[U-Boot] [PATCH 2/5 v2] dm: ls1021a: Bring in ls1021a dts files from linux kernel
Bring in required device tree files for ls1021a from Linux. These are initially unchanged and have a number of pieces not needed by U-Boot.
Signed-off-by: Haikun Wang Haikun.Wang@freescale.com ---
Changes in v2: - Use CONFIG_LS102XA in arch/arm/dts/Makefile
Changes in v1: None
arch/arm/dts/Makefile | 3 + arch/arm/dts/ls1021a-qds.dts | 201 +++++++++++++++++++++++ arch/arm/dts/ls1021a-twr.dts | 88 ++++++++++ arch/arm/dts/ls1021a.dtsi | 370 +++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 662 insertions(+) create mode 100644 arch/arm/dts/ls1021a-qds.dts create mode 100644 arch/arm/dts/ls1021a-twr.dts create mode 100644 arch/arm/dts/ls1021a.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cbe5b86..c326707 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -54,6 +54,9 @@ dtb-$(CONFIG_SOCFPGA) += \ socfpga_cyclone5_socdk.dtb \ socfpga_cyclone5_socrates.dtb
+dtb-$(CONFIG_LS102XA) += ls1021a-qds.dtb \ + ls1021a-twr.dtb + targets += $(dtb-y)
DTC_FLAGS += -R 4 -p 0x1000 diff --git a/arch/arm/dts/ls1021a-qds.dts b/arch/arm/dts/ls1021a-qds.dts new file mode 100644 index 0000000..c89f85e --- /dev/null +++ b/arch/arm/dts/ls1021a-qds.dts @@ -0,0 +1,201 @@ +/* + * Freescale ls1021a QDS board device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "ls1021a.dtsi" + +/ { + model = "LS1021A QDS Board"; + + aliases { + enet0_rgmii_phy = &rgmii_phy1; + enet1_rgmii_phy = &rgmii_phy2; + enet2_rgmii_phy = &rgmii_phy3; + enet0_sgmii_phy = &sgmii_phy1c; + enet1_sgmii_phy = &sgmii_phy1d; + }; +}; + +&dspi0 { + bus-num = <0>; + status = "okay"; + + dspiflash: at45db021d@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "atmel,at45db021d", "atmel,at45", "atmel,dataflash"; + spi-max-frequency = <16000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; +}; + +&i2c0 { + status = "okay"; + + pca9547: mux@77 { + reg = <0x77>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0>; + + ds3232: rtc@68 { + compatible = "dallas,ds3232"; + reg = <0x68>; + interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x2>; + + ina220@40 { + compatible = "ti,ina220"; + reg = <0x40>; + shunt-resistor = <1000>; + }; + + ina220@41 { + compatible = "ti,ina220"; + reg = <0x41>; + shunt-resistor = <1000>; + }; + }; + + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3>; + + eeprom@56 { + compatible = "atmel,24c512"; + reg = <0x56>; + }; + + eeprom@57 { + compatible = "atmel,24c512"; + reg = <0x57>; + }; + + adt7461a@4c { + compatible = "adi,adt7461a"; + reg = <0x4c>; + }; + }; + }; +}; + +&ifc { + #address-cells = <2>; + #size-cells = <1>; + /* NOR, NAND Flashes and FPGA on board */ + ranges = <0x0 0x0 0x0 0x60000000 0x08000000 + 0x2 0x0 0x0 0x7e800000 0x00010000 + 0x3 0x0 0x0 0x7fb00000 0x00000100>; + status = "okay"; + + nor@0,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "cfi-flash"; + reg = <0x0 0x0 0x8000000>; + bank-width = <2>; + device-width = <1>; + }; + + fpga: board-control@3,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + reg = <0x3 0x0 0x0000100>; + bank-width = <1>; + device-width = <1>; + ranges = <0 3 0 0x100>; + + mdio-mux-emi1 { + compatible = "mdio-mux-mmioreg"; + mdio-parent-bus = <&mdio0>; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x54 1>; /* BRDCFG4 */ + mux-mask = <0xe0>; /* EMI1[2:0] */ + + /* Onboard PHYs */ + ls1021amdio0: mdio@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + rgmii_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + }; + + ls1021amdio1: mdio@20 { + reg = <0x20>; + #address-cells = <1>; + #size-cells = <0>; + rgmii_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + }; + + ls1021amdio2: mdio@40 { + reg = <0x40>; + #address-cells = <1>; + #size-cells = <0>; + rgmii_phy3: ethernet-phy@3 { + reg = <0x3>; + }; + }; + + ls1021amdio3: mdio@60 { + reg = <0x60>; + #address-cells = <1>; + #size-cells = <0>; + sgmii_phy1c: ethernet-phy@1c { + reg = <0x1c>; + }; + }; + + ls1021amdio4: mdio@80 { + reg = <0x80>; + #address-cells = <1>; + #size-cells = <0>; + sgmii_phy1d: ethernet-phy@1d { + reg = <0x1d>; + }; + }; + }; + }; +}; + +&lpuart0 { + status = "okay"; +}; + +&mdio0 { + tbi0: tbi-phy@8 { + reg = <0x8>; + device_type = "tbi-phy"; + }; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; diff --git a/arch/arm/dts/ls1021a-twr.dts b/arch/arm/dts/ls1021a-twr.dts new file mode 100644 index 0000000..34ac82d --- /dev/null +++ b/arch/arm/dts/ls1021a-twr.dts @@ -0,0 +1,88 @@ +/* + * Freescale ls1021a TWR board device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "ls1021a.dtsi" + +/ { + model = "LS1021A TWR Board"; + + aliases { + enet2_rgmii_phy = &rgmii_phy1; + enet0_sgmii_phy = &sgmii_phy2; + enet1_sgmii_phy = &sgmii_phy0; + }; +}; + +&dspi1 { + bus-num = <0>; + status = "okay"; + + dspiflash: s25fl064k@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spansion,s25fl064k"; + spi-max-frequency = <16000000>; + spi-cpol; + spi-cpha; + reg = <0>; + }; +}; + +&i2c0 { + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +&ifc { + #address-cells = <2>; + #size-cells = <1>; + /* NOR Flash on board */ + ranges = <0x0 0x0 0x0 0x60000000 0x08000000>; + status = "okay"; + + nor@0,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "cfi-flash"; + reg = <0x0 0x0 0x8000000>; + bank-width = <2>; + device-width = <1>; + }; +}; + +&lpuart0 { + status = "okay"; +}; + +&mdio0 { + sgmii_phy0: ethernet-phy@0 { + reg = <0x0>; + }; + rgmii_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + sgmii_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + tbi1: tbi-phy@1f { + reg = <0x1f>; + device_type = "tbi-phy"; + }; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi new file mode 100644 index 0000000..434b938 --- /dev/null +++ b/arch/arm/dts/ls1021a.dtsi @@ -0,0 +1,370 @@ +/* + * Freescale ls1021a SOC common device tree source + * + * Copyright 2013-2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "skeleton64.dtsi" +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + compatible = "fsl,ls1021a"; + interrupt-parent = <&gic>; + + aliases { + serial0 = &lpuart0; + serial1 = &lpuart1; + serial2 = &lpuart2; + serial3 = &lpuart3; + serial4 = &lpuart4; + serial5 = &lpuart5; + sysclk = &sysclk; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@f00 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0xf00>; + clocks = <&cluster1_clk>; + }; + + cpu@f01 { + compatible = "arm,cortex-a7"; + device_type = "cpu"; + reg = <0xf01>; + clocks = <&cluster1_clk>; + }; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; + }; + + pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + device_type = "soc"; + interrupt-parent = <&gic>; + ranges; + + gic: interrupt-controller@1400000 { + compatible = "arm,cortex-a7-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x1401000 0x0 0x1000>, + <0x0 0x1402000 0x0 0x1000>, + <0x0 0x1404000 0x0 0x2000>, + <0x0 0x1406000 0x0 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_HIGH)>; + + }; + + ifc: ifc@1530000 { + compatible = "fsl,ifc", "simple-bus"; + reg = <0x0 0x1530000 0x0 0x10000>; + interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + }; + + dcfg: dcfg@1ee0000 { + compatible = "fsl,ls1021a-dcfg", "syscon"; + reg = <0x0 0x1ee0000 0x0 0x10000>; + big-endian; + }; + + esdhc: esdhc@1560000 { + compatible = "fsl,esdhc"; + reg = <0x0 0x1560000 0x0 0x10000>; + interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <0>; + voltage-ranges = <1800 1800 3300 3300>; + sdhci,auto-cmd12; + big-endian; + bus-width = <4>; + status = "disabled"; + }; + + scfg: scfg@1570000 { + compatible = "fsl,ls1021a-scfg", "syscon"; + reg = <0x0 0x1570000 0x0 0x10000>; + big-endian; + }; + + clockgen: clocking@1ee1000 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1ee1000 0x10000>; + + sysclk: sysclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-output-names = "sysclk"; + }; + + cga_pll1: pll@800 { + compatible = "fsl,qoriq-core-pll-2.0"; + #clock-cells = <1>; + reg = <0x800 0x10>; + clocks = <&sysclk>; + clock-output-names = "cga-pll1", "cga-pll1-div2", + "cga-pll1-div4"; + }; + + platform_clk: pll@c00 { + compatible = "fsl,qoriq-core-pll-2.0"; + #clock-cells = <1>; + reg = <0xc00 0x10>; + clocks = <&sysclk>; + clock-output-names = "platform-clk", "platform-clk-div2"; + }; + + cluster1_clk: clk0c0@0 { + compatible = "fsl,qoriq-core-mux-2.0"; + #clock-cells = <0>; + reg = <0x0 0x10>; + clock-names = "pll1cga", "pll1cga-div2", "pll1cga-div4"; + clocks = <&cga_pll1 0>, <&cga_pll1 1>, <&cga_pll1 2>; + clock-output-names = "cluster1-clk"; + }; + }; + + dspi0: dspi@2100000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2100000 0x0 0x10000>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clock-names = "dspi"; + clocks = <&platform_clk 1>; + spi-num-chipselects = <5>; + big-endian; + status = "disabled"; + }; + + dspi1: dspi@2110000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2110000 0x0 0x10000>; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + clock-names = "dspi"; + clocks = <&platform_clk 1>; + spi-num-chipselects = <5>; + big-endian; + status = "disabled"; + }; + + i2c0: i2c@2180000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2180000 0x0 0x10000>; + interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; + clock-names = "i2c"; + clocks = <&platform_clk 1>; + status = "disabled"; + }; + + i2c1: i2c@2190000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2190000 0x0 0x10000>; + interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; + clock-names = "i2c"; + clocks = <&platform_clk 1>; + status = "disabled"; + }; + + i2c2: i2c@21a0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21a0000 0x0 0x10000>; + interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; + clock-names = "i2c"; + clocks = <&platform_clk 1>; + status = "disabled"; + }; + + uart0: serial@21c0500 { + compatible = "fsl,16550-FIFO64", "ns16550a"; + reg = <0x0 0x21c0500 0x0 0x100>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <0>; + fifo-size = <15>; + status = "disabled"; + }; + + uart1: serial@21c0600 { + compatible = "fsl,16550-FIFO64", "ns16550a"; + reg = <0x0 0x21c0600 0x0 0x100>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <0>; + fifo-size = <15>; + status = "disabled"; + }; + + uart2: serial@21d0500 { + compatible = "fsl,16550-FIFO64", "ns16550a"; + reg = <0x0 0x21d0500 0x0 0x100>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <0>; + fifo-size = <15>; + status = "disabled"; + }; + + uart3: serial@21d0600 { + compatible = "fsl,16550-FIFO64", "ns16550a"; + reg = <0x0 0x21d0600 0x0 0x100>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <0>; + fifo-size = <15>; + status = "disabled"; + }; + + lpuart0: serial@2950000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2950000 0x0 0x1000>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&sysclk>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart1: serial@2960000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2960000 0x0 0x1000>; + interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart2: serial@2970000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2970000 0x0 0x1000>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart3: serial@2980000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2980000 0x0 0x1000>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart4: serial@2990000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x2990000 0x0 0x1000>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "ipg"; + status = "disabled"; + }; + + lpuart5: serial@29a0000 { + compatible = "fsl,ls1021a-lpuart"; + reg = <0x0 0x29a0000 0x0 0x1000>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "ipg"; + status = "disabled"; + }; + + wdog0: watchdog@2ad0000 { + compatible = "fsl,imx21-wdt"; + reg = <0x0 0x2ad0000 0x0 0x10000>; + interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "wdog-en"; + big-endian; + }; + + sai1: sai@2b50000 { + compatible = "fsl,vf610-sai"; + reg = <0x0 0x2b50000 0x0 0x10000>; + interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "sai"; + dma-names = "tx", "rx"; + dmas = <&edma0 1 47>, + <&edma0 1 46>; + big-endian; + status = "disabled"; + }; + + sai2: sai@2b60000 { + compatible = "fsl,vf610-sai"; + reg = <0x0 0x2b60000 0x0 0x10000>; + interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&platform_clk 1>; + clock-names = "sai"; + dma-names = "tx", "rx"; + dmas = <&edma0 1 45>, + <&edma0 1 44>; + big-endian; + status = "disabled"; + }; + + edma0: edma@2c00000 { + #dma-cells = <2>; + compatible = "fsl,vf610-edma"; + reg = <0x0 0x2c00000 0x0 0x10000>, + <0x0 0x2c10000 0x0 0x10000>, + <0x0 0x2c20000 0x0 0x10000>; + interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "edma-tx", "edma-err"; + dma-channels = <32>; + big-endian; + clock-names = "dmamux0", "dmamux1"; + clocks = <&platform_clk 1>, + <&platform_clk 1>; + }; + + mdio0: mdio@2d24000 { + compatible = "gianfar"; + device_type = "mdio"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2d24000 0x0 0x4000>; + }; + + usb@8600000 { + compatible = "fsl-usb2-dr-v2.5", "fsl-usb2-dr"; + reg = <0x0 0x8600000 0x0 0x1000>; + interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + phy_type = "ulpi"; + }; + + usb3@3100000 { + compatible = "snps,dwc3"; + reg = <0x0 0x3100000 0x0 0x10000>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + }; + }; +};
Changes in v2:
Changes in v1: None
Changes in v2:
Changes in v1: None
Applied to u-boot-dm/next, thanks!
Haikun Wang
