[U-Boot] [PULL] Please pull u-boot-imx
Hi Tom,
please pull from u-boot-imx, thanks !
The following changes since commit 3d3a74cc8c774345be7d1661b215555ad41f4515:
mmc: move MMC_SDHCI_IO_ACCESSORS to Kconfig (2016-12-29 13:08:17 -0500)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 7c4f0ff81e6fc3b58b8af5f64c3da98624e40132:
udoo: neo: Fix indentation (2017-01-02 17:55:58 +0100)
---------------------------------------------------------------- Fabio Estevam (4): udoo_neo: Remove USDHC3 entry udoo_neo: Use 'fdtfile' variable name mx6qsabreauto: Fix the EIM clock for the mx6qp variant udoo: neo: Fix indentation
Jagan Teki (12): imx6: engicam: Use bootm instead of bootz configs: engicam: Rename nand with gpmi-name in mtdparts defconfigs: engicam: Enable MMC commands in nand defconfigs: engicam: Enable UBI commands imx6: engicam: Add nandboot env support defconfigs: imx6: engicam: Enable FIT configs: engicam: Enable CONFIG_IMAGE_FORMAT_LEGACY configs: engicam: Cleanup on mmcboot env configs: engicam: Add fitboot env support imx6ul: geam6ul: Add MAINTAINERS for nand_defconfig imx6ul: geam6ul: Enable I2C support
Kevin Hilman (1): ARM: imx7s-warp: enable USB gadget ethernet
Peng Fan (1): imx: thermal: Kconfig: add MX7
Sven Ebenfeld (5): arm: imx: remove bmode , hdmidet and dek commands from SPL arm: imx: add HAB authentication of image to SPL boot tools: mkimage: add firmware-ivt image type for HAB verification doc: imx6: add section for secure boot with SPL Makefile: preserve output for images that can contain HAB Blocks
.gitignore | 2 +- Makefile | 15 +++++++++++++-- arch/arm/Makefile | 2 +- arch/arm/imx-common/Makefile | 6 ++++++ arch/arm/imx-common/hab.c | 129 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------------------- arch/arm/imx-common/spl.c | 25 +++++++++++++++++++++++++ arch/arm/imx-common/spl_sd.cfg | 10 ++++++++++ arch/arm/include/asm/imx-common/hab.h | 2 ++ board/engicam/geam6ul/MAINTAINERS | 1 + board/freescale/mx6qsabreauto/mx6qsabreauto.c | 28 ++++++++++++++++++++++++++++ board/udoo/neo/neo.c | 7 +++---- board/warp7/warp7.c | 14 ++++++++++++++ common/image.c | 6 ++++++ configs/imx6dl_icore_mmc_defconfig | 4 +++- configs/imx6dl_icore_nand_defconfig | 10 +++++++++- configs/imx6dl_icore_rqs_mmc_defconfig | 4 +++- configs/imx6q_icore_mmc_defconfig | 4 +++- configs/imx6q_icore_nand_defconfig | 10 +++++++++- configs/imx6q_icore_rqs_mmc_defconfig | 4 +++- configs/imx6ul_geam_mmc_defconfig | 4 +++- configs/imx6ul_geam_nand_defconfig | 12 +++++++++++- configs/warp7_defconfig | 5 +++++ doc/README.imx6 | 49 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/thermal/Kconfig | 2 +- include/configs/imx6qdl_icore.h | 77 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------- include/configs/imx6qdl_icore_rqs.h | 43 ++++++++++++++++++++++++++++++------------- include/configs/imx6ul_geam.h | 76 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------- include/configs/mx6_common.h | 3 +++ include/configs/udoo_neo.h | 12 ++++++------ include/configs/warp7.h | 7 +++++++ include/image.h | 1 + scripts/Makefile.lib | 3 ++- scripts/Makefile.spl | 4 +++- tools/default_image.c | 10 ++++++++-- tools/mkimage.c | 32 ++++++++++++++++++++++++++++++++ 35 files changed, 486 insertions(+), 137 deletions(-)
Best regards, Stefano
On Mon, Jan 02, 2017 at 06:08:01PM +0100, Stefano Babic wrote:
Hi Tom,
Stefano Babic
