[U-Boot] fw_printernv fw_setenv usage on redundant environment copies
Hi all,
Thanks in Advance. Please help me regarding the below U-Boot problem
I am planning to use fw_printenv & fw_setenv utilities to access U-Boot env variables from Linux Application.
In U-Boot, if we have four "redundant environment" copies in the same partition(mtd1)... Does the below fw_env.config configuration hold good ?
# File: fw_env.config
# Configuration file for fw_(printenv/saveenv) utility.
# Up to two entries are valid, in this case the redundand # environment sector is assumed present.
# MTD device name Device offset Env. size Flash sector size
/dev/mtd1 0x00000 0x02000 0x20000
/dev/mtd1 0x20000 0x02000 0x20000
/dev/mtd1 0x40000 0x02000 0x20000
/dev/mtd1 0x60000 0x02000 0x20000
Thanks & Regards Amarendra Reddy
Larsen & Toubro Limited
www.larsentoubro.com
This Email may contain confidential or privileged information for the intended recipient (s) If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
Amarendra Reddy
