[U-Boot] [PATCH v2] usb: add clock support for generic EHCI
This driver is designed in a generic manner, so clocks should be handled genericly as well.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - rephrase git-log - rebase on commit 12f229ea - do not store clk devices and IDs in the private data
drivers/usb/host/ehci-generic.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 1292caa..98f9db7 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include "ehci.h"
@@ -21,6 +22,20 @@ static int ehci_usb_probe(struct udevice *dev) { struct ehci_hccr *hccr = (struct ehci_hccr *)dev_get_addr(dev); struct ehci_hcor *hcor; + int i = 0; + + while (1) { + struct udevice *clk_dev; + int clk_id; + + clk_id = clk_get_by_index(dev, i, &clk_dev); + if (clk_id < 0) + break; + if (clk_enable(clk_dev, clk_id)) + printf("failed to enable clock (dev=%s, id=%d)\n", + clk_dev->name, clk_id); + i++; + }
hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
Changes in v2:
- rephrase git-log
- int i = 0;
- while (1) {
You can do for (i = 0; ; i++) {} here ;-)
int clk_id;
if (clk_id < 0)
break;
i++;
What about disabling the clock? Is it doable with the current clock framework or shall we abandon it for now ?
Best regards, Marek Vasut
2016-01-25 14:13 GMT+09:00 Marek Vasut marex@denx.de:
Changes in v2:
- rephrase git-log
int i = 0;
while (1) {
int clk_id;
if (clk_id < 0)
break;
i++;
} hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
clk_disable() is not supported in U-Boot, at least for now. (see include/clk.h and you will only find clk_enable.)
I think this patch is the best I can do now.
(ccing Simon, again)
Changes in v2:
- rephrase git-log
#include <common.h>
+#include <clk.h>
int i = 0;
while (1) {
I forgot to mention that if you do the for() thing, you can drop the i++ at the end of this function and you also can drop the explicit int i = 0; initialization.
int clk_id;
if (clk_id < 0)
break;
i++;
} hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase )));
In that case, I am fine with it. Thanks!
Masahiro Yamada
