bootstd: CACHE Misaligned operation errors (Marvell Armada 385)
I've been testing the boostd for a few Marvell boards and seeing this error on the Thecus N2350 (Marvell Armada 385, dual-core CPU). The "bootflow scan scsi" command triggered the "CACHE: Misaligned operation at range" error. However, this error did not affect the result of the scan, i.e. the bootflow for scsi partition was created correctly, and u-boot is running normally.
Enabling CONFIG_SYS_DCACHE_OFF got rid of the errors altogether. Perhaps this is a case where the DCACHE is not required and should be turned off?
Please see the log after the break below.
All the best, Tony
U-Boot 2023.10-rc4-tld-1-00036-gbb16283b81-dirty (Sep 11 2023 - 11:56:18 -0700) Thecus N2350
SoC: MV88F6820-A0 at 1066 MHz DRAM: 1 GiB (533 MHz, 32-bit, ECC not enabled) Core: 65 devices, 23 uclasses, devicetree: separate NAND: 512 MiB MMC: Loading Environment from SPIFlash... SF: Detected mx25l3205d with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment
Model: Thecus N2350 Net: Warning: ethernet@70000 (eth0) using random MAC address - be:13:ae:99:49:ab eth0: ethernet@70000 Hit any key to stop autoboot: 0
N2350 > env def -a ## Resetting to default environment
N2350 > bootdev l Seq Probed Status Uclass Name --- ------ ------ -------- ------------------ 0 [ ] OK ethernet ethernet@70000.bootdev --- ------ ------ -------- ------------------ (1 bootdev)
N2350 > bootdev hunt scsi Hunting with: scsi pcie0.0: Link down pcie1.0: Link down scanning bus for devices... SATA link 0 timeout. Target spinup took 0 ms. AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode flags: 64bit ncq led only pmp fbss pio slum part sxs Device 0: (1:0) Vendor: ATA Prod.: ST750LX003-1AC15 Rev: SM12 Type: Hard Disk Capacity: 715404.8 MB = 698.6 GB (1465149168 x 512)
N2350 > bootflow scan usb Bus usb@58000: USB EHCI 1.00 Bus usb3@f0000: MVEBU XHCI INIT controller @ 0xf10f4000 Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 Bus usb3@f8000: MVEBU XHCI INIT controller @ 0xf10fc000 Register 2000120 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus usb@58000 for devices... 1 USB Device(s) found scanning bus usb3@f0000 for devices... 1 USB Device(s) found scanning bus usb3@f8000 for devices... 2 USB Device(s) found ** File not found /boot/boot.bmp **
N2350 > bootflow scan scsi CACHE: Misaligned operation at range [3fb7fe48, 3fb80248] CACHE: Misaligned operation at range [3fb7fe48, 3fb80248] CACHE: Misaligned operation at range [3fb7fe48, 3fb80248] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb7fe48 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb80248 ** File not found /boot/boot.bmp ** ** File not found /boot/boot.bmp **
N2350 > bootflow scan scsi CACHE: Misaligned operation at range [3fb88a88, 3fb88e88] CACHE: Misaligned operation at range [3fb88a88, 3fb88e88] CACHE: Misaligned operation at range [3fb88a88, 3fb88e88] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb88a88 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb88e88 ** File not found /boot/boot.bmp ** ** File not found /boot/boot.bmp **
N2350 > bootflow l Showing all bootflows Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- 0 script ready scsi 1 ahci_scsi.id1lun0.bootdev /boot/boot.scr 1 script ready usb_mass_ 1 usb_mass_storage.lun0.boo /boot/boot.scr --- ----------- ------ -------- ---- ------------------------ ---------------- (2 bootflows, 2 valid)
N2350 > boot Scanning for bootflows in all bootdevs Seq Method State Uclass Part Name Filename --- ----------- ------ -------- ---- ------------------------ ---------------- Scanning global bootmeth 'efi_mgr': Hunting with: mmc Scanning bootdev 'ahci_scsi.id1lun0.bootdev': CACHE: Misaligned operation at range [3fb91d08, 3fb92108] CACHE: Misaligned operation at range [3fb91d08, 3fb92108] CACHE: Misaligned operation at range [3fb91d08, 3fb92108] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb91d08 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb92108 ** File not found /boot/boot.bmp ** 0 script ready scsi 1 ahci_scsi.id1lun0.bootdev /boot/boot.scr ** Booting bootflow 'ahci_scsi.id1lun0.bootdev.part_1' with script Booting with distro boot script loading uImage from scsi 0:1 ... 5118888 bytes read in 120 ms (40.7 MiB/s) loading uInitrd from scsi 0:1 ... 7355687 bytes read in 197 ms (35.6 MiB/s) loading DTB file from scsi 0:1 ... 20906 bytes read in 16 ms (1.2 MiB/s) ## Booting kernel from Legacy Image at 01000000 ... Image Name: Linux-6.4.11-mvebu-tld-1 Created: 2023-08-20 17:34:55 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 5118824 Bytes = 4.9 MiB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 02200000 ... Image Name: initramfs-6.4.11-mvebu-tld-1 Created: 2023-08-20 17:34:57 UTC Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 7355623 Bytes = 7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 02000000 Booting using the fdt blob at 0x2000000 Working FDT set to 2000000
Starting kernel ...
Loading Kernel Image Loading Ramdisk to 0f8fc000, end 0ffffce7 ... OK Loading Device Tree to 0f8f3000, end 0f8fb1a9 ... OK Working FDT set to f8f3000
Starting kernel ...
Can you please try -next ? There's at least one SCSI related cache alignment fix there that's not in master, thanks.
Hi Tom,
Unfortunately I got the same errors. This time the ranges are different, of course.
master:
N2350 > bootflow scan scsi CACHE: Misaligned operation at range [3fb99f88, 3fb9a388] CACHE: Misaligned operation at range [3fb99f88, 3fb9a388] CACHE: Misaligned operation at range [3fb99f88, 3fb9a388] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb99f88 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb9a388
next:
N2350 > bootflow scan scsi CACHE: Misaligned operation at range [3fb80388, 3fb80788] CACHE: Misaligned operation at range [3fb80388, 3fb80788] CACHE: Misaligned operation at range [3fb80388, 3fb80788] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb80388 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb80788
Thanks, Tony
-- Tom
On Wed, Sep 13, 2023 at 12:56:53PM -0700, Tony Dinh wrote:
Hi Tom,
master:
next:
Can you debug to where these calls are so we can align these buffers? See 02660defdc8a ("scsi: Cache align temporary buffer") for an example.
Hi Tom,
Hi Tom,
master:
next:
I've added some printfs to the code. Looks like the last calls were SCSI_READ16 (0x48) in this sequence: scsi_exec() --> ahci_scsi_exec() --> ata_scsiop_read_write()
Note that the misaligned errors do not always occur.
I've also looked at the other recent commit by Marek and tried to enable CONFIG_BOUNCE_BUFFER: https://github.com/u-boot/u-boot/commit/4f543e82b9831333bc0effe9540d8e6a9dde... But I think it is a noop without a callback from the driver.
Please see the boot log below after the break.
Thanks, Tony
U-Boot 2023.10-rc4-tld-1-00284-gce67ba1e30-dirty (Sep 13 2023 - 16:44:56 -0700) Thecus N2350
Model: Thecus N2350 Net: Warning: ethernet@70000 (eth0) using random MAC address - a2:6f:f1:4a:2e:51 eth0: ethernet@70000 Hit any key to stop autoboot: 0
N2350 > bootdev hunt scsi Hunting with: scsi pcie0.0: Link down pcie1.0: Link down scsi_scan scanning bus for devices... scsi_scan_dev SATA link 0 timeout. Target spinup took 0 ms. AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode flags: 64bit ncq led only pmp fbss pio slum part sxs do_scsi_scan_one scsi_detect_dev scsi_setup_inquiry scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x12 do_scsi_scan_one scsi_detect_dev scsi_setup_inquiry scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x12 scsi_ident_cpy scsi_ident_cpy scsi_ident_cpy scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x0 scsi_read_capacity scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x25 scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write Device 0: (1:0) Vendor: ATA Prod.: ST750LX003-1AC15 Rev: SM12 Type: Hard Disk Capacity: 715404.8 MB = 698.6 GB (1465149168 x 512)
N2350 > bootflow scan scsi scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x28 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write CACHE: Misaligned operation at range [3fb6f8d8, 3fb6fcd8] scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write CACHE: Misaligned operation at range [3fb6f8d8, 3fb6fcd8] CACHE: Misaligned operation at range [3fb6f8d8, 3fb6fcd8] CACHE: Misaligned operation at range [3fb6f8d8, 3fb6fcd8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb6f8d8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb6fcd8 CACHE: Misaligned operation at range [3fb6f8d8, 3fb6fcd8] CACHE: Misaligned operation at range [3fb6f8d8, 3fb6fcd8] ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3fb6f8d8 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3fb6fcd8 scsi_exec ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ata_scsiop_read_write ** File not found /boot/boot.bmp **
-- Tom
Hi Tom,
Hi Tom,
this
be
turned off?
master:
0x3fb99f88
0x3fb9a388
next:
0x3fb80388
0x3fb80788
I wonder if we need to use memalign() when allocating memory to read things from the media? But I am not sure which file time is being read, or which bootmeth it is.
Hi Simon,
On Wed, Sep 13, 2023 at 8:38 PM Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
master:
next:
Looks like we probably need to align the buffer tempbuff.
/drivers/scsi/scsi.c static int scsi_detect_dev(struct udevice *dev, int target, int lun, struct blk_desc *dev_desc) { unsigned char perq, modi; lbaint_t capacity; unsigned long blksz; struct scsi_cmd *pccb = (struct scsi_cmd *)&tempccb; int count, err;
pccb->target = target; pccb->lun = lun; pccb->pdata = (unsigned char *)&tempbuff; pccb->datalen = 512;
If you look at the log I posted previously, this error shows up during "bootflow scan scsi".
All the best, Tony
Hi Tom, Hi Simon,
On Wed, Sep 13, 2023 at 9:53 PM Tony Dinh mibodhi@gmail.com wrote:
Hi Simon,
Hi Tom,
Hi Tom,
master:
next:
Taking the hint from Simon. I turned on log_debug and can see where the alignment is not correct. It is fs.c fs_read_alloc(). The memalign() call here probably needs to be revised to take into consideration ARCH_DMA_MINALIGN somehow? It is 64 for armv7.
diff --git a/fs/fs.c b/fs/fs.c index 2b815b1db0..b70281532e 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -1019,9 +1019,12 @@ int fs_read_alloc(const char *fname, ulong size, uint align, void **bufp) int ret;
buf = memalign(align, size + 1); + log_debug("aligned buf addr 0x%x\n", (unsigned int)buf); + if (!buf) return log_msg_ret("buf", -ENOMEM); addr = map_to_sysmem(buf); + log_debug("aligned buf sysmem addr 0x%x\n", (unsigned int)addr);
ret = fs_read(fname, addr, 0, size, &bytes_read); if (ret) {
Please see the log below after the break.
All the best, Tony
Log:
bootmeth_try_file() /boot/boot.scr - err=0 fs_devread() <2, 0, 1024> fs_devread() <8, 0, 32> fs_devread() <8216, 256, 128>
bootmeth_alloc_file() - script file size 4b7
fs_read_alloc() aligned buf addr 0x3eb4b608 fs_read_alloc() aligned buf sysmem addr 0x3eb4b608 fs_devread() <12312, 0, 8>
<snip>
fs_devread() <551551112, 256, 128> fs_devread() <551592072, 0, 1207>
scsi_read buffer addr=0x3eb4b608 scsi_read_ext: startblk 20e0a88a, blccnt 0 buffer 3EB4B608 scsi_exec pdata=0x3eb4b608 ahci_scsi_exec ahci_scsi_exec cmd = 0x48 ahci_scsi_exec pdata=0x3eb4b608 ata_scsiop_read_write ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3eb4b608 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3eb4ba08 ata_scsiop_read_write exiting... ahci_scsi_exec exiting... scsi_read exiting... ERROR: v7_outer_cache_inval_range - start address is not aligned - 0x3eb4b608 ERROR: v7_outer_cache_inval_range - stop address is not aligned - 0x3eb4ba08
All the best, Tony
On Fri, Sep 15, 2023 at 6:32 PM Tony Dinh mibodhi@gmail.com wrote:
Hi Tom, Hi Simon,
Hi Simon,
Hi Tom,
Hi Tom,
> I've been testing the boostd for a few Marvell boards and seeing this > error on the Thecus N2350 (Marvell Armada 385, dual-core CPU). The > "bootflow scan scsi" command triggered the "CACHE: Misaligned > operation at range" error. However, this error did not affect the > result of the scan, i.e. the bootflow for scsi partition was created > correctly, and u-boot is running normally. > > Enabling CONFIG_SYS_DCACHE_OFF got rid of the errors altogether. > Perhaps this is a case where the DCACHE is not required and should be > turned off? > > Please see the log after the break below.
master:
next:
log_debug("aligned buf sysmem addr 0x%x\n", (unsigned int)addr); ret = fs_read(fname, addr, 0, size, &bytes_read); if (ret) {
Actually, it looks like the fix should be in bootmeth_script.c.
diff --git a/boot/bootmeth_script.c b/boot/bootmeth_script.c index 0269e0f9b0..68e77aa50a 100644 --- a/boot/bootmeth_script.c +++ b/boot/bootmeth_script.c @@ -99,7 +99,7 @@ static int script_read_bootflow_file(struct udevice *bootstd, if (!bflow->subdir) return log_msg_ret("prefix", -ENOMEM);
- ret = bootmeth_alloc_file(bflow, 0x10000, 1); + ret = bootmeth_alloc_file(bflow, 0x10000, ARCH_DMA_MINALIGN);
All the best, Tony
Log:
<snip>
All the best, Tony
Hi Simon,
Hi Tom, Hi Simon,
Hi Simon,
Hi Tom,
Hi Tom,
On Wed, Sep 13, 2023 at 9:22 AM Tom Rini trini@konsulko.com wrote: > > On Tue, Sep 12, 2023 at 12:38:00PM -0700, Tony Dinh wrote: > > > I've been testing the boostd for a few Marvell boards and seeing this > > error on the Thecus N2350 (Marvell Armada 385, dual-core CPU). The > > "bootflow scan scsi" command triggered the "CACHE: Misaligned > > operation at range" error. However, this error did not affect the > > result of the scan, i.e. the bootflow for scsi partition was created > > correctly, and u-boot is running normally. > > > > Enabling CONFIG_SYS_DCACHE_OFF got rid of the errors altogether. > > Perhaps this is a case where the DCACHE is not required and should be > > turned off? > > > > Please see the log after the break below. > > Can you please try -next ? There's at least one SCSI related cache > alignment fix there that's not in master, thanks.
master:
next:
Yes, it is working with the patch above. I don't see the misaligned errors anymore.
All the best , Tony
Tony Dinh
