[PATCH] drivers: fpga: Add FPGA configuration during bootm for Intel SOCFPGA
This enable the capability to automatically perform FPGA configuration when booting Linux FIT image via bootm command. The FPGA configuration bitstream shall be packed within the FIT image.
Signed-off-by: Yau Wai Gan yau.wai.gan@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- drivers/fpga/altera.c | 41 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/drivers/fpga/altera.c b/drivers/fpga/altera.c index 10c0475d25..35eb95544d 100644 --- a/drivers/fpga/altera.c +++ b/drivers/fpga/altera.c @@ -10,6 +10,10 @@ /* * Altera FPGA support */ +#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) +#include <asm/arch/misc.h> +#endif #include <common.h> #include <errno.h> #include <ACEX1K.h> @@ -49,6 +53,43 @@ static const struct altera_fpga { #endif };
+#if IS_ENABLED(CONFIG_TARGET_SOCFPGA_AGILEX) || \ + IS_ENABLED(CONFIG_TARGET_SOCFPGA_STRATIX10) +int fpga_is_partial_data(int devnum, size_t img_len) +{ + /* + * The FPGA data (full or partial) is checked by + * the SDM hardware, for Intel SDM Mailbox based + * devices. Hence always return full bitstream. + * + * For Cyclone V and Arria 10 family, the bitstream + * type paramater is not handled by the driver. + */ + return 0; +} + +int fpga_loadbitstream(int devnum, char *fpgadata, size_t size, + bitstream_type bstype) +{ + int ret_val; + int flags = 0; + + ret_val = fpga_load(devnum, (void *)fpgadata, size, bstype, flags); + + /* + * Enable the HPS to FPGA bridges when FPGA load is completed + * successfully. This is to ensure the FPGA is accessible + * by the HPS. + */ + if (!ret_val) { + printf("Enable FPGA bridges\n"); + do_bridge_reset(1, ~0); + } + + return ret_val; +} +#endif + static int altera_validate(Altera_desc *desc, const char *fn) { if (!desc) {
Jit Loon Lim
