[U-Boot-Users] Write buffer programming for AMD flash chips
The patch attached adds write buffer programming support for AMD flash chips in the drivers/cfi_flash.c file. I've tested this on a custom board with AMD S29GL256M flash chips.
I tried not to change the program flow for other flash chips available before, but I have no possibility to test this. Brad, Yuli, can you check this patch if it complies with your previous work?
Patching the write_buff function
+ /* write buffer until next buffered_size aligned boundary */ + i = buffered_size - (wp % buffered_size); + if (i>cnt) + i = cnt;
is necessary because AMD chips require the write buffer to be aligned with the size of the available write buffer. It probably doesn't hurt when programming other (Intel) chips.
Thomas Schäfer
____________________________________
Kontron Modular Computers GmbH
Konrad-Zuse-Str. 9 66115 Saarbrücken
Tel.: + 49 (0)681 / 95916 - 203 Fax: + 49 (0)681 / 95916 - 100 E-mail: thomas.schaefer@kontron.com
Thomas Schäfer
