[U-Boot] [PATCH] cmd_nvedit: Make 'env import -c' require size parameter
When importing a checksummed area we need to be told how big the area in question is so that we know that will match the size of the area which the checksum is generated against.
Reported-by: Pierre AUBERT p.aubert@staubli.com Signed-off-by: Tom Rini trini@ti.com --- common/cmd_nvedit.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 5bcc324..c53601c 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -1008,6 +1008,9 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag,
if (argc == 2) { size = simple_strtoul(argv[1], NULL, 16); + } else if (argc == 1 && chk) { + puts("## Error: external checksum format must pass size\n"); + return CMD_RET_FAILURE; } else { char *s = addr;
