[U-Boot] [PATCH] imx: add Boundary Devices Nitrogen8M board support
This adds basic support for the Nitrogen8M board. It's based on the NXP i.MX8MQ and provides 2GB of memory. This code has been based on the i.MX8M EVK board support, and Boundary Devices' git repository. So far the eMMC and onboard Ethernet can be used to boot, with more device support yet to be implemented. Please note that this only supports the 2G version, with 1 rank bit, which is Boundary Devices' "nitrogen8m" defconfig as well.
Signed-off-by: Patrick Wildt patrick@blueri.se
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 62da168ef8..66f013acfb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -629,7 +629,9 @@ dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qxp-colibri.dtb \ fsl-imx8qxp-mek.dtb
-dtb-$(CONFIG_ARCH_IMX8M) += fsl-imx8mq-evk.dtb +dtb-$(CONFIG_ARCH_IMX8M) += \ + fsl-imx8mq-evk.dtb \ + imx8mq-nitrogen8m.dtb
dtb-$(CONFIG_RCAR_GEN2) += \ r8a7790-lager-u-boot.dtb \ diff --git a/arch/arm/dts/imx8mq-nitrogen8m.dts b/arch/arm/dts/imx8mq-nitrogen8m.dts new file mode 100644 index 0000000000..0e028508cc --- /dev/null +++ b/arch/arm/dts/imx8mq-nitrogen8m.dts @@ -0,0 +1,363 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2018 Boundary Devices + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x40000000 0x00020000; + +#include "fsl-imx8mq.dtsi" + +/ { + model = "Boundary Devices i.MX8MQ Nitrogen8M"; + compatible = "boundary,imx8mq-nitrogen8m", "fsl,imx8mq"; + + chosen { + bootargs = "console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200"; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + power { + label = "Power Button"; + gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + gpio-key,wakeup; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_vref_1v8: regulator-vref-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vref-1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + iomuxc-pinctrlgrp { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x23 + MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x19 + MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x59 + >; + }; + + pinctrl_gpio_keys: gpio-keysgrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x19 + >; + }; + + pinctrl_hog: hoggrp { + fsl,pins = < + /* J17 connector, odd */ + MX8MQ_IOMUXC_SAI1_RXFS_GPIO4_IO0 0x19 /* Pin 19 */ + MX8MQ_IOMUXC_SAI1_RXC_GPIO4_IO1 0x19 /* Pin 21 */ + MX8MQ_IOMUXC_SAI1_RXD1_GPIO4_IO3 0x19 /* Pin 23 */ + MX8MQ_IOMUXC_SAI1_RXD2_GPIO4_IO4 0x19 /* Pin 25 */ + MX8MQ_IOMUXC_SAI1_RXD3_GPIO4_IO5 0x19 /* Pin 27 */ + MX8MQ_IOMUXC_SAI1_RXD4_GPIO4_IO6 0x19 /* Pin 29 */ + MX8MQ_IOMUXC_SAI1_RXD5_GPIO4_IO7 0x19 /* Pin 31 */ + MX8MQ_IOMUXC_SAI1_RXD6_GPIO4_IO8 0x19 /* Pin 33 */ + MX8MQ_IOMUXC_SAI1_RXD7_GPIO4_IO9 0x19 /* Pin 35 */ + MX8MQ_IOMUXC_SAI1_TXD1_GPIO4_IO13 0x19 /* Pin 39 */ + MX8MQ_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x19 /* Pin 41 */ + MX8MQ_IOMUXC_SAI1_TXD3_GPIO4_IO15 0x19 /* Pin 43 */ + MX8MQ_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x19 /* Pin 45 */ + MX8MQ_IOMUXC_SAI1_TXD5_GPIO4_IO17 0x19 /* Pin 47 */ + MX8MQ_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x19 /* Pin 49 */ + MX8MQ_IOMUXC_SAI1_TXD7_GPIO4_IO19 0x19 /* Pin 51 */ + + /* J17 connector, even */ + MX8MQ_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x19 /* Pin 44 */ + MX8MQ_IOMUXC_SAI3_RXC_GPIO4_IO29 0x19 /* Pin 48 */ + MX8MQ_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x19 /* Pin 50 */ + MX8MQ_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x19 /* Pin 54 */ + MX8MQ_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x19 /* Pin 56 */ + + /* J18 connector, odd */ + MX8MQ_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x19 /* Pin 41 */ + MX8MQ_IOMUXC_NAND_CLE_GPIO3_IO5 0x19 /* Pin 43 */ + MX8MQ_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 /* Pin 45 */ + MX8MQ_IOMUXC_NAND_DATA05_GPIO3_IO11 0x19 /* Pin 47 */ + MX8MQ_IOMUXC_NAND_WP_B_GPIO3_IO18 0x19 /* Pin 49 */ + MX8MQ_IOMUXC_NAND_DQS_GPIO3_IO14 0x19 /* Pin 53 */ + + /* J18 connector, even */ + MX8MQ_IOMUXC_NAND_ALE_GPIO3_IO0 0x19 /* Pin 32 */ + MX8MQ_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x19 /* Pin 36 */ + MX8MQ_IOMUXC_NAND_DATA00_GPIO3_IO6 0x19 /* Pin 38 */ + MX8MQ_IOMUXC_NAND_DATA01_GPIO3_IO7 0x19 /* Pin 40 */ + MX8MQ_IOMUXC_NAND_DATA02_GPIO3_IO8 0x19 /* Pin 42 */ + MX8MQ_IOMUXC_NAND_DATA03_GPIO3_IO9 0x19 /* Pin 44 */ + MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x19 /* Pin 46 */ + + /* J13 Pin 2, WL_WAKE */ + MX8MQ_IOMUXC_SAI5_RXD2_GPIO3_IO23 0xd6 + /* J13 Pin 4, WL_IRQ, not needed for Silex */ + MX8MQ_IOMUXC_SAI5_RXD0_GPIO3_IO21 0xd6 + /* J13 pin 9, unused */ + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x19 + /* J13 Pin 41, BT_CLK_REQ */ + MX8MQ_IOMUXC_SAI5_RXD1_GPIO3_IO22 0xd6 + /* J13 Pin 42, BT_HOST_WAKE */ + MX8MQ_IOMUXC_SAI5_MCLK_GPIO3_IO25 0xd6 + + /* Clock for both CSI1 and CSI2 */ + MX8MQ_IOMUXC_GPIO1_IO15_CCMSRCGPCMIX_CLKO2 0x07 + /* test points */ + MX8MQ_IOMUXC_GPIO1_IO04_GPIO1_IO4 0xc1 /* TP87 */ + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x4000007f + MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x4000007f + >; + }; + + pinctrl_i2c1_pca9546: i2c1-pca9546grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x49 + >; + }; + + pinctrl_i2c1d_rv4162: i2c1d-rv4162grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x49 + >; + }; + + pinctrl_reg_arm_dram: reg-arm-dram { + fsl,pins = < + MX8MQ_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x16 + >; + }; + + pinctrl_reg_dram_1p1v: reg-dram-1p1v { + fsl,pins = < + MX8MQ_IOMUXC_SD1_STROBE_GPIO2_IO11 0x16 + >; + }; + + pinctrl_reg_soc_gpu_vpu: reg-soc-gpu-vpu { + fsl,pins = < + MX8MQ_IOMUXC_SD2_WP_GPIO2_IO20 0x16 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 + MX8MQ_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x41 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <4>; + interrupts-extended = <&gpio1 11 IRQ_TYPE_LEVEL_LOW>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + i2cmux@70 { + compatible = "pca9546"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1_pca9546>; + reg = <0x70>; + reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; + #address-cells = <1>; + #size-cells = <0>; + + i2c1a: i2c1@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1b: i2c1@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1c: i2c1@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1d: i2c1@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; + +&i2c1a { + reg_arm_dram: fan53555@60 { + compatible = "fcs,fan53555"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_arm_dram>; + reg = <0x60>; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + vsel-gpios = <&gpio3 24 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c1b { + reg_dram_1p1v: fan53555@60 { + compatible = "fcs,fan53555"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_dram_1p1v>; + reg = <0x60>; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + vsel-gpios = <&gpio2 11 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c1c { + reg_soc_gpu_vpu: fan53555@60 { + compatible = "fcs,fan53555"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_soc_gpu_vpu>; + reg = <0x60>; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + vsel-gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c1d { + rtc@68 { + compatible = "microcrystal,rv4162"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1d_rv4162>; + reg = <0x68>; + interrupts-extended = <&gpio1 6 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&usdhc1 { + bus-width = <8>; + no-mmc-hs400; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>; + non-removable; + vqmmc-1-8-v; + vmmc-supply = <®_vref_1v8>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 317dee9bc1..44b92e9fa4 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -16,8 +16,14 @@ config TARGET_IMX8MQ_EVK select IMX8M select IMX8M_LPDDR4
+config TARGET_NITROGEN8M + bool "nitrogen8m" + select IMX8M + select IMX8M_LPDDR4 + endchoice
source "board/freescale/imx8mq_evk/Kconfig" +source "board/boundary/nitrogen8m/Kconfig"
endif diff --git a/board/boundary/nitrogen8m/Kconfig b/board/boundary/nitrogen8m/Kconfig new file mode 100644 index 0000000000..1c799f620a --- /dev/null +++ b/board/boundary/nitrogen8m/Kconfig @@ -0,0 +1,16 @@ +if TARGET_NITROGEN8M + +config SYS_BOARD + default "nitrogen8m" + +config SYS_VENDOR + default "boundary" + +config SYS_CONFIG_NAME + default "nitrogen8m" + +config DDR_RANK_BITS + int "ddr rank bits" + default 1 + +endif diff --git a/board/boundary/nitrogen8m/Makefile b/board/boundary/nitrogen8m/Makefile new file mode 100644 index 0000000000..b8c69c96ad --- /dev/null +++ b/board/boundary/nitrogen8m/Makefile @@ -0,0 +1,12 @@ +# +# Copyright 2016 Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += nitrogen8m.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-y += lpddr4_timing.o +endif diff --git a/board/boundary/nitrogen8m/lpddr4_timing.c b/board/boundary/nitrogen8m/lpddr4_timing.c new file mode 100644 index 0000000000..cb2ce37144 --- /dev/null +++ b/board/boundary/nitrogen8m/lpddr4_timing.c @@ -0,0 +1,1259 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +#define DDR_BOOT_P1 /* default DDR boot frequency point */ + +#define WR_POST_EXT_3200 +#ifdef WR_POST_EXT_3200 // recommend to define +#define VAL_INIT4 ((LPDDR4_MR3 << 16) | 0x00020008) +#else +#define VAL_INIT4 ((LPDDR4_MR3 << 16) | 0x00000008) +#endif + +#ifdef LPDDR4_CS +#undef LPDDR4_CS +#endif + +#if CONFIG_DDR_RANK_BITS == 0 +#define LPDDR4_CS 0x1 /* 0 rank bits, 1 chip select */ +#if CONFIG_DDR_MB == 2048 + /* Address map is from MSB 28: r15, r14, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x0000001F +#define VAL_DDRC_ADDRMAP6 0x07070707 +#else +#error unsupported memory size +#endif +#elif CONFIG_DDR_RANK_BITS == 1 +#define LPDDR4_CS 0x3 /* 1 rank bit, 2 chip selects */ +#if CONFIG_DDR_MB == 2048 + /* Address map is from MSB 28: cs, r14, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x00000016 +#define VAL_DDRC_ADDRMAP6 0x0f070707 +#elif CONFIG_DDR_MB == 3072 + /* Address map is from MSB 29: r15, r14, cs, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x00000015 +#define VAL_DDRC_ADDRMAP6 0x48080707 +#elif CONFIG_DDR_MB == 4096 + /* Address map is from MSB 29: cs, r15, r14, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x00000017 +#define VAL_DDRC_ADDRMAP6 0x07070707 +#else +#error unsupported memory size +#endif +#else +#error unsupported rank bits +#endif + +static struct dram_cfg_param lpddr4_ddrc_cfg[] = { + /* Start to config, default 3200mbps */ + /* dis_dq=1, indicates no reads or writes are issued to SDRAM */ + { DDRC_DBG1(0), 0x00000001 }, + /* selfref_en=1, SDRAM enter self-refresh state */ + { DDRC_PWRCTL(0), 0x00000001 }, + { DDRC_MSTR(0), 0xa0080020 | (LPDDR4_CS << 24) }, + { DDRC_MSTR2(0), 0x00000000 }, + { DDRC_DERATEEN(0), 0x00000203 }, + { DDRC_DERATEINT(0), 0x0186A000 }, + { DDRC_RFSHTMG(0), 0x006100E0 }, + { DDRC_INIT0(0), 0xC003061C }, + { DDRC_INIT1(0), 0x009E0000 }, + { DDRC_INIT3(0), 0x00D4002D }, + { DDRC_INIT4(0), VAL_INIT4 }, + { DDRC_INIT6(0), 0x0066004A }, + { DDRC_INIT7(0), 0x0016004A }, + + { DDRC_DRAMTMG0(0), 0x1A201B22 }, + { DDRC_DRAMTMG1(0), 0x00060633 }, + { DDRC_DRAMTMG3(0), 0x00C0C000 }, + { DDRC_DRAMTMG4(0), 0x0F04080F }, + { DDRC_DRAMTMG5(0), 0x02040C0C }, + { DDRC_DRAMTMG6(0), 0x01010007 }, + { DDRC_DRAMTMG7(0), 0x00000401 }, + { DDRC_DRAMTMG12(0), 0x00020600 }, + { DDRC_DRAMTMG13(0), 0x0C100002 }, + { DDRC_DRAMTMG14(0), 0x000000E6 }, + { DDRC_DRAMTMG17(0), 0x00A00050 }, + + { DDRC_ZQCTL0(0), 0xC3200018 }, + { DDRC_ZQCTL1(0), 0x028061A8 }, + { DDRC_ZQCTL2(0), 0x00000000 }, + + { DDRC_DFITMG0(0), 0x0497820A }, + { DDRC_DFITMG1(0), 0x00080303 }, + { DDRC_DFIUPD0(0), 0xE0400018 }, + { DDRC_DFIUPD1(0), 0x00DF00E4 }, + { DDRC_DFIUPD2(0), 0x80000000 }, + { DDRC_DFIMISC(0), 0x00000011 }, + { DDRC_DFITMG2(0), 0x0000170A }, + + { DDRC_DBICTL(0), 0x00000001 }, + { DDRC_DFIPHYMSTR(0), 0x00000001 }, + + /* need be refined by ddrphy trained value */ + { DDRC_RANKCTL(0), 0x639 }, + { DDRC_DRAMTMG2(0), 0x070e1214 }, + + /* address mapping */ + { DDRC_ADDRMAP0(0), VAL_DDRC_ADDRMAP0 }, + { DDRC_ADDRMAP3(0), 0x00000000 }, + /* addrmap_col_b10 and addrmap_col_b11 set to de-activated (5-bit width) */ + { DDRC_ADDRMAP4(0), 0x00001F1F }, + /* bank interleave */ + /* addrmap_bank_b2, addrmap_bank_b1, addrmap_bank_b0 */ + { DDRC_ADDRMAP1(0), 0x00080808 }, + /* addrmap_row_b11, addrmap_row_b10_b2, addrmap_row_b1, addrmap_row_b0 */ + { DDRC_ADDRMAP5(0), 0x07070707 }, + /* addrmap_row_b15, addrmap_row_b14, addrmap_row_b13, addrmap_row_b12 */ + { DDRC_ADDRMAP6(0), VAL_DDRC_ADDRMAP6 }, + { DDRC_ADDRMAP7(0), 0x00000f0f }, + + /* 667mts frequency setting */ + { DDRC_FREQ1_DERATEEN(0), 0x0000001 }, + { DDRC_FREQ1_DERATEINT(0), 0x00518B00 }, + { DDRC_FREQ1_RFSHCTL0(0), 0x0020D040 }, + { DDRC_FREQ1_RFSHTMG(0), 0x0014002F }, + { DDRC_FREQ1_INIT3(0), 0x00940009 }, + { DDRC_FREQ1_INIT4(0), VAL_INIT4 }, + { DDRC_FREQ1_INIT6(0), 0x0066004A }, + { DDRC_FREQ1_INIT7(0), 0x0016004A }, + { DDRC_FREQ1_DRAMTMG0(0), 0x0B070508 }, + { DDRC_FREQ1_DRAMTMG1(0), 0x0003040B }, + { DDRC_FREQ1_DRAMTMG2(0), 0x0305090C }, + { DDRC_FREQ1_DRAMTMG3(0), 0x00505000 }, + { DDRC_FREQ1_DRAMTMG4(0), 0x04040204 }, + { DDRC_FREQ1_DRAMTMG5(0), 0x02030303 }, + { DDRC_FREQ1_DRAMTMG6(0), 0x01010004 }, + { DDRC_FREQ1_DRAMTMG7(0), 0x00000301 }, + { DDRC_FREQ1_DRAMTMG12(0), 0x00020300 }, + { DDRC_FREQ1_DRAMTMG13(0), 0x0A100002 }, + { DDRC_FREQ1_DRAMTMG14(0), 0x00000031 }, + { DDRC_FREQ1_DRAMTMG17(0), 0x00220011 }, + { DDRC_FREQ1_ZQCTL0(0), 0xC0A70006 }, + { DDRC_FREQ1_DFITMG0(0), 0x03858202 }, + { DDRC_FREQ1_DFITMG1(0), 0x00080303 }, + { DDRC_FREQ1_DFITMG2(0), 0x00000502 }, + + /* 100mts frequency setting */ + { DDRC_FREQ2_DERATEEN(0), 0x0000001 }, + { DDRC_FREQ2_DERATEINT(0), 0x000C3500 }, + { DDRC_FREQ2_RFSHCTL0(0), 0x0020D040 }, + { DDRC_FREQ2_RFSHTMG(0), 0x00030007 }, + { DDRC_FREQ2_INIT3(0), 0x00840000 }, + { DDRC_FREQ2_INIT4(0), VAL_INIT4 }, + { DDRC_FREQ2_INIT6(0), 0x0066004A }, + { DDRC_FREQ2_INIT7(0), 0x0016004A }, + { DDRC_FREQ2_DRAMTMG0(0), 0x0A010102 }, + { DDRC_FREQ2_DRAMTMG1(0), 0x00030404 }, + { DDRC_FREQ2_DRAMTMG2(0), 0x0203060B }, + { DDRC_FREQ2_DRAMTMG3(0), 0x00505000 }, + { DDRC_FREQ2_DRAMTMG4(0), 0x02040202 }, + { DDRC_FREQ2_DRAMTMG5(0), 0x02030202 }, + { DDRC_FREQ2_DRAMTMG6(0), 0x01010004 }, + { DDRC_FREQ2_DRAMTMG7(0), 0x00000301 }, + { DDRC_FREQ2_DRAMTMG12(0), 0x00020300 }, + { DDRC_FREQ2_DRAMTMG13(0), 0x0A100002 }, + { DDRC_FREQ2_DRAMTMG14(0), 0x00000008 }, + { DDRC_FREQ2_DRAMTMG17(0), 0x00050003 }, + { DDRC_FREQ2_ZQCTL0(0), 0xC0190004 }, + { DDRC_FREQ2_DFITMG0(0), 0x03818200 }, + { DDRC_FREQ2_DFITMG1(0), 0x00080303 }, + { DDRC_FREQ2_DFITMG2(0), 0x00000100 }, + + /* performance setting */ + { DDRC_ODTCFG(0), 0x0b060908 }, + { DDRC_ODTMAP(0), 0x00000000 }, + { DDRC_SCHED(0), 0x29001505 }, + { DDRC_SCHED1(0), 0x0000002c }, + { DDRC_PERFHPR1(0), 0x5900575b }, + /* 150T starve and 0x90 max tran len */ + { DDRC_PERFLPR1(0), 0x90000096 }, + /* 300T starve and 0x10 max tran len */ + { DDRC_PERFWR1(0), 0x1000012c }, + + { DDRC_DBG0(0), 0x00000016 }, + { DDRC_DBG1(0), 0x00000000 }, + { DDRC_DBGCMD(0), 0x00000000 }, + { DDRC_SWCTL(0), 0x00000001 }, + { DDRC_POISONCFG(0), 0x00000011 }, + { DDRC_PCCFG(0), 0x00000111 }, + { DDRC_PCFGR_0(0), 0x000010f3 }, + { DDRC_PCFGW_0(0), 0x000072ff }, + { DDRC_PCTRL_0(0), 0x00000001 }, + /* disable Read Qos*/ + { DDRC_PCFGQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGQOS1_0(0), 0x0062ffff }, + /* disable Write Qos*/ + { DDRC_PCFGWQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGWQOS1_0(0), 0x0000ffff }, + + /* boot start point */ +#ifdef DDR_BOOT_P2 + { DDRC_MSTR2(0), 0x2 }, +#elif defined(DDR_BOOT_P1) + { DDRC_MSTR2(0), 0x1 }, +#endif +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param lpddr4_ddrphy_cfg[] = { + { 0x20110, 0x02 }, /* MapCAB0toDFI */ + { 0x20111, 0x03 }, /* MapCAB1toDFI */ + { 0x20112, 0x04 }, /* MapCAB2toDFI */ + { 0x20113, 0x05 }, /* MapCAB3toDFI */ + { 0x20114, 0x00 }, /* MapCAB4toDFI */ + { 0x20115, 0x01 }, /* MapCAB5toDFI */ + + /* Initialize PHY Configuration */ + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + + { 0x2002e, 0x2 }, + { 0x12002e, 0x1 }, + { 0x22002e, 0x2 }, + + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + + { 0x20024, 0xe3 }, + { 0x2003a, 0x2 }, + + { 0x120024, 0xa3 }, + { 0x2003a, 0x2 }, + + { 0x220024, 0xa3 }, + { 0x2003a, 0x2 }, + + { 0x20056, 0x3 }, + { 0x120056, 0xa }, + { 0x220056, 0xa }, + + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + + { 0x10049, 0xfbe }, + { 0x10149, 0xfbe }, + { 0x11049, 0xfbe }, + { 0x11149, 0xfbe }, + { 0x12049, 0xfbe }, + { 0x12149, 0xfbe }, + { 0x13049, 0xfbe }, + { 0x13149, 0xfbe }, + + { 0x110049, 0xfbe }, + { 0x110149, 0xfbe }, + { 0x111049, 0xfbe }, + { 0x111149, 0xfbe }, + { 0x112049, 0xfbe }, + { 0x112149, 0xfbe }, + { 0x113049, 0xfbe }, + { 0x113149, 0xfbe }, + + { 0x210049, 0xfbe }, + { 0x210149, 0xfbe }, + { 0x211049, 0xfbe }, + { 0x211149, 0xfbe }, + { 0x212049, 0xfbe }, + { 0x212149, 0xfbe }, + { 0x213049, 0xfbe }, + { 0x213149, 0xfbe }, + + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0xa7 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x600 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5655 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, +}; + +/* P0 message block parameter for training firmware */ +static struct dram_cfg_param lpddr4_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x131f }, + { 0x54009, LPDDR4_HDT_CTL_3200_1D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_1d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x10 | (LPDDR4_CS << 8) }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, LPDDR4_CS }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +static struct dram_cfg_param lpddr4_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x61 }, + { 0x54009, LPDDR4_HDT_CTL_2D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_2d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, (LPDDR4_2D_SHARE << 8) | 0x00 }, + { 0x54010, LPDDR4_2D_WEIGHT }, + { 0x54011, 0x0 }, + { 0x54012, 0x10 | (LPDDR4_CS << 8) }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54024, 0x5 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, LPDDR4_CS }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block parameter for training firmware */ +static struct dram_cfg_param lpddr4_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x1 }, + { 0x54003, 0x29c }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, 0x0 }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x10 | (LPDDR4_CS << 8) }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x914 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401e, 0x6 }, + { 0x5401f, 0x914 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, LPDDR4_CS }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0x1400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, 0x600 }, + { 0x54038, 0x1400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param lpddr4_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0xd }, + { 0x900a5, 0x7c0 }, + { 0x900a6, 0x109 }, + { 0x900a7, 0x4 }, + { 0x900a8, 0x7c0 }, + { 0x900a9, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900aa, 0x0 }, + { 0x900ab, 0x790 }, + { 0x900ac, 0x11a }, + { 0x900ad, 0x8 }, + { 0x900ae, 0x7aa }, + { 0x900af, 0x2a }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x7b2 }, + { 0x900b2, 0x2a }, + { 0x900b3, 0x0 }, + { 0x900b4, 0x7c8 }, + { 0x900b5, 0x109 }, + { 0x900b6, 0x10 }, + { 0x900b7, 0x10 }, + { 0x900b8, 0x109 }, + { 0x900b9, 0x10 }, + { 0x900ba, 0x2a8 }, + { 0x900bb, 0x129 }, + { 0x900bc, 0x8 }, + { 0x900bd, 0x370 }, + { 0x900be, 0x129 }, + { 0x900bf, 0xa }, + { 0x900c0, 0x3c8 }, + { 0x900c1, 0x1a9 }, + { 0x900c2, 0xc }, + { 0x900c3, 0x408 }, + { 0x900c4, 0x199 }, + { 0x900c5, 0x14 }, + { 0x900c6, 0x790 }, + { 0x900c7, 0x11a }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x4 }, + { 0x900ca, 0x18 }, + { 0x900cb, 0xe }, + { 0x900cc, 0x408 }, + { 0x900cd, 0x199 }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x8568 }, + { 0x900d0, 0x108 }, + { 0x900d1, 0x18 }, + { 0x900d2, 0x790 }, + { 0x900d3, 0x16a }, + { 0x900d4, 0x8 }, + { 0x900d5, 0x1d8 }, + { 0x900d6, 0x169 }, + { 0x900d7, 0x10 }, + { 0x900d8, 0x8558 }, + { 0x900d9, 0x168 }, + { 0x900da, 0x70 }, + { 0x900db, 0x788 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x1ff8 }, + { 0x900de, 0x85a8 }, + { 0x900df, 0x1e8 }, + { 0x900e0, 0x50 }, + { 0x900e1, 0x798 }, + { 0x900e2, 0x16a }, + { 0x900e3, 0x60 }, + { 0x900e4, 0x7a0 }, + { 0x900e5, 0x16a }, + { 0x900e6, 0x8 }, + { 0x900e7, 0x8310 }, + { 0x900e8, 0x168 }, + { 0x900e9, 0x8 }, + { 0x900ea, 0xa310 }, + { 0x900eb, 0x168 }, + { 0x900ec, 0xa }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x6e }, + { 0x900f0, 0x0 }, + { 0x900f1, 0x68 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0x408 }, + { 0x900f4, 0x169 }, + { 0x900f5, 0x0 }, + { 0x900f6, 0x8310 }, + { 0x900f7, 0x168 }, + { 0x900f8, 0x0 }, + { 0x900f9, 0xa310 }, + { 0x900fa, 0x168 }, + { 0x900fb, 0x1ff8 }, + { 0x900fc, 0x85a8 }, + { 0x900fd, 0x1e8 }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x798 }, + { 0x90100, 0x16a }, + { 0x90101, 0x78 }, + { 0x90102, 0x7a0 }, + { 0x90103, 0x16a }, + { 0x90104, 0x68 }, + { 0x90105, 0x790 }, + { 0x90106, 0x16a }, + { 0x90107, 0x8 }, + { 0x90108, 0x8b10 }, + { 0x90109, 0x168 }, + { 0x9010a, 0x8 }, + { 0x9010b, 0xab10 }, + { 0x9010c, 0x168 }, + { 0x9010d, 0xa }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x58 }, + { 0x90111, 0x0 }, + { 0x90112, 0x68 }, + { 0x90113, 0x0 }, + { 0x90114, 0x408 }, + { 0x90115, 0x169 }, + { 0x90116, 0x0 }, + { 0x90117, 0x8b10 }, + { 0x90118, 0x168 }, + { 0x90119, 0x0 }, + { 0x9011a, 0xab10 }, + { 0x9011b, 0x168 }, + { 0x9011c, 0x0 }, + { 0x9011d, 0x1d8 }, + { 0x9011e, 0x169 }, + { 0x9011f, 0x80 }, + { 0x90120, 0x790 }, + { 0x90121, 0x16a }, + { 0x90122, 0x18 }, + { 0x90123, 0x7aa }, + { 0x90124, 0x6a }, + { 0x90125, 0xa }, + { 0x90126, 0x0 }, + { 0x90127, 0x1e9 }, + { 0x90128, 0x8 }, + { 0x90129, 0x8080 }, + { 0x9012a, 0x108 }, + { 0x9012b, 0xf }, + { 0x9012c, 0x408 }, + { 0x9012d, 0x169 }, + { 0x9012e, 0xc }, + { 0x9012f, 0x0 }, + { 0x90130, 0x68 }, + { 0x90131, 0x9 }, + { 0x90132, 0x0 }, + { 0x90133, 0x1a9 }, + { 0x90134, 0x0 }, + { 0x90135, 0x408 }, + { 0x90136, 0x169 }, + { 0x90137, 0x0 }, + { 0x90138, 0x8080 }, + { 0x90139, 0x108 }, + { 0x9013a, 0x8 }, + { 0x9013b, 0x7aa }, + { 0x9013c, 0x6a }, + { 0x9013d, 0x0 }, + { 0x9013e, 0x8568 }, + { 0x9013f, 0x108 }, + { 0x90140, 0xb7 }, + { 0x90141, 0x790 }, + { 0x90142, 0x16a }, + { 0x90143, 0x1f }, + { 0x90144, 0x0 }, + { 0x90145, 0x68 }, + { 0x90146, 0x8 }, + { 0x90147, 0x8558 }, + { 0x90148, 0x168 }, + { 0x90149, 0xf }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0xc }, + { 0x9014d, 0x0 }, + { 0x9014e, 0x68 }, + { 0x9014f, 0x0 }, + { 0x90150, 0x408 }, + { 0x90151, 0x169 }, + { 0x90152, 0x0 }, + { 0x90153, 0x8558 }, + { 0x90154, 0x168 }, + { 0x90155, 0x8 }, + { 0x90156, 0x3c8 }, + { 0x90157, 0x1a9 }, + { 0x90158, 0x3 }, + { 0x90159, 0x370 }, + { 0x9015a, 0x129 }, + { 0x9015b, 0x20 }, + { 0x9015c, 0x2aa }, + { 0x9015d, 0x9 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x400 }, + { 0x90160, 0x10e }, + { 0x90161, 0x8 }, + { 0x90162, 0xe8 }, + { 0x90163, 0x109 }, + { 0x90164, 0x0 }, + { 0x90165, 0x8140 }, + { 0x90166, 0x10c }, + { 0x90167, 0x10 }, + { 0x90168, 0x8138 }, + { 0x90169, 0x10c }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x7c8 }, + { 0x9016c, 0x101 }, + { 0x9016d, 0x8 }, + { 0x9016e, 0x0 }, + { 0x9016f, 0x8 }, + { 0x90170, 0x8 }, + { 0x90171, 0x448 }, + { 0x90172, 0x109 }, + { 0x90173, 0xf }, + { 0x90174, 0x7c0 }, + { 0x90175, 0x109 }, + { 0x90176, 0x0 }, + { 0x90177, 0xe8 }, + { 0x90178, 0x109 }, + { 0x90179, 0x47 }, + { 0x9017a, 0x630 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x618 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0xe0 }, + { 0x90181, 0x109 }, + { 0x90182, 0x0 }, + { 0x90183, 0x7c8 }, + { 0x90184, 0x109 }, + { 0x90185, 0x8 }, + { 0x90186, 0x8140 }, + { 0x90187, 0x10c }, + { 0x90188, 0x0 }, + { 0x90189, 0x1 }, + { 0x9018a, 0x8 }, + { 0x9018b, 0x8 }, + { 0x9018c, 0x4 }, + { 0x9018d, 0x8 }, + { 0x9018e, 0x8 }, + { 0x9018f, 0x7c8 }, + { 0x90190, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2b }, + { 0x90026, 0x6c }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0x14 }, + { 0x12000c, 0x29 }, + { 0x12000d, 0x1a1 }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 }, +}; + +static struct dram_fsp_msg lpddr4_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = lpddr4_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_2d_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp1_cfg), + }, +#if 0 + { + /* P1 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp2_cfg), + }, +#endif +}; + +struct dram_timing_info dram_timing = { + .ddrc_cfg = lpddr4_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(lpddr4_ddrc_cfg), + .ddrphy_cfg = lpddr4_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(lpddr4_ddrphy_cfg), + .fsp_msg = lpddr4_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(lpddr4_dram_fsp_msg), + .ddrphy_pie = lpddr4_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(lpddr4_phy_pie), + .fsp_table = { 3200, 400, }, +}; diff --git a/board/boundary/nitrogen8m/nitrogen8m.c b/board/boundary/nitrogen8m/nitrogen8m.c new file mode 100644 index 0000000000..de0ce5e332 --- /dev/null +++ b/board/boundary/nitrogen8m/nitrogen8m.c @@ -0,0 +1,237 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2017-2018 NXP + */ + +#include <common.h> +#include <env.h> +#include <malloc.h> +#include <errno.h> +#include <asm/io.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/video.h> +#include <video_fb.h> +#include <spl.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIRQ_ENET_PHY IMX_GPIO_NR(1, 2) +#define GPIRQ_GT911 IMX_GPIO_NR(3, 12) +#define GP_ARM_DRAM_VSEL IMX_GPIO_NR(3, 24) +#define GP_CSI1_MIPI_PWDN IMX_GPIO_NR(3, 3) +#define GP_CSI1_MIPI_RESET IMX_GPIO_NR(3, 17) +#define GP_CSI2_MIPI_PWDN IMX_GPIO_NR(3, 2) +#define GP_CSI2_MIPI_RESET IMX_GPIO_NR(2, 19) +#define GP_DRAM_1P1_VSEL IMX_GPIO_NR(2, 11) +#define GP_EMMC_RESET IMX_GPIO_NR(2, 10) +#define GP_FASTBOOT_KEY IMX_GPIO_NR(1, 7) +#define GP_GT911_RESET IMX_GPIO_NR(3, 13) +#define GP_I2C1_PCA9546_RESET IMX_GPIO_NR(1, 8) +#define GP_I2C4_SN65DSI83_EN IMX_GPIO_NR(3, 15) +#define GP_LCM_JM430_BKL_EN IMX_GPIO_NR(1, 1) +/* This enables 5V power on LTK080A60A004T mipi display */ +#define GP_LTK08_MIPI_EN IMX_GPIO_NR(1, 1) +#define GP_MIPI_RESET IMX_GPIO_NR(3, 15) +#define GP_RGMII_PHY_RESET IMX_GPIO_NR(1, 9) +#define GP_SOC_GPU_VPU_VSEL IMX_GPIO_NR(2, 20) +#define GP_ST1633_RESET IMX_GPIO_NR(3, 13) +#define GP_TC358762_EN IMX_GPIO_NR(3, 15) + +#define ENET_MDC_PAD_CTRL (PAD_CTL_DSE3) +#define ENET_MDIO_PAD_CTRL (PAD_CTL_DSE3 | PAD_CTL_ODE) +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define WEAK_PULLUP (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) + +static iomux_v3_cfg_t const init_pads[] = { + IMX8MQ_PAD_GPIO1_IO01__GPIO1_IO1 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), + IMX8MQ_PAD_GPIO1_IO07__GPIO1_IO7 | MUX_PAD_CTRL(WEAK_PULLUP), + IMX8MQ_PAD_GPIO1_IO08__GPIO1_IO8 | MUX_PAD_CTRL(0x49), + IMX8MQ_PAD_NAND_CE1_B__GPIO3_IO2 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_NAND_CE2_B__GPIO3_IO3 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_NAND_DATA06__GPIO3_IO12 | MUX_PAD_CTRL(0xd6), + IMX8MQ_PAD_NAND_DATA07__GPIO3_IO13 | MUX_PAD_CTRL(0x49), + IMX8MQ_PAD_NAND_RE_B__GPIO3_IO15 | MUX_PAD_CTRL(0x6), + IMX8MQ_PAD_NAND_WE_B__GPIO3_IO17 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_SAI5_RXD3__GPIO3_IO24 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(0x41), + IMX8MQ_PAD_SD1_STROBE__GPIO2_IO11 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_SD2_WP__GPIO2_IO20 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_UART1_RXD__UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART1_TXD__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(WEAK_PULLUP), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(init_pads, ARRAY_SIZE(init_pads)); + set_wdog_reset(wdog); + + gpio_direction_output(GP_ARM_DRAM_VSEL, 0); + gpio_direction_output(GP_DRAM_1P1_VSEL, 0); + gpio_direction_output(GP_SOC_GPU_VPU_VSEL, 0); + gpio_direction_output(GP_EMMC_RESET, 1); + gpio_direction_output(GP_I2C1_PCA9546_RESET, 0); + gpio_direction_output(GP_I2C4_SN65DSI83_EN, 0); + gpio_direction_output(GP_CSI1_MIPI_PWDN, 1); + gpio_direction_output(GP_CSI1_MIPI_RESET, 0); + gpio_direction_output(GP_CSI2_MIPI_PWDN, 1); + gpio_direction_output(GP_CSI2_MIPI_RESET, 0); + + return 0; +} + +#define MAX_LOW_SIZE (0x100000000ULL - CONFIG_SYS_SDRAM_BASE) +#define SDRAM_SIZE ((1ULL * CONFIG_DDR_MB) << 20) + +#if SDRAM_SIZE > MAX_LOW_SIZE +#define MEM_SIZE MAX_LOW_SIZE +#else +#define MEM_SIZE SDRAM_SIZE +#endif + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = SDRAM_SIZE; + return 0; +} + +int dram_init(void) +{ + /* rom_pointer[1] contains the size of TEE occupies */ + gd->ram_size = MEM_SIZE - rom_pointer[1]; + return 0; +} + +#ifdef CONFIG_FEC_MXC +static iomux_v3_cfg_t const fec1_strap_pads[] = { + IMX8MQ_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(WEAK_PULLUP), + IMX8MQ_PAD_ENET_RD0__GPIO1_IO26 | MUX_PAD_CTRL(0xd1), + IMX8MQ_PAD_ENET_RD1__GPIO1_IO27 | MUX_PAD_CTRL(0xd1), + IMX8MQ_PAD_ENET_RD2__GPIO1_IO28 | MUX_PAD_CTRL(0xd1), + IMX8MQ_PAD_ENET_RD3__GPIO1_IO29 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RX_CTL__GPIO1_IO24 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RXC__GPIO1_IO25 | MUX_PAD_CTRL(0xd1), +}; + +static iomux_v3_cfg_t const fec1_enet_pads[] = { + IMX8MQ_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(WEAK_PULLUP), + IMX8MQ_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_MDC_PAD_CTRL), + IMX8MQ_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_MDIO_PAD_CTRL), + IMX8MQ_PAD_ENET_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RX_CTL__ENET_RGMII_RX_CTL | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TX_CTL__ENET_RGMII_TX_CTL | MUX_PAD_CTRL(0x1f), +}; + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + /* Pull PHY into reset */ + gpio_request(IMX_GPIO_NR(1, 9), "fec1_rst"); + gpio_direction_output(IMX_GPIO_NR(1, 9), 0); + + /* Set bootstrap pins for AR8035 */ + gpio_request(IMX_GPIO_NR(1, 26), "fec1_rd0"); + gpio_direction_output(IMX_GPIO_NR(1, 26), 0); + gpio_request(IMX_GPIO_NR(1, 27), "fec1_rd1"); + gpio_direction_output(IMX_GPIO_NR(1, 27), 0); + gpio_request(IMX_GPIO_NR(1, 28), "fec1_rd2"); + gpio_direction_output(IMX_GPIO_NR(1, 28), 0); + gpio_request(IMX_GPIO_NR(1, 29), "fec1_rd3"); + gpio_direction_output(IMX_GPIO_NR(1, 29), 1); + gpio_request(IMX_GPIO_NR(1, 24), "fec1_rx_ctl"); + gpio_direction_output(IMX_GPIO_NR(1, 24), 0); + gpio_request(IMX_GPIO_NR(1, 25), "fec1_rxc"); + gpio_direction_output(IMX_GPIO_NR(1, 25), 1); + imx_iomux_v3_setup_multiple_pads(fec1_strap_pads, + ARRAY_SIZE(fec1_strap_pads)); + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); + set_clk_enet(ENET_125MHZ); + udelay(1000); + + /* Release PHY from reset */ + gpio_direction_output(IMX_GPIO_NR(1, 9), 1); + udelay(500); + + /* Setup pins for ethernet */ + imx_iomux_v3_setup_multiple_pads(fec1_enet_pads, + ARRAY_SIZE(fec1_enet_pads)); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_init(void) +{ +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + gpio_request(GP_I2C4_SN65DSI83_EN, "sn65dsi83_enable"); + gpio_request(GP_GT911_RESET, "gt911_reset"); + gpio_request(GPIRQ_GT911, "gt911_irq"); + gpio_request(GP_LTK08_MIPI_EN, "lkt08_mipi_en"); + gpio_direction_output(GP_GT911_RESET, 0); + + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return 0; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "nitrogen8m"); +#endif + + return 0; +} diff --git a/board/boundary/nitrogen8m/spl.c b/board/boundary/nitrogen8m/spl.c new file mode 100644 index 0000000000..4f7279aba2 --- /dev/null +++ b/board/boundary/nitrogen8m/spl.c @@ -0,0 +1,237 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017 NXP + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void spl_dram_init(void) +{ + /* ddr init */ + ddr_init(&dram_timing); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + } + + return ret; +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC1_BASE_ADDR, 0, 8}, +}; + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + init_clk_usdhc(0); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +#define GP_I2C1_PCA9546_RESET IMX_GPIO_NR(1, 8) +#define GP_ARM_DRAM_VSEL IMX_GPIO_NR(3, 24) +#define GP_DRAM_1P1_VSEL IMX_GPIO_NR(2, 11) +#define GP_SOC_GPU_VPU_VSEL IMX_GPIO_NR(2, 20) + +#define I2C_MUX_ADDR 0x70 +#define I2C_FAN53555_ADDR 0x60 + +static iomux_v3_cfg_t const i2c1_pads[] = { + IMX8MQ_PAD_GPIO1_IO08__GPIO1_IO8 | MUX_PAD_CTRL(0x49), +}; + +int power_init_board(void) +{ + u8 val8; + + imx_iomux_v3_setup_multiple_pads(i2c1_pads, ARRAY_SIZE(i2c1_pads)); + + gpio_set_value(GP_I2C1_PCA9546_RESET, 1); + gpio_set_value(GP_ARM_DRAM_VSEL, 0); + gpio_set_value(GP_DRAM_1P1_VSEL, 0); + gpio_set_value(GP_SOC_GPU_VPU_VSEL, 0); + + /* + * 9e (1e = 30) default .9 V + * 0.6V to 1.23V in 10 MV steps + */ + + /* Enable I2C1A, ARM/DRAM */ + i2c_write(I2C_MUX_ADDR, 1, 1, NULL, 0); + /* + * .6 + .40 = 1.00 + */ + val8 = 0x80 + 40; + i2c_write(I2C_FAN53555_ADDR, 0, 1, &val8, 1); + i2c_write(I2C_FAN53555_ADDR, 1, 1, &val8, 1); + + /* Enable I2C1B, DRAM 1.1V */ + i2c_write(I2C_MUX_ADDR, 2, 1, NULL, 0); + /* + * .6 + .50 = 1.10 + */ + val8 = 0x80 + 50; + i2c_write(I2C_FAN53555_ADDR, 0, 1, &val8, 1); + i2c_write(I2C_FAN53555_ADDR, 1, 1, &val8, 1); + + /* Enable I2C1C, soc/gpu/vpu */ + i2c_write(I2C_MUX_ADDR, 4, 1, NULL, 0); + /* + * .6 + .30 = .90 + */ + val8 = 0x80 + 30; + i2c_write(I2C_FAN53555_ADDR, 0, 1, &val8, 1); + i2c_write(I2C_FAN53555_ADDR, 1, 1, &val8, 1); + + /* Disable I2C1A-I2C1D */ + i2c_write(I2C_MUX_ADDR, 0, 1, NULL, 0); + + return 0; +} + +void spl_board_init(void) +{ + /* Serial download mode */ + if (is_usb_boot()) { + puts("Back to ROM, SDP\n"); + restore_boot_params(); + } + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + init_uart_clk(0); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* Adjust pmic voltage to 1.0V for 800M */ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/nitrogen8m_defconfig b/configs/nitrogen8m_defconfig new file mode 100644 index 0000000000..146102bb23 --- /dev/null +++ b/configs/nitrogen8m_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_NITROGEN8M=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg,DDR_MB=2048" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-nitrogen8m" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y +CONFIG_DM_THERMAL=y diff --git a/include/configs/nitrogen8m.h b/include/configs/nitrogen8m.h new file mode 100644 index 0000000000..caf1b4f1b9 --- /dev/null +++ b/include/configs/nitrogen8m.h @@ -0,0 +1,157 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 Boundary Devices + */ + +#ifndef __NITROGEN8M_H +#define __NITROGEN8M_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_CSF_SIZE 0x2000 /* 8K region */ +#endif + +#define CONFIG_SPL_MAX_SIZE (124 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 + +#ifdef CONFIG_SPL_BUILD + +/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#undef CONFIG_DM_MMC +#undef CONFIG_DM_PMIC +#undef CONFIG_DM_PMIC_PFUZE100 + +#define CONFIG_SYS_I2C +#endif + +#define CONFIG_REMAKE_ELF + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV +#undef CONFIG_CMD_IMLS + +#undef CONFIG_CMD_CRC32 +#undef CONFIG_BOOTM_NETBSD + +/* ENET Config */ +/* ENET1 */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_FEC_MXC +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 4 +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_PHY_GIGE +#define IMX_FEC_BASE 0x30BE0000 + +#endif + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x40480000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */ +#define CONFIG_SYS_MMC_ENV_PART 1 /* mmcblk0boot0 */ +#define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (2 * 1024) + (16 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x40000000u) + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR + +/* Monitor Command Prompt */ +#undef CONFIG_SYS_PROMPT +#define CONFIG_SYS_PROMPT "u-boot=> " +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_IMX_BOOTAUX + +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_MXC_GPIO + +#define CONFIG_CMD_FUSE + +/* I2C Configs */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_OF_SYSTEM_SETUP + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200\0" \ + "env_dev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "env_part=" __stringify(CONFIG_SYS_MMC_ENV_PART) "\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "boot_fdt=try\0" \ + "fdt_file=imx8mq-nitrogen8m.dtb\0" \ + "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "pxefile_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "scriptaddr=" __stringify(CONFIG_LOADADDR) "\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + BOOTENV + +#endif
Hi Patrick,
[Adding Troy, NXP U-Boot folks and Stefano]
Thanks for your contribution.
On Tue, Oct 1, 2019 at 4:15 PM Patrick Wildt patrick@blueri.se wrote:
This adds basic support for the Nitrogen8M board. It's based on the NXP i.MX8MQ and provides 2GB of memory. This code has been based on the i.MX8M EVK board support, and Boundary Devices' git repository. So far the eMMC and onboard Ethernet can be used to boot, with more device support yet to be implemented. Please note that this only supports the 2G version, with 1 rank bit, which is Boundary Devices' "nitrogen8m" defconfig as well.
Signed-off-by: Patrick Wildt patrick@blueri.se
model = "Boundary Devices i.MX8MQ Nitrogen8M";
compatible = "boundary,imx8mq-nitrogen8m", "fsl,imx8mq";
chosen {
bootargs = "console=ttymxc0,115200 earlycon=ec_imx6q,0x30860000,115200";
This earlycon part should be removed.
/* P1 400mts 1D */
.drate = 400,
+#if 0
No if 0 please.
There is DM support from the FEC, so no need to have all this board code.
These commands look too cryptic.
* .6 + .40 = 1.00
val8 = 0x80 + 40;
Please add defines for these values.
On Thu, Oct 03, 2019 at 10:27:12AM -0300, Fabio Estevam wrote:
Hi Patrick,
Thanks for looking at it!
chosen {
Sure, ok.
/* P1 400mts 1D */
.drate = 400,
+#if 0
No if 0 please.
That was taken from Boundary Devices directly, I'll get rid of it.
I should have added a better comment for this whole block I think, sorry. This does not bootrstrap the FEC, but it bootstrap the Phy. The thing is that Boundary Devices configures the Phy by pulling the Ethernet TX/RX pins to specific modes. When the Phy is pulled from reset, it will sample those pins and configure itself based on the information. I don't think the FEC driver takes care of it, and I highly doubt it is supposed to take care of it.
I agree. This code is taken from Boundary devices. I will try to find the datasheet for the controller and come up with something nicer.
* .6 + .40 = 1.00
val8 = 0x80 + 40;
Thanks! Patrick
Signed-off-by: Patrick Wildt patrick@blueri.se --- Changes for v2: - Added explanation for the phy initialization - Improved readability of the voltage regulator initialization - Used correct fdtfile environment variable instead of fdt_file - Removed earlycon from device tree and extra environment - Removed #if 0 from LPDDR4 timing
arch/arm/dts/Makefile | 4 +- arch/arm/dts/imx8mq-nitrogen8m.dts | 363 ++++++ arch/arm/mach-imx/imx8m/Kconfig | 6 + board/boundary/nitrogen8m/Kconfig | 16 + board/boundary/nitrogen8m/Makefile | 12 + board/boundary/nitrogen8m/lpddr4_timing.c | 1250 +++++++++++++++++++++ board/boundary/nitrogen8m/nitrogen8m.c | 244 ++++ board/boundary/nitrogen8m/spl.c | 232 ++++ configs/nitrogen8m_defconfig | 61 + include/configs/nitrogen8m.h | 157 +++ 10 files changed, 2344 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mq-nitrogen8m.dts create mode 100644 board/boundary/nitrogen8m/Kconfig create mode 100644 board/boundary/nitrogen8m/Makefile create mode 100644 board/boundary/nitrogen8m/lpddr4_timing.c create mode 100644 board/boundary/nitrogen8m/nitrogen8m.c create mode 100644 board/boundary/nitrogen8m/spl.c create mode 100644 configs/nitrogen8m_defconfig create mode 100644 include/configs/nitrogen8m.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 62da168ef8..66f013acfb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -629,7 +629,9 @@ dtb-$(CONFIG_ARCH_IMX8) += \ fsl-imx8qxp-colibri.dtb \ fsl-imx8qxp-mek.dtb
-dtb-$(CONFIG_ARCH_IMX8M) += fsl-imx8mq-evk.dtb +dtb-$(CONFIG_ARCH_IMX8M) += \ + fsl-imx8mq-evk.dtb \ + imx8mq-nitrogen8m.dtb
dtb-$(CONFIG_RCAR_GEN2) += \ r8a7790-lager-u-boot.dtb \ diff --git a/arch/arm/dts/imx8mq-nitrogen8m.dts b/arch/arm/dts/imx8mq-nitrogen8m.dts new file mode 100644 index 0000000000..a5b0c386e3 --- /dev/null +++ b/arch/arm/dts/imx8mq-nitrogen8m.dts @@ -0,0 +1,363 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright 2018 Boundary Devices + */ + +/dts-v1/; + +/* First 128KB is for PSCI ATF. */ +/memreserve/ 0x40000000 0x00020000; + +#include "fsl-imx8mq.dtsi" + +/ { + model = "Boundary Devices i.MX8MQ Nitrogen8M"; + compatible = "boundary,imx8mq-nitrogen8m", "fsl,imx8mq"; + + chosen { + bootargs = "console=ttymxc0,115200"; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + power { + label = "Power Button"; + gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + gpio-key,wakeup; + }; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + reg_vref_1v8: regulator-vref-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vref-1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + iomuxc-pinctrlgrp { + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x23 + MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x19 + MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x59 + >; + }; + + pinctrl_gpio_keys: gpio-keysgrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO07_GPIO1_IO7 0x19 + >; + }; + + pinctrl_hog: hoggrp { + fsl,pins = < + /* J17 connector, odd */ + MX8MQ_IOMUXC_SAI1_RXFS_GPIO4_IO0 0x19 /* Pin 19 */ + MX8MQ_IOMUXC_SAI1_RXC_GPIO4_IO1 0x19 /* Pin 21 */ + MX8MQ_IOMUXC_SAI1_RXD1_GPIO4_IO3 0x19 /* Pin 23 */ + MX8MQ_IOMUXC_SAI1_RXD2_GPIO4_IO4 0x19 /* Pin 25 */ + MX8MQ_IOMUXC_SAI1_RXD3_GPIO4_IO5 0x19 /* Pin 27 */ + MX8MQ_IOMUXC_SAI1_RXD4_GPIO4_IO6 0x19 /* Pin 29 */ + MX8MQ_IOMUXC_SAI1_RXD5_GPIO4_IO7 0x19 /* Pin 31 */ + MX8MQ_IOMUXC_SAI1_RXD6_GPIO4_IO8 0x19 /* Pin 33 */ + MX8MQ_IOMUXC_SAI1_RXD7_GPIO4_IO9 0x19 /* Pin 35 */ + MX8MQ_IOMUXC_SAI1_TXD1_GPIO4_IO13 0x19 /* Pin 39 */ + MX8MQ_IOMUXC_SAI1_TXD2_GPIO4_IO14 0x19 /* Pin 41 */ + MX8MQ_IOMUXC_SAI1_TXD3_GPIO4_IO15 0x19 /* Pin 43 */ + MX8MQ_IOMUXC_SAI1_TXD4_GPIO4_IO16 0x19 /* Pin 45 */ + MX8MQ_IOMUXC_SAI1_TXD5_GPIO4_IO17 0x19 /* Pin 47 */ + MX8MQ_IOMUXC_SAI1_TXD6_GPIO4_IO18 0x19 /* Pin 49 */ + MX8MQ_IOMUXC_SAI1_TXD7_GPIO4_IO19 0x19 /* Pin 51 */ + + /* J17 connector, even */ + MX8MQ_IOMUXC_SAI3_RXFS_GPIO4_IO28 0x19 /* Pin 44 */ + MX8MQ_IOMUXC_SAI3_RXC_GPIO4_IO29 0x19 /* Pin 48 */ + MX8MQ_IOMUXC_GPIO1_IO10_GPIO1_IO10 0x19 /* Pin 50 */ + MX8MQ_IOMUXC_GPIO1_IO03_GPIO1_IO3 0x19 /* Pin 54 */ + MX8MQ_IOMUXC_GPIO1_IO05_GPIO1_IO5 0x19 /* Pin 56 */ + + /* J18 connector, odd */ + MX8MQ_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x19 /* Pin 41 */ + MX8MQ_IOMUXC_NAND_CLE_GPIO3_IO5 0x19 /* Pin 43 */ + MX8MQ_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 /* Pin 45 */ + MX8MQ_IOMUXC_NAND_DATA05_GPIO3_IO11 0x19 /* Pin 47 */ + MX8MQ_IOMUXC_NAND_WP_B_GPIO3_IO18 0x19 /* Pin 49 */ + MX8MQ_IOMUXC_NAND_DQS_GPIO3_IO14 0x19 /* Pin 53 */ + + /* J18 connector, even */ + MX8MQ_IOMUXC_NAND_ALE_GPIO3_IO0 0x19 /* Pin 32 */ + MX8MQ_IOMUXC_NAND_CE0_B_GPIO3_IO1 0x19 /* Pin 36 */ + MX8MQ_IOMUXC_NAND_DATA00_GPIO3_IO6 0x19 /* Pin 38 */ + MX8MQ_IOMUXC_NAND_DATA01_GPIO3_IO7 0x19 /* Pin 40 */ + MX8MQ_IOMUXC_NAND_DATA02_GPIO3_IO8 0x19 /* Pin 42 */ + MX8MQ_IOMUXC_NAND_DATA03_GPIO3_IO9 0x19 /* Pin 44 */ + MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x19 /* Pin 46 */ + + /* J13 Pin 2, WL_WAKE */ + MX8MQ_IOMUXC_SAI5_RXD2_GPIO3_IO23 0xd6 + /* J13 Pin 4, WL_IRQ, not needed for Silex */ + MX8MQ_IOMUXC_SAI5_RXD0_GPIO3_IO21 0xd6 + /* J13 pin 9, unused */ + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x19 + /* J13 Pin 41, BT_CLK_REQ */ + MX8MQ_IOMUXC_SAI5_RXD1_GPIO3_IO22 0xd6 + /* J13 Pin 42, BT_HOST_WAKE */ + MX8MQ_IOMUXC_SAI5_MCLK_GPIO3_IO25 0xd6 + + /* Clock for both CSI1 and CSI2 */ + MX8MQ_IOMUXC_GPIO1_IO15_CCMSRCGPCMIX_CLKO2 0x07 + /* test points */ + MX8MQ_IOMUXC_GPIO1_IO04_GPIO1_IO4 0xc1 /* TP87 */ + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x4000007f + MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x4000007f + >; + }; + + pinctrl_i2c1_pca9546: i2c1-pca9546grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO08_GPIO1_IO8 0x49 + >; + }; + + pinctrl_i2c1d_rv4162: i2c1d-rv4162grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO06_GPIO1_IO6 0x49 + >; + }; + + pinctrl_reg_arm_dram: reg-arm-dram { + fsl,pins = < + MX8MQ_IOMUXC_SAI5_RXD3_GPIO3_IO24 0x16 + >; + }; + + pinctrl_reg_dram_1p1v: reg-dram-1p1v { + fsl,pins = < + MX8MQ_IOMUXC_SD1_STROBE_GPIO2_IO11 0x16 + >; + }; + + pinctrl_reg_soc_gpu_vpu: reg-soc-gpu-vpu { + fsl,pins = < + MX8MQ_IOMUXC_SD2_WP_GPIO2_IO20 0x16 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 + MX8MQ_IOMUXC_SD1_RESET_B_GPIO2_IO10 0x41 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@4 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <4>; + interrupts-extended = <&gpio1 11 IRQ_TYPE_LEVEL_LOW>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + i2cmux@70 { + compatible = "pca9546"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1_pca9546>; + reg = <0x70>; + reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; + #address-cells = <1>; + #size-cells = <0>; + + i2c1a: i2c1@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1b: i2c1@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1c: i2c1@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1d: i2c1@3 { + reg = <3>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; + +&i2c1a { + reg_arm_dram: fan53555@60 { + compatible = "fcs,fan53555"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_arm_dram>; + reg = <0x60>; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + vsel-gpios = <&gpio3 24 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c1b { + reg_dram_1p1v: fan53555@60 { + compatible = "fcs,fan53555"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_dram_1p1v>; + reg = <0x60>; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + vsel-gpios = <&gpio2 11 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c1c { + reg_soc_gpu_vpu: fan53555@60 { + compatible = "fcs,fan53555"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_soc_gpu_vpu>; + reg = <0x60>; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + vsel-gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; + }; +}; + +&i2c1d { + rtc@68 { + compatible = "microcrystal,rv4162"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1d_rv4162>; + reg = <0x68>; + interrupts-extended = <&gpio1 6 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&usdhc1 { + bus-width = <8>; + no-mmc-hs400; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + reset-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>; + non-removable; + vqmmc-1-8-v; + vmmc-supply = <®_vref_1v8>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 317dee9bc1..44b92e9fa4 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -16,8 +16,14 @@ config TARGET_IMX8MQ_EVK select IMX8M select IMX8M_LPDDR4
+config TARGET_NITROGEN8M + bool "nitrogen8m" + select IMX8M + select IMX8M_LPDDR4 + endchoice
source "board/freescale/imx8mq_evk/Kconfig" +source "board/boundary/nitrogen8m/Kconfig"
endif diff --git a/board/boundary/nitrogen8m/Kconfig b/board/boundary/nitrogen8m/Kconfig new file mode 100644 index 0000000000..1c799f620a --- /dev/null +++ b/board/boundary/nitrogen8m/Kconfig @@ -0,0 +1,16 @@ +if TARGET_NITROGEN8M + +config SYS_BOARD + default "nitrogen8m" + +config SYS_VENDOR + default "boundary" + +config SYS_CONFIG_NAME + default "nitrogen8m" + +config DDR_RANK_BITS + int "ddr rank bits" + default 1 + +endif diff --git a/board/boundary/nitrogen8m/Makefile b/board/boundary/nitrogen8m/Makefile new file mode 100644 index 0000000000..b8c69c96ad --- /dev/null +++ b/board/boundary/nitrogen8m/Makefile @@ -0,0 +1,12 @@ +# +# Copyright 2016 Freescale Semiconductor +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += nitrogen8m.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-y += lpddr4_timing.o +endif diff --git a/board/boundary/nitrogen8m/lpddr4_timing.c b/board/boundary/nitrogen8m/lpddr4_timing.c new file mode 100644 index 0000000000..d1eba580af --- /dev/null +++ b/board/boundary/nitrogen8m/lpddr4_timing.c @@ -0,0 +1,1250 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 NXP + */ +#include <linux/kernel.h> +#include <common.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +#define DDR_BOOT_P1 /* default DDR boot frequency point */ + +#define WR_POST_EXT_3200 +#ifdef WR_POST_EXT_3200 // recommend to define +#define VAL_INIT4 ((LPDDR4_MR3 << 16) | 0x00020008) +#else +#define VAL_INIT4 ((LPDDR4_MR3 << 16) | 0x00000008) +#endif + +#ifdef LPDDR4_CS +#undef LPDDR4_CS +#endif + +#if CONFIG_DDR_RANK_BITS == 0 +#define LPDDR4_CS 0x1 /* 0 rank bits, 1 chip select */ +#if CONFIG_DDR_MB == 2048 + /* Address map is from MSB 28: r15, r14, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x0000001F +#define VAL_DDRC_ADDRMAP6 0x07070707 +#else +#error unsupported memory size +#endif +#elif CONFIG_DDR_RANK_BITS == 1 +#define LPDDR4_CS 0x3 /* 1 rank bit, 2 chip selects */ +#if CONFIG_DDR_MB == 2048 + /* Address map is from MSB 28: cs, r14, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x00000016 +#define VAL_DDRC_ADDRMAP6 0x0f070707 +#elif CONFIG_DDR_MB == 3072 + /* Address map is from MSB 29: r15, r14, cs, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x00000015 +#define VAL_DDRC_ADDRMAP6 0x48080707 +#elif CONFIG_DDR_MB == 4096 + /* Address map is from MSB 29: cs, r15, r14, r13-r0, b2-b0, c9-c0 */ +#define VAL_DDRC_ADDRMAP0 0x00000017 +#define VAL_DDRC_ADDRMAP6 0x07070707 +#else +#error unsupported memory size +#endif +#else +#error unsupported rank bits +#endif + +static struct dram_cfg_param lpddr4_ddrc_cfg[] = { + /* Start to config, default 3200mbps */ + /* dis_dq=1, indicates no reads or writes are issued to SDRAM */ + { DDRC_DBG1(0), 0x00000001 }, + /* selfref_en=1, SDRAM enter self-refresh state */ + { DDRC_PWRCTL(0), 0x00000001 }, + { DDRC_MSTR(0), 0xa0080020 | (LPDDR4_CS << 24) }, + { DDRC_MSTR2(0), 0x00000000 }, + { DDRC_DERATEEN(0), 0x00000203 }, + { DDRC_DERATEINT(0), 0x0186A000 }, + { DDRC_RFSHTMG(0), 0x006100E0 }, + { DDRC_INIT0(0), 0xC003061C }, + { DDRC_INIT1(0), 0x009E0000 }, + { DDRC_INIT3(0), 0x00D4002D }, + { DDRC_INIT4(0), VAL_INIT4 }, + { DDRC_INIT6(0), 0x0066004A }, + { DDRC_INIT7(0), 0x0016004A }, + + { DDRC_DRAMTMG0(0), 0x1A201B22 }, + { DDRC_DRAMTMG1(0), 0x00060633 }, + { DDRC_DRAMTMG3(0), 0x00C0C000 }, + { DDRC_DRAMTMG4(0), 0x0F04080F }, + { DDRC_DRAMTMG5(0), 0x02040C0C }, + { DDRC_DRAMTMG6(0), 0x01010007 }, + { DDRC_DRAMTMG7(0), 0x00000401 }, + { DDRC_DRAMTMG12(0), 0x00020600 }, + { DDRC_DRAMTMG13(0), 0x0C100002 }, + { DDRC_DRAMTMG14(0), 0x000000E6 }, + { DDRC_DRAMTMG17(0), 0x00A00050 }, + + { DDRC_ZQCTL0(0), 0xC3200018 }, + { DDRC_ZQCTL1(0), 0x028061A8 }, + { DDRC_ZQCTL2(0), 0x00000000 }, + + { DDRC_DFITMG0(0), 0x0497820A }, + { DDRC_DFITMG1(0), 0x00080303 }, + { DDRC_DFIUPD0(0), 0xE0400018 }, + { DDRC_DFIUPD1(0), 0x00DF00E4 }, + { DDRC_DFIUPD2(0), 0x80000000 }, + { DDRC_DFIMISC(0), 0x00000011 }, + { DDRC_DFITMG2(0), 0x0000170A }, + + { DDRC_DBICTL(0), 0x00000001 }, + { DDRC_DFIPHYMSTR(0), 0x00000001 }, + + /* need be refined by ddrphy trained value */ + { DDRC_RANKCTL(0), 0x639 }, + { DDRC_DRAMTMG2(0), 0x070e1214 }, + + /* address mapping */ + { DDRC_ADDRMAP0(0), VAL_DDRC_ADDRMAP0 }, + { DDRC_ADDRMAP3(0), 0x00000000 }, + /* addrmap_col_b10 and addrmap_col_b11 set to de-activated (5-bit width) */ + { DDRC_ADDRMAP4(0), 0x00001F1F }, + /* bank interleave */ + /* addrmap_bank_b2, addrmap_bank_b1, addrmap_bank_b0 */ + { DDRC_ADDRMAP1(0), 0x00080808 }, + /* addrmap_row_b11, addrmap_row_b10_b2, addrmap_row_b1, addrmap_row_b0 */ + { DDRC_ADDRMAP5(0), 0x07070707 }, + /* addrmap_row_b15, addrmap_row_b14, addrmap_row_b13, addrmap_row_b12 */ + { DDRC_ADDRMAP6(0), VAL_DDRC_ADDRMAP6 }, + { DDRC_ADDRMAP7(0), 0x00000f0f }, + + /* 667mts frequency setting */ + { DDRC_FREQ1_DERATEEN(0), 0x0000001 }, + { DDRC_FREQ1_DERATEINT(0), 0x00518B00 }, + { DDRC_FREQ1_RFSHCTL0(0), 0x0020D040 }, + { DDRC_FREQ1_RFSHTMG(0), 0x0014002F }, + { DDRC_FREQ1_INIT3(0), 0x00940009 }, + { DDRC_FREQ1_INIT4(0), VAL_INIT4 }, + { DDRC_FREQ1_INIT6(0), 0x0066004A }, + { DDRC_FREQ1_INIT7(0), 0x0016004A }, + { DDRC_FREQ1_DRAMTMG0(0), 0x0B070508 }, + { DDRC_FREQ1_DRAMTMG1(0), 0x0003040B }, + { DDRC_FREQ1_DRAMTMG2(0), 0x0305090C }, + { DDRC_FREQ1_DRAMTMG3(0), 0x00505000 }, + { DDRC_FREQ1_DRAMTMG4(0), 0x04040204 }, + { DDRC_FREQ1_DRAMTMG5(0), 0x02030303 }, + { DDRC_FREQ1_DRAMTMG6(0), 0x01010004 }, + { DDRC_FREQ1_DRAMTMG7(0), 0x00000301 }, + { DDRC_FREQ1_DRAMTMG12(0), 0x00020300 }, + { DDRC_FREQ1_DRAMTMG13(0), 0x0A100002 }, + { DDRC_FREQ1_DRAMTMG14(0), 0x00000031 }, + { DDRC_FREQ1_DRAMTMG17(0), 0x00220011 }, + { DDRC_FREQ1_ZQCTL0(0), 0xC0A70006 }, + { DDRC_FREQ1_DFITMG0(0), 0x03858202 }, + { DDRC_FREQ1_DFITMG1(0), 0x00080303 }, + { DDRC_FREQ1_DFITMG2(0), 0x00000502 }, + + /* 100mts frequency setting */ + { DDRC_FREQ2_DERATEEN(0), 0x0000001 }, + { DDRC_FREQ2_DERATEINT(0), 0x000C3500 }, + { DDRC_FREQ2_RFSHCTL0(0), 0x0020D040 }, + { DDRC_FREQ2_RFSHTMG(0), 0x00030007 }, + { DDRC_FREQ2_INIT3(0), 0x00840000 }, + { DDRC_FREQ2_INIT4(0), VAL_INIT4 }, + { DDRC_FREQ2_INIT6(0), 0x0066004A }, + { DDRC_FREQ2_INIT7(0), 0x0016004A }, + { DDRC_FREQ2_DRAMTMG0(0), 0x0A010102 }, + { DDRC_FREQ2_DRAMTMG1(0), 0x00030404 }, + { DDRC_FREQ2_DRAMTMG2(0), 0x0203060B }, + { DDRC_FREQ2_DRAMTMG3(0), 0x00505000 }, + { DDRC_FREQ2_DRAMTMG4(0), 0x02040202 }, + { DDRC_FREQ2_DRAMTMG5(0), 0x02030202 }, + { DDRC_FREQ2_DRAMTMG6(0), 0x01010004 }, + { DDRC_FREQ2_DRAMTMG7(0), 0x00000301 }, + { DDRC_FREQ2_DRAMTMG12(0), 0x00020300 }, + { DDRC_FREQ2_DRAMTMG13(0), 0x0A100002 }, + { DDRC_FREQ2_DRAMTMG14(0), 0x00000008 }, + { DDRC_FREQ2_DRAMTMG17(0), 0x00050003 }, + { DDRC_FREQ2_ZQCTL0(0), 0xC0190004 }, + { DDRC_FREQ2_DFITMG0(0), 0x03818200 }, + { DDRC_FREQ2_DFITMG1(0), 0x00080303 }, + { DDRC_FREQ2_DFITMG2(0), 0x00000100 }, + + /* performance setting */ + { DDRC_ODTCFG(0), 0x0b060908 }, + { DDRC_ODTMAP(0), 0x00000000 }, + { DDRC_SCHED(0), 0x29001505 }, + { DDRC_SCHED1(0), 0x0000002c }, + { DDRC_PERFHPR1(0), 0x5900575b }, + /* 150T starve and 0x90 max tran len */ + { DDRC_PERFLPR1(0), 0x90000096 }, + /* 300T starve and 0x10 max tran len */ + { DDRC_PERFWR1(0), 0x1000012c }, + + { DDRC_DBG0(0), 0x00000016 }, + { DDRC_DBG1(0), 0x00000000 }, + { DDRC_DBGCMD(0), 0x00000000 }, + { DDRC_SWCTL(0), 0x00000001 }, + { DDRC_POISONCFG(0), 0x00000011 }, + { DDRC_PCCFG(0), 0x00000111 }, + { DDRC_PCFGR_0(0), 0x000010f3 }, + { DDRC_PCFGW_0(0), 0x000072ff }, + { DDRC_PCTRL_0(0), 0x00000001 }, + /* disable Read Qos*/ + { DDRC_PCFGQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGQOS1_0(0), 0x0062ffff }, + /* disable Write Qos*/ + { DDRC_PCFGWQOS0_0(0), 0x00000e00 }, + { DDRC_PCFGWQOS1_0(0), 0x0000ffff }, + + /* boot start point */ +#ifdef DDR_BOOT_P2 + { DDRC_MSTR2(0), 0x2 }, +#elif defined(DDR_BOOT_P1) + { DDRC_MSTR2(0), 0x1 }, +#endif +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param lpddr4_ddrphy_cfg[] = { + { 0x20110, 0x02 }, /* MapCAB0toDFI */ + { 0x20111, 0x03 }, /* MapCAB1toDFI */ + { 0x20112, 0x04 }, /* MapCAB2toDFI */ + { 0x20113, 0x05 }, /* MapCAB3toDFI */ + { 0x20114, 0x00 }, /* MapCAB4toDFI */ + { 0x20115, 0x01 }, /* MapCAB5toDFI */ + + /* Initialize PHY Configuration */ + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + + { 0x2002e, 0x2 }, + { 0x12002e, 0x1 }, + { 0x22002e, 0x2 }, + + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + + { 0x20024, 0xe3 }, + { 0x2003a, 0x2 }, + + { 0x120024, 0xa3 }, + { 0x2003a, 0x2 }, + + { 0x220024, 0xa3 }, + { 0x2003a, 0x2 }, + + { 0x20056, 0x3 }, + { 0x120056, 0xa }, + { 0x220056, 0xa }, + + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + + { 0x10049, 0xfbe }, + { 0x10149, 0xfbe }, + { 0x11049, 0xfbe }, + { 0x11149, 0xfbe }, + { 0x12049, 0xfbe }, + { 0x12149, 0xfbe }, + { 0x13049, 0xfbe }, + { 0x13149, 0xfbe }, + + { 0x110049, 0xfbe }, + { 0x110149, 0xfbe }, + { 0x111049, 0xfbe }, + { 0x111149, 0xfbe }, + { 0x112049, 0xfbe }, + { 0x112149, 0xfbe }, + { 0x113049, 0xfbe }, + { 0x113149, 0xfbe }, + + { 0x210049, 0xfbe }, + { 0x210149, 0xfbe }, + { 0x211049, 0xfbe }, + { 0x211149, 0xfbe }, + { 0x212049, 0xfbe }, + { 0x212149, 0xfbe }, + { 0x213049, 0xfbe }, + { 0x213149, 0xfbe }, + + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0xa7 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0x104 }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0x104 }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0x104 }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x600 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5655 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, +}; + +/* P0 message block parameter for training firmware */ +static struct dram_cfg_param lpddr4_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x131f }, + { 0x54009, LPDDR4_HDT_CTL_3200_1D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_1d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x10 | (LPDDR4_CS << 8) }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, LPDDR4_CS }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800 | LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +static struct dram_cfg_param lpddr4_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x61 }, + { 0x54009, LPDDR4_HDT_CTL_2D }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, (LPDDR4_CATRAIN_3200_2d << 8) }, + { 0x5400e, 0x0 }, + { 0x5400f, (LPDDR4_2D_SHARE << 8) | 0x00 }, + { 0x54010, LPDDR4_2D_WEIGHT }, + { 0x54011, 0x0 }, + { 0x54012, 0x10 | (LPDDR4_CS << 8) }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54024, 0x5 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401d, 0x0 }, + { 0x5401e, LPDDR4_MR22_RANK0 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x3) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, LPDDR4_CS }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0xd400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, (LPDDR4_MR22_RANK0 << 8) }, + { 0x54038, 0xd400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x3) << 8) | 0x2d }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0x54044, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block parameter for training firmware */ +static struct dram_cfg_param lpddr4_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54000, 0x0 }, + { 0x54001, 0x0 }, + { 0x54002, 0x1 }, + { 0x54003, 0x29c }, + { 0x54004, 0x2 }, + { 0x54005, ((LPDDR4_PHY_RON << 8) | LPDDR4_PHY_RTT) }, + { 0x54006, LPDDR4_PHY_VREF_VALUE }, + { 0x54007, 0x0 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400a, 0x0 }, + { 0x5400b, 0x2 }, + { 0x5400c, 0x0 }, + { 0x5400d, 0x0 }, + { 0x5400e, 0x0 }, + { 0x5400f, 0x0 }, + { 0x54010, 0x0 }, + { 0x54011, 0x0 }, + { 0x54012, 0x10 | (LPDDR4_CS << 8) }, + { 0x54013, 0x0 }, + { 0x54014, 0x0 }, + { 0x54015, 0x0 }, + { 0x54016, 0x0 }, + { 0x54017, 0x0 }, + { 0x54018, 0x0 }, + { 0x54019, 0x914 }, + { 0x5401a, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x5401b, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) }, + { 0x5401c, ((LPDDR4_VREF_VALUE_DQ_RANK0 << 8) | 0x08) }, + { 0x5401e, 0x6 }, + { 0x5401f, 0x914 }, + { 0x54020, (((LPDDR4_RON) << 3) | 0x1) }, + { 0x54021, ((LPDDR4_VREF_VALUE_CA << 8) | (LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) }, + { 0x54022, ((LPDDR4_VREF_VALUE_DQ_RANK1 << 8) | 0x08) }, + { 0x54023, 0x0 }, + { 0x54024, LPDDR4_MR22_RANK1 }, + { 0x54025, 0x0 }, + { 0x54026, 0x0 }, + { 0x54027, 0x0 }, + { 0x54028, 0x0 }, + { 0x54029, 0x0 }, + { 0x5402a, 0x0 }, + { 0x5402b, 0x1000 }, + { 0x5402c, LPDDR4_CS }, + { 0x5402d, 0x0 }, + { 0x5402e, 0x0 }, + { 0x5402f, 0x0 }, + { 0x54030, 0x0 }, + { 0x54031, 0x0 }, + { 0x54032, 0x1400 }, + { 0x54033, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 }, + { 0x54034, (((LPDDR4_RTT_CA_BANK0 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x54035, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x54036, LPDDR4_VREF_VALUE_DQ_RANK0 }, + { 0x54037, 0x600 }, + { 0x54038, 0x1400 }, + { 0x54039, ((((LPDDR4_RON) << 3) | 0x1) << 8) | 0x09 }, + { 0x5403a, (((LPDDR4_RTT_CA_BANK1 << 4) | LPDDR4_RTT_DQ) << 8) }, + { 0x5403b, (0x0800|LPDDR4_VREF_VALUE_CA) }, + { 0x5403c, LPDDR4_VREF_VALUE_DQ_RANK1 }, + { 0x5403d, (LPDDR4_MR22_RANK1 << 8) }, + { 0x5403e, 0x0 }, + { 0x5403f, 0x0 }, + { 0x54040, 0x0 }, + { 0x54041, 0x0 }, + { 0x54042, 0x0 }, + { 0x54043, 0x0 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param lpddr4_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xb }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0xd }, + { 0x900a5, 0x7c0 }, + { 0x900a6, 0x109 }, + { 0x900a7, 0x4 }, + { 0x900a8, 0x7c0 }, + { 0x900a9, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900aa, 0x0 }, + { 0x900ab, 0x790 }, + { 0x900ac, 0x11a }, + { 0x900ad, 0x8 }, + { 0x900ae, 0x7aa }, + { 0x900af, 0x2a }, + { 0x900b0, 0x10 }, + { 0x900b1, 0x7b2 }, + { 0x900b2, 0x2a }, + { 0x900b3, 0x0 }, + { 0x900b4, 0x7c8 }, + { 0x900b5, 0x109 }, + { 0x900b6, 0x10 }, + { 0x900b7, 0x10 }, + { 0x900b8, 0x109 }, + { 0x900b9, 0x10 }, + { 0x900ba, 0x2a8 }, + { 0x900bb, 0x129 }, + { 0x900bc, 0x8 }, + { 0x900bd, 0x370 }, + { 0x900be, 0x129 }, + { 0x900bf, 0xa }, + { 0x900c0, 0x3c8 }, + { 0x900c1, 0x1a9 }, + { 0x900c2, 0xc }, + { 0x900c3, 0x408 }, + { 0x900c4, 0x199 }, + { 0x900c5, 0x14 }, + { 0x900c6, 0x790 }, + { 0x900c7, 0x11a }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x4 }, + { 0x900ca, 0x18 }, + { 0x900cb, 0xe }, + { 0x900cc, 0x408 }, + { 0x900cd, 0x199 }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x8568 }, + { 0x900d0, 0x108 }, + { 0x900d1, 0x18 }, + { 0x900d2, 0x790 }, + { 0x900d3, 0x16a }, + { 0x900d4, 0x8 }, + { 0x900d5, 0x1d8 }, + { 0x900d6, 0x169 }, + { 0x900d7, 0x10 }, + { 0x900d8, 0x8558 }, + { 0x900d9, 0x168 }, + { 0x900da, 0x70 }, + { 0x900db, 0x788 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x1ff8 }, + { 0x900de, 0x85a8 }, + { 0x900df, 0x1e8 }, + { 0x900e0, 0x50 }, + { 0x900e1, 0x798 }, + { 0x900e2, 0x16a }, + { 0x900e3, 0x60 }, + { 0x900e4, 0x7a0 }, + { 0x900e5, 0x16a }, + { 0x900e6, 0x8 }, + { 0x900e7, 0x8310 }, + { 0x900e8, 0x168 }, + { 0x900e9, 0x8 }, + { 0x900ea, 0xa310 }, + { 0x900eb, 0x168 }, + { 0x900ec, 0xa }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x6e }, + { 0x900f0, 0x0 }, + { 0x900f1, 0x68 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0x408 }, + { 0x900f4, 0x169 }, + { 0x900f5, 0x0 }, + { 0x900f6, 0x8310 }, + { 0x900f7, 0x168 }, + { 0x900f8, 0x0 }, + { 0x900f9, 0xa310 }, + { 0x900fa, 0x168 }, + { 0x900fb, 0x1ff8 }, + { 0x900fc, 0x85a8 }, + { 0x900fd, 0x1e8 }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x798 }, + { 0x90100, 0x16a }, + { 0x90101, 0x78 }, + { 0x90102, 0x7a0 }, + { 0x90103, 0x16a }, + { 0x90104, 0x68 }, + { 0x90105, 0x790 }, + { 0x90106, 0x16a }, + { 0x90107, 0x8 }, + { 0x90108, 0x8b10 }, + { 0x90109, 0x168 }, + { 0x9010a, 0x8 }, + { 0x9010b, 0xab10 }, + { 0x9010c, 0x168 }, + { 0x9010d, 0xa }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x58 }, + { 0x90111, 0x0 }, + { 0x90112, 0x68 }, + { 0x90113, 0x0 }, + { 0x90114, 0x408 }, + { 0x90115, 0x169 }, + { 0x90116, 0x0 }, + { 0x90117, 0x8b10 }, + { 0x90118, 0x168 }, + { 0x90119, 0x0 }, + { 0x9011a, 0xab10 }, + { 0x9011b, 0x168 }, + { 0x9011c, 0x0 }, + { 0x9011d, 0x1d8 }, + { 0x9011e, 0x169 }, + { 0x9011f, 0x80 }, + { 0x90120, 0x790 }, + { 0x90121, 0x16a }, + { 0x90122, 0x18 }, + { 0x90123, 0x7aa }, + { 0x90124, 0x6a }, + { 0x90125, 0xa }, + { 0x90126, 0x0 }, + { 0x90127, 0x1e9 }, + { 0x90128, 0x8 }, + { 0x90129, 0x8080 }, + { 0x9012a, 0x108 }, + { 0x9012b, 0xf }, + { 0x9012c, 0x408 }, + { 0x9012d, 0x169 }, + { 0x9012e, 0xc }, + { 0x9012f, 0x0 }, + { 0x90130, 0x68 }, + { 0x90131, 0x9 }, + { 0x90132, 0x0 }, + { 0x90133, 0x1a9 }, + { 0x90134, 0x0 }, + { 0x90135, 0x408 }, + { 0x90136, 0x169 }, + { 0x90137, 0x0 }, + { 0x90138, 0x8080 }, + { 0x90139, 0x108 }, + { 0x9013a, 0x8 }, + { 0x9013b, 0x7aa }, + { 0x9013c, 0x6a }, + { 0x9013d, 0x0 }, + { 0x9013e, 0x8568 }, + { 0x9013f, 0x108 }, + { 0x90140, 0xb7 }, + { 0x90141, 0x790 }, + { 0x90142, 0x16a }, + { 0x90143, 0x1f }, + { 0x90144, 0x0 }, + { 0x90145, 0x68 }, + { 0x90146, 0x8 }, + { 0x90147, 0x8558 }, + { 0x90148, 0x168 }, + { 0x90149, 0xf }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0xc }, + { 0x9014d, 0x0 }, + { 0x9014e, 0x68 }, + { 0x9014f, 0x0 }, + { 0x90150, 0x408 }, + { 0x90151, 0x169 }, + { 0x90152, 0x0 }, + { 0x90153, 0x8558 }, + { 0x90154, 0x168 }, + { 0x90155, 0x8 }, + { 0x90156, 0x3c8 }, + { 0x90157, 0x1a9 }, + { 0x90158, 0x3 }, + { 0x90159, 0x370 }, + { 0x9015a, 0x129 }, + { 0x9015b, 0x20 }, + { 0x9015c, 0x2aa }, + { 0x9015d, 0x9 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x400 }, + { 0x90160, 0x10e }, + { 0x90161, 0x8 }, + { 0x90162, 0xe8 }, + { 0x90163, 0x109 }, + { 0x90164, 0x0 }, + { 0x90165, 0x8140 }, + { 0x90166, 0x10c }, + { 0x90167, 0x10 }, + { 0x90168, 0x8138 }, + { 0x90169, 0x10c }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x7c8 }, + { 0x9016c, 0x101 }, + { 0x9016d, 0x8 }, + { 0x9016e, 0x0 }, + { 0x9016f, 0x8 }, + { 0x90170, 0x8 }, + { 0x90171, 0x448 }, + { 0x90172, 0x109 }, + { 0x90173, 0xf }, + { 0x90174, 0x7c0 }, + { 0x90175, 0x109 }, + { 0x90176, 0x0 }, + { 0x90177, 0xe8 }, + { 0x90178, 0x109 }, + { 0x90179, 0x47 }, + { 0x9017a, 0x630 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x8 }, + { 0x9017d, 0x618 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0xe0 }, + { 0x90181, 0x109 }, + { 0x90182, 0x0 }, + { 0x90183, 0x7c8 }, + { 0x90184, 0x109 }, + { 0x90185, 0x8 }, + { 0x90186, 0x8140 }, + { 0x90187, 0x10c }, + { 0x90188, 0x0 }, + { 0x90189, 0x1 }, + { 0x9018a, 0x8 }, + { 0x9018b, 0x8 }, + { 0x9018c, 0x4 }, + { 0x9018d, 0x8 }, + { 0x9018e, 0x8 }, + { 0x9018f, 0x7c8 }, + { 0x90190, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2b }, + { 0x90026, 0x6c }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0x14 }, + { 0x12000c, 0x29 }, + { 0x12000d, 0x1a1 }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x20089, 0x1 }, + { 0x20088, 0x19 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 }, +}; + +static struct dram_fsp_msg lpddr4_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = lpddr4_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp0_2d_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = lpddr4_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(lpddr4_fsp1_cfg), + }, +}; + +struct dram_timing_info dram_timing = { + .ddrc_cfg = lpddr4_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(lpddr4_ddrc_cfg), + .ddrphy_cfg = lpddr4_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(lpddr4_ddrphy_cfg), + .fsp_msg = lpddr4_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(lpddr4_dram_fsp_msg), + .ddrphy_pie = lpddr4_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(lpddr4_phy_pie), + .fsp_table = { 3200, 400, }, +}; diff --git a/board/boundary/nitrogen8m/nitrogen8m.c b/board/boundary/nitrogen8m/nitrogen8m.c new file mode 100644 index 0000000000..60d7a4eccc --- /dev/null +++ b/board/boundary/nitrogen8m/nitrogen8m.c @@ -0,0 +1,244 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2017-2018 NXP + */ + +#include <common.h> +#include <env.h> +#include <malloc.h> +#include <errno.h> +#include <asm/io.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/mach-imx/boot_mode.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm-generic/gpio.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/video.h> +#include <video_fb.h> +#include <spl.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define GPIRQ_ENET_PHY IMX_GPIO_NR(1, 2) +#define GPIRQ_GT911 IMX_GPIO_NR(3, 12) +#define GP_ARM_DRAM_VSEL IMX_GPIO_NR(3, 24) +#define GP_CSI1_MIPI_PWDN IMX_GPIO_NR(3, 3) +#define GP_CSI1_MIPI_RESET IMX_GPIO_NR(3, 17) +#define GP_CSI2_MIPI_PWDN IMX_GPIO_NR(3, 2) +#define GP_CSI2_MIPI_RESET IMX_GPIO_NR(2, 19) +#define GP_DRAM_1P1_VSEL IMX_GPIO_NR(2, 11) +#define GP_EMMC_RESET IMX_GPIO_NR(2, 10) +#define GP_FASTBOOT_KEY IMX_GPIO_NR(1, 7) +#define GP_GT911_RESET IMX_GPIO_NR(3, 13) +#define GP_I2C1_PCA9546_RESET IMX_GPIO_NR(1, 8) +#define GP_I2C4_SN65DSI83_EN IMX_GPIO_NR(3, 15) +#define GP_LCM_JM430_BKL_EN IMX_GPIO_NR(1, 1) +/* This enables 5V power on LTK080A60A004T mipi display */ +#define GP_LTK08_MIPI_EN IMX_GPIO_NR(1, 1) +#define GP_MIPI_RESET IMX_GPIO_NR(3, 15) +#define GP_RGMII_PHY_RESET IMX_GPIO_NR(1, 9) +#define GP_SOC_GPU_VPU_VSEL IMX_GPIO_NR(2, 20) +#define GP_ST1633_RESET IMX_GPIO_NR(3, 13) +#define GP_TC358762_EN IMX_GPIO_NR(3, 15) + +#define ENET_MDC_PAD_CTRL (PAD_CTL_DSE3) +#define ENET_MDIO_PAD_CTRL (PAD_CTL_DSE3 | PAD_CTL_ODE) +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define WEAK_PULLUP (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) + +static iomux_v3_cfg_t const init_pads[] = { + IMX8MQ_PAD_GPIO1_IO01__GPIO1_IO1 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), + IMX8MQ_PAD_GPIO1_IO07__GPIO1_IO7 | MUX_PAD_CTRL(WEAK_PULLUP), + IMX8MQ_PAD_GPIO1_IO08__GPIO1_IO8 | MUX_PAD_CTRL(0x49), + IMX8MQ_PAD_NAND_CE1_B__GPIO3_IO2 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_NAND_CE2_B__GPIO3_IO3 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_NAND_DATA06__GPIO3_IO12 | MUX_PAD_CTRL(0xd6), + IMX8MQ_PAD_NAND_DATA07__GPIO3_IO13 | MUX_PAD_CTRL(0x49), + IMX8MQ_PAD_NAND_RE_B__GPIO3_IO15 | MUX_PAD_CTRL(0x6), + IMX8MQ_PAD_NAND_WE_B__GPIO3_IO17 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_SAI5_RXD3__GPIO3_IO24 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(0x41), + IMX8MQ_PAD_SD1_STROBE__GPIO2_IO11 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(0x61), + IMX8MQ_PAD_SD2_WP__GPIO2_IO20 | MUX_PAD_CTRL(0x16), + IMX8MQ_PAD_UART1_RXD__UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART1_TXD__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(WEAK_PULLUP), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(init_pads, ARRAY_SIZE(init_pads)); + set_wdog_reset(wdog); + + gpio_direction_output(GP_ARM_DRAM_VSEL, 0); + gpio_direction_output(GP_DRAM_1P1_VSEL, 0); + gpio_direction_output(GP_SOC_GPU_VPU_VSEL, 0); + gpio_direction_output(GP_EMMC_RESET, 1); + gpio_direction_output(GP_I2C1_PCA9546_RESET, 0); + gpio_direction_output(GP_I2C4_SN65DSI83_EN, 0); + gpio_direction_output(GP_CSI1_MIPI_PWDN, 1); + gpio_direction_output(GP_CSI1_MIPI_RESET, 0); + gpio_direction_output(GP_CSI2_MIPI_PWDN, 1); + gpio_direction_output(GP_CSI2_MIPI_RESET, 0); + + return 0; +} + +#define MAX_LOW_SIZE (0x100000000ULL - CONFIG_SYS_SDRAM_BASE) +#define SDRAM_SIZE ((1ULL * CONFIG_DDR_MB) << 20) + +#if SDRAM_SIZE > MAX_LOW_SIZE +#define MEM_SIZE MAX_LOW_SIZE +#else +#define MEM_SIZE SDRAM_SIZE +#endif + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = SDRAM_SIZE; + return 0; +} + +int dram_init(void) +{ + /* rom_pointer[1] contains the size of TEE occupies */ + gd->ram_size = MEM_SIZE - rom_pointer[1]; + return 0; +} + +#ifdef CONFIG_FEC_MXC +static iomux_v3_cfg_t const fec1_strap_pads[] = { + IMX8MQ_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(WEAK_PULLUP), + IMX8MQ_PAD_ENET_RD0__GPIO1_IO26 | MUX_PAD_CTRL(0xd1), + IMX8MQ_PAD_ENET_RD1__GPIO1_IO27 | MUX_PAD_CTRL(0xd1), + IMX8MQ_PAD_ENET_RD2__GPIO1_IO28 | MUX_PAD_CTRL(0xd1), + IMX8MQ_PAD_ENET_RD3__GPIO1_IO29 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RX_CTL__GPIO1_IO24 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RXC__GPIO1_IO25 | MUX_PAD_CTRL(0xd1), +}; + +static iomux_v3_cfg_t const fec1_enet_pads[] = { + IMX8MQ_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(WEAK_PULLUP), + IMX8MQ_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_MDC_PAD_CTRL), + IMX8MQ_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_MDIO_PAD_CTRL), + IMX8MQ_PAD_ENET_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_RX_CTL__ENET_RGMII_RX_CTL | MUX_PAD_CTRL(0x91), + IMX8MQ_PAD_ENET_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(0x1f), + IMX8MQ_PAD_ENET_TX_CTL__ENET_RGMII_TX_CTL | MUX_PAD_CTRL(0x1f), +}; + +/* + * This sets up the AR8035 phy connected to the FEC. The phy + * samples the settings it is supposed to use from the TX/RX + * pins, which means that for a short amount of time we have + * to handle those pins as plain GPIOs before connecting them + * back to the ethernet controller. + */ +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + /* Pull PHY into reset */ + gpio_request(IMX_GPIO_NR(1, 9), "fec1_rst"); + gpio_direction_output(IMX_GPIO_NR(1, 9), 0); + + /* Set bootstrap pins for AR8035 */ + gpio_request(IMX_GPIO_NR(1, 26), "fec1_rd0"); + gpio_direction_output(IMX_GPIO_NR(1, 26), 0); + gpio_request(IMX_GPIO_NR(1, 27), "fec1_rd1"); + gpio_direction_output(IMX_GPIO_NR(1, 27), 0); + gpio_request(IMX_GPIO_NR(1, 28), "fec1_rd2"); + gpio_direction_output(IMX_GPIO_NR(1, 28), 0); + gpio_request(IMX_GPIO_NR(1, 29), "fec1_rd3"); + gpio_direction_output(IMX_GPIO_NR(1, 29), 1); + gpio_request(IMX_GPIO_NR(1, 24), "fec1_rx_ctl"); + gpio_direction_output(IMX_GPIO_NR(1, 24), 0); + gpio_request(IMX_GPIO_NR(1, 25), "fec1_rxc"); + gpio_direction_output(IMX_GPIO_NR(1, 25), 1); + imx_iomux_v3_setup_multiple_pads(fec1_strap_pads, + ARRAY_SIZE(fec1_strap_pads)); + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); + set_clk_enet(ENET_125MHZ); + udelay(1000); + + /* Release PHY from reset */ + gpio_direction_output(IMX_GPIO_NR(1, 9), 1); + udelay(500); + + /* Setup pins for ethernet */ + imx_iomux_v3_setup_multiple_pads(fec1_enet_pads, + ARRAY_SIZE(fec1_enet_pads)); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_init(void) +{ +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + + gpio_request(GP_I2C4_SN65DSI83_EN, "sn65dsi83_enable"); + gpio_request(GP_GT911_RESET, "gt911_reset"); + gpio_request(GPIRQ_GT911, "gt911_irq"); + gpio_request(GP_LTK08_MIPI_EN, "lkt08_mipi_en"); + gpio_direction_output(GP_GT911_RESET, 0); + + return 0; +} + +int board_mmc_get_env_dev(int devno) +{ + return 0; +} + +int board_late_init(void) +{ +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + env_set("board_name", "nitrogen8m"); +#endif + + return 0; +} diff --git a/board/boundary/nitrogen8m/spl.c b/board/boundary/nitrogen8m/spl.c new file mode 100644 index 0000000000..6a2840cb09 --- /dev/null +++ b/board/boundary/nitrogen8m/spl.c @@ -0,0 +1,232 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017 NXP + */ + +#include <common.h> +#include <asm/io.h> +#include <errno.h> +#include <asm/io.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void spl_dram_init(void) +{ + /* ddr init */ + ddr_init(&dram_timing); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + } + + return ret; +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC1_BASE_ADDR, 0, 8}, +}; + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + init_clk_usdhc(0); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +#define GP_I2C1_PCA9546_RESET IMX_GPIO_NR(1, 8) +#define GP_ARM_DRAM_VSEL IMX_GPIO_NR(3, 24) +#define GP_DRAM_1P1_VSEL IMX_GPIO_NR(2, 11) +#define GP_SOC_GPU_VPU_VSEL IMX_GPIO_NR(2, 20) + +#define I2C_MUX_ADDR 0x70 +#define I2C_FAN53555_ADDR 0x60 + +/* + * The FAN53555 option used here has a range of 0.6 V + * to 1.23 V configurable in 10 mV steps. + */ +#define FAN53555_VSEL_BUCK_EN 0x80 +#define FAN53555_VSEL_NSEL_0_9V 30 +#define FAN53555_VSEL_NSEL_1_0V 40 +#define FAN53555_VSEL_NSEL_1_1V 50 + +static iomux_v3_cfg_t const i2c1_pads[] = { + IMX8MQ_PAD_GPIO1_IO08__GPIO1_IO8 | MUX_PAD_CTRL(0x49), +}; + +int power_init_board(void) +{ + u8 val; + + imx_iomux_v3_setup_multiple_pads(i2c1_pads, ARRAY_SIZE(i2c1_pads)); + + gpio_set_value(GP_I2C1_PCA9546_RESET, 1); + gpio_set_value(GP_ARM_DRAM_VSEL, 0); + gpio_set_value(GP_DRAM_1P1_VSEL, 0); + gpio_set_value(GP_SOC_GPU_VPU_VSEL, 0); + + /* Switch Mux to I2C1A for ARM/DRAM buck */ + i2c_write(I2C_MUX_ADDR, 1, 1, NULL, 0); + val = FAN53555_VSEL_BUCK_EN | FAN53555_VSEL_NSEL_1_0V; + i2c_write(I2C_FAN53555_ADDR, 0, 1, &val, 1); + i2c_write(I2C_FAN53555_ADDR, 1, 1, &val, 1); + + /* Switch Mux to I2C1B for DRAM 1.1V buck */ + i2c_write(I2C_MUX_ADDR, 2, 1, NULL, 0); + val = FAN53555_VSEL_BUCK_EN | FAN53555_VSEL_NSEL_1_1V; + i2c_write(I2C_FAN53555_ADDR, 0, 1, &val, 1); + i2c_write(I2C_FAN53555_ADDR, 1, 1, &val, 1); + + /* Switch Mux to I2C1C for soc/gpu/vpu buck * */ + i2c_write(I2C_MUX_ADDR, 4, 1, NULL, 0); + val = FAN53555_VSEL_BUCK_EN | FAN53555_VSEL_NSEL_0_9V; + i2c_write(I2C_FAN53555_ADDR, 0, 1, &val, 1); + i2c_write(I2C_FAN53555_ADDR, 1, 1, &val, 1); + + /* Disable I2C1A-I2C1D */ + i2c_write(I2C_MUX_ADDR, 0, 1, NULL, 0); + + return 0; +} + +void spl_board_init(void) +{ + /* Serial download mode */ + if (is_usb_boot()) { + puts("Back to ROM, SDP\n"); + restore_boot_params(); + } + puts("Normal Boot\n"); +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + init_uart_clk(0); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + /* Adjust pmic voltage to 1.0V for 800M */ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + power_init_board(); + + /* DDR initialization */ + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/nitrogen8m_defconfig b/configs/nitrogen8m_defconfig new file mode 100644 index 0000000000..146102bb23 --- /dev/null +++ b/configs/nitrogen8m_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_NITROGEN8M=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage.cfg,DDR_MB=2048" +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_PARTITION_TYPE_GUID=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-nitrogen8m" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_I2C_MXC_I2C4=y +CONFIG_DM_MMC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_ATHEROS=y +CONFIG_DM_ETH=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y +CONFIG_DM_THERMAL=y diff --git a/include/configs/nitrogen8m.h b/include/configs/nitrogen8m.h new file mode 100644 index 0000000000..c78f72a624 --- /dev/null +++ b/include/configs/nitrogen8m.h @@ -0,0 +1,157 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018 Boundary Devices + */ + +#ifndef __NITROGEN8M_H +#define __NITROGEN8M_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> + +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_CSF_SIZE 0x2000 /* 8K region */ +#endif + +#define CONFIG_SPL_MAX_SIZE (124 * 1024) +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 + +#ifdef CONFIG_SPL_BUILD + +/*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 /* 512 KB */ +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#undef CONFIG_DM_MMC +#undef CONFIG_DM_PMIC +#undef CONFIG_DM_PMIC_PFUZE100 + +#define CONFIG_SYS_I2C +#endif + +#define CONFIG_REMAKE_ELF + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV +#undef CONFIG_CMD_IMLS + +#undef CONFIG_CMD_CRC32 +#undef CONFIG_BOOTM_NETBSD + +/* ENET Config */ +/* ENET1 */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_FEC_MXC +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 4 +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_PHY_GIGE +#define IMX_FEC_BASE 0x30BE0000 + +#endif + +/* Link Definitions */ +#define CONFIG_LOADADDR 0x40480000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */ +#define CONFIG_SYS_MMC_ENV_PART 1 /* mmcblk0boot0 */ +#define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */ + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN ((CONFIG_ENV_SIZE + (2 * 1024) + (16 * 1024)) * 1024) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x40000000u) + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE_ADDR + +/* Monitor Command Prompt */ +#undef CONFIG_SYS_PROMPT +#define CONFIG_SYS_PROMPT "u-boot=> " +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_CBSIZE 2048 +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) + +#define CONFIG_IMX_BOOTAUX + +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 + +#define CONFIG_MXC_GPIO + +#define CONFIG_CMD_FUSE + +/* I2C Configs */ +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_OF_SYSTEM_SETUP + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "console=ttymxc0,115200\0" \ + "env_dev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "env_part=" __stringify(CONFIG_SYS_MMC_ENV_PART) "\0" \ + "fdt_addr=0x43000000\0" \ + "fdt_addr_r=0x43000000\0" \ + "boot_fdt=try\0" \ + "fdtfile=imx8mq-nitrogen8m.dtb\0" \ + "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "pxefile_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "scriptaddr=" __stringify(CONFIG_LOADADDR) "\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + BOOTENV + +#endif
On Thu, Oct 3, 2019 at 4:51 PM Patrick Wildt patrick@blueri.se wrote:
This adds basic support for the Nitrogen8M board. It's based on the NXP i.MX8MQ and provides 2GB of memory. This code has been based on the i.MX8M EVK board support, and Boundary Devices' git repository. So far the eMMC and onboard Ethernet can be used to boot, with more device support yet to be implemented. Please note that this only supports the 2G version, with 1 rank bit, which is Boundary Devices' "nitrogen8m" defconfig as well.
Signed-off-by: Patrick Wildt patrick@blueri.se
Troy, could you please help reviewing this?
Thanks
Fabio Estevam
Patrick Wildt
