Re: [U-Boot] Uboot with at91sam9G20ek
Hi Abhishek,
I'm also trying to get U-Boot 2010.12 working on an AT91 board. I came across the following mailing list archive that may help.
http://old.nabble.com/-U-Boot--various-at91-patches-to-make-some-boards- compilable-again-td30103062.html
Here's a tinyurl (http://tinyurl.com/4fkedr3) in case the above line-wrapped oddly.
Seems like we may need to patch in AT91 support. I hope someone on the list can indicate when the changes needed for AT91 support are integrated into the master.
Please let me know if you get this working in the meantime!
Thanks, Chris
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Abhishek Ashtekar Sent: Monday, January 17, 2011 8:19 AM To: u-boot@lists.denx.de Subject: [U-Boot] Uboot with at91sam9G20ek
Hello,
I have spent now more than 2 weeks with U - boot and want the network interface to work
so that tftpboot works but my current state seems not very encouraging.
A) I am using the AT91SAM9G20EK board. I downloaded tried the U-Boot.2010.12.
I have the following results (issues) when I try to build.
1) make at91sam9g20ek_nandflash_config
make CROSS_COMPILE=arm-linux-
Error 1: You need to define CONFIG_AT91FAMILY in your board config
Action: Defined CONFIG_AT91FAMILY in the file /include/configs/at91sam9260ek.h
Also defined CONFIG_AT91SAM9G20EK in the same file
2) Error 2: board.c:233: CONFIG_SYS_SDRAM_BASE undeclared
Error 3: board.c:279: CONFIG_SYS_INIT_SP_ADDR undeclared
Error 4: board.c:312: CONFIG_SYS_SDRAM_BASE undeclared
In the file board.c,
#define CONFIG_SYS_SDRAM_BASE 0x00000000
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE - GENERATED_GBL_DATA_SIZE)
3) Error 5: Undefined reference to 'CONFIG_SYS_INIT_SP_ADDR' in file /arc/arm/cpu/arm926ejs/start.S
Cannot find a work around
Error 6: /drivers/spi/atmel_dataflash_spi.c:161: undefined reference to 'reset_timer_masked'
Error 7: /drivers/spi/atmel_dataflash_spi.c:161: undefined reference to 'get_timer_masked'
Why are these definitions removed in the 2010.12 build?
B) Initially I was trying the u-boot-2010.09.
I want to use the MII interface instead of RMII.
so #undef ed RMII and #defined CONFIG_MII and CONFIG_CMD_MII
The Ping to self as well as host does not function at all despite of correct settings.
I tried with putting debug outputs in various functions called.
Actually no data is sentout TXD0 - TXD3 and no activity on the TX_EN or EX_ER.
At the end, I get ping failed; host xx.xx.xx.xx is not alive.
Can anyone guide me regarding the further line of efforts.
Thanks a lot in advance.
Regards,
Abhishek
Dear Chris Verges, dear Abhishek,
Please have a look at git://git.denx.de/u-boot-atmel.git, rework101229 branch,
there is a working port for the at91sam9260ek which should also work for the at91sam9g20ek (if I am not mistaken).
Best Regards, Reinhard
Chris Verges
Reinhard Meyer
