[U-Boot] [PATCH 01/10] ddr: altera: Replace ad-hoc constant with macro
The bit 22 is in fact DQS tracking enable bit (dqstrken) and there is a macro for this bit already, so use it.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 79c265f..34b1aa7 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -3486,7 +3486,7 @@ static int run_mem_calibrate(void) writel(PHY_MGR_CAL_RESET, &phy_mgr_cfg->cal_status);
/* Stop tracking manager. */ - clrbits_le32(&sdr_ctrl->ctrl_cfg, 1 << 22); + clrbits_le32(&sdr_ctrl->ctrl_cfg, SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK);
phy_mgr_initialize(); rw_mgr_mem_initialize(); @@ -3507,7 +3507,7 @@ static int run_mem_calibrate(void) writel(0x2, &phy_mgr_cfg->mux_sel);
/* Start tracking manager. */ - setbits_le32(&sdr_ctrl->ctrl_cfg, 1 << 22); + setbits_le32(&sdr_ctrl->ctrl_cfg, SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK);
return pass; }
In the most unlikely case the DQS tracking was to be disabled, make sure we do not errornously re-enable it. Note that DQS tracking is enabled on all systems observed thus far.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 34b1aa7..bf74b4e 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -3479,6 +3479,7 @@ grp_failed: /* A group failed, increment the counter. */ static int run_mem_calibrate(void) { int pass; + u32 ctrl_cfg;
debug("%s:%d\n", __func__, __LINE__);
@@ -3486,7 +3487,9 @@ static int run_mem_calibrate(void) writel(PHY_MGR_CAL_RESET, &phy_mgr_cfg->cal_status);
/* Stop tracking manager. */ - clrbits_le32(&sdr_ctrl->ctrl_cfg, SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK); + ctrl_cfg = readl(&sdr_ctrl->ctrl_cfg); + writel(ctrl_cfg & ~SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK, + &sdr_ctrl->ctrl_cfg);
phy_mgr_initialize(); rw_mgr_mem_initialize(); @@ -3507,7 +3510,7 @@ static int run_mem_calibrate(void) writel(0x2, &phy_mgr_cfg->mux_sel);
/* Start tracking manager. */ - setbits_le32(&sdr_ctrl->ctrl_cfg, SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK); + writel(ctrl_cfg, &sdr_ctrl->ctrl_cfg);
return pass; }
u32 ctrl_cfg; debug("%s:%d\n", __func__, __LINE__);
&sdr_ctrl->ctrl_cfg); phy_mgr_initialize(); rw_mgr_mem_initialize();
writel(ctrl_cfg, &sdr_ctrl->ctrl_cfg); return pass;
2.7.0
Tested on: SoCKit, DE0_Nano_SoC Tested-by: George Broz <brozgeo at gmail.com>
The code should be setting registers to zero, not one register to value. Swap the order of arguments to correct the behavior. The behavior is now in-line with code generated by Quartus 15.1 .
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index bf74b4e..3859e66 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -279,7 +279,7 @@ static void scc_mgr_initialize(void) for (i = 0; i < 16; i++) { debug_cond(DLEVEL == 1, "%s:%d: Clearing SCC RFILE index %u\n", __func__, __LINE__, i); - scc_mgr_set(SCC_MGR_HHP_RFILE_OFFSET, 0, i); + scc_mgr_set(SCC_MGR_HHP_RFILE_OFFSET, i, 0); } }
-- 2.7.0
The hi address bitfield in the protection rule must be set to the last address in the region which the rule represents. The behavior is now in-line with code generated by Quartus 15.1 .
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sdram.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/altera/sdram.c b/drivers/ddr/altera/sdram.c index 2996942..7e4606d 100644 --- a/drivers/ddr/altera/sdram.c +++ b/drivers/ddr/altera/sdram.c @@ -118,7 +118,7 @@ static void sdram_set_rule(struct sdram_prot_rule *prule)
/* Obtain the address bits */ lo_addr_bits = prule->sdram_start >> 20ULL; - hi_addr_bits = prule->sdram_end >> 20ULL; + hi_addr_bits = (prule->sdram_end - 1) >> 20ULL;
debug("sdram set rule start %x, %d\n", lo_addr_bits, prule->sdram_start);
hi_addr_bits = (prule->sdram_end - 1) >> 20ULL; debug("sdram set rule start %x, %d\n", lo_addr_bits, prule->sdram_start);
-- 2.7.0
Every invocation of the scc_mgr_set_dqs_en_delay_all_ranks() is followed by SCC manager update. Moreover, only this function triggers the SCC manager update internally. Thus, remove the internal invocation to avoid triggering the update twice.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 3859e66..6bf75ba 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -424,7 +424,6 @@ static void scc_mgr_set_dqs_en_delay_all_ranks(u32 read_group, */ scc_mgr_set_all_ranks(SCC_MGR_DQS_EN_DELAY_OFFSET, read_group, delay, 1); - writel(0, &sdr_scc_mgr->update); }
2.7.0
There is no point in resetting the ODT setting if the write test failed, since the code will always retry the calibration and thus reconfigure the ODT anyway OR the code will fail calibration and halt.
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 6bf75ba..254b130 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -1207,7 +1207,6 @@ rw_mgr_mem_calibrate_write_test(const u32 rank_bgn, const u32 write_group, *bit_chk == param->write_correct_mask); return *bit_chk == param->write_correct_mask; } else { - set_rank_and_odt_mask(0, RW_MGR_ODT_MODE_OFF); debug_cond(DLEVEL == 2, "write_test(%u,%u,ONE) : %u != %i => %i\n", write_group, use_dm, *bit_chk, 0, *bit_chk != 0);
-- 2.7.0
This one last set of delay configuration registers was not properly zeroed out originally, fix it and zero them out.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 254b130..0321e3b 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -303,15 +303,22 @@ static void scc_mgr_set_dqs_en_delay(u32 read_group, u32 delay) scc_mgr_set(SCC_MGR_DQS_EN_DELAY_OFFSET, read_group, delay); }
+static void scc_mgr_set_dq_in_delay(u32 dq_in_group, u32 delay) +{ + scc_mgr_set(SCC_MGR_IO_IN_DELAY_OFFSET, dq_in_group, delay); +} + static void scc_mgr_set_dqs_io_in_delay(u32 delay) { scc_mgr_set(SCC_MGR_IO_IN_DELAY_OFFSET, rwcfg->mem_dq_per_write_dqs, delay); }
-static void scc_mgr_set_dq_in_delay(u32 dq_in_group, u32 delay) +static void scc_mgr_set_dm_in_delay(u32 dm, u32 delay) { - scc_mgr_set(SCC_MGR_IO_IN_DELAY_OFFSET, dq_in_group, delay); + scc_mgr_set(SCC_MGR_IO_IN_DELAY_OFFSET, + rwcfg->mem_dq_per_write_dqs + 1 + dm, + delay); }
static void scc_mgr_set_dq_out1_delay(u32 dq_in_group, u32 delay) @@ -584,8 +591,11 @@ static void scc_mgr_zero_group(const u32 write_group, const int out_only) writel(0xff, &sdr_scc_mgr->dq_ena);
/* Zero all DM config settings. */ - for (i = 0; i < RW_MGR_NUM_DM_PER_WRITE_GROUP; i++) + for (i = 0; i < RW_MGR_NUM_DM_PER_WRITE_GROUP; i++) { + if (!out_only) + scc_mgr_set_dm_in_delay(i, 0); scc_mgr_set_dm_out1_delay(i, 0); + }
/* Multicast to all DM enables. */ writel(0xff, &sdr_scc_mgr->dm_ena);
delay);
if (!out_only)
} /* Multicast to all DM enables. */ writel(0xff, &sdr_scc_mgr->dm_ena);
-- 2.7.0
Originally, the DLEVEL selects the debug level within the sequencer code, but only displays the messages on that particular debug level. Tweak the handling such that for particular debug level, debug messages on that level and lower are displayed. This allows better regulation of debug message verbosity.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 132 ++++++++++++++++++++--------------------- 1 file changed, 66 insertions(+), 66 deletions(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 0321e3b..c41555f 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -277,7 +277,7 @@ static void scc_mgr_initialize(void) int i;
for (i = 0; i < 16; i++) { - debug_cond(DLEVEL == 1, "%s:%d: Clearing SCC RFILE index %u\n", + debug_cond(DLEVEL >= 1, "%s:%d: Clearing SCC RFILE index %u\n", __func__, __LINE__, i); scc_mgr_set(SCC_MGR_HHP_RFILE_OFFSET, i, 0); } @@ -479,10 +479,10 @@ static void scc_mgr_set_hhp_extras(void) SCC_MGR_HHP_GLOBALS_OFFSET | SCC_MGR_HHP_EXTRAS_OFFSET;
- debug_cond(DLEVEL == 1, "%s:%d Setting HHP Extras\n", + debug_cond(DLEVEL >= 1, "%s:%d Setting HHP Extras\n", __func__, __LINE__); writel(value, addr); - debug_cond(DLEVEL == 1, "%s:%d Done Setting HHP Extras\n", + debug_cond(DLEVEL >= 1, "%s:%d Done Setting HHP Extras\n", __func__, __LINE__); }
@@ -693,7 +693,7 @@ static void scc_mgr_apply_group_all_out_delay_add(const u32 write_group, /* DQS shift */ new_delay = READ_SCC_DQS_IO_OUT2_DELAY + delay; if (new_delay > iocfg->io_out2_delay_max) { - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d (%u, %u) DQS: %u > %d; adding %u to OUT1\n", __func__, __LINE__, write_group, delay, new_delay, iocfg->io_out2_delay_max, @@ -707,7 +707,7 @@ static void scc_mgr_apply_group_all_out_delay_add(const u32 write_group, /* OCT shift */ new_delay = READ_SCC_OCT_OUT2_DELAY + delay; if (new_delay > iocfg->io_out2_delay_max) { - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d (%u, %u) DQS: %u > %d; adding %u to OUT1\n", __func__, __LINE__, write_group, delay, new_delay, iocfg->io_out2_delay_max, @@ -1210,14 +1210,14 @@ rw_mgr_mem_calibrate_write_test(const u32 rank_bgn, const u32 write_group,
set_rank_and_odt_mask(0, RW_MGR_ODT_MODE_OFF); if (all_correct) { - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "write_test(%u,%u,ALL) : %u == %u => %i\n", write_group, use_dm, *bit_chk, param->write_correct_mask, *bit_chk == param->write_correct_mask); return *bit_chk == param->write_correct_mask; } else { - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "write_test(%u,%u,ONE) : %u != %i => %i\n", write_group, use_dm, *bit_chk, 0, *bit_chk != 0); return *bit_chk != 0x00; @@ -1292,7 +1292,7 @@ rw_mgr_mem_calibrate_read_test_patterns(const u32 rank_bgn, const u32 group, if (bit_chk != param->read_correct_mask) ret = -EIO;
- debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d test_load_patterns(%u,ALL) => (%u == %u) => %i\n", __func__, __LINE__, group, bit_chk, param->read_correct_mask, ret); @@ -1453,13 +1453,13 @@ rw_mgr_mem_calibrate_read_test(const u32 rank_bgn, const u32 group,
if (all_correct) { ret = (*bit_chk == param->read_correct_mask); - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d read_test(%u,ALL,%u) => (%u == %u) => %i\n", __func__, __LINE__, group, all_groups, *bit_chk, param->read_correct_mask, ret); } else { ret = (*bit_chk != 0x00); - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d read_test(%u,ONE,%u) => (%u != %u) => %i\n", __func__, __LINE__, group, all_groups, *bit_chk, 0, ret); @@ -1523,7 +1523,7 @@ static int find_vfifo_failing_read(const u32 grp) u32 v, ret, fail_cnt = 0;
for (v = 0; v < misccfg->read_valid_fifo_size; v++) { - debug_cond(DLEVEL == 2, "%s:%d: vfifo %u\n", + debug_cond(DLEVEL >= 2, "%s:%d: vfifo %u\n", __func__, __LINE__, v); ret = rw_mgr_mem_calibrate_read_test_all_ranks(grp, 1, PASS_ONE_BIT, 0); @@ -1539,7 +1539,7 @@ static int find_vfifo_failing_read(const u32 grp) }
/* No failing read found! Something must have gone wrong. */ - debug_cond(DLEVEL == 2, "%s:%d: vfifo failed\n", __func__, __LINE__); + debug_cond(DLEVEL >= 2, "%s:%d: vfifo failed\n", __func__, __LINE__); return 0; }
@@ -1646,7 +1646,7 @@ static int sdr_working_phase(const u32 grp, u32 *work_bgn, u32 *d, }
/* Cannot find working solution */ - debug_cond(DLEVEL == 2, "%s:%d find_dqs_en_phase: no vfifo/ptap/dtap\n", + debug_cond(DLEVEL >= 2, "%s:%d find_dqs_en_phase: no vfifo/ptap/dtap\n", __func__, __LINE__); return -EINVAL; } @@ -1722,7 +1722,7 @@ static int sdr_nonworking_phase(const u32 grp, u32 *work_end, u32 *p, u32 *i) ret = sdr_find_phase(0, grp, work_end, i, p); if (ret) { /* Cannot see edge of failing read. */ - debug_cond(DLEVEL == 2, "%s:%d: end: failed\n", + debug_cond(DLEVEL >= 2, "%s:%d: end: failed\n", __func__, __LINE__); }
@@ -1746,21 +1746,21 @@ static int sdr_find_window_center(const u32 grp, const u32 work_bgn,
work_mid = (work_bgn + work_end) / 2;
- debug_cond(DLEVEL == 2, "work_bgn=%d work_end=%d work_mid=%d\n", + debug_cond(DLEVEL >= 2, "work_bgn=%d work_end=%d work_mid=%d\n", work_bgn, work_end, work_mid); /* Get the middle delay to be less than a VFIFO delay */ tmp_delay = (iocfg->dqs_en_phase_max + 1) * iocfg->delay_per_opa_tap;
- debug_cond(DLEVEL == 2, "vfifo ptap delay %d\n", tmp_delay); + debug_cond(DLEVEL >= 2, "vfifo ptap delay %d\n", tmp_delay); work_mid %= tmp_delay; - debug_cond(DLEVEL == 2, "new work_mid %d\n", work_mid); + debug_cond(DLEVEL >= 2, "new work_mid %d\n", work_mid);
tmp_delay = rounddown(work_mid, iocfg->delay_per_opa_tap); if (tmp_delay > iocfg->dqs_en_phase_max * iocfg->delay_per_opa_tap) tmp_delay = iocfg->dqs_en_phase_max * iocfg->delay_per_opa_tap; p = tmp_delay / iocfg->delay_per_opa_tap;
- debug_cond(DLEVEL == 2, "new p %d, tmp_delay=%d\n", p, tmp_delay); + debug_cond(DLEVEL >= 2, "new p %d, tmp_delay=%d\n", p, tmp_delay);
d = DIV_ROUND_UP(work_mid - tmp_delay, iocfg->delay_per_dqs_en_dchain_tap); @@ -1768,7 +1768,7 @@ static int sdr_find_window_center(const u32 grp, const u32 work_bgn, d = iocfg->dqs_en_delay_max; tmp_delay += d * iocfg->delay_per_dqs_en_dchain_tap;
- debug_cond(DLEVEL == 2, "new d %d, tmp_delay=%d\n", d, tmp_delay); + debug_cond(DLEVEL >= 2, "new d %d, tmp_delay=%d\n", d, tmp_delay);
scc_mgr_set_dqs_en_phase_all_ranks(grp, p); scc_mgr_set_dqs_en_delay_all_ranks(grp, d); @@ -1778,11 +1778,11 @@ static int sdr_find_window_center(const u32 grp, const u32 work_bgn, * because the largest possible margin in 1 VFIFO cycle. */ for (i = 0; i < misccfg->read_valid_fifo_size; i++) { - debug_cond(DLEVEL == 2, "find_dqs_en_phase: center\n"); + debug_cond(DLEVEL >= 2, "find_dqs_en_phase: center\n"); if (rw_mgr_mem_calibrate_read_test_all_ranks(grp, 1, PASS_ONE_BIT, 0)) { - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d center: found: ptap=%u dtap=%u\n", __func__, __LINE__, p, d); return 0; @@ -1792,7 +1792,7 @@ static int sdr_find_window_center(const u32 grp, const u32 work_bgn, rw_mgr_incr_vfifo(grp); }
- debug_cond(DLEVEL == 2, "%s:%d center: failed.\n", + debug_cond(DLEVEL >= 2, "%s:%d center: failed.\n", __func__, __LINE__); return -EINVAL; } @@ -1868,7 +1868,7 @@ static int rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(const u32 grp)
d = 0;
- debug_cond(DLEVEL == 2, "%s:%d p: ptap=%u\n", + debug_cond(DLEVEL >= 2, "%s:%d p: ptap=%u\n", __func__, __LINE__, p); }
@@ -1880,18 +1880,18 @@ static int rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(const u32 grp) if (d != 0) work_end -= iocfg->delay_per_dqs_en_dchain_tap;
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d p/d: ptap=%u dtap=%u end=%u\n", __func__, __LINE__, p, d - 1, work_end);
if (work_end < work_bgn) { /* nil range */ - debug_cond(DLEVEL == 2, "%s:%d end-2: failed\n", + debug_cond(DLEVEL >= 2, "%s:%d end-2: failed\n", __func__, __LINE__); return -EINVAL; }
- debug_cond(DLEVEL == 2, "%s:%d found range [%u,%u]\n", + debug_cond(DLEVEL >= 2, "%s:%d found range [%u,%u]\n", __func__, __LINE__, work_bgn, work_end);
/* @@ -1899,18 +1899,18 @@ static int rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(const u32 grp) * To do that we'll back up a ptap and re-find the edge of the * window using dtaps */ - debug_cond(DLEVEL == 2, "%s:%d calculate dtaps_per_ptap for tracking\n", + debug_cond(DLEVEL >= 2, "%s:%d calculate dtaps_per_ptap for tracking\n", __func__, __LINE__);
/* Special case code for backing up a phase */ if (p == 0) { p = iocfg->dqs_en_phase_max; rw_mgr_decr_vfifo(grp); - debug_cond(DLEVEL == 2, "%s:%d backedup cycle/phase: p=%u\n", + debug_cond(DLEVEL >= 2, "%s:%d backedup cycle/phase: p=%u\n", __func__, __LINE__, p); } else { p = p - 1; - debug_cond(DLEVEL == 2, "%s:%d backedup phase only: p=%u", + debug_cond(DLEVEL >= 2, "%s:%d backedup phase only: p=%u", __func__, __LINE__, p); }
@@ -1923,7 +1923,7 @@ static int rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(const u32 grp) */
/* Find a passing read. */ - debug_cond(DLEVEL == 2, "%s:%d find passing read\n", + debug_cond(DLEVEL >= 2, "%s:%d find passing read\n", __func__, __LINE__);
initial_failing_dtap = d; @@ -1931,13 +1931,13 @@ static int rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(const u32 grp) found_passing_read = !sdr_find_phase_delay(1, 1, grp, NULL, 0, &d); if (found_passing_read) { /* Find a failing read. */ - debug_cond(DLEVEL == 2, "%s:%d find failing read\n", + debug_cond(DLEVEL >= 2, "%s:%d find failing read\n", __func__, __LINE__); d++; found_failing_read = !sdr_find_phase_delay(0, 1, grp, NULL, 0, &d); } else { - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d failed to calculate dtaps per ptap. Fall back on static value\n", __func__, __LINE__); } @@ -1952,7 +1952,7 @@ static int rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(const u32 grp) dtaps_per_ptap = d - initial_failing_dtap;
writel(dtaps_per_ptap, &sdr_reg_file->dtaps_per_ptap); - debug_cond(DLEVEL == 2, "%s:%d dtaps_per_ptap=%u - %u = %u", + debug_cond(DLEVEL >= 2, "%s:%d dtaps_per_ptap=%u - %u = %u", __func__, __LINE__, d, initial_failing_dtap, dtaps_per_ptap);
/* Step 6: Find the centre of the window. */ @@ -2008,7 +2008,7 @@ static u32 search_stop_check(const int write, const int d, const int rank_bgn, } *sticky_bit_chk = *sticky_bit_chk | *bit_chk; ret = ret && (*sticky_bit_chk == correct_mask); - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d center(left): dtap=%u => %u == %u && %u", __func__, __LINE__, d, *sticky_bit_chk, correct_mask, ret); @@ -2087,7 +2087,7 @@ static void search_left_edge(const int write, const int rank_bgn,
*sticky_bit_chk = 0; for (i = per_dqs - 1; i >= 0; i--) { - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d vfifo_center: left_edge[%u]: %d right_edge[%u]: %d\n", __func__, __LINE__, i, left_edge[i], i, right_edge[i]); @@ -2100,7 +2100,7 @@ static void search_left_edge(const int write, const int rank_bgn, if ((left_edge[i] == delay_max + 1) && (right_edge[i] != delay_max + 1)) { right_edge[i] = delay_max + 1; - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d vfifo_center: reset right_edge[%u]: %d\n", __func__, __LINE__, i, right_edge[i]); } @@ -2230,12 +2230,12 @@ static int search_right_edge(const int write, const int rank_bgn, } }
- debug_cond(DLEVEL == 2, "%s:%d center[r,d=%u]: ", + debug_cond(DLEVEL >= 2, "%s:%d center[r,d=%u]: ", __func__, __LINE__, d); - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "bit_chk_test=%i left_edge[%u]: %d ", bit_chk & 1, i, left_edge[i]); - debug_cond(DLEVEL == 2, "right_edge[%u]: %d\n", i, + debug_cond(DLEVEL >= 2, "right_edge[%u]: %d\n", i, right_edge[i]); bit_chk >>= 1; } @@ -2243,7 +2243,7 @@ static int search_right_edge(const int write, const int rank_bgn,
/* Check that all bits have a window */ for (i = 0; i < per_dqs; i++) { - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d write_center: left_edge[%u]: %d right_edge[%u]: %d", __func__, __LINE__, i, left_edge[i], i, right_edge[i]); @@ -2292,7 +2292,7 @@ static int get_window_mid_index(const int write, int *left_edge, (*mid_min)++; *mid_min = *mid_min / 2;
- debug_cond(DLEVEL == 1, "%s:%d vfifo_center: *mid_min=%d (index=%u)\n", + debug_cond(DLEVEL >= 1, "%s:%d vfifo_center: *mid_min=%d (index=%u)\n", __func__, __LINE__, *mid_min, min_index); return min_index; } @@ -2338,7 +2338,7 @@ static void center_dq_windows(const int write, int *left_edge, int *right_edge, (left_edge[min_index] - right_edge[min_index]))/2 + (orig_mid_min - mid_min);
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "vfifo_center: before: shift_dq[%u]=%d\n", i, shift_dq);
@@ -2350,7 +2350,7 @@ static void center_dq_windows(const int write, int *left_edge, int *right_edge, else if (shift_dq + temp_dq_io_delay1 < 0) shift_dq = -temp_dq_io_delay1;
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "vfifo_center: after: shift_dq[%u]=%d\n", i, shift_dq);
@@ -2363,7 +2363,7 @@ static void center_dq_windows(const int write, int *left_edge, int *right_edge,
scc_mgr_load_dq(p);
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "vfifo_center: margin[%u]=[%d,%d]\n", i, left_edge[i] - shift_dq + (-mid_min), right_edge[i] + shift_dq - (-mid_min)); @@ -2445,7 +2445,7 @@ static int rw_mgr_mem_calibrate_vfifo_center(const u32 rank_bgn, scc_mgr_load_dqs(rw_group); writel(0, &sdr_scc_mgr->update);
- debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d vfifo_center: failed to find edge [%u]: %d %d", __func__, __LINE__, i, left_edge[i], right_edge[i]); if (use_read_test) { @@ -2473,7 +2473,7 @@ static int rw_mgr_mem_calibrate_vfifo_center(const u32 rank_bgn, new_dqs = 0;
mid_min = start_dqs - new_dqs; - debug_cond(DLEVEL == 1, "vfifo_center: new mid_min=%d new_dqs=%d\n", + debug_cond(DLEVEL >= 1, "vfifo_center: new mid_min=%d new_dqs=%d\n", mid_min, new_dqs);
if (iocfg->shift_dqs_en_when_shift_dqs) { @@ -2485,7 +2485,7 @@ static int rw_mgr_mem_calibrate_vfifo_center(const u32 rank_bgn, } new_dqs = start_dqs - mid_min;
- debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "vfifo_center: start_dqs=%d start_dqs_en=%d new_dqs=%d mid_min=%d\n", start_dqs, iocfg->shift_dqs_en_when_shift_dqs ? start_dqs_en : -1, @@ -2505,7 +2505,7 @@ static int rw_mgr_mem_calibrate_vfifo_center(const u32 rank_bgn, /* Move DQS */ scc_mgr_set_dqs_bus_in_delay(rw_group, new_dqs); scc_mgr_load_dqs(rw_group); - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d vfifo_center: dq_margin=%d dqs_margin=%d", __func__, __LINE__, dq_margin, dqs_margin);
@@ -2538,7 +2538,7 @@ static int rw_mgr_mem_calibrate_guaranteed_write(const u32 rw_group, /* Set a particular DQ/DQS phase. */ scc_mgr_set_dqdqs_output_phase_all_ranks(rw_group, phase);
- debug_cond(DLEVEL == 1, "%s:%d guaranteed write: g=%u p=%u\n", + debug_cond(DLEVEL >= 1, "%s:%d guaranteed write: g=%u p=%u\n", __func__, __LINE__, rw_group, phase);
/* @@ -2557,7 +2557,7 @@ static int rw_mgr_mem_calibrate_guaranteed_write(const u32 rw_group, */ ret = rw_mgr_mem_calibrate_read_test_patterns(0, rw_group, 1); if (ret) - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d Guaranteed read test failed: g=%u p=%u\n", __func__, __LINE__, rw_group, phase); return ret; @@ -2593,7 +2593,7 @@ static int rw_mgr_mem_calibrate_dqs_enable_calibration(const u32 rw_group, for (i = 0, p = test_bgn, d = 0; i < rwcfg->mem_dq_per_read_dqs; i++, p++, d += delay_step) { - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d: g=%u r=%u i=%u p=%u d=%u\n", __func__, __LINE__, rw_group, r, i, p, d);
@@ -2610,7 +2610,7 @@ static int rw_mgr_mem_calibrate_dqs_enable_calibration(const u32 rw_group, */ ret = rw_mgr_mem_calibrate_vfifo_find_dqs_en_phase(rw_group);
- debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d: g=%u found=%u; Reseting delay chain to zero\n", __func__, __LINE__, rw_group, !ret);
@@ -2816,7 +2816,7 @@ static u32 rw_mgr_mem_calibrate_lfifo(void)
do { writel(gbl->curr_read_lat, &phy_mgr_cfg->phy_rlat); - debug_cond(DLEVEL == 2, "%s:%d lfifo: read_lat=%u", + debug_cond(DLEVEL >= 2, "%s:%d lfifo: read_lat=%u", __func__, __LINE__, gbl->curr_read_lat);
if (!rw_mgr_mem_calibrate_read_test_all_ranks(0, NUM_READ_TESTS, @@ -2838,14 +2838,14 @@ static u32 rw_mgr_mem_calibrate_lfifo(void) /* Add a fudge factor to the read latency that was determined */ gbl->curr_read_lat += 2; writel(gbl->curr_read_lat, &phy_mgr_cfg->phy_rlat); - debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d lfifo: success: using read_lat=%u\n", __func__, __LINE__, gbl->curr_read_lat); } else { set_failing_group_stage(0xff, CAL_STAGE_LFIFO, CAL_SUBSTAGE_READ_LATENCY);
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d lfifo: failed at initial read_lat=%u\n", __func__, __LINE__, gbl->curr_read_lat); } @@ -3008,7 +3008,7 @@ rw_mgr_mem_calibrate_writes_center(const u32 rank_bgn, const u32 write_group, orig_mid_min = mid_min; new_dqs = start_dqs; mid_min = 0; - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "%s:%d write_center: start_dqs=%d new_dqs=%d mid_min=%d\n", __func__, __LINE__, start_dqs, new_dqs, mid_min);
@@ -3021,7 +3021,7 @@ rw_mgr_mem_calibrate_writes_center(const u32 rank_bgn, const u32 write_group, writel(0, &sdr_scc_mgr->update);
/* Centre DM */ - debug_cond(DLEVEL == 2, "%s:%d write_center: DM\n", __func__, __LINE__); + debug_cond(DLEVEL >= 2, "%s:%d write_center: DM\n", __func__, __LINE__);
/* * Set the left and right edge of each bit to an illegal value. @@ -3055,7 +3055,7 @@ rw_mgr_mem_calibrate_writes_center(const u32 rank_bgn, const u32 write_group, left_edge[0] = -1 * bgn_best; right_edge[0] = end_best;
- debug_cond(DLEVEL == 2, "%s:%d dm_calib: left=%d right=%d\n", + debug_cond(DLEVEL >= 2, "%s:%d dm_calib: left=%d right=%d\n", __func__, __LINE__, left_edge[0], right_edge[0]);
/* Move DQS (back to orig). */ @@ -3079,14 +3079,14 @@ rw_mgr_mem_calibrate_writes_center(const u32 rank_bgn, const u32 write_group, scc_mgr_apply_group_dm_out1_delay(mid); writel(0, &sdr_scc_mgr->update);
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d dm_calib: left=%d right=%d mid=%d dm_margin=%d\n", __func__, __LINE__, left_edge[0], right_edge[0], mid, dm_margin); /* Export values. */ gbl->fom_out += dq_margin + dqs_margin;
- debug_cond(DLEVEL == 2, + debug_cond(DLEVEL >= 2, "%s:%d write_center: dq_margin=%d dqs_margin=%d dm_margin=%d\n", __func__, __LINE__, dq_margin, dqs_margin, dm_margin);
@@ -3745,27 +3745,27 @@ int sdram_calibration_full(void) printf("%s: Preparing to start memory calibration\n", __FILE__);
debug("%s:%d\n", __func__, __LINE__); - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "DDR3 FULL_RATE ranks=%u cs/dimm=%u dq/dqs=%u,%u vg/dqs=%u,%u ", rwcfg->mem_number_of_ranks, rwcfg->mem_number_of_cs_per_dimm, rwcfg->mem_dq_per_read_dqs, rwcfg->mem_dq_per_write_dqs, rwcfg->mem_virtual_groups_per_read_dqs, rwcfg->mem_virtual_groups_per_write_dqs); - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "dqs=%u,%u dq=%u dm=%u ptap_delay=%u dtap_delay=%u ", rwcfg->mem_if_read_dqs_width, rwcfg->mem_if_write_dqs_width, rwcfg->mem_data_width, rwcfg->mem_data_mask_width, iocfg->delay_per_opa_tap, iocfg->delay_per_dchain_tap); - debug_cond(DLEVEL == 1, "dtap_dqsen_delay=%u, dll=%u", + debug_cond(DLEVEL >= 1, "dtap_dqsen_delay=%u, dll=%u", iocfg->delay_per_dqs_en_dchain_tap, iocfg->dll_chain_length); - debug_cond(DLEVEL == 1, + debug_cond(DLEVEL >= 1, "max values: en_p=%u dqdqs_p=%u en_d=%u dqs_in_d=%u ", iocfg->dqs_en_phase_max, iocfg->dqdqs_out_phase_max, iocfg->dqs_en_delay_max, iocfg->dqs_in_delay_max); - debug_cond(DLEVEL == 1, "io_in_d=%u io_out1_d=%u io_out2_d=%u ", + debug_cond(DLEVEL >= 1, "io_in_d=%u io_out1_d=%u io_out2_d=%u ", iocfg->io_in_delay_max, iocfg->io_out1_delay_max, iocfg->io_out2_delay_max); - debug_cond(DLEVEL == 1, "dqs_in_reserve=%u dqs_out_reserve=%u\n", + debug_cond(DLEVEL >= 1, "dqs_in_reserve=%u dqs_out_reserve=%u\n", iocfg->dqs_in_reserve, iocfg->dqs_out_reserve);
hc_initialize_rom_data();
debug_cond(DLEVEL >= 2, "new work_mid %d\n", work_mid); tmp_delay = rounddown(work_mid, iocfg->delay_per_opa_tap); if (tmp_delay > iocfg->dqs_en_phase_max * iocfg->delay_per_opa_tap) tmp_delay = iocfg->dqs_en_phase_max * iocfg->delay_per_opa_tap; p = tmp_delay / iocfg->delay_per_opa_tap;
debug_cond(DLEVEL >= 2, "new p %d, tmp_delay=%d\n", p, tmp_delay); d = DIV_ROUND_UP(work_mid - tmp_delay, iocfg->delay_per_dqs_en_dchain_tap);
debug_cond(DLEVEL >= 2, "new d %d, tmp_delay=%d\n", d, tmp_delay); scc_mgr_set_dqs_en_phase_all_ranks(grp, p); scc_mgr_set_dqs_en_delay_all_ranks(grp, d);
d = 0;
debug_cond(DLEVEL >= 2, "%s:%d p/d: ptap=%u dtap=%u end=%u\n", __func__, __LINE__, p, d - 1, work_end); if (work_end < work_bgn) { /* nil range */
debug_cond(DLEVEL >= 2, "%s:%d found range [%u,%u]\n", __func__, __LINE__, work_bgn, work_end); /*
debug_cond(DLEVEL >= 2, "%s:%d calculate dtaps_per_ptap for tracking\n", __func__, __LINE__); /* Special case code for backing up a phase */ if (p == 0) { p = iocfg->dqs_en_phase_max; rw_mgr_decr_vfifo(grp);
debug_cond(DLEVEL >= 2, "%s:%d find passing read\n", __func__, __LINE__); initial_failing_dtap = d;
debug_cond(DLEVEL >= 2, "%s:%d dtaps_per_ptap=%u - %u = %u", __func__, __LINE__, d, initial_failing_dtap, dtaps_per_ptap); /* Step 6: Find the centre of the window. */
scc_mgr_load_dq(p);
debug_cond(DLEVEL >= 1, "vfifo_center: new mid_min=%d new_dqs=%d\n", mid_min, new_dqs); if (iocfg->shift_dqs_en_when_shift_dqs) {
debug_cond(DLEVEL >= 1, "%s:%d guaranteed write: g=%u p=%u\n", __func__, __LINE__, rw_group, phase); /*
debug_cond(DLEVEL >= 2, "%s:%d lfifo: read_lat=%u", __func__, __LINE__, gbl->curr_read_lat); if (!rw_mgr_mem_calibrate_read_test_all_ranks(0, NUM_READ_TESTS,
/* Centre DM */
debug_cond(DLEVEL >= 2, "%s:%d write_center: DM\n", __func__, __LINE__); /* * Set the left and right edge of each bit to an illegal value.
debug_cond(DLEVEL >= 2, "%s:%d dm_calib: left=%d right=%d\n", __func__, __LINE__, left_edge[0], right_edge[0]); /* Move DQS (back to orig). */
debug_cond(DLEVEL >= 1, "dqs_in_reserve=%u dqs_out_reserve=%u\n", iocfg->dqs_in_reserve, iocfg->dqs_out_reserve); hc_initialize_rom_data();
-- 2.7.0
Just staticize global variables in sequencer, since there is no point in having these symbols available outside of the DDR code.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index c41555f..5ea53ad 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -57,7 +57,7 @@ const struct socfpga_sdram_misc_config *misccfg; STATIC_SKIP_DELAY_LOOPS)
/* calibration steps requested by the rtl */ -u16 dyn_calib_steps; +static u16 dyn_calib_steps;
/* * To make CALIB_SKIP_DELAY_LOOPS a dynamic conditional option @@ -68,13 +68,13 @@ u16 dyn_calib_steps; * zero when skipping */
-u16 skip_delay_mask; /* mask off bits when skipping/not-skipping */ +static u16 skip_delay_mask; /* mask off bits when skipping/not-skipping */
#define SKIP_DELAY_LOOP_VALUE_OR_ZERO(non_skip_value) \ ((non_skip_value) & skip_delay_mask)
-struct gbl_type *gbl; -struct param_type *param; +static struct gbl_type *gbl; +static struct param_type *param;
static void set_failing_group_stage(u32 group, u32 stage, u32 substage)
- To make CALIB_SKIP_DELAY_LOOPS a dynamic conditional option
- zero when skipping
static void set_failing_group_stage(u32 group, u32 stage, u32 substage) -- 2.7.0
Acked-by: Pavel Machek pavel@denx.de
The code uses a lot of signed numbers, which ended up in variables of unsigned type, which resulted in all sorts of underflows. This in turn caused incorrect calibration on certain boards. Moreover, repair the readout of the DQ delay, which was being pulled from wrong register.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Chin Liang See clsee@altera.com --- drivers/ddr/altera/sequencer.c | 15 +++++++-------- 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/ddr/altera/sequencer.c b/drivers/ddr/altera/sequencer.c index 5ea53ad..6c6bd90 100644 --- a/drivers/ddr/altera/sequencer.c +++ b/drivers/ddr/altera/sequencer.c @@ -2316,15 +2316,15 @@ static void center_dq_windows(const int write, int *left_edge, int *right_edge, const int min_index, const int test_bgn, int *dq_margin, int *dqs_margin) { - const u32 delay_max = write ? iocfg->io_out1_delay_max : + const s32 delay_max = write ? iocfg->io_out1_delay_max : iocfg->io_in_delay_max; - const u32 per_dqs = write ? rwcfg->mem_dq_per_write_dqs : + const s32 per_dqs = write ? rwcfg->mem_dq_per_write_dqs : rwcfg->mem_dq_per_read_dqs; - const u32 delay_off = write ? SCC_MGR_IO_OUT1_DELAY_OFFSET : + const s32 delay_off = write ? SCC_MGR_IO_OUT1_DELAY_OFFSET : SCC_MGR_IO_IN_DELAY_OFFSET; - const u32 addr = SDR_PHYGRP_SCCGRP_ADDRESS | delay_off; + const s32 addr = SDR_PHYGRP_SCCGRP_ADDRESS | delay_off;
- u32 temp_dq_io_delay1, temp_dq_io_delay2; + s32 temp_dq_io_delay1; int shift_dq, i, p;
/* Initialize data for export structures */ @@ -2342,11 +2342,10 @@ static void center_dq_windows(const int write, int *left_edge, int *right_edge, "vfifo_center: before: shift_dq[%u]=%d\n", i, shift_dq);
- temp_dq_io_delay1 = readl(addr + (p << 2)); - temp_dq_io_delay2 = readl(addr + (i << 2)); + temp_dq_io_delay1 = readl(addr + (i << 2));
if (shift_dq + temp_dq_io_delay1 > delay_max) - shift_dq = delay_max - temp_dq_io_delay2; + shift_dq = delay_max - temp_dq_io_delay1; else if (shift_dq + temp_dq_io_delay1 < 0) shift_dq = -temp_dq_io_delay1;
s32 temp_dq_io_delay1; int shift_dq, i, p; /* Initialize data for export structures */
temp_dq_io_delay1 = readl(addr + (i << 2)); if (shift_dq + temp_dq_io_delay1 > delay_max)
-- 2.7.0
clrbits_le32(&sdr_ctrl->ctrl_cfg, SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK); phy_mgr_initialize(); rw_mgr_mem_initialize();
setbits_le32(&sdr_ctrl->ctrl_cfg, SDR_CTRLGRP_CTRLCFG_DQSTRKEN_MASK); return pass;
2.7.0
George Broz
Pavel Machek
