[PATCH v2] fastboot: Fix overflow when calculating chunk size
If a chunk was larger than 4GiB, then chunk_data_sz would overflow and blkcnt would not be calculated correctly. Upgrade it to a u64 and cast its multiplicands as well. Also fix bytes_written while we're at it.
Signed-off-by: Sean Anderson sean.anderson@seco.com --- sizes for pico-dwarf-imx7d are as follows:
text data bss dec hex version 431079 45114 38612 514805 7daf5 u-boot/master 431529 45114 38612 515255 7dcb7 u-boot/V1 431245 45114 38652 515011 7dbc3 u-boot/V2
so a total growth of around 200 bytes, down from 450.
Changes in v2: - Converted divisions to use do_div
lib/image-sparse.c | 17 +++++++++-------- 1 file changed, 9 insertions(+), 8 deletions(-)
diff --git a/lib/image-sparse.c b/lib/image-sparse.c index 187ac28cd3..d80fdbbf58 100644 --- a/lib/image-sparse.c +++ b/lib/image-sparse.c @@ -55,10 +55,10 @@ int write_sparse_image(struct sparse_storage *info, lbaint_t blk; lbaint_t blkcnt; lbaint_t blks; - uint32_t bytes_written = 0; + uint64_t bytes_written = 0; unsigned int chunk; unsigned int offset; - unsigned int chunk_data_sz; + uint64_t chunk_data_sz; uint32_t *fill_buf = NULL; uint32_t fill_val; sparse_header_t *sparse_header; @@ -132,8 +132,8 @@ int write_sparse_image(struct sparse_storage *info, sizeof(chunk_header_t)); }
- chunk_data_sz = sparse_header->blk_sz * chunk_header->chunk_sz; - blkcnt = chunk_data_sz / info->blksz; + chunk_data_sz = ((u64)sparse_header->blk_sz) * chunk_header->chunk_sz; + blkcnt = DIV_ROUND_UP_ULL(chunk_data_sz, info->blksz); switch (chunk_header->chunk_type) { case CHUNK_TYPE_RAW: if (chunk_header->total_sz != @@ -162,7 +162,7 @@ int write_sparse_image(struct sparse_storage *info, return -1; } blk += blks; - bytes_written += blkcnt * info->blksz; + bytes_written += ((u64)blkcnt) * info->blksz; total_blocks += chunk_header->chunk_sz; data += chunk_data_sz; break; @@ -222,8 +222,9 @@ int write_sparse_image(struct sparse_storage *info, blk += blks; i += j; } - bytes_written += blkcnt * info->blksz; - total_blocks += chunk_data_sz / sparse_header->blk_sz; + bytes_written += ((u64)blkcnt) * info->blksz; + total_blocks += DIV_ROUND_UP_ULL(chunk_data_sz, + sparse_header->blk_sz); free(fill_buf); break;
@@ -253,7 +254,7 @@ int write_sparse_image(struct sparse_storage *info,
debug("Wrote %d blocks, expected to write %d blocks\n", total_blocks, sparse_header->total_blks); - printf("........ wrote %u bytes to '%s'\n", bytes_written, part_name); + printf("........ wrote %llu bytes to '%s'\n", bytes_written, part_name);
if (total_blocks != sparse_header->total_blks) { info->mssg("sparse image write failure", response);
This should have
Reviewed-by: Heiko Schocher hs@denx.de
from v1, which I forgot to add.
Changes in v2:
- uint64_t bytes_written = 0; unsigned int chunk; unsigned int offset;
- uint64_t chunk_data_sz; uint32_t *fill_buf = NULL; uint32_t fill_val; sparse_header_t *sparse_header;
switch (chunk_header->chunk_type) { case CHUNK_TYPE_RAW: if (chunk_header->total_sz !=blkcnt = DIV_ROUND_UP_ULL(chunk_data_sz, info->blksz);
Signed-off-by: Sean Anderson sean.anderson@seco.com Reviewed-by: Heiko Schocher hs@denx.de
Sean Anderson
