[PATCH 1/3] stm32mp: stm32prog: Add support of ENV partition type
Add support of "ENV" partition type in flashlayout to select the "u-boot-env" GUID, with PARTITION_U_BOOT_ENVIRONMENT = 3de21764-95bd-54bd-a5c3-4abe786f38a8, that mean a partition holding a U-Boot environment introduced by commit c0364ce1c695 ("doc/README.gpt: define partition type GUID for U-Boot environment")'
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 5 +++++ arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h | 1 + 2 files changed, 6 insertions(+)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 6f3641ccf57b..1bd86b5187da 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -430,6 +430,8 @@ static int parse_type(struct stm32prog_data *data, } } else if (!strcmp(p, "FIP")) { part->part_type = PART_FIP; + } else if (!strcmp(p, "ENV")) { + part->part_type = PART_ENV; } else if (!strcmp(p, "System")) { part->part_type = PART_SYSTEM; } else if (!strcmp(p, "FileSystem")) { @@ -1130,6 +1132,9 @@ static int create_gpt_partitions(struct stm32prog_data *data) case PART_BINARY: type_str = LINUX_RESERVED_UUID; break; + case PART_ENV: + type_str = "u-boot-env"; + break; case PART_FIP: type_str = FIP_TYPE_UUID; break; diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index 58f4b96fa752..4c2c1314d990 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -100,6 +100,7 @@ struct stm32_header_v2 { enum stm32prog_part_type { PART_BINARY, PART_FIP, + PART_ENV, PART_SYSTEM, PART_FILESYSTEM, RAW_IMAGE,
Add support of "ESP" partition type in flashlayout to select the "EFI System Partition", associated to U-Boot "system" partition type guid, PARTITION_SYSTEM_GUID = C12A7328-F81F-11d2-BA4B-00A0C93EC93B.
This partition is the bootable partition for efi boot.
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 8 +++++++- arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h | 8 +++++++- 2 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 1bd86b5187da..07369919620e 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -434,6 +434,8 @@ static int parse_type(struct stm32prog_data *data, part->part_type = PART_ENV; } else if (!strcmp(p, "System")) { part->part_type = PART_SYSTEM; + } else if (!strcmp(p, "ESP")) { + part->part_type = PART_ESP; } else if (!strcmp(p, "FileSystem")) { part->part_type = PART_FILESYSTEM; } else if (!strcmp(p, "RawImage")) { @@ -1138,7 +1140,11 @@ static int create_gpt_partitions(struct stm32prog_data *data) case PART_FIP: type_str = FIP_TYPE_UUID; break; - default: + case PART_ESP: + /* EFI System Partition */ + type_str = "system"; + break; + default: /* PART_FILESYSTEM or PART_SYSTEM for distro */ type_str = "linux"; break; } diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index 4c2c1314d990..a6fb9d5e9cc5 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -96,13 +96,19 @@ struct stm32_header_v2 { u8 extension_padding[376]; };
-/* partition type in flashlayout file */ +/* + * partition type in flashlayout file + * SYSTEM = linux partition, bootable + * FILESYSTEM = linux partition + * ESP = EFI system partition + */ enum stm32prog_part_type { PART_BINARY, PART_FIP, PART_ENV, PART_SYSTEM, PART_FILESYSTEM, + PART_ESP, RAW_IMAGE, };
- } else if (!strcmp(p, "ESP")) {
} else if (!strcmp(p, "FileSystem")) { part->part_type = PART_FILESYSTEM; } else if (!strcmp(p, "RawImage")) {part->part_type = PART_ESP;
default:
case PART_ESP:
break;
- partition type in flashlayout file
- SYSTEM = linux partition, bootable
- FILESYSTEM = linux partition
- ESP = EFI system partition
- PART_ESP, RAW_IMAGE,
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
default:
case PART_ESP:
break;
Applied to u-boot-stm/next
Thanks
Patrice
Add support of "FWU_MDATA" partition type in flashlayout to select the TF-A firmware update metadata partition type guid, associated to U-Boot "system" partition type guid, FWU_MDATA_GUID introduced by commit 2eaedc95164f ("FWU: Add FWU metadata structure and driver for accessing metadata") and used in gpt_get_mdata_partitions() for commit 554b38f7a532 ("FWU: Add FWU metadata access driver for GPT partitioned block devices")
See also recommendation in FWU-PSA-A_DEN0118_1.0ALP3.pdf 4.1.2 Metadata integration with GPT When embedded in a GPT, each metadata replica occupies a single partition with PartitionTypeGUID = metadata_uuid. UUID = 8a7a84a0-8387-40f6-ab41-a8b9a5a60d23
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 11 +++++++++++ arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h | 1 + 2 files changed, 12 insertions(+)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 07369919620e..a2ff5558a519 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -63,6 +63,12 @@ static const efi_guid_t uuid_mmc[3] = { ROOTFS_MMC2_UUID };
+/* + * GUID value defined in the FWU specification for identification + * of the FWU metadata partition. + */ +#define FWU_MDATA_UUID "8a7a84a0-8387-40f6-ab41-a8b9a5a60d23" + /* FIP type partition UUID used by TF-A*/ #define FIP_TYPE_UUID "19D5DF83-11B0-457B-BE2C-7559C13142A5"
@@ -430,6 +436,8 @@ static int parse_type(struct stm32prog_data *data, } } else if (!strcmp(p, "FIP")) { part->part_type = PART_FIP; + } else if (!strcmp(p, "FWU_MDATA")) { + part->part_type = PART_FWU_MDATA; } else if (!strcmp(p, "ENV")) { part->part_type = PART_ENV; } else if (!strcmp(p, "System")) { @@ -1140,6 +1148,9 @@ static int create_gpt_partitions(struct stm32prog_data *data) case PART_FIP: type_str = FIP_TYPE_UUID; break; + case PART_FWU_MDATA: + type_str = FWU_MDATA_UUID; + break; case PART_ESP: /* EFI System Partition */ type_str = "system"; diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h index a6fb9d5e9cc5..02b286be8182 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.h @@ -105,6 +105,7 @@ struct stm32_header_v2 { enum stm32prog_part_type { PART_BINARY, PART_FIP, + PART_FWU_MDATA, PART_ENV, PART_SYSTEM, PART_FILESYSTEM,
- GUID value defined in the FWU specification for identification
- of the FWU metadata partition.
- } else if (!strcmp(p, "FWU_MDATA")) {
} else if (!strcmp(p, "ENV")) { part->part_type = PART_ENV; } else if (!strcmp(p, "System")) {part->part_type = PART_FWU_MDATA;
- PART_FWU_MDATA, PART_ENV, PART_SYSTEM, PART_FILESYSTEM,
Thanks Patrice
Thanks
Patrice
- } else if (!strcmp(p, "ENV")) {
} else if (!strcmp(p, "System")) { part->part_type = PART_SYSTEM; } else if (!strcmp(p, "FileSystem")) {part->part_type = PART_ENV;
case PART_ENV:
- PART_ENV, PART_SYSTEM, PART_FILESYSTEM, RAW_IMAGE,
Thanks Patrice
case PART_ENV:
Thanks
Patrice
Patrice CHOTARD
Patrick Delaunay
