[U-Boot] [PATCH 1/4] net: sh_eth: clean up for the SH7757's code
The SH7757's ETHER can work using the SH7724's setting. So, the patch modifies it.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- drivers/net/sh_eth.c | 9 +-------- drivers/net/sh_eth.h | 14 ++------------ 2 files changed, 3 insertions(+), 20 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index bb57e4d..1825059 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -376,12 +376,7 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) outl((FIFO_F_D_RFF | FIFO_F_D_RFD), FCFTR(port));
/* Configure e-mac registers */ -#if defined(CONFIG_CPU_SH7757) - outl(ECSIPR_BRCRXIP | ECSIPR_PSRTOIP | ECSIPR_LCHNGIP | - ECSIPR_MPDIP | ECSIPR_ICDIP, ECSIPR(port)); -#else outl(0, ECSIPR(port)); -#endif
/* Set Mac address */ val = dev->enetaddr[0] << 24 | dev->enetaddr[1] << 16 | @@ -395,14 +390,12 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) #if !defined(CONFIG_CPU_SH7757) && !defined(CONFIG_CPU_SH7724) outl(0, PIPR(port)); #endif -#if !defined(CONFIG_CPU_SH7724) +#if !defined(CONFIG_CPU_SH7724) && !defined(CONFIG_CPU_SH7757) outl(APR_AP, APR(port)); outl(MPR_MP, MPR(port)); #endif #if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) outl(TPAUSER_TPAUSE, TPAUSER(port)); -#elif defined(CONFIG_CPU_SH7757) - outl(TPAUSER_UNLIMITED, TPAUSER(port)); #endif
#if defined(CONFIG_CPU_SH7734) diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index 50f4b69..5276be3 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -319,7 +319,7 @@ enum EESR_BIT { EESR_FTC = 0x00200000, EESR_TDE = 0x00100000, EESR_TFE = 0x00080000, EESR_FRC = 0x00040000, EESR_RDE = 0x00020000, EESR_RFE = 0x00010000, -#if defined(CONFIG_CPU_SH7724) && !defined(CONFIG_CPU_SH7757) +#if defined(CONFIG_CPU_SH7724) || defined(CONFIG_CPU_SH7757) EESR_CND = 0x00000800, #endif EESR_DLC = 0x00000400, @@ -426,9 +426,7 @@ enum FELIC_MODE_BIT { #if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) #define ECMR_CHG_DM (ECMR_TRCCM | ECMR_RZPF | ECMR_ZPF | ECMR_PFR | ECMR_RXF | \ ECMR_TXF | ECMR_MCT) -#elif CONFIG_CPU_SH7757 -#define ECMR_CHG_DM (ECMR_ZPF) -#elif CONFIG_CPU_SH7724 +#elif CONFIG_CPU_SH7724 || CONFIG_CPU_SH7757 #define ECMR_CHG_DM (ECMR_ZPF | ECMR_PFR | ECMR_RXF | ECMR_TXF) #else #define ECMR_CHG_DM (ECMR_ZPF | ECMR_PFR | ECMR_RXF | ECMR_TXF | ECMR_MCT) @@ -473,20 +471,12 @@ enum ECSIPR_STATUS_MASK_BIT {
/* APR */ enum APR_BIT { -#ifdef CONFIG_CPU_SH7757 - APR_AP = 0x00000001, -#else APR_AP = 0x00000004, -#endif };
/* MPR */ enum MPR_BIT { -#ifdef CONFIG_CPU_SH7757 - MPR_MP = 0x00000001, -#else MPR_MP = 0x00000006, -#endif };
/* TRSCER */
Tested-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Acked-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
2012/6/27 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
#endif
/* TRSCER */
1.7.1
Hi Iwamatsu-san,
Thank for the test and Acked-by:
Today I checked remotes/origin/{master,next} in u-boot-net.git, but, the patches have not applied yet. Should I resend the patches?
Best regards, Yoshihiro Shimoda
#endif
/* TRSCER */
1.7.1
Perhaps, your patch already are in Joe' patch queue, I think. http://patchwork.ozlabs.org/patch/167486/
Nobuhiro
2012/7/23 Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com:
Hi Iwamatsu-san,
#endif
/* TRSCER */
1.7.1
-- Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com EC No. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Thank you for the reply. I will wait until it is merged.
Nobuhiro
Hi Iwamatsu-san,
#endif
/* TRSCER */
1.7.1
Hi Yoshihiro,
On Mon, Jul 23, 2012 at 7:52 PM, Shimoda, Yoshihiro yoshihiro.shimoda.uh@renesas.com wrote:
Applied to next, thanks.
-Joe
Joe Hershberger
Nobuhiro Iwamatsu
Shimoda, Yoshihiro
