[U-Boot] [PATCH] distro: not taint environment variables if possible
The aim of this patch is not to have temporary variables used in distro_bootcmd left as environment variables after run something. See the discussion[1]. Without this patch, saveenv command also saves those variables, too. While they are apparently safe, scsi_need_init can be harmful.
Please note that, in most cases, a variable should be converted to hush's local variable, while "devplist" cannot because it is created by "part" command as an environment variable.
[1] https://lists.denx.de/pipermail/u-boot/2018-December/350209.html
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/config_distro_bootcmd.h | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 373fee78a999..979aca6475a9 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -27,7 +27,7 @@
#define BOOTENV_SHARED_BLKDEV_BODY(devtypel) \ "if " #devtypel " dev ${devnum}; then " \ - "setenv devtype " #devtypel "; " \ + "devtype=" #devtypel "; " \ "run scan_dev_for_boot_part; " \ "fi\0"
@@ -37,7 +37,7 @@
#define BOOTENV_DEV_BLKDEV(devtypeu, devtypel, instance) \ "bootcmd_" #devtypel #instance "=" \ - "setenv devnum " #instance "; " \ + "devnum=" #instance "; " \ "run " #devtypel "_boot\0"
#define BOOTENV_DEV_NAME_BLKDEV(devtypeu, devtypel, instance) \ @@ -77,7 +77,7 @@ "if ubi part ${bootubipart} && " \ "ubifsmount ubi${devnum}:${bootubivol}; " \ "then " \ - "setenv devtype ubi; " \ + "devtype=ubi; " \ "run scan_dev_for_boot; " \ "fi\0" #define BOOTENV_DEV_UBIFS BOOTENV_DEV_BLKDEV @@ -180,11 +180,11 @@
#ifdef CONFIG_SCSI #define BOOTENV_RUN_SCSI_INIT "run scsi_init; " -#define BOOTENV_SET_SCSI_NEED_INIT "setenv scsi_need_init; " +#define BOOTENV_SET_SCSI_NEED_INIT "scsi_need_init=; " #define BOOTENV_SHARED_SCSI \ "scsi_init=" \ "if ${scsi_need_init}; then " \ - "setenv scsi_need_init false; " \ + "scsi_need_init=false; " \ "scsi scan; " \ "fi\0" \ \ @@ -404,7 +404,8 @@ "bootfstype; then " \ "run scan_dev_for_boot; " \ "fi; " \ - "done\0" \ + "done; " \ + "setenv devplist\0" \ \ BOOT_TARGET_DEVICES(BOOTENV_DEV) \ \
AKASHI Takahiro
