ + + + ((AT91PS_SMC2)AT91C_BASE_SMC2)->SMC2_CSR[4] = SM_RWH | SM_RWS | AT91C_SMC2_ACSS_STANDARD | AT91C_SMC2_DBW_16 | AT91C_SMC2_BAT | AT91C_SMC2_WSEN | SM_NWS; + + debug("AT9RM92000 CF driver\n"); + + return 0; + +} + +#endif /* CONFIG_COMMANDS & CFG_CMD_PCMCIA */ /* YD End */ diff -uNrp u-boot-1.1.1-ori/common/cmd_ide.c u-boot-1.1.1/common/cmd_ide.c --- u-boot-1.1.1-ori/common/cmd_ide.c Fri Apr 23 22:32:06 2004 +++ u-boot-1.1.1/common/cmd_ide.c Tue Sep 7 10:38:42 2004 @@ -787,7 +787,7 @@ set_pcmcia_timing (int pmode)
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) +#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_AT91RM9200DK) /*YD*/ static void __inline__ ide_outb(int dev, int port, unsigned char val) { @@ -807,7 +807,7 @@ ide_outb(int dev, int port, unsigned cha #endif /* __PPC__ */
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) +#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_AT91RM9200DK) /*YD*/ static unsigned char __inline__ ide_inb(int dev, int port) { @@ -885,7 +885,7 @@ input_swap_data(int dev, ulong *sect_buf #endif /* __LITTLE_ENDIAN || CONFIG_AU1X00 */
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) +#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_AT91RM9200DK) /*YD*/ static void output_data(int dev, ulong *sect_buf, int words) { @@ -929,7 +929,7 @@ output_data(int dev, ulong *sect_buf, in } #endif /* __PPC__ */
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) +#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_AT91RM9200DK) /*YD*/ static void input_data(int dev, ulong *sect_buf, int words) { @@ -1585,7 +1585,7 @@ static void ide_led (uchar led, uchar st #define AT_PRINTF(fmt,args...) #endif
-#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) +#if defined(__PPC__) || defined(CONFIG_PXA_PCMCIA) || defined(CONFIG_AT91RM9200DK) /*YD*/ /* since ATAPI may use commands with not 4 bytes alligned length * we have our own transfer functions, 2 bytes alligned */ static void diff -uNrp u-boot-1.1.1-ori/common/cmd_pcmcia.c u-boot-1.1.1/common/cmd_pcmcia.c --- u-boot-1.1.1-ori/common/cmd_pcmcia.c Sun Apr 18 19:39:39 2004 +++ u-boot-1.1.1/common/cmd_pcmcia.c Tue Sep 7 10:32:25 2004 @@ -99,7 +99,7 @@ static u_int m8xx_get_speed(u_int ns, u_ /* -------------------------------------------------------------------- */
#ifndef CONFIG_PXA_PCMCIA - +#ifndef CONFIG_AT91RM9200DK /* look up table for pgcrx registers */
static u_int *pcmcia_pgcrx[2] = { @@ -108,6 +108,7 @@ static u_int *pcmcia_pgcrx[2] = { }; #define PCMCIA_PGCRX(slot) (*pcmcia_pgcrx[slot])
+#endif /* CONFIG_AT91RM9200DK */ #endif /* CONFIG_PXA_PCMCIA */
#endif /* CONFIG_I82365 */ @@ -166,6 +167,7 @@ int pcmcia_on (void) #else
#ifndef CONFIG_PXA_PCMCIA +#ifndef CONFIG_AT91RM9200DK
#ifdef CONFIG_HMI10 # define HMI10_FRAM_TIMING (PCMCIA_SHT(2) | PCMCIA_SST(2) | PCMCIA_SL(4)) @@ -288,8 +290,10 @@ int pcmcia_on (void) return (rc); }
+ #endif /* CONFIG_I82365 */
#ifdef CONFIG_PXA_PCMCIA @@ -389,6 +393,45 @@ int pcmcia_on (void)
+ +#ifdef CONFIG_AT91RM9200DK /* YD */ + +static int hardware_enable (int slot) +{ + at91_pcmcia_low_level_init(); + return 0; /* No hardware to enable */ +} + +static int hardware_disable(int slot) +{ + return 0; /* No hardware to disable */ +} + +static int voltage_set(int slot, int vcc, int vpp) +{ + return 0; +} + +void msWait(unsigned msVal) +{ + udelay(msVal*1000); +} + +int pcmcia_on (void) +{ + int rc; + + debug ("%s\n", __FUNCTION__); + + hardware_enable(0); + + rc = check_ide_device (0); /* use just slot 0 */ + + return rc; +} + +#endif /* CONFIG_AT91RM9200DK */ /* YD End */ + /* -------------------------------------------------------------------- */
#if (CONFIG_COMMANDS & CFG_CMD_PCMCIA) @@ -405,7 +448,7 @@ static int pcmcia_off (void) #else
#ifndef CONFIG_PXA_PCMCIA - +#ifndef CONFIG_AT91RM9200DK /*YD*/ static int pcmcia_off (void) { int i; @@ -438,6 +481,7 @@ static int pcmcia_off (void) return 0; }
+#endif /* CONFIG_AT91RM9200DK */ /*YD*/ #endif /* CONFIG_PXA_PCMCIA */
#endif /* CONFIG_I82365 */ @@ -449,6 +493,13 @@ static int pcmcia_off (void) } #endif
+#ifdef CONFIG_AT91RM9200DK /*YD*/ +static int pcmcia_off (void) +{ + return 0; +} +#endif /*YD End*/ + #endif /* CFG_CMD_PCMCIA */
/* -------------------------------------------------------------------- */ @@ -541,7 +592,12 @@ static int check_ide_device (int slot) ide_devices_found |= (1 << slot);
/* set I/O area in config reg -> only valid for ARGOSY D5!!! */ - *((uchar *)(addr + config_base)) = 1; +#ifndef CONFIG_AT91RM9200DK /*YD*/ + *((uchar *)(addr + config_base)) = 1; +#endif +#ifdef CONFIG_AT91RM9200DK + *((uchar *)(addr + config_base)) = 0;/* No iois16 line on dk board...*/ +#endif /*YD End*/
return (0); }
diff -uNrp u-boot-1.1.1-ori/include/configs/at91rm9200dk.h u-boot-1.1.1/include/configs/at91rm9200dk.h --- u-boot-1.1.1-ori/include/configs/at91rm9200dk.h Mon Mar 15 10:00:03 2004 +++ u-boot-1.1.1/include/configs/at91rm9200dk.h Tue Sep 7 10:26:36 2004 @@ -73,7 +73,9 @@ CFG_CMD_AUTOSCRIPT | \ CFG_CMD_FPGA | \ CFG_CMD_MISC | \ - CFG_CMD_LOADS )) + CFG_CMD_LOADS ) | \ + CFG_CMD_PCMCIA | \ + CFG_CMD_IDE )
/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ #include <cmd_confdefs.h> @@ -188,4 +190,43 @@ struct bd_info_ext #error CONFIG_USE_IRQ not supported #endif
+ +/*Pmcia Pc card*/ +#define DEBUG 2 +/* #define IDE_DEBUG 2 */ +#define CONFIG_IDE_8xx_PCCARD 1 +/*#define CONFIG_PXA_PCMCIA 1*/ +#define CONFIG_PXA_IDE 1 + +#define CONFIG_PCMCIA_SLOT_A 1 +/* just to keep build system happy */ + +#define CFG_PCMCIA_MEM_ADDR 0x50000000 +#define CFG_PCMCIA_MEM_SIZE 0x10000000 + +/* memory configuration */ + +#define CFG_IDE_MAXBUS 1 +/* max. 1 IDE bus */ +#define CFG_IDE_MAXDEVICE 1 +/* max. 1 drive per IDE bus */ + + +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SUPPORT_VFAT + + +#define CFG_ATA_IDE0_OFFSET 0x0000 + +#define CFG_ATA_BASE_ADDR 0x50000000|(1 << 22) + +/* Offset for data I/O */ +#define CFG_ATA_DATA_OFFSET 0/*0x1f0*/ + +/* Offset for normal register accesses */ +#define CFG_ATA_REG_OFFSET 0/*0x1f0*/ + +/* Offset for alternate registers */ +#define CFG_ATA_ALT_OFFSET 0e/*0x3f0*/ + #endif
The patch you sent seems to read the CF. When I try to load the kernel image from CF, I get: ** Bad Magic Number **
The CF was formatted on a Win2K system using FAT16. It only contains one partition. I've tried a 64M and 128M CF card and received the same error on both. The number that it does read is 0x4d903ceb on both. I'm sure it's something simple, but I'm not sure what it is. Any ideas?
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of Yann Desplanches Sent: Wednesday, September 22, 2004 3:28 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] Re: pcmcia support for at91rm9200dk
hello david,
regards,
Yann
see http://www.denx.de/twiki/bin/view/DULG/UsingPCCard .
hello david,
regards,
Yann
David A. Peters
Yann Desplanches
