[U-Boot] [PATCH 1/2] 85xx: seperate PIXIS virtual from physical address
Added a PIXIS_BASE_PHYS for use as the physical address and maintain PIXIS_BASE as the virtual address of the PIXIS fpga registers.
This allows us to deal with 36-bit phys on these boards in the future.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
These require the 'FSL: Moved BR_PHYS_ADDR for localbus to common header' patch
- k
board/freescale/mpc8536ds/law.c | 2 +- board/freescale/mpc8536ds/tlb.c | 2 +- board/freescale/mpc8572ds/law.c | 2 +- board/freescale/mpc8572ds/tlb.c | 2 +- include/configs/MPC8536DS.h | 3 ++- include/configs/MPC8572DS.h | 3 ++- 6 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/board/freescale/mpc8536ds/law.c b/board/freescale/mpc8536ds/law.c index 0861fa7..caccce4 100644 --- a/board/freescale/mpc8536ds/law.c +++ b/board/freescale/mpc8536ds/law.c @@ -37,7 +37,7 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAWAR_SIZE_512M, LAW_TRGT_IF_PCIE_3), SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), - SET_LAW(PIXIS_BASE, LAW_SIZE_4K, LAW_TRGT_IF_LBC), + SET_LAW(PIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), };
diff --git a/board/freescale/mpc8536ds/tlb.c b/board/freescale/mpc8536ds/tlb.c index c81a959..89d5097 100644 --- a/board/freescale/mpc8536ds/tlb.c +++ b/board/freescale/mpc8536ds/tlb.c @@ -41,7 +41,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 0, BOOKE_PAGESZ_4K, 0),
- SET_TLB_ENTRY(0, PIXIS_BASE, PIXIS_BASE, + SET_TLB_ENTRY(0, PIXIS_BASE, PIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 0, BOOKE_PAGESZ_4K, 0),
diff --git a/board/freescale/mpc8572ds/law.c b/board/freescale/mpc8572ds/law.c index 83eb681..9814479 100644 --- a/board/freescale/mpc8572ds/law.c +++ b/board/freescale/mpc8572ds/law.c @@ -35,7 +35,7 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_PCIE2_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_2), SET_LAW(CONFIG_SYS_PCIE3_MEM_PHYS, LAWAR_SIZE_512M, LAW_TRGT_IF_PCIE_3), SET_LAW(CONFIG_SYS_PCIE3_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_3), - SET_LAW(PIXIS_BASE, LAW_SIZE_4K, LAW_TRGT_IF_LBC), + SET_LAW(PIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), };
diff --git a/board/freescale/mpc8572ds/tlb.c b/board/freescale/mpc8572ds/tlb.c index 8d1f646..3832e01 100644 --- a/board/freescale/mpc8572ds/tlb.c +++ b/board/freescale/mpc8572ds/tlb.c @@ -41,7 +41,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 0, BOOKE_PAGESZ_4K, 0),
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index fff888a..136fb48 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -195,8 +195,9 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
#define CONFIG_FSL_PIXIS 1 /* use common PIXIS code */ #define PIXIS_BASE 0xffdf0000 /* PIXIS registers */ +#define PIXIS_BASE_PHYS PIXIS_BASE
-#define CONFIG_SYS_BR3_PRELIM (PIXIS_BASE | 0x0801) /* port size 8bit */ +#define CONFIG_SYS_BR3_PRELIM (BR_PHYS_ADDR(PIXIS_BASE_PHYS) | BR_PS_8 | BR_V) #define CONFIG_SYS_OR3_PRELIM 0xffffeff7 /* 32KB but only 4k mapped */
#define PIXIS_ID 0x0 /* Board ID at offset 0 */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index c3693b8..f40be92 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -196,8 +196,9 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash.
- k
board/freescale/mpc8536ds/law.c | 2 +- board/freescale/mpc8536ds/mpc8536ds.c | 2 +- board/freescale/mpc8536ds/tlb.c | 2 +- board/freescale/mpc8572ds/law.c | 2 +- board/freescale/mpc8572ds/mpc8572ds.c | 2 +- board/freescale/mpc8572ds/tlb.c | 2 +- include/configs/MPC8536DS.h | 9 +++++---- include/configs/MPC8572DS.h | 9 +++++---- 8 files changed, 16 insertions(+), 14 deletions(-)
diff --git a/board/freescale/mpc8536ds/law.c b/board/freescale/mpc8536ds/law.c index caccce4..31614d2 100644 --- a/board/freescale/mpc8536ds/law.c +++ b/board/freescale/mpc8536ds/law.c @@ -30,7 +30,7 @@ struct law_entry law_table[] = { SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_PCI), SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_FLASH_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAWAR_SIZE_128M, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAWAR_SIZE_128M, LAW_TRGT_IF_PCIE_2), diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index 6fed4ea..b2c37f0 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -445,7 +445,7 @@ int board_early_init_r(void) /* invalidate existing TLB entry for flash + promjet */ disable_tlb(flash_esel);
- set_tlb(1, flashbase, flashbase, /* tlb, epn, rpn */ + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, /* tlb, epn, rpn */ MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, /* perms, wimge */ 0, flash_esel, BOOKE_PAGESZ_256M, 1); /* ts, esel, tsize, iprot */
diff --git a/board/freescale/mpc8536ds/tlb.c b/board/freescale/mpc8536ds/tlb.c index 89d5097..f4bab55 100644 --- a/board/freescale/mpc8536ds/tlb.c +++ b/board/freescale/mpc8536ds/tlb.c @@ -53,7 +53,7 @@ struct fsl_e_tlb_entry tlb_table[] = {
/* W**G* - Flash/promjet, localbus */ /* This will be changed to *I*G* after relocation to RAM. */ - SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE, + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 1, BOOKE_PAGESZ_256M, 1),
diff --git a/board/freescale/mpc8572ds/law.c b/board/freescale/mpc8572ds/law.c index 9814479..02ea0ec 100644 --- a/board/freescale/mpc8572ds/law.c +++ b/board/freescale/mpc8572ds/law.c @@ -28,7 +28,7 @@ #include <asm/mmu.h>
struct law_entry law_table[] = { - SET_LAW(CONFIG_SYS_FLASH_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAWAR_SIZE_512M, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_PCIE_1), SET_LAW(CONFIG_SYS_PCIE2_MEM_PHYS, LAWAR_SIZE_512M, LAW_TRGT_IF_PCIE_2), diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 3a78c98..3e8052f 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -368,7 +368,7 @@ int board_early_init_r(void) /* invalidate existing TLB entry for flash + promjet */ disable_tlb(flash_esel);
diff --git a/board/freescale/mpc8572ds/tlb.c b/board/freescale/mpc8572ds/tlb.c index 3832e01..c8ded15 100644 --- a/board/freescale/mpc8572ds/tlb.c +++ b/board/freescale/mpc8572ds/tlb.c @@ -58,7 +58,7 @@ struct fsl_e_tlb_entry tlb_table[] = {
/* W**G* - Flash/promjet, localbus */ /* This will be changed to *I*G* after relocation to RAM. */ - SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE, + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 136fb48..acd6823 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -167,12 +167,13 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * Local Bus Definitions */ #define CONFIG_SYS_FLASH_BASE 0xe0000000 /* start of FLASH 128M */ +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE
-#define CONFIG_SYS_BR0_PRELIM 0xe8001001 -#define CONFIG_SYS_OR0_PRELIM 0xf8000ff7 +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | BR_PS_16 | BR_V) +#define CONFIG_SYS_OR0_PRELIM 0xf8000ff7
-#define CONFIG_SYS_BR1_PRELIM 0xe0001001 -#define CONFIG_SYS_OR1_PRELIM 0xf8000ff7 +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) +#define CONFIG_SYS_OR1_PRELIM 0xf8000ff7
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE + 0x8000000, CONFIG_SYS_FLASH_BASE} #define CONFIG_SYS_FLASH_QUIET_TEST diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index f40be92..d604bd7 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -168,12 +168,13 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); * Local Bus Definitions */ #define CONFIG_SYS_FLASH_BASE 0xe0000000 /* start of FLASH 128M */ +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE
Nit: s/seperate/separate/ here and 2/2.
jdl
I'll leave it to Andy to fix my lack of spelling ability when he commits these.
- k
I don't know, maybe we should have public floggings for spelling mistakes ;-)
FYI, I have a very similar patch series coming for all the 86xx platforms. I've got a bunch of other stuff on tap as well; I expect to push everything in the next day or two.
-B
Becky Bruce
Jon Loeliger
Kumar Gala
