[U-Boot] Pull request: u-boot-atmel/at91
The following changes since commit bd2313078114c4b44c4a5ce149af43bcb7fc8854: Wolfgang Denk (1): Merge branch 'master' of ssh://gemini/home/wd/git/u-boot/master
git://git.denx.de/u-boot-atmel at91
Alexander Stein (1): at91_pit: Fix AT91_PIT_MR_PIV_MASK macro
Daniel Gorsulowski (3): at91: Defined main clock frequency on esd at91 boards at91: Update meesc board to new SoC access at91: Enabeling USB host on meesc board
Eric Bénard (2): cpuat91: convert to new at91 soc architecture cpuat91: update defaut environement
Jens Scharsig (1): AT91 Fix: return value of get_tbclk
Reinhard Meyer (7): AT91: MCI: add SD/MMC driver using mmc framework AT91: add RTT and GPBR based RTC AT91SAM9XE: add embedded flash support AT91: fix at91sam9260.h for AT91SAM9XE AT91: reset.c: fix comments, add option AT91/AVR32: atmel_spi.c: flush RDR before next SPI transaction AT91: add option to enable pullups in at91sam9260_devices.c
Makefile | 2 +- arch/arm/cpu/arm926ejs/at91/Makefile | 1 + arch/arm/cpu/arm926ejs/at91/at91sam9260_devices.c | 56 +++- arch/arm/cpu/arm926ejs/at91/eflash.c | 271 ++++++++++++++++ arch/arm/cpu/arm926ejs/at91/reset.c | 21 +- arch/arm/cpu/arm926ejs/at91/timer.c | 5 +- arch/arm/include/asm/arch-at91/at91_common.h | 1 + arch/arm/include/asm/arch-at91/at91_dbu.h | 41 +++ arch/arm/include/asm/arch-at91/at91_eefc.h | 51 +++ arch/arm/include/asm/arch-at91/at91_gpbr.h | 45 +++ arch/arm/include/asm/arch-at91/at91_pit.h | 2 +- arch/arm/include/asm/arch-at91/at91_rtt.h | 36 ++ arch/arm/include/asm/arch-at91/at91sam9260.h | 18 +- arch/arm/include/asm/arch-at91/clk.h | 5 + arch/arm/include/asm/arch-at91/hardware.h | 1 + board/esd/meesc/meesc.c | 116 ++++---- board/eukrea/cpuat91/cpuat91.c | 53 ++-- doc/README.atmel_mci | 86 +++++ drivers/mmc/Makefile | 5 +- drivers/mmc/atmel_mci.h | 48 +++- drivers/mmc/gen_atmel_mci.c | 353 +++++++++++++++++++++ drivers/rtc/Makefile | 1 + drivers/rtc/at91sam9_rtt.c | 100 ++++++ drivers/spi/atmel_spi.c | 13 +- include/configs/cpuat91.h | 53 ++- include/configs/meesc.h | 26 +- include/configs/otc570.h | 1 + include/mmc.h | 15 +- 28 files changed, 1278 insertions(+), 148 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/at91/eflash.c create mode 100644 arch/arm/include/asm/arch-at91/at91_dbu.h create mode 100644 arch/arm/include/asm/arch-at91/at91_eefc.h create mode 100644 arch/arm/include/asm/arch-at91/at91_gpbr.h create mode 100644 arch/arm/include/asm/arch-at91/at91_rtt.h create mode 100644 doc/README.atmel_mci create mode 100644 drivers/mmc/gen_atmel_mci.c create mode 100644 drivers/rtc/at91sam9_rtt.c
Dear Reinhard Meyer,
Applied to u-boot-arm, thanks.
Reinhard Meyer
