I captured some packets using ethereal and I see the request to the bootp server contains the wrong file name. The reply from the server matches the request.
Here is the output from U-boot in the 3 cases I described:
(1) Environment variable bootfile = zImage, try to load some other file:
u-boot> bootp 100000 10got.img BOOTP broadcast 1 DHCP client bound to address 192.168.0.43 TftpStart(zImage:192.168.0.1) TFTP from server 192.168.0.1; our IP address is 192.168.0.43 Filename 'zImage'. Load address: 0x100000 Loading: ################################################################# ################################################## done Bytes transferred = 585718 (8eff6 hex) u-boot>
(2) no bootfile env variable
u-boot> bootp 100000 10got.img BOOTP broadcast 1 DHCP client bound to address 192.168.0.43 TftpStart(no bootfile:192.168.0.1) *** Warning: no boot file name; using '2B00A8C0.img' TFTP from server 192.168.0.1; our IP address is 192.168.0.43 Filename '2B00A8C0.img'. Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again
(3) tftpboot command
u-boot> tftpboot 100000 10got.img TftpStart(zImage:192.168.0.1) TFTP from server 192.168.0.1; our IP address is 192.168.0.44 Filename '10got.img'. Load address: 0x100000 Loading: # done Bytes transferred = 921 (399 hex) u-boot>
In message E1Awx0E-000193-Ly@server4.anonymousnetworks.com you
wrote:
I'm using u-boot 1.0.0 on a xilinx embedded ppc 405 and I see the follow unexplained behavior:
if I do a bootp <address> <filename> it always bootp's the filename stored in environment variable bootfile rather than the filename I specify in the command line. If I have no bootfile env variable it tries to bootp a garbage file name.
What does the reply packet sent by your BOOTP server contain exactly?
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de If God had a beard, he'd be a UNIX programmer.
SF.Net is sponsored by: Speed Start Your Linux Apps Now. Build and deploy apps & Web services for Linux with a free DVD software kit from IBM. Click Now! http://ads.osdn.com/?ad_id=1356&alloc_id=3438&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
ppc user
