[U-Boot] [PATCH 0/4 v2] Clean up the Nomadik board and add OneNand
This patch-set cleans up some glitches in my first submission. I posted it as a single patch and a separate timer patch. The first one is split as JC asked, and the timer patch is there as well since it is conceptually in the same set, although I had no comments on the timer part yet.
JC: I didn't split "clean" and "onenand", since the change in partitioning information in the config file is part of introducing onenand. A split would have introduced a never-tested artificial middle version.
Alessandro Rubini (4): arm nomadik: rename board to nhk8815 arm nomadik: cleanup reset arm nomadik: allow Nand and OneNand to coexists arm nomadik: use 1000 as HZ value and rewrite timer code
Makefile | 10 +- board/st/{nmdk8815 => nhk8815}/Makefile | 2 +- board/st/{nmdk8815 => nhk8815}/config.mk | 0 .../st/{nmdk8815/nmdk8815.c => nhk8815/nhk8815.c} | 4 + board/st/{nmdk8815 => nhk8815}/platform.S | 0 cpu/arm926ejs/nomadik/reset.S | 13 +-- cpu/arm926ejs/nomadik/timer.c | 190 ++++++-------------- doc/{README.nmdk8815 => README.nhk8815} | 10 + include/configs/{nmdk8815.h => nhk8815.h} | 59 ++++--- 9 files changed, 109 insertions(+), 179 deletions(-) rename board/st/{nmdk8815 => nhk8815}/Makefile (98%) rename board/st/{nmdk8815 => nhk8815}/config.mk (100%) rename board/st/{nmdk8815/nmdk8815.c => nhk8815/nhk8815.c} (91%) rename board/st/{nmdk8815 => nhk8815}/platform.S (100%) rename doc/{README.nmdk8815 => README.nhk8815} (75%) rename include/configs/{nmdk8815.h => nhk8815.h} (76%)
This is an error in my side in the initial submission: nobody calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead.
Signed-off-by: Alessandro Rubini rubini@unipv.it Acked-by: Andrea Gallo andrea.gallo@stericsson.com --- Makefile | 6 +++--- board/st/{nmdk8815 => nhk8815}/Makefile | 2 +- board/st/{nmdk8815 => nhk8815}/config.mk | 0 .../st/{nmdk8815/nmdk8815.c => nhk8815/nhk8815.c} | 0 board/st/{nmdk8815 => nhk8815}/platform.S | 0 doc/{README.nmdk8815 => README.nhk8815} | 0 include/configs/{nmdk8815.h => nhk8815.h} | 3 ++- 7 files changed, 6 insertions(+), 5 deletions(-) rename board/st/{nmdk8815 => nhk8815}/Makefile (98%) rename board/st/{nmdk8815 => nhk8815}/config.mk (100%) rename board/st/{nmdk8815/nmdk8815.c => nhk8815/nhk8815.c} (100%) rename board/st/{nmdk8815 => nhk8815}/platform.S (100%) rename doc/{README.nmdk8815 => README.nhk8815} (100%) rename include/configs/{nmdk8815.h => nhk8815.h} (97%)
diff --git a/Makefile b/Makefile index bcc81c9..37e50f0 100644 --- a/Makefile +++ b/Makefile @@ -2839,8 +2839,8 @@ mx1fs2_config : unconfig netstar_config: unconfig @$(MKCONFIG) $(@:_config=) arm arm925t netstar
-nmdk8815_config \ -nmdk8815_onenand_config: unconfig +nhk8815_config \ +nhk8815_onenand_config: unconfig @mkdir -p $(obj)include @ > $(obj)include/config.h @if [ "$(findstring _onenand, $@)" ] ; then \ @@ -2849,7 +2849,7 @@ nmdk8815_onenand_config: unconfig else \ $(XECHO) "... configured for Nand Flash"; \ fi - @$(MKCONFIG) -a nmdk8815 arm arm926ejs nmdk8815 st nomadik + @$(MKCONFIG) -a nhk8815 arm arm926ejs nhk8815 st nomadik
omap1510inn_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm925t omap1510inn diff --git a/board/st/nmdk8815/Makefile b/board/st/nhk8815/Makefile similarity index 98% rename from board/st/nmdk8815/Makefile rename to board/st/nhk8815/Makefile index be9a424..b37fe53 100644 --- a/board/st/nmdk8815/Makefile +++ b/board/st/nhk8815/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := nmdk8815.o +COBJS := nhk8815.o SOBJS := platform.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/board/st/nmdk8815/config.mk b/board/st/nhk8815/config.mk similarity index 100% rename from board/st/nmdk8815/config.mk rename to board/st/nhk8815/config.mk diff --git a/board/st/nmdk8815/nmdk8815.c b/board/st/nhk8815/nhk8815.c similarity index 100% rename from board/st/nmdk8815/nmdk8815.c rename to board/st/nhk8815/nhk8815.c diff --git a/board/st/nmdk8815/platform.S b/board/st/nhk8815/platform.S similarity index 100% rename from board/st/nmdk8815/platform.S rename to board/st/nhk8815/platform.S diff --git a/doc/README.nmdk8815 b/doc/README.nhk8815 similarity index 100% rename from doc/README.nmdk8815 rename to doc/README.nhk8815 diff --git a/include/configs/nmdk8815.h b/include/configs/nhk8815.h similarity index 97% rename from include/configs/nmdk8815.h rename to include/configs/nhk8815.h index 6d7b94f..df9d523 100644 --- a/include/configs/nmdk8815.h +++ b/include/configs/nhk8815.h @@ -1,7 +1,8 @@ /* * (C) Copyright 2005 * STMicroelectronics. - * Configuration settings for the STn8815 nomadik board. + * Configuration settings for the "Nomadik Hardware Kit" NHK-8815, + * the evaluation board for the Nomadik 8815 System on Chip. * * See file CREDITS for list of people who contributed to this * project.
There is only one public release of the Nomadik chip, so the ifdef in reset code as well as a define in the config file are not needed
Signed-off-by: Alessandro Rubini rubini@unipv.it Acked-by: Andrea Gallo andrea.gallo@stericsson.com --- cpu/arm926ejs/nomadik/reset.S | 13 +------------ include/configs/nhk8815.h | 5 ++--- 2 files changed, 3 insertions(+), 15 deletions(-)
diff --git a/cpu/arm926ejs/nomadik/reset.S b/cpu/arm926ejs/nomadik/reset.S index 948996b..ec95472 100644 --- a/cpu/arm926ejs/nomadik/reset.S +++ b/cpu/arm926ejs/nomadik/reset.S @@ -6,20 +6,9 @@ .align 5 .globl reset_cpu reset_cpu: -#if defined CONFIG_NOMADIK_8815 - ldr r0, =NOMADIK_SRC_BASE + ldr r0, =NOMADIK_SRC_BASE /* System and Reset Controller */ ldr r1, =0x1 str r1, [r0, #0x18] -#else - ldr r1, rstctl1 /* get clkm1 reset ctl */ - mov r3, #0x0 - strh r3, [r1] /* clear it */ - mov r3, #0x8 - strh r3, [r1] /* force dsp+arm reset */ -#endif
_loop_forever: b _loop_forever - -rstctl1: - .word 0xfffece10 diff --git a/include/configs/nhk8815.h b/include/configs/nhk8815.h index df9d523..321adfa 100644 --- a/include/configs/nhk8815.h +++ b/include/configs/nhk8815.h @@ -30,9 +30,8 @@
#define CONFIG_ARM926EJS #define CONFIG_NOMADIK -#define CONFIG_NOMADIK_8815 -#define CONFIG_NOMADIK_NDK15 -#define CONFIG_NOMADIK_NHK15 +#define CONFIG_NOMADIK_8815 /* cpu variant */ +#define CONFIG_NOMADIK_NHK8815 /* board variant */
#define CONFIG_SKIP_LOWLEVEL_INIT /* we have already been loaded to RAM */
The evaluation kit has both Nand and OneNand, both drivers are there and the two configurations only select a different default for the jffs partition. This adds the OneNand driver and cleans up storage.
Signed-off-by: Alessandro Rubini rubini@unipv.it Acked-by: Andrea Gallo andrea.gallo@stericsson.com --- Makefile | 4 +- board/st/nhk8815/nhk8815.c | 4 +++ doc/README.nhk8815 | 10 +++++++++ include/configs/nhk8815.h | 49 +++++++++++++++++++++++++++---------------- 4 files changed, 47 insertions(+), 20 deletions(-)
diff --git a/Makefile b/Makefile index 37e50f0..d2454c8 100644 --- a/Makefile +++ b/Makefile @@ -2845,9 +2845,9 @@ nhk8815_onenand_config: unconfig @ > $(obj)include/config.h @if [ "$(findstring _onenand, $@)" ] ; then \ echo "#define CONFIG_BOOT_ONENAND" >> $(obj)include/config.h; \ - $(XECHO) "... configured for OneNand Flash"; \ + $(XECHO) "... configured to boot from OneNand Flash"; \ else \ - $(XECHO) "... configured for Nand Flash"; \ + $(XECHO) "... configured to boot from Nand Flash"; \ fi @$(MKCONFIG) -a nhk8815 arm arm926ejs nhk8815 st nomadik
diff --git a/board/st/nhk8815/nhk8815.c b/board/st/nhk8815/nhk8815.c index edf4626..085a5e0 100644 --- a/board/st/nhk8815/nhk8815.c +++ b/board/st/nhk8815/nhk8815.c @@ -53,6 +53,10 @@ int board_init(void) writel(0x0000305b, REG_FSMC_BCR1); writel(0x00033f33, REG_FSMC_BTR1);
+ /* Set up SMCS0 for OneNand: sram-like once again */ + writel(0x000030db, NOMADIK_FSMC_BASE + 0x00); /* FSMC_BCR0 */ + writel(0x02100551, NOMADIK_FSMC_BASE + 0x04); /* FSMC_BTR0 */ + icache_enable(); return 0; } diff --git a/doc/README.nhk8815 b/doc/README.nhk8815 index 453cfae..9008e39 100644 --- a/doc/README.nhk8815 +++ b/doc/README.nhk8815 @@ -15,6 +15,16 @@ SDRAM configuration, PLL setup and initial loading from NAND is implemented in the X-Loader, so U-Boot is already running in SDRAM when control is handed over to it.
+The Makefile offers two different configurations to be used if you +boot from Nand or OneNand. + + make nhk8815_config + make nhk8815_onenand_config + +Both support OneNand and Nand. Since U-Boot, running in RAM, can't know +where it was loaded from, the configurations differ in where the filesystem +is looked for by default. +
On www.st.com/nomadik and on www.stnwireless.com there are documents, summary data and white papers on Nomadik. The full datasheet for diff --git a/include/configs/nhk8815.h b/include/configs/nhk8815.h index 321adfa..bf1a915 100644 --- a/include/configs/nhk8815.h +++ b/include/configs/nhk8815.h @@ -55,6 +55,7 @@ #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "Nomadik> " #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + sizeof(CONFIG_SYS_PROMPT) + 16) @@ -90,6 +91,7 @@ #define CONFIG_SYS_MEMTEST_END 0x0FFFFFFF #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 256 * 1024) #define CONFIG_SYS_GBL_DATA_SIZE 128 /* for initial data */ +#define CONFIG_SYS_64BIT_VSPRINTF /* mtd desires this */
#define CONFIG_MISC_INIT_R /* call misc_init_r during start up */
@@ -120,43 +122,54 @@ #define CONFIG_SMC_USE_32_BIT #define CONFIG_BOOTFILE "uImage"
-/* flash memory and filesystem information */ -#define CONFIG_DOS_PARTITION +/* Storage information: onenand and nand */ +#define CONFIG_CMD_ONENAND #define CONFIG_MTD_ONENAND_VERIFY_WRITE #define CONFIG_SYS_ONENAND_BASE 0x30000000 + +#define CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 /* SMPS0n */
+/* + * Filesystem information + * + * Since U-Boot has been loaded to RAM by vendor code, we could use + * either or both OneNand and Nand. However, we need to know where the + * filesystem lives. Comments below report vendor-selected partitions + */ #ifdef CONFIG_BOOT_ONENAND - -# define CONFIG_CMD_ONENAND /* Temporary: nand and onenand can't coexist */ /* Partition Size Start * XloaderTOC + X-Loader 256KB 0x00000000 * Memory init function 256KB 0x00040000 - * U-Boot 2MB 0x00080000 + * U-Boot + env 2MB 0x00080000 * Sysimage (kernel + ramdisk) 4MB 0x00280000 * JFFS2 Root filesystem 22MB 0x00680000 * JFFS2 User Data 227.5MB 0x01C80000 */ -# define CONFIG_JFFS2_PART_SIZE 0x400000 -# define CONFIG_JFFS2_PART_OFFSET 0x280000 - +# define CONFIG_JFFS2_DEV "onenand0" +# define CONFIG_JFFS2_PART_SIZE 0x01600000 +# define CONFIG_JFFS2_PART_OFFSET 0x00680000 # define CONFIG_ENV_IS_IN_ONENAND -# define CONFIG_ENV_SIZE (256 * 1024) -# define CONFIG_ENV_ADDR 0x30300000 - -#else /* ! CONFIG_BOOT_ONENAND */ - -# define CONFIG_CMD_NAND /* Temporary: nand and onenand can't coexist */ +# define CONFIG_ENV_SIZE 0x20000 /* 128 Kb - one sector */ +# define CONFIG_ENV_ADDR (0x00280000 - CONFIG_ENV_SIZE)
+#else /* BOOT_NAND */ + /* Partition Size Start + * XloaderTOC + X-Loader 256KB 0x00000000 + * Memory init function 256KB 0x00040000 + * U-Boot + env 2MB 0x00080000 + * Kernel Image 3MB 0x00280000 + * JFFS2 Root filesystem 22MB 0x00580000 + * JFFS2 User Data 100.5MB 0x01b80000 + */ # define CONFIG_JFFS2_DEV "nand0" # define CONFIG_JFFS2_NAND 1 /* For the jffs2 support*/ -# define CONFIG_JFFS2_PART_SIZE 0x00300000 -# define CONFIG_JFFS2_PART_OFFSET 0x00280000 - +# define CONFIG_JFFS2_PART_SIZE 0x01600000 +# define CONFIG_JFFS2_PART_OFFSET 0x00580000 # define CONFIG_ENV_IS_IN_NAND # define CONFIG_ENV_SIZE 0x20000 /* 128 Kb - one sector */ -# define CONFIG_ENV_OFFSET (0x8000000 - CONFIG_ENV_SIZE) +# define CONFIG_ENV_OFFSET (0x00280000 - CONFIG_ENV_SIZE)
#endif /* CONFIG_BOOT_ONENAND */
This sets CONFIG_SYS_HZ to 1000 as required, and completely rewrites timer code, which is now both correct and much smaller. Unused functions like udelay_masked() have been removed as no driver uses them, even the ones that are not currently active for this board.
Signed-off-by: Alessandro Rubini rubini@unipv.it Acked-by: Andrea Gallo andrea.gallo@stericsson.com --- cpu/arm926ejs/nomadik/timer.c | 190 +++++++++++----------------------------- include/configs/nhk8815.h | 2 +- 2 files changed, 53 insertions(+), 139 deletions(-)
diff --git a/cpu/arm926ejs/nomadik/timer.c b/cpu/arm926ejs/nomadik/timer.c index 2870d24..3618c4a 100644 --- a/cpu/arm926ejs/nomadik/timer.c +++ b/cpu/arm926ejs/nomadik/timer.c @@ -1,20 +1,5 @@ /* - * (C) Copyright 2003 - * Texas Instruments <www.ti.com> - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Alex Zuepke azu@sysgo.de - * - * (C) Copyright 2002-2004 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2004 - * Philippe Robin, ARM Ltd. philippe.robin@arm.com + * (C) Copyright 2009 Alessandro Rubini * * See file CREDITS for list of people who contributed to this * project. @@ -38,145 +23,74 @@ #include <common.h> #include <asm/io.h>
-#define TIMER_LOAD_VAL 0xffffffff +/* + * Registers in the MTU block -- same as <mach/mtu.h> in linux +*/ + +#define MTU_IMSC 0x00 /* Interrupt mask set/clear */ +#define MTU_RIS 0x04 /* Raw interrupt status */ +#define MTU_MIS 0x08 /* Masked interrupt status */ +#define MTU_ICR 0x0C /* Interrupt clear register */ + +/* per-timer registers take 0..3 as argument */ +#define MTU_LR(x) (0x10 + 0x10 * (x) + 0x00) /* Load value */ +#define MTU_VAL(x) (0x10 + 0x10 * (x) + 0x04) /* Current value */ +#define MTU_CR(x) (0x10 + 0x10 * (x) + 0x08) /* Control reg */ +#define MTU_BGLR(x) (0x10 + 0x10 * (x) + 0x0c) /* At next overflow */ + +/* bits for the control register */ +#define MTU_CRn_ENA 0x80 +#define MTU_CRn_PERIODIC 0x40 /* if 0 = free-running */ +#define MTU_CRn_PRESCALE_MASK 0x0c +#define MTU_CRn_PRESCALE_1 0x00 +#define MTU_CRn_PRESCALE_16 0x04 +#define MTU_CRn_PRESCALE_256 0x08 +#define MTU_CRn_32BITS 0x02 +#define MTU_CRn_ONESHOT 0x01 /* if 0 = wraps reloading from BGLR*/
-/* macro to read the 32 bit timer */ -#define READ_TIMER readl(CONFIG_SYS_TIMERBASE + 20)
-static ulong timestamp; -static ulong lastdec; +/* + * The timer is a decrementer, we'll left it free running at 2.4MHz. + * We have 2.4 ticks per microsecond and an overflow in almost 30min + */ +#define TIMER_CLOCK (24*100*1000) +#define COUNT_TO_USEC(x) ((x)*5/12) /* overflows at 6min */ +#define USEC_TO_COUNT(x) ((x)*12/5) /* overflows at 6min */ +#define TICKS_PER_HZ (TIMER_CLOCK/CONFIG_SYS_HZ) +#define TICKS_TO_HZ(x) ((x)/TICKS_PER_HZ) + +/* macro to read the 32 bit timer: since it decrements, we invert read value */ +#define READ_TIMER() (~readl(CONFIG_SYS_TIMERBASE + MTU_VAL(0)))
-/* nothing really to do with interrupts, just starts up a counter. */ +/* Configure a free-running, auto-wrap counter with no prescaler */ int timer_init(void) { - /* Load timer with initial value */ - writel(TIMER_LOAD_VAL, CONFIG_SYS_TIMERBASE + 16); - - /* - * Set timer to be enabled, free-running, no interrupts, 256 divider, - * 32-bit, wrap-mode - */ - writel(0x8a, CONFIG_SYS_TIMERBASE + 24); - - /* init the timestamp and lastdec value */ - reset_timer_masked(); - + writel(MTU_CRn_ENA | MTU_CRn_PRESCALE_1 | MTU_CRn_32BITS, + CONFIG_SYS_TIMERBASE + MTU_CR(0)); + reset_timer(); return 0; }
-/* - * timer without interrupts - */ +/* Restart counting from 0 */ void reset_timer(void) { - reset_timer_masked(); + writel(0, CONFIG_SYS_TIMERBASE + MTU_LR(0)); /* Immediate effect */ }
+/* Return how many HZ passed since "base" */ ulong get_timer(ulong base) { - return get_timer_masked() - base; -} - -void set_timer(ulong t) -{ - timestamp = t; + ulong res = TICKS_TO_HZ(READ_TIMER()) - base; + return res; }
-/* delay x useconds AND perserve advance timstamp value */ +/* Delay x useconds */ void udelay(unsigned long usec) { - ulong tmo, tmp; - - if (usec >= 1000) { - /* if "big" number, spread normalization to seconds */ - tmo = usec / 1000; /* start to normalize */ - tmo *= CONFIG_SYS_HZ; /* find number of "ticks" */ - tmo /= 1000; /* finish normalize. */ - } else { - /* small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ; - tmo /= (1000 * 1000); - } - - tmp = get_timer(0); /* get current timestamp */ - if ((tmo + tmp + 1) < tmp) /* will roll time stamp? */ - reset_timer_masked(); /* reset to 0, set lastdec value */ - else - tmo += tmp; - - while (get_timer_masked() < tmo) - /* nothing */ ; -} - -void reset_timer_masked(void) -{ - /* reset time */ - lastdec = READ_TIMER; /* capure current decrementer value time */ - timestamp = 0; /* start "advancing" time stamp from 0 */ -} - -ulong get_timer_masked(void) -{ - ulong now = READ_TIMER; /* current tick value */ - - if (lastdec >= now) { /* normal mode (non roll) */ - /* move stamp fordward */ - timestamp += lastdec - now; - } else { - /* - * An overflow is expected. - * nts = ts + ld + (TLV - now) - * ts=old stamp, ld=time that passed before passing through -1 - * (TLV-now) amount of time after passing though -1 - * nts = new "advancing time stamp"...it could also roll - */ - timestamp += lastdec + TIMER_LOAD_VAL - now; - } - lastdec = now; - - return timestamp; -} - -/* waits specified delay value and resets timestamp */ -void udelay_masked(unsigned long usec) -{ - ulong tmo; - - if (usec >= 1000) { - /* if "big" number, spread normalization to seconds */ - tmo = usec / 1000; /* start to normalize */ - tmo *= CONFIG_SYS_HZ; /* find number of "ticks" */ - tmo /= 1000; /* finish normalize. */ - } else { - /* else small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ; - tmo /= (1000*1000); - } - - reset_timer_masked(); - /* set "advancing" timestamp to 0, set lastdec vaule */ - - while (get_timer_masked() < tmo) - /* nothing */ ; -} - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On ARM it returns the number of timer ticks per second. - */ -ulong get_tbclk(void) -{ - ulong tbclk; + ulong ini, end;
- tbclk = CONFIG_SYS_HZ; - return tbclk; + ini = READ_TIMER(); + end = ini + USEC_TO_COUNT(usec); + while ((signed)(end - READ_TIMER()) > 0) + ; } diff --git a/include/configs/nhk8815.h b/include/configs/nhk8815.h index bf1a915..3e2e09f 100644 --- a/include/configs/nhk8815.h +++ b/include/configs/nhk8815.h @@ -96,7 +96,7 @@ #define CONFIG_MISC_INIT_R /* call misc_init_r during start up */
/* timing informazion */ -#define CONFIG_SYS_HZ (2400000 / 256) /* Timer0: 2.4Mhz + divider */ +#define CONFIG_SYS_HZ 1000 /* Mandatory... */ #define CONFIG_SYS_TIMERBASE 0x101E2000
/* serial port (PL011) configuration */
for the record what is its precision now?
- (C) Copyright 2003
- Texas Instruments <www.ti.com>
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- Alex Zuepke azu@sysgo.de
- (C) Copyright 2002-2004
- Gary Jennejohn, DENX Software Engineering, garyj@denx.de
- (C) Copyright 2004
- Philippe Robin, ARM Ltd. philippe.robin@arm.com
- (C) Copyright 2009 Alessandro Rubini
- project.
- Registers in the MTU block -- same as <mach/mtu.h> in linux
so please simply import it
- The timer is a decrementer, we'll left it free running at 2.4MHz.
- We have 2.4 ticks per microsecond and an overflow in almost 30min
please add space before and after */
* 32-bit, wrap-mode
- writel(MTU_CRn_ENA | MTU_CRn_PRESCALE_1 | MTU_CRn_32BITS,
- reset_timer(); return 0;
- timer without interrupts
- writel(0, CONFIG_SYS_TIMERBASE + MTU_LR(0)); /* Immediate effect */
- timestamp = t;
- ulong res = TICKS_TO_HZ(READ_TIMER()) - base;
please return directly
- return res;
Best Regards, J.
This sets CONFIG_SYS_HZ to 1000 as required, and completely rewrites timer code, which is now both correct and much smaller. Unused functions like udelay_masked() have been removed as no driver uses them, even the ones that are not currently active for this board. mtu.h is copied literally from the kernel sources.
I've used mtu.h from kernel sources and done the other changes as requested (the extra variable just to return it was a mishap from an earlier printf I needed to find a misconfig).
it counts at 2.4MHz, so the 1000HZ tick has no approximation and udelay is correct with sub-microsecond error. I'll use in soft_i2c, needed to turn on the LCD light.
cpu/arm926ejs/nomadik/mtu.h | 45 +++++++++++ cpu/arm926ejs/nomadik/timer.c | 166 +++++++---------------------------------- include/configs/nhk8815.h | 2 +- 3 files changed, 73 insertions(+), 140 deletions(-) create mode 100644 cpu/arm926ejs/nomadik/mtu.h
diff --git a/cpu/arm926ejs/nomadik/mtu.h b/cpu/arm926ejs/nomadik/mtu.h new file mode 100644 index 0000000..21b4a7a --- /dev/null +++ b/cpu/arm926ejs/nomadik/mtu.h @@ -0,0 +1,45 @@ + +#ifndef __ASM_ARCH_MTU_H +#define __ASM_ARCH_MTU_H + +/* + * The MTU device hosts four different counters, with 4 set of + * registers. These are register names. + */ + +#define MTU_IMSC 0x00 /* Interrupt mask set/clear */ +#define MTU_RIS 0x04 /* Raw interrupt status */ +#define MTU_MIS 0x08 /* Masked interrupt status */ +#define MTU_ICR 0x0C /* Interrupt clear register */ + +/* per-timer registers take 0..3 as argument */ +#define MTU_LR(x) (0x10 + 0x10 * (x) + 0x00) /* Load value */ +#define MTU_VAL(x) (0x10 + 0x10 * (x) + 0x04) /* Current value */ +#define MTU_CR(x) (0x10 + 0x10 * (x) + 0x08) /* Control reg */ +#define MTU_BGLR(x) (0x10 + 0x10 * (x) + 0x0c) /* At next overflow */ + +/* bits for the control register */ +#define MTU_CRn_ENA 0x80 +#define MTU_CRn_PERIODIC 0x40 /* if 0 = free-running */ +#define MTU_CRn_PRESCALE_MASK 0x0c +#define MTU_CRn_PRESCALE_1 0x00 +#define MTU_CRn_PRESCALE_16 0x04 +#define MTU_CRn_PRESCALE_256 0x08 +#define MTU_CRn_32BITS 0x02 +#define MTU_CRn_ONESHOT 0x01 /* if 0 = wraps reloading from BGLR*/ + +/* Other registers are usual amba/primecell registers, currently not used */ +#define MTU_ITCR 0xff0 +#define MTU_ITOP 0xff4 + +#define MTU_PERIPH_ID0 0xfe0 +#define MTU_PERIPH_ID1 0xfe4 +#define MTU_PERIPH_ID2 0xfe8 +#define MTU_PERIPH_ID3 0xfeC + +#define MTU_PCELL0 0xff0 +#define MTU_PCELL1 0xff4 +#define MTU_PCELL2 0xff8 +#define MTU_PCELL3 0xffC + +#endif /* __ASM_ARCH_MTU_H */ diff --git a/cpu/arm926ejs/nomadik/timer.c b/cpu/arm926ejs/nomadik/timer.c index 2870d24..d0946ec 100644 --- a/cpu/arm926ejs/nomadik/timer.c +++ b/cpu/arm926ejs/nomadik/timer.c @@ -1,20 +1,5 @@ /* - * (C) Copyright 2003 - * Texas Instruments <www.ti.com> - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Alex Zuepke azu@sysgo.de - * - * (C) Copyright 2002-2004 - * Gary Jennejohn, DENX Software Engineering, garyj@denx.de - * - * (C) Copyright 2004 - * Philippe Robin, ARM Ltd. philippe.robin@arm.com + * (C) Copyright 2009 Alessandro Rubini * * See file CREDITS for list of people who contributed to this * project. @@ -37,146 +22,49 @@
#include <common.h> #include <asm/io.h> +#include "mtu.h"
-#define TIMER_LOAD_VAL 0xffffffff - -/* macro to read the 32 bit timer */ -#define READ_TIMER readl(CONFIG_SYS_TIMERBASE + 20) +/* + * The timer is a decrementer, we'll left it free running at 2.4MHz. + * We have 2.4 ticks per microsecond and an overflow in almost 30min + */ +#define TIMER_CLOCK (24 * 100 * 1000) +#define COUNT_TO_USEC(x) ((x) * 5 / 12) /* overflows at 6min */ +#define USEC_TO_COUNT(x) ((x) * 12 / 5) /* overflows at 6min */ +#define TICKS_PER_HZ (TIMER_CLOCK / CONFIG_SYS_HZ) +#define TICKS_TO_HZ(x) ((x) / TICKS_PER_HZ)
-static ulong timestamp; -static ulong lastdec; +/* macro to read the 32 bit timer: since it decrements, we invert read value */ +#define READ_TIMER() (~readl(CONFIG_SYS_TIMERBASE + MTU_VAL(0)))
+/* Return how many HZ passed since "base" */ ulong get_timer(ulong base) { - return get_timer_masked() - base; + return TICKS_TO_HZ(READ_TIMER()) - base; }
-void set_timer(ulong t) -{ - timestamp = t; -} - -/* delay x useconds AND perserve advance timstamp value */ +/* Delay x useconds */ void udelay(unsigned long usec) { - ulong tmo, tmp; - - if (usec >= 1000) { - /* if "big" number, spread normalization to seconds */ - tmo = usec / 1000; /* start to normalize */ - tmo *= CONFIG_SYS_HZ; /* find number of "ticks" */ - tmo /= 1000; /* finish normalize. */ - } else { - /* small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ; - tmo /= (1000 * 1000); - } - - tmp = get_timer(0); /* get current timestamp */ - if ((tmo + tmp + 1) < tmp) /* will roll time stamp? */ - reset_timer_masked(); /* reset to 0, set lastdec value */ - else - tmo += tmp; - - while (get_timer_masked() < tmo) - /* nothing */ ; -} - -void reset_timer_masked(void) -{ - /* reset time */ - lastdec = READ_TIMER; /* capure current decrementer value time */ - timestamp = 0; /* start "advancing" time stamp from 0 */ -} - -ulong get_timer_masked(void) -{ - ulong now = READ_TIMER; /* current tick value */ - - if (lastdec >= now) { /* normal mode (non roll) */ - /* move stamp fordward */ - timestamp += lastdec - now; - } else { - /* - * An overflow is expected. - * nts = ts + ld + (TLV - now) - * ts=old stamp, ld=time that passed before passing through -1 - * (TLV-now) amount of time after passing though -1 - * nts = new "advancing time stamp"...it could also roll - */ - timestamp += lastdec + TIMER_LOAD_VAL - now; - } - lastdec = now; - - return timestamp; -} - -/* waits specified delay value and resets timestamp */ -void udelay_masked(unsigned long usec) -{ - ulong tmo; - - if (usec >= 1000) { - /* if "big" number, spread normalization to seconds */ - tmo = usec / 1000; /* start to normalize */ - tmo *= CONFIG_SYS_HZ; /* find number of "ticks" */ - tmo /= 1000; /* finish normalize. */ - } else { - /* else small number, don't kill it prior to HZ multiply */ - tmo = usec * CONFIG_SYS_HZ; - tmo /= (1000*1000); - } - - reset_timer_masked(); - /* set "advancing" timestamp to 0, set lastdec vaule */ - - while (get_timer_masked() < tmo) - /* nothing */ ; -} - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -/* - * This function is derived from PowerPC code (timebase clock frequency). - * On ARM it returns the number of timer ticks per second. - */ -ulong get_tbclk(void) -{ - ulong tbclk; + ulong ini, end;
if it's ok with I'll move it to include/asm-arm/arch-nomadik/
Best Regards, J.
fine
ok
ok
ok
I'll take a look on it this WE
Best Regards, J.
all applied to u-boot-arm patch 4 with the agreed update
Best Regards, J.
Alessandro Rubini
Jean-Christophe PLAGNIOL-VILLARD
