[PATCH RESEND] watchdog: Hide WATCHDOG_RESET_DISABLE
This option is only supported by the IMX watchdog and seems to be similar to CONFIG_WATCHDOG.
Move it below the IMX watchdog and make it dependent on IMX_WATCHDOG.
Signed-off-by: Michael Walle michael@walle.cc ---
This patch was part of the watchdog behavior patch (series), because I thought it would result in conflicts if I send the patches individually. That isn't the case.
drivers/watchdog/Kconfig | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 210d9f8093..4532a40e45 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -21,12 +21,6 @@ config WATCHDOG_TIMEOUT_MSECS config HW_WATCHDOG bool
-config WATCHDOG_RESET_DISABLE - bool "Disable reset watchdog" - help - Disable reset watchdog, which can let WATCHDOG_RESET invalid, so - that the watchdog will not be fed in u-boot. - config IMX_WATCHDOG bool "Enable Watchdog Timer support for IMX and LSCH2 of NXP" select HW_WATCHDOG if !WDT @@ -34,6 +28,13 @@ config IMX_WATCHDOG Select this to enable the IMX and LSCH2 of Layerscape watchdog driver.
+config WATCHDOG_RESET_DISABLE + bool "Disable reset watchdog" + depends on IMX_WATCHDOG + help + Disable reset watchdog, which can let WATCHDOG_RESET invalid, so + that the watchdog will not be fed in u-boot. + config OMAP_WATCHDOG bool "TI OMAP watchdog driver" depends on ARCH_OMAP2PLUS
This option is only supported by the IMX watchdog and seems to be similar to CONFIG_WATCHDOG. Move it below the IMX watchdog and make it dependent on IMX_WATCHDOG. Signed-off-by: Michael Walle michael@walle.cc
Best regards, Stefano Babic
Michael Walle
sbabic@denx.de
