[U-Boot] [PATCH v3 0/8] assortment of fixes/enhancements
This patch set is an assortment of fixes/enhancements distilled straight from our downstream integration work.
Marcel Ziswiler (4): net: asix: fix operation without eeprom generic-board: allow showing custom board info colibri_vf: remove spurious new line mtd/nand/ubi: assortment of alignment fixes
Max Krummenacher (3): fs/fs.c: read up to EOF when len would read past EOF image-fdt.c: store returned error value tftp.c: fix CONFIG_TFTP_TSIZE for small files
Stefan Agner (1): logos: add Toradex logo
common/board_info.c | 2 +- common/cmd_ubi.c | 2 +- common/image-fdt.c | 3 ++- drivers/mtd/nand/nand_util.c | 2 +- drivers/usb/eth/asix.c | 40 ++++++++++++++++++++++++++++++++++------ fs/fs.c | 6 ++---- fs/ubifs/super.c | 5 +++-- fs/ubifs/ubifs.c | 4 ++-- include/configs/colibri_vf.h | 1 - include/malloc.h | 8 ++++++++ lib/gzip.c | 2 +- net/tftp.c | 2 ++ tools/logos/toradex.bmp | Bin 0 -> 24982 bytes 13 files changed, 57 insertions(+), 20 deletions(-) create mode 100644 tools/logos/toradex.bmp
From: Max Krummenacher max.krummenacher@toradex.com
http://lists.denx.de/pipermail/u-boot/2012-September/134347.html allows for reading files in chunks from the shell.
When this feature is used to read past the end of a file an error was returned instead of returning the bytes read up to the end of file. Thus the following fails in the shell:
offset = 0 len = chunksize do read file, offset, len write data until bytes_read < len
The patch changes the behaviour to printing an informational message and returning the actual read number of bytes aka read(2) behaviour for convenient use in U-Boot scripts.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Acked-by: Marek Vasut marex@denx.de --- Changes in v2: mention read(2) behaviour as suggested by Marek
fs/fs.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/fs/fs.c b/fs/fs.c index ac0897d..827b143 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -301,10 +301,8 @@ int fs_read(const char *filename, ulong addr, loff_t offset, loff_t len, unmap_sysmem(buf);
/* If we requested a specific number of bytes, check we got it */ - if (ret == 0 && len && *actread != len) { - printf("** Unable to read file %s **\n", filename); - ret = -1; - } + if (ret == 0 && len && *actread != len) + printf("** %s shorter than offset + len **\n", filename); fs_close();
return ret;
This patch fixes operation of our on-board AX88772B chip without EEPROM but with a ethaddr coming from the regular U-Boot environment. This is a forward port of some remaining parts initially implemented by Antmicro.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- Changes in v3 as suggested by Marek: - introduce ctl variable - fix comment style - use mdelay Changes in v2: - run it through checkpatch.pl as suggested by Marek and Joe - cleanup comments and use VID/PID defines as suggested by Marek - dug out an AX88772 (not B) dongle again and verified operation - AX88772 (not B) indeed does not work with B modifications (e.g. VID/PID based differentiation is indeed required) - dug out another AX88772B dongle as well and verified operation
drivers/usb/eth/asix.c | 40 ++++++++++++++++++++++++++++++++++------ 1 file changed, 34 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index 72ec41e..8a43e7c 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -1,6 +1,8 @@ /* * Copyright (c) 2011 The Chromium OS Authors. * + * Patched for AX88772B by Antmicro Ltd <www.antmicro.com> + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -64,8 +66,11 @@ AX_MEDIUM_AC | AX_MEDIUM_RE)
/* AX88772 & AX88178 RX_CTL values */ -#define AX_RX_CTL_SO 0x0080 -#define AX_RX_CTL_AB 0x0008 +#define AX_RX_CTL_RH2M 0x0200 /* 32-bit aligned RX IP header */ +#define AX_RX_CTL_RH1M 0x0100 /* Enable RX header format type 1 */ +#define AX_RX_CTL_SO 0x0080 +#define AX_RX_CTL_AB 0x0008 +#define AX_RX_HEADER_DEFAULT (AX_RX_CTL_RH1M | AX_RX_CTL_RH2M)
#define AX_DEFAULT_RX_CTL \ (AX_RX_CTL_SO | AX_RX_CTL_AB) @@ -92,6 +97,8 @@ #define FLAG_TYPE_AX88772B (1U << 2) #define FLAG_EEPROM_MAC (1U << 3) /* initial mac address in eeprom */
+#define ASIX_USB_VENDOR_ID 0x0b95 +#define AX88772B_USB_PRODUCT_ID 0x772b
/* driver private */ struct asix_private { @@ -418,15 +425,23 @@ static int asix_basic_reset(struct ueth_data *dev) return 0; }
-static int asix_init_common(struct ueth_data *dev) +static int asix_init_common(struct ueth_data *dev, uint8_t *enetaddr) { int timeout = 0; #define TIMEOUT_RESOLUTION 50 /* ms */ int link_detected; + u32 ctl = AX_DEFAULT_RX_CTL;
debug("** %s()\n", __func__);
- if (asix_write_rx_ctl(dev, AX_DEFAULT_RX_CTL) < 0) + if ((dev->pusb_dev->descriptor.idVendor == ASIX_USB_VENDOR_ID) && + (dev->pusb_dev->descriptor.idProduct == AX88772B_USB_PRODUCT_ID)) + ctl |= AX_RX_HEADER_DEFAULT; + + if (asix_write_rx_ctl(dev, ctl) < 0) + goto out_err; + + if (asix_write_hwaddr_common(dev, enetaddr) < 0) goto out_err;
do { @@ -447,6 +462,12 @@ static int asix_init_common(struct ueth_data *dev) goto out_err; }
+ /* + * Wait some more to avoid timeout on first transfer + * (e.g. EHCI timed out on TD - token=0x8008d80) + */ + mdelay(25); + return 0; out_err: return -1; @@ -488,7 +509,7 @@ static int asix_init(struct eth_device *eth, bd_t *bd) { struct ueth_data *dev = (struct ueth_data *)eth->priv;
- return asix_init_common(dev); + return asix_init_common(dev, eth->enetaddr); }
static int asix_send(struct eth_device *eth, void *packet, int length) @@ -550,6 +571,12 @@ static int asix_recv(struct eth_device *eth) return -1; }
+ if ((dev->pusb_dev->descriptor.idVendor == + ASIX_USB_VENDOR_ID) && + (dev->pusb_dev->descriptor.idProduct == + AX88772B_USB_PRODUCT_ID)) + buf_ptr += 2; + /* Notify net stack */ net_process_received_packet(buf_ptr + sizeof(packet_len), packet_len); @@ -729,9 +756,10 @@ int asix_eth_get_info(struct usb_device *dev, struct ueth_data *ss, #ifdef CONFIG_DM_ETH static int asix_eth_start(struct udevice *dev) { + struct eth_pdata *pdata = dev_get_platdata(dev); struct asix_private *priv = dev_get_priv(dev);
- return asix_init_common(&priv->ueth); + return asix_init_common(&priv->ueth, pdata->enetaddr); }
void asix_eth_stop(struct udevice *dev)
Joe should pick it, but if you want this through USB tree, just let me know.
Best regards, Marek Vasut
Whatever makes most sense. I still hope somebody could pull in the whole series as it has been cooking for a while now. Will send out a v4 shortly with Scott's final suggestion.
Maybe you should've split it into separate patches, that way this could be picked by various subsystem maintainers separately ;-)
OK, I will send a v5 split up into separate patches to be picked up by the various subsystem maintainers.
Allow showing custom board info from a checkboard() function being implemented if CONFIG_CUSTOM_BOARDINFO is specified. Previously the device tree model was always displayed not taking any CONFIG_CUSTOM_BOARDINFO into account.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: reword commit message as requested by Simon
common/board_info.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_info.c b/common/board_info.c index 4e5a1f7..839fa5a 100644 --- a/common/board_info.c +++ b/common/board_info.c @@ -18,7 +18,7 @@ int __weak checkboard(void) */ int show_board_info(void) { -#ifdef CONFIG_OF_CONTROL +#if defined(CONFIG_OF_CONTROL) && !defined(CONFIG_CUSTOM_BOARDINFO) DECLARE_GLOBAL_DATA_PTR; const char *model;
Use the boot loader splash screen from WinCE which matches our wallpapers position wise. Although the logo is an 8-bit indexed BMP as well colours looked odd at first in U-Boot. After converting to full RGB palette and converting back to an indexed BMP using imagemagick the Logo showed up properly.
$ convert tools/logos/toradex-rgb.bmp -type Palette -colors 256 \ -compress none -verbose BMP3:tools/logos/toradex.bmp
Signed-off-by: Stefan Agner stefan.agner@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- tools/logos/toradex.bmp | Bin 0 -> 24982 bytes 1 file changed, 0 insertions(+), 0 deletions(-) create mode 100644 tools/logos/toradex.bmp
diff --git a/tools/logos/toradex.bmp b/tools/logos/toradex.bmp new file mode 100644 index 0000000000000000000000000000000000000000..3e2dcf23358dd46fc7b1bb0dae70d3ba985606ee GIT binary patch literal 24982 zcmeHPy>H~k6(3!0Ppji;#g)jt)k#_{wd9K2#Q*^=NL&Xlg21U<8%UaK+}lmcz@3r8 zfPpKV!nJ|?0|wHjaPQK8fh$)A3?uJj-pr63?s8A3a}M4CL=NZUy*Iyk^WK{wSAYD= z=YLa_e*aLZ5_0byDD@|}AE+Uf|Mdf<P9y$<Lad;4aB!dw9z0MF;P2q!Z`5EgP!Em{ z)o?ge$H&KN5I<3e=V$8d>`X=FOvUf4RF-9GwOXm?&!4O0&+n+q7w@T?zki_KefM4U z{`>E%7cX9@4?p}+ee}^sYW=T|)$^Ax)NlX&5B0nM{8Rnmzn`m5KKVp_`st_Yv(G+L zFJHb?UwrX}`tr*!)mLAArM~|9YxT`H->7fD{Z@VV-FNEy@4r_+{P2VN@y8$4Pe1*n ze*XDq7JPr*Bd|wckH8**|6c?$-BY$WuXH)>+4$GltT&d^Dw`HM`*ot!Z`8f993j0- z)2$!rUtO!-SQ0X^-mmg*71<5T=*=whD64cerzMc+B?zC=6_$mH3O3tvSK1o<LQ{fn zB&EG%WnAcLMi@*>T@|n=0S?u4y2i3urHi;E<0ZADLN604a@3Vdz+-S{=(3z(U(17X znYN6Qr7kB^4V;ov=iHE?rY_KKnQ&(-KGM5~6zSz0hL2#*Gz!F5#Bx;SV790BUc(Z0 zTv-Oqn?tM$W9kcC%w|iVo9ld5RfuJ#p|YwFOR0^@Y6e(ik%uM7P-H~~<O`ioml`Lh zi_r+?4k#c_Knq%8Lx*KlVfCBAQpF%dg7c}COP$KqNCS@*)L<ptlZ5j)M9DRW$Uw!Q z-k5_FV`hXv#kzp!44-Z7RD;q@sjZ_v)g>(yr6y$P3UnRR#$JdDh!I0)kSeB$piwli zoMCm70SR_rmkN-I^b~gactsR=W&uNkn%r4}ZY+6frZ7y<DoivOB15BQY;7$~)rcVC z=5Pg7GEf>S2_kA?G+<#9tYAS&ASQ!Xr<WlHmeajtaEYWk$(JBrlH-XCOA}>0*K!x; z-B@Ca2s%}0dokq%Dw5+IL1Ak-Q^#^bYnnQ9HPUNgiS<~)g3>jFWrb^jJ7eblQ;MrE z)6qmnQw<9XREmU~Rys%ZlDn0p6HB%TK#rXgjE<WkInxP8Y-?%RH-?(yvgE|o3U36I zy=0cr7A!*yg!+BllM1CTm$3el0<U1hP{gTT;*zy@$Ga0t=w<Y>oIrxH=TwAO&Jie; z)Q0qODds^L?T!Li5>?ehFKK<y960gsFE`T__#84?)eHj~bgPJEg^L}M-1!Nw9222k z#pP!%)Qj!qOy#IJBd}*P@DFTu*<Mn7VrvU*M(zpjCY6j6KCxX*aM5=$>d;GEPKY4c z%LW6(=k?zrh`(^O6LjJbQQ{RaBrJ{1v)0XWhaD~?jQcR00xyjh7%-bxT%;)~_XILD z4)U`x!I9$#ZS55Ku~W9hJ-tlHbmll6VMZ|t%HkSRf%G%<R<zp*F|eFocV@;W5!i!g zoKlE6g)Cw@gLp6pq2%sZduzNZXG>k+1?)ry5jMn^Xzu~;8BGGmm#Aww#h0|+q!!~# zh|6L4E_wD6s9=nX)w<58B1W(%tX?KylBO^-gk@Fbvl2(-1+b38edRD5!c^it(YUM= z&?yoTHYX)2pWGqK$-{CAf%pV=G}I6#1ou6-z#`n_PzLusJYp>30La$jzNfJSJwFaq zKm^)M>pG)S7+EYcbZEv&!Tt+&L*&AU0c{3E`1`wSgXK;f9G3NNJg|BhJ$V&%C8XMV z5yY1`2fL>_nce%}xkrI(bJujQSb{aBV0~vme{n2hSa*5*<k?fC0MP7vz}YlXXD_cJ zFydwrm~GgPqq*BDWh79O*iIzw*ceaomteE&$s2sVf}S`gG9i;!-`UHn2#mE=6fev< zkw?34wneOO$9roR?Wz<c$)x6xJ>k3x3Z=X%$Oek)4R(1N?Q9!%p}udsM_`Y@9)Udq zdj$3f>=D=_ut#7g1dfhR;S1NZ)A5s?x@~D3CDUxNSX@uy!IqYx>XUQ^oo}Y;rl8-k z7=~y_Sua}B_%8Q{<7bywk}ggk??@{yFtzrODuu13q}y2?kiiZ1p`)-cw+LQpOIj5Z z04l;B4L0~ifuwSd2hyR`rbVrW3!=C<Z1=h5ns&vulJU9VXzr&++q%^1QyNVZ7x);W zmR56rXErFYa#5q>Jq+MoTP@vA;FTe!r(UZj3!T>|jGMM;$+WZJ`o<&4SvVQNwDa-T z<7W*d;ql_QMSep;2+PAci{oD_Pqx7=*0e{#Y~UESmGXFnWe&^1b*qhrGv#Iq(lXQf zlqs~-fQucgCe4oLCl_rfp=8|AJX9RO5?%qd(+Xdqn6weglu&CDsMc6w2RIC|(E3_9 zn0wk#aH6`tJ>lvbX5vjUl#jSe*F-lMxW~s~D6g(|(9AZLL(!`;pQh<#RuBvzw*_+( zmZ`K}&L?U5^rnV}U}>R*PnL*<;6HbRgItRiH(OT><{=Aezw*Gorfj*<m(`f?!=t9D zv`Tu}-=Vj$%z3(RCt@N`<^~@zRU5E8F{tF$m83E?KvuA9u^7!vKRaJAM79fBTUv*y zQRiD0ZB$XO!t+1$)`!pK1Bi7OomuQ!nTto=-Rd<hERE^T{F#NX@i2)7bYm&1BB&ED zL(ySrEM1MoiGkeCfjT6sOfT=9$c9$VVOq?S>`qM$<r;g}xjT2<LeMKX?e15vX<|8I z1!=s081cA_>+Z&qhgvy6h#B*+ScX{~va&91Fxx?ENy%`S;1p|o7f&f+Y<=Z6HCt{0 z7w*8k>>Fn`v1EhZig%1j=OJ`r8Ig5d*S!G@Lo}1uI7bOB7DJvd(J7|2Ewtfqz;KLs z`QWD{yQL=%xKOUIVm7d3ohijsI+3^?1JH>jW7hP>K*ZQN!ZISw53pdZk`LrMX*ro7 zHz?Mqi}b<ffVmiBT5GoD;WUJxD?7K{2fpP~^(Xus1(RJBY;a`FSQ?Nad&Y0BJF)cI z_+9B^Q)EL}^12i^<hRRdiJIlxNz3m68!8SI3NQ_<qpOC2sW%Tiji349(8cNTv2#TD zbb4`R7I}PAm2U4g%5JNoHjD<AG_}EZ{R{yu-!3digvC4{FV6&Hxj<BdELbslUQdWt zK*gKXjkmuxT7e%Z?UWpFsEB9ev?Xpor#<B33l7-Rl|Mds8IH*}D0M7{-Md2uihNQR zmQ1T<EpcePVsRD+B!e%49r__wt+|S6rBP?Hy||^m=CSoa-}c1J*ezwqN&LfpU7XGn zGMFqlNXYtR;tuQgfL0w#2F$K_pDP1M1MR|+09%E&)$olHCd860a*zd?)ioPT2EXb~ zZpzI5hd3;~SksrjGhdI<t(T$VGwDTp9}_dsM@#t8l}TdXp=}*Y__z;Jc$v`hFOYl} zmgJyI8`Ov-ct0V+h~*|0M4%!#0!IQw!d{$BH$g4dNCfP&-kf)5Y^b1i_f0F`B1;RO zY!foMMT#bpty!xOmTt;@IcWMfVo4FAH&0$~R(QmcCp63gevBf*nXM5PgcH&-$pmcB zF02L8E_CmOCHWq!{)DB~($cy1{#erJHeyLL_nNS@S`bFk?MD%yB(MVw0T(E1xE|Bu z5xI7Wg&vW*+Eq>GCcL~rI6{QGg|H0Iu3O_AE_y_a1f*7F&|<lj&8yw5P=9>1n`ReJ zw7PJ_a$iWnvawt9Nq6PzVY(b-n1Iuq5si7VbNH%Pe6k{w?X9pnmK?1GMLHxG&s$%j z(*})f$l9EU)rDs^82W8s!E?k|vOUV@fy86-!pOU<adqrRmwfp9NMiR(RLF<pOU9JX zBKZ?prG^ZGKc#gnISvdiQ`RiDQtV{C(J*k_B&c#^Y*w_LqF^G(f_FrWC9f!7Qad^9 zq1@KY^F2mqY|}oOqcKF|E}fs9d5`pTDX%J$*>&p7V=}$AXKBQ!fhEZqR4v|Bu+lMT ztx#@AAzpj!!z6k&OsF*xAPwsxW6A2fjTQ~Tclocdfdm@$Ak*P$ayB+1cHNf-maGn~ za|c<P<`jp6A|A9)nr(<@L8Q`!>Jk(MSjZt8Yg{KSM%=k^<5A(GdQ8DhfQZp`Kk_uO zg=GJu^#+y$4(Ho&@X%xgjEy@tG(z%BxMMSsoedf<akH}z8~_=2W2UGdEtneG*ujri zcqHyL74Zsi-8OPd37c3d@G_mPR7^p{(uB%3u$7%!xwFG_qTm+isjW<YKW2%(4|$ zGk6kT%GpwrmN^U(TJWP2tBz(af;P4xQS))5V)lOH)5Ov!=52i^$WVHFPcB$D!DK_) zcn217+-)bqoWL#X4j+C=$Vp7cCR)-)5NF!V$Gi<{!nOH%!@+uAYuVgG0z>o0#(%*I zKhw37FCv*>Ywp|{)fn9<Je(3f<Mjf<0E?lECoN8WXmOi0dorV=JHI$X$vap1`9m4< z)_YSg@t1d;mJ`;^m``BVy5=K|-0;gN9>?e@!8b5_ztv4LK;BVm3h38(A`LUu@b4cC z3*$J5vBlEpuLfEa{|9IpLSn{^?F{%e;oN=i0F#g1y1V%`Z7kt8dnQ%IVv)<)lDtWk z&a&44MDoR=SeeaKWV8^D0I*mVt~PJGOmE9#<+EV64omZv35q*tnIPTyZuW`Z5)f&7 z-0QnZ<Au)qzUx5-0W9t78Nrn9@`m3^6|>cMjrbfb_@#o*NK0+sFpH85hr<%SLUPny zE|XoV@k7oK<8Ll8?R>UQf{oje5g!dZu{Y;JSgM3SvvA_W*F$cfAp}RVe5D<G(7}wO z6e)$fZ+uN}v7%n9Vnk}?VW|S2%6PQQi!(p$=S@M~9ErSJ??<%_(ACwm{+}5T?I4zF z2tNb$lY7fi6UhIL0Gf+Ijq4z<vU*U!B!GoE-C;)X0T){rA4>=yyJ@w83nXkzX3_A8 zHL<%Nj>fWqygWbM5y|ixM_$oHzUW)u&fB58h?8WuMhmOl+nmPNO9K@AHaUbOvk-H- zE*B{p0Wza?ECHRF&|1}KMT;Vb)I5kuu`n;XMHbOJ?nlSt)6?<s<Nog35(?`jRYx&= z5R@ieP#6+}Q39>fxM>5Rcrs}hTgJj-f-H;$3}Oild(o;>{w1C^VEN|7>B92OOY%w_ zdFLhp+AEQGeVyJeER(d6*cUDur4n_#KA3t@db_ZcO^xrQ1NkjBvKKI~(CF>L(rs!2 z2-+e!9eV{h?$qTi!_w>wENsEd9?O0z;Wo@c7^!gG3~>69zH_U$O)phkc7Ir6YWyAU RodMc`0Q`TRs=7z!{{x@?rvLx|
literal 0 HcmV?d00001
Remove spurious new line in configuration file.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Tested-by: Marek Vasut marex@denx.de Acked-by: Marek Vasut marex@denx.de --- include/configs/colibri_vf.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index ab8d293..e4a0c66 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -69,7 +69,6 @@ "512k(u-boot-env)," \ "-(ubi)"
- #define CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0
Yup :-)
This fixes the following warning (and the runtime error reporting): ../common/image-fdt.c:491:4: warning: 'fdt_ret' may be used uninitialized in this function [-Wmaybe-uninitialized]
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Acked-by: Marek Vasut marex@denx.de Acked-by: Simon Glass sjg@chromium.org --- Changes in v2: run it through checkpatch.pl and replace spaces with tab
common/image-fdt.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/common/image-fdt.c b/common/image-fdt.c index 80e3e63..5180a03 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -492,7 +492,8 @@ int image_setup_libfdt(bootm_headers_t *images, void *blob, } } if (IMAGE_OF_SYSTEM_SETUP) { - if (ft_system_setup(blob, gd->bd)) { + fdt_ret = ft_system_setup(blob, gd->bd); + if (fdt_ret) { printf("ERROR: system-specific fdt fixup failed: %s\n", fdt_strerror(fdt_ret)); goto err;
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form:
ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v3: introduce malloc_cache_aligned() as suggested by Scott Changes in v2: run it through checkpatch.pl and fix long lines
common/cmd_ubi.c | 2 +- drivers/mtd/nand/nand_util.c | 2 +- fs/ubifs/super.c | 5 +++-- fs/ubifs/ubifs.c | 4 ++-- include/malloc.h | 8 ++++++++ lib/gzip.c | 2 +- 6 files changed, 16 insertions(+), 7 deletions(-)
diff --git a/common/cmd_ubi.c b/common/cmd_ubi.c index cbc10c5..10eea65 100644 --- a/common/cmd_ubi.c +++ b/common/cmd_ubi.c @@ -363,7 +363,7 @@ int ubi_volume_read(char *volume, char *buf, size_t size) tbuf_size = vol->usable_leb_size; if (size < tbuf_size) tbuf_size = ALIGN(size, ubi->min_io_size); - tbuf = malloc(tbuf_size); + tbuf = malloc_cache_aligned(tbuf_size); if (!tbuf) { printf("NO MEM\n"); return ENOMEM; diff --git a/drivers/mtd/nand/nand_util.c b/drivers/mtd/nand/nand_util.c index ee2c24d..21b4a61 100644 --- a/drivers/mtd/nand/nand_util.c +++ b/drivers/mtd/nand/nand_util.c @@ -839,7 +839,7 @@ int nand_torture(nand_info_t *nand, loff_t offset)
patt_count = ARRAY_SIZE(patterns);
- buf = malloc(nand->erasesize); + buf = malloc_cache_aligned(nand->erasesize); if (buf == NULL) { puts("Out of memory for erase block buffer\n"); return -ENOMEM; diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index 10f8fff..0bf52db 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -57,7 +57,8 @@ struct inode *iget_locked(struct super_block *sb, unsigned long ino) { struct inode *inode;
- inode = (struct inode *)malloc(sizeof(struct ubifs_inode)); + inode = (struct inode *)malloc_cache_aligned( + sizeof(struct ubifs_inode)); if (inode) { inode->i_ino = ino; inode->i_sb = sb; @@ -104,7 +105,7 @@ void iput(struct inode *inode) /* * Allocate and use new inode */ - ino = (struct inode *)malloc(sizeof(struct ubifs_inode)); + ino = (struct inode *)malloc_cache_aligned(sizeof(struct ubifs_inode)); memcpy(ino, inode, sizeof(struct ubifs_inode));
/* diff --git a/fs/ubifs/ubifs.c b/fs/ubifs/ubifs.c index 6dd6174..4daa7fa 100644 --- a/fs/ubifs/ubifs.c +++ b/fs/ubifs/ubifs.c @@ -108,7 +108,7 @@ static inline struct crypto_comp *crypto_alloc_comp(const char *alg_name, struct crypto_comp *ptr; int i = 0;
- ptr = malloc(sizeof(struct crypto_comp)); + ptr = malloc_cache_aligned(sizeof(struct crypto_comp)); while (i < UBIFS_COMPR_TYPES_CNT) { comp = ubifs_compressors[i]; if (!comp) { @@ -723,7 +723,7 @@ static int do_readpage(struct ubifs_info *c, struct inode *inode, * destination area to a multiple of * UBIFS_BLOCK_SIZE. */ - buff = malloc(UBIFS_BLOCK_SIZE); + buff = malloc_cache_aligned(UBIFS_BLOCK_SIZE); if (!buff) { printf("%s: Error, malloc fails!\n", __func__); diff --git a/include/malloc.h b/include/malloc.h index f4da9e6..5933a94 100644 --- a/include/malloc.h +++ b/include/malloc.h @@ -955,6 +955,14 @@ extern ulong mem_malloc_brk;
void mem_malloc_init(ulong start, ulong size);
+#include <asm/cache.h> +#include <linux/kernel.h> + +static inline void *malloc_cache_aligned(size_t size) +{ + return memalign(ARCH_DMA_MINALIGN, ALIGN(size, ARCH_DMA_MINALIGN)); +} + #ifdef __cplusplus }; /* end of extern "C" */ #endif diff --git a/lib/gzip.c b/lib/gzip.c index ff37d4f..cd8e9fe 100644 --- a/lib/gzip.c +++ b/lib/gzip.c @@ -25,7 +25,7 @@ static void *zalloc(void *x, unsigned items, unsigned size) size *= items; size = (size + ZALLOC_ALIGNMENT - 1) & ~(ZALLOC_ALIGNMENT - 1);
- p = malloc (size); + p = malloc_cache_aligned(size);
return (p); }
malloc.h is for dlmalloc itself -- please put this somewhere like common.h.
Otherwise, ACK.
-Scott
CONFIG_TFTP_TSIZE should limit a tftp downloads progress to 50 '#' chars. Make this work also for small files.
If the file size is small, i.e. smaller than 2 tftp block sizes the number of '#' can get much larger. i.e. with a 1 byte file 65000 characters are printed, with a 512 byte file around 500.
When using CONFIG TFTP BLOCKSIZE together with CONFIG_IP_DEFRAG the issue is more notable.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Reviewed-by: Marek Vasut marex@denx.de --- Changes in v2: run it through checkpatch.pl and fix missing space in if clause as suggested by Marek
net/tftp.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/net/tftp.c b/net/tftp.c index 3e99e73..89be32a 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -249,6 +249,8 @@ static void show_block_marker(void) if (tftp_tsize) { ulong pos = tftp_cur_block * tftp_block_size + tftp_block_wrap_offset; + if (pos > tftp_tsize) + pos = tftp_tsize;
while (tftp_tsize_num_hash < pos * 50 / tftp_tsize) { putc('#');
Marcel Ziswiler
Scott Wood
