[PATCH] board: sl28: move to OF_UPSTREAM
Use the new device devicetree files in dts/upstream/ and delete the old ones. Still keep the -u-boot.dtsi with all u-boot specifics around.
There is one catch and that is fsl-ls1028a-kontron-sl28-var3.dts which is not available upstream (yet!). For now, the base dts is used for this variant as this only differ in the compatible and the (human readable) model name.
Signed-off-by: Michael Walle michael@walle.cc --- I'll send a patch to linux to add the var3.dts, then I'll add the correct var3 dts again. --- .../arm/dts/fsl-ls1028a-kontron-sl28-var1.dts | 59 ---- .../arm/dts/fsl-ls1028a-kontron-sl28-var2.dts | 65 ---- .../arm/dts/fsl-ls1028a-kontron-sl28-var3.dts | 15 - .../arm/dts/fsl-ls1028a-kontron-sl28-var4.dts | 47 --- arch/arm/dts/fsl-ls1028a-kontron-sl28.dts | 308 ------------------ board/kontron/sl28/spl.c | 11 +- configs/kontron_sl28_defconfig | 5 +- 7 files changed, 8 insertions(+), 502 deletions(-) delete mode 100644 arch/arm/dts/fsl-ls1028a-kontron-sl28-var1.dts delete mode 100644 arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts delete mode 100644 arch/arm/dts/fsl-ls1028a-kontron-sl28-var3.dts delete mode 100644 arch/arm/dts/fsl-ls1028a-kontron-sl28-var4.dts delete mode 100644 arch/arm/dts/fsl-ls1028a-kontron-sl28.dts
diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var1.dts b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var1.dts deleted file mode 100644 index 7cd29ab970..0000000000 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var1.dts +++ /dev/null @@ -1,59 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Device Tree file for the Kontron SMARC-sAL28 board. - * - * This is for the network variant 1 which has one ethernet port. It is - * different than the base variant, which also has one port, but here the - * port is connected via RGMII. This port is not TSN aware. - * None of the four SerDes lanes are used by the module, instead they are - * all led out to the carrier for customer use. - * - * Copyright (C) 2021 Michael Walle michael@walle.cc - * - */ - -/dts-v1/; -#include "fsl-ls1028a-kontron-sl28.dts" -#include <dt-bindings/net/qca-ar803x.h> - -/ { - model = "Kontron SMARC-sAL28 (4 Lanes)"; - compatible = "kontron,sl28-var1", "kontron,sl28", "fsl,ls1028a"; -}; - -&enetc_mdio_pf3 { - /* Delete unused phy node */ - /delete-node/ ethernet-phy@5; - - phy0: ethernet-phy@4 { - reg = <0x4>; - eee-broken-1000t; - eee-broken-100tx; - qca,clk-out-frequency = <125000000>; - qca,clk-out-strength = <AR803X_STRENGTH_FULL>; - qca,keep-pll-enabled; - vddio-supply = <&vddio>; - - vddio: vddio-regulator { - regulator-name = "VDDIO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddh: vddh-regulator { - regulator-name = "VDDH"; - }; - }; -}; - -&enetc_port0 { - status = "disabled"; - /* Delete the phy-handle to the old phy0 label */ - /delete-property/ phy-handle; -}; - -&enetc_port1 { - phy-handle = <&phy0>; - phy-mode = "rgmii-id"; - status = "okay"; -}; diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts deleted file mode 100644 index 330e34f933..0000000000 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var2.dts +++ /dev/null @@ -1,65 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Device Tree file for the Kontron SMARC-sAL28 board. - * - * This is for the network variant 2 which has two ethernet ports. These - * ports are connected to the internal switch. - * - * Copyright (C) 2021 Michael Walle michael@walle.cc - * - */ - -/dts-v1/; -#include "fsl-ls1028a-kontron-sl28.dts" - -/ { - model = "Kontron SMARC-sAL28 (TSN-on-module)"; - compatible = "kontron,sl28-var2", "kontron,sl28", "fsl,ls1028a"; -}; - -&enetc_mdio_pf3 { - phy1: ethernet-phy@4 { - reg = <0x4>; - eee-broken-1000t; - eee-broken-100tx; - }; -}; - -&enetc_port0 { - status = "disabled"; - /* - * In the base device tree the PHY at address 5 was assigned for - * this port. On this module this PHY is connected to a switch - * port instead. Therefore, delete the phy-handle property here. - */ - /delete-property/ phy-handle; -}; - -&enetc_port2 { - status = "okay"; -}; - -&mscc_felix { - status = "okay"; -}; - -&mscc_felix_port0 { - label = "swp0"; - managed = "in-band-status"; - phy-handle = <&phy0>; - phy-mode = "sgmii"; - status = "okay"; -}; - -&mscc_felix_port1 { - label = "swp1"; - managed = "in-band-status"; - phy-handle = <&phy1>; - phy-mode = "sgmii"; - status = "okay"; -}; - -&mscc_felix_port4 { - ethernet = <&enetc_port2>; - status = "okay"; -}; diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var3.dts b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var3.dts deleted file mode 100644 index 0c8b2af41a..0000000000 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var3.dts +++ /dev/null @@ -1,15 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Device Tree file for the Kontron SMARC-sAL28 board. - * - * Copyright (C) 2019 Michael Walle michael@walle.cc - * - */ - -/dts-v1/; -#include "fsl-ls1028a-kontron-sl28.dts" - -/ { - model = "Kontron SMARC-sAL28 (Single PHY)"; - compatible = "kontron,sl28-var3", "kontron,sl28", "fsl,ls1028a"; -}; diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var4.dts b/arch/arm/dts/fsl-ls1028a-kontron-sl28-var4.dts deleted file mode 100644 index 9b5e92fb75..0000000000 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28-var4.dts +++ /dev/null @@ -1,47 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Device Tree file for the Kontron SMARC-sAL28 board. - * - * This is for the network variant 4 which has two ethernet ports. It - * extends the base and provides one more port connected via RGMII. - * - * Copyright (C) 2021 Michael Walle michael@walle.cc - * - */ - -/dts-v1/; -#include "fsl-ls1028a-kontron-sl28.dts" -#include <dt-bindings/net/qca-ar803x.h> - -/ { - model = "Kontron SMARC-sAL28 (Dual PHY)"; - compatible = "kontron,sl28-var4", "kontron,sl28", "fsl,ls1028a"; -}; - -&enetc_mdio_pf3 { - phy1: ethernet-phy@4 { - reg = <0x4>; - eee-broken-1000t; - eee-broken-100tx; - qca,clk-out-frequency = <125000000>; - qca,clk-out-strength = <AR803X_STRENGTH_FULL>; - qca,keep-pll-enabled; - vddio-supply = <&vddio>; - - vddio: vddio-regulator { - regulator-name = "VDDIO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vddh: vddh-regulator { - regulator-name = "VDDH"; - }; - }; -}; - -&enetc_port1 { - phy-handle = <&phy1>; - phy-mode = "rgmii-id"; - status = "okay"; -}; diff --git a/arch/arm/dts/fsl-ls1028a-kontron-sl28.dts b/arch/arm/dts/fsl-ls1028a-kontron-sl28.dts deleted file mode 100644 index ab713b4949..0000000000 --- a/arch/arm/dts/fsl-ls1028a-kontron-sl28.dts +++ /dev/null @@ -1,308 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Device Tree file for the Kontron SMARC-sAL28 board. - * - * Copyright (C) 2021 Michael Walle michael@walle.cc - * - */ - -/dts-v1/; -#include "fsl-ls1028a.dtsi" -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> - -/ { - model = "Kontron SMARC-sAL28"; - compatible = "kontron,sl28", "fsl,ls1028a"; - - aliases { - crypto = &crypto; - serial0 = &duart0; - serial1 = &duart1; - serial2 = &lpuart1; - spi0 = &fspi; - spi1 = &dspi2; - mmc0 = &esdhc1; - mmc1 = &esdhc; - rtc0 = &rtc; - rtc1 = &ftm_alarm0; - }; - - buttons0 { - compatible = "gpio-keys"; - - power-button { - interrupts-extended = <&sl28cpld_intc - 4 IRQ_TYPE_EDGE_BOTH>; - linux,code = <KEY_POWER>; - label = "Power"; - }; - - sleep-button { - interrupts-extended = <&sl28cpld_intc - 5 IRQ_TYPE_EDGE_BOTH>; - linux,code = <KEY_SLEEP>; - label = "Sleep"; - }; - }; - - buttons1 { - compatible = "gpio-keys-polled"; - poll-interval = <200>; - - lid-switch { - linux,input-type = <EV_SW>; - linux,code = <SW_LID>; - gpios = <&sl28cpld_gpio3 4 GPIO_ACTIVE_LOW>; - label = "Lid"; - }; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&can0 { - status = "okay"; -}; - -&dspi2 { - status = "okay"; -}; - -&duart0 { - status = "okay"; -}; - -&duart1 { - status = "okay"; -}; - -&enetc_mdio_pf3 { - phy0: ethernet-phy@5 { - reg = <0x5>; - eee-broken-1000t; - eee-broken-100tx; - }; -}; - -&enetc_port0 { - phy-handle = <&phy0>; - phy-mode = "sgmii"; - managed = "in-band-status"; - status = "okay"; -}; - -&esdhc { - sd-uhs-sdr104; - sd-uhs-sdr50; - sd-uhs-sdr25; - sd-uhs-sdr12; - status = "okay"; -}; - -&esdhc1 { - mmc-hs200-1_8v; - mmc-hs400-1_8v; - bus-width = <8>; - status = "okay"; -}; - -&fspi { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - m25p,fast-read; - spi-max-frequency = <133000000>; - reg = <0>; - /* The following setting enables 1-1-2 (CMD-ADDR-DATA) mode */ - spi-rx-bus-width = <2>; /* 2 SPI Rx lines */ - spi-tx-bus-width = <1>; /* 1 SPI Tx line */ - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - reg = <0x000000 0x010000>; - label = "rcw"; - read-only; - }; - - partition@10000 { - reg = <0x010000 0x1d0000>; - label = "failsafe bootloader"; - read-only; - }; - - partition@200000 { - reg = <0x200000 0x010000>; - label = "configuration store"; - }; - - partition@210000 { - reg = <0x210000 0x1d0000>; - label = "bootloader"; - }; - - partition@3e0000 { - reg = <0x3e0000 0x020000>; - label = "bootloader environment"; - }; - }; - }; -}; - -&gpio1 { - gpio-line-names = - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "TDO", "TCK", - "", "", "", "", "", "", "", ""; -}; - -&gpio2 { - gpio-line-names = - "", "", "", "", "", "", "TMS", "TDI", - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", ""; -}; - -&i2c0 { - status = "okay"; - - rtc: rtc@32 { - compatible = "microcrystal,rv8803"; - reg = <0x32>; - }; - - sl28cpld@4a { - compatible = "kontron,sl28cpld"; - reg = <0x4a>; - #address-cells = <1>; - #size-cells = <0>; - - watchdog@4 { - compatible = "kontron,sl28cpld-wdt"; - reg = <0x4>; - kontron,assert-wdt-timeout-pin; - }; - - hwmon@b { - compatible = "kontron,sl28cpld-fan"; - reg = <0xb>; - }; - - sl28cpld_pwm0: pwm@c { - compatible = "kontron,sl28cpld-pwm"; - reg = <0xc>; - #pwm-cells = <2>; - }; - - sl28cpld_pwm1: pwm@e { - compatible = "kontron,sl28cpld-pwm"; - reg = <0xe>; - #pwm-cells = <2>; - }; - - sl28cpld_gpio0: gpio@10 { - compatible = "kontron,sl28cpld-gpio"; - reg = <0x10>; - interrupts-extended = <&gpio2 6 - IRQ_TYPE_EDGE_FALLING>; - - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = - "GPIO0_CAM0_PWR_N", "GPIO1_CAM1_PWR_N", - "GPIO2_CAM0_RST_N", "GPIO3_CAM1_RST_N", - "GPIO4_HDA_RST_N", "GPIO5_PWM_OUT", - "GPIO6_TACHIN", "GPIO7"; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - sl28cpld_gpio1: gpio@15 { - compatible = "kontron,sl28cpld-gpio"; - reg = <0x15>; - interrupts-extended = <&gpio2 6 - IRQ_TYPE_EDGE_FALLING>; - - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = - "GPIO8", "GPIO9", "GPIO10", "GPIO11", - "", "", "", ""; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - sl28cpld_gpio2: gpio@1a { - compatible = "kontron,sl28cpld-gpo"; - reg = <0x1a>; - - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = - "LCD0 voltage enable", - "LCD0 backlight enable", - "eMMC reset", "LVDS bridge reset", - "LVDS bridge power-down", - "SDIO power enable", - "", ""; - }; - - sl28cpld_gpio3: gpio@1b { - compatible = "kontron,sl28cpld-gpi"; - reg = <0x1b>; - - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = - "Power button", "Force recovery", "Sleep", - "Battery low", "Lid state", "Charging", - "Charger present", ""; - }; - - sl28cpld_intc: interrupt-controller@1c { - compatible = "kontron,sl28cpld-intc"; - reg = <0x1c>; - interrupts-extended = <&gpio2 6 - IRQ_TYPE_EDGE_FALLING>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - }; - - eeprom@50 { - compatible = "atmel,24c32"; - reg = <0x50>; - pagesize = <32>; - }; -}; - -&i2c3 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; - - eeprom@50 { - compatible = "atmel,24c32"; - reg = <0x50>; - pagesize = <32>; - }; -}; - -&lpuart1 { - status = "okay"; -}; diff --git a/board/kontron/sl28/spl.c b/board/kontron/sl28/spl.c index ffaf517a8b..80acde7495 100644 --- a/board/kontron/sl28/spl.c +++ b/board/kontron/sl28/spl.c @@ -47,15 +47,14 @@ int board_fit_config_name_match(const char *name)
switch (variant) { case 1: - return strcmp(name, "fsl-ls1028a-kontron-sl28-var1"); + return strcmp(name, "freescale/fsl-ls1028a-kontron-sl28-var1"); case 2: - return strcmp(name, "fsl-ls1028a-kontron-sl28-var2"); - case 3: - return strcmp(name, "fsl-ls1028a-kontron-sl28-var3"); + return strcmp(name, "freescale/fsl-ls1028a-kontron-sl28-var2"); case 4: - return strcmp(name, "fsl-ls1028a-kontron-sl28-var4"); + return strcmp(name, "freescale/fsl-ls1028a-kontron-sl28-var4"); + case 3: default: - return strcmp(name, "fsl-ls1028a-kontron-sl28"); + return strcmp(name, "freescale/fsl-ls1028a-kontron-sl28"); } }
diff --git a/configs/kontron_sl28_defconfig b/configs/kontron_sl28_defconfig index 639c5c6ce1..adc1d501ba 100644 --- a/configs/kontron_sl28_defconfig +++ b/configs/kontron_sl28_defconfig @@ -11,7 +11,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x1800eff0 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x3e0000 CONFIG_ENV_SECT_SIZE=0x10000 -CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1028a-kontron-sl28" +CONFIG_DEFAULT_DEVICE_TREE="freescale/fsl-ls1028a-kontron-sl28" CONFIG_SPL_TEXT_BASE=0x18010000 CONFIG_SYS_FSL_SDHC_CLK_DIV=1 CONFIG_OF_LIBFDT_OVERLAY=y @@ -73,7 +73,8 @@ CONFIG_CMD_EFIDEBUG=y CONFIG_CMD_RNG=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="fsl-ls1028a-kontron-sl28 fsl-ls1028a-kontron-sl28-var1 fsl-ls1028a-kontron-sl28-var2 fsl-ls1028a-kontron-sl28-var3 fsl-ls1028a-kontron-sl28-var4" +CONFIG_OF_UPSTREAM=y +CONFIG_OF_LIST="freescale/fsl-ls1028a-kontron-sl28 freescale/fsl-ls1028a-kontron-sl28-var1 freescale/fsl-ls1028a-kontron-sl28-var2 freescale/fsl-ls1028a-kontron-sl28-var4" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y
Ping. Any news here?
-michael
Applied.
Thanks, Peng.
-michael
Michael Walle
Peng Fan
