[U-Boot] [PATCH 1/2] arm: mvebu: theadorable: Add USB power toggle and tweak USB PHY register
This patch adds an USB power toggle for theadorable. Additionally, the USB PHY RX Channel Control 0 Register is changed to fix some issues noticed while accessing some specific USB sticks.
Signed-off-by: Stefan Roese sr@denx.de --- board/theadorable/theadorable.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 14e08a6..9c3b97c 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -5,6 +5,7 @@ */
#include <common.h> +#include <asm/gpio.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> @@ -19,6 +20,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#define MV_USB_PHY_BASE (MVEBU_AXP_USB_BASE + 0x800) +#define PHY_CHANNEL_RX_CTRL0_REG(port, chan) \ + (MV_USB_PHY_BASE + ((port) << 12) + ((chan) << 6) + 0x8) + #define THEADORABLE_GPP_OUT_ENA_LOW 0x00336780 #define THEADORABLE_GPP_OUT_ENA_MID 0x00003cf0 #define THEADORABLE_GPP_OUT_ENA_HIGH (~(0x0)) @@ -27,6 +32,9 @@ DECLARE_GLOBAL_DATA_PTR; #define THEADORABLE_GPP_OUT_VAL_MID 0x0007000c #define THEADORABLE_GPP_OUT_VAL_HIGH 0x00000000
+#define GPIO_USB0_PWR_ON 18 +#define GPIO_USB1_PWR_ON 19 + /* DDR3 static configuration */ static MV_DRAM_MC_INIT ddr3_theadorable[MV_MAX_DDR3_STATIC_SIZE] = { {0x00001400, 0x7301ca28}, /* DDR SDRAM Configuration Register */ @@ -135,6 +143,8 @@ int board_early_init_f(void)
int board_init(void) { + int ret; + /* adress of boot parameters */ gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100;
@@ -147,6 +157,28 @@ int board_init(void) mbus_dt_setup_win(&mbus_state, SPI_BUS1_DEV2_BASE, SPI_BUS0_DEV1_SIZE, CPU_TARGET_DEVICEBUS_BOOTROM_SPI, CPU_ATTR_SPI1_CS2);
+ /* + * Set RX Channel Control 0 Register: + * Tests have shown, that setting the LPF_COEF from 0 (1/8) + * to 3 (1/1) results in a more stable USB connection. + */ + setbits_le32(PHY_CHANNEL_RX_CTRL0_REG(0, 1), 0xc); + setbits_le32(PHY_CHANNEL_RX_CTRL0_REG(0, 2), 0xc); + setbits_le32(PHY_CHANNEL_RX_CTRL0_REG(0, 3), 0xc); + + /* Toggle USB power */ + ret = gpio_request(GPIO_USB0_PWR_ON, "USB0_PWR_ON"); + if (ret < 0) + return ret; + gpio_direction_output(GPIO_USB0_PWR_ON, 0); + ret = gpio_request(GPIO_USB1_PWR_ON, "USB1_PWR_ON"); + if (ret < 0) + return ret; + gpio_direction_output(GPIO_USB1_PWR_ON, 0); + mdelay(1); + gpio_set_value(GPIO_USB0_PWR_ON, 1); + gpio_set_value(GPIO_USB1_PWR_ON, 1); + return 0; }
This patch adds bootcount support to the MVEBU theadorable board. Since no reset-safe registers seem to be available, it uses the last 4KiB of SDRAM for the bootcounter location.
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/theadorable.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index a4bcf21..20a44c9 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -120,6 +120,14 @@ #define CONFIG_FPGA_STRATIX_V
/* + * Bootcounter + */ +#define CONFIG_BOOTCOUNT_LIMIT +#define CONFIG_BOOTCOUNT_RAM +/* Max size of RAM minus BOOTCOUNT_ADDR is the bootcounter address */ +#define BOOTCOUNT_ADDR 0x1000 + +/* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros */
Stefan Roese
