[U-Boot] [PATCH 1/3] USB: Armada100: Add UTMI PHY interface driver
This patch adds USB host controller's UTMI PHY interface driver for Armada100 SOCs.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- arch/arm/include/asm/arch-armada100/armada100.h | 7 ++ drivers/usb/host/utmi-armada100.c | 87 +++++++++++++++++++++++ drivers/usb/host/utmi-armada100.h | 79 ++++++++++++++++++++ 3 files changed, 173 insertions(+), 0 deletions(-) create mode 100644 drivers/usb/host/utmi-armada100.c create mode 100644 drivers/usb/host/utmi-armada100.h
diff --git a/arch/arm/include/asm/arch-armada100/armada100.h b/arch/arm/include/asm/arch-armada100/armada100.h index 0ed3a8e..d6984dc 100644 --- a/arch/arm/include/asm/arch-armada100/armada100.h +++ b/arch/arm/include/asm/arch-armada100/armada100.h @@ -43,6 +43,13 @@ #define SSP2_APBCLK 0x01 #define SSP2_FNCLK 0x02
+/* USB Clock/reset control bits */ +#define USB_SPH_AXICLK_EN 0x10 +#define USB_SPH_AXI_RST 0x02 + +/* MPMU Clocks */ +#define MPMU_EN_ALL_CLKS 0x1EFFFF + /* Register Base Addresses */ #define ARMD1_DRAM_BASE 0xB0000000 #define ARMD1_FEC_BASE 0xC0800000 diff --git a/drivers/usb/host/utmi-armada100.c b/drivers/usb/host/utmi-armada100.c new file mode 100644 index 0000000..b8225dd --- /dev/null +++ b/drivers/usb/host/utmi-armada100.c @@ -0,0 +1,87 @@ +/* + * (C) Copyright 2012 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <usb.h> +#include <asm/arch/cpu.h> +#include <asm/arch/armada100.h> +#include "utmi-armada100.h" + +static void utmi_phy_init(void) +{ + struct armd1usb_phy_reg *phy_regs = + (struct armd1usb_phy_reg *)UTMI_PHY_BASE; + + setbits_le32(&phy_regs->utmi_ctrl, INPKT_DELAY_SOF | PLL_PWR_UP); + udelay(1000); + setbits_le32(&phy_regs->utmi_ctrl, PHY_PWR_UP); + + clrbits_le32(&phy_regs->utmi_pll, PLL_FBDIV_MASK | PLL_REFDIV_MASK); + setbits_le32(&phy_regs->utmi_pll, N_DIVIDER << PLL_FBDIV | M_DIVIDER); + + setbits_le32(&phy_regs->utmi_tx, PHSEL_VAL << CK60_PHSEL); + + /* Calibrate pll */ + while ((readl(&phy_regs->utmi_pll) & PLL_READY) == 0) + ; + + udelay(200); + setbits_le32(&phy_regs->utmi_pll, VCOCAL_START); + udelay(400); + clrbits_le32(&phy_regs->utmi_pll, VCOCAL_START); + + udelay(200); + setbits_le32(&phy_regs->utmi_tx, RCAL_START); + udelay(400); + clrbits_le32(&phy_regs->utmi_tx, RCAL_START); + + while ((readl(&phy_regs->utmi_pll) & PLL_READY) == 0) + ; +} + +/* + * Initialize USB host controller's UTMI Physical interface + */ +void utmi_init(void) +{ + struct armd1mpmu_registers *mpmu_regs = + (struct armd1mpmu_registers *)ARMD1_MPMU_BASE; + + struct armd1apmu_registers *apmu_regs = + (struct armd1apmu_registers *)ARMD1_APMU_BASE; + + /* Turn on main PMU clocks */ + writel(MPMU_EN_ALL_CLKS, &mpmu_regs->acgr); + + /* USB Clock reset */ + writel(USB_SPH_AXICLK_EN, &apmu_regs->usbcrc); + writel(USB_SPH_AXICLK_EN | USB_SPH_AXI_RST, &apmu_regs->usbcrc); + + /* Initialize UTMI transceiver */ + utmi_phy_init(); +} diff --git a/drivers/usb/host/utmi-armada100.h b/drivers/usb/host/utmi-armada100.h new file mode 100644 index 0000000..dd0ccdb --- /dev/null +++ b/drivers/usb/host/utmi-armada100.h @@ -0,0 +1,79 @@ +/* + * (C) Copyright 2012 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __UTMI_ARMADA100__ +#define __UTMI_ARMADA100__ + +#define UTMI_PHY_BASE 0xD4206000 + +/* utmi_ctrl - bits */ +#define INPKT_DELAY_SOF (1 << 28) +#define PLL_PWR_UP 2 +#define PHY_PWR_UP 1 + +/* utmi_pll - bits */ +#define PLL_FBDIV_MASK 0x00000FF0 +#define PLL_FBDIV 4 +#define PLL_REFDIV_MASK 0x0000000F +#define PLL_REFDIV 0 +#define PLL_READY 0x800000 +#define VCOCAL_START (1 << 21) + +#define N_DIVIDER 0xEE +#define M_DIVIDER 0x0B + +/* utmi_tx - bits */ +#define CK60_PHSEL 17 +#define PHSEL_VAL 0x4 +#define RCAL_START (1 << 12) + +/* + * USB PHY registers + * Refer Datasheet Appendix A.21 + */ +struct armd1usb_phy_reg { + u32 utmi_rev; /* USB PHY Revision */ + u32 utmi_ctrl; /* USB PHY Control register */ + u32 utmi_pll; /* PLL register */ + u32 utmi_tx; /* Tx register */ + u32 utmi_rx; /* Rx register */ + u32 utmi_ivref; /* IVREF register */ + u32 utmi_tst_g0; /* Test group 0 register */ + u32 utmi_tst_g1; /* Test group 1 register */ + u32 utmi_tst_g2; /* Test group 2 register */ + u32 utmi_tst_g3; /* Test group 3 register */ + u32 utmi_tst_g4; /* Test group 4 register */ + u32 utmi_tst_g5; /* Test group 5 register */ + u32 utmi_reserve; /* Reserve Register */ + u32 utmi_usb_int; /* USB interuppt register */ + u32 utmi_dbg_ctl; /* Debug control register */ + u32 utmi_otg_addon; /* OTG addon register */ +}; + +void utmi_init(void); + +#endif /* __UTMI_ARMADA100__ */
This patch adds support for USB EHCI driver for Armada100 SOCs.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- arch/arm/include/asm/arch-armada100/armada100.h | 1 + drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-armada100.c | 62 +++++++++++++++++++++++ 3 files changed, 64 insertions(+), 0 deletions(-) create mode 100644 drivers/usb/host/ehci-armada100.c
diff --git a/arch/arm/include/asm/arch-armada100/armada100.h b/arch/arm/include/asm/arch-armada100/armada100.h index d6984dc..26f836e 100644 --- a/arch/arm/include/asm/arch-armada100/armada100.h +++ b/arch/arm/include/asm/arch-armada100/armada100.h @@ -67,6 +67,7 @@ #define ARMD1_SSP5_BASE 0xD4021000 #define ARMD1_UART3_BASE 0xD4026000 #define ARMD1_MPMU_BASE 0xD4050000 +#define ARMD1_USB_HOST_BASE 0xD4209000 #define ARMD1_APMU_BASE 0xD4282800 #define ARMD1_CPU_BASE 0xD4282C00
diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index 77e217f..94e72c3 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -35,6 +35,7 @@ COBJS-$(CONFIG_USB_SL811HS) += sl811-hcd.o
# echi COBJS-$(CONFIG_USB_EHCI) += ehci-hcd.o +COBJS-$(CONFIG_USB_EHCI_ARMADA100) += ehci-armada100.o utmi-armada100.o ifdef CONFIG_MPC512X COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-mpc512x.o else diff --git a/drivers/usb/host/ehci-armada100.c b/drivers/usb/host/ehci-armada100.c new file mode 100644 index 0000000..cf05d1a --- /dev/null +++ b/drivers/usb/host/ehci-armada100.c @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2012 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * This driver is based on Kirkwood echi driver + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <usb.h> +#include "ehci.h" +#include "ehci-core.h" +#include <asm/arch/cpu.h> +#include <asm/arch/armada100.h> +#include "utmi-armada100.h" + +/* + * EHCI host controller init + */ +int ehci_hcd_init(void) +{ + utmi_init(); + hccr = (struct ehci_hccr *)(ARMD1_USB_HOST_BASE + 0x100); + hcor = (struct ehci_hcor *)((uint32_t) hccr + + HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + printf("Kirkwood-ehci: init hccr %x and hcor %x hc_length %d\n", + (uint32_t)hccr, (uint32_t)hcor, + (uint32_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + return 0; +} + +/* + * EHCI host controller stop + */ +int ehci_hcd_stop(void) +{ + return 0; +}
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: 25 January 2012 17:50 To: linux@bohmer.net Cc: Prafulla Wadaskar; marek.vasut@gmail.com; u-boot@lists.denx.de; Ajay Bhargav Subject: [PATCH 2/3] USB: Armada100: ECHI Driver for Armada100 SOCs
# echi COBJS-$(CONFIG_USB_EHCI) += ehci-hcd.o +COBJS-$(CONFIG_USB_EHCI_ARMADA100) += ehci-armada100.o utmi- armada100.o ifdef CONFIG_MPC512X COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-mpc512x.o else diff --git a/drivers/usb/host/ehci-armada100.c b/drivers/usb/host/ehci-armada100.c new file mode 100644 index 0000000..cf05d1a --- /dev/null +++ b/drivers/usb/host/ehci-armada100.c @@ -0,0 +1,62 @@ +/*
- (C) Copyright 2012
- eInfochips Ltd. <www.einfochips.com>
- Written-by: Ajay Bhargav ajay.bhargav@einfochips.com
- This driver is based on Kirkwood echi driver
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- project.
- Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- MA 02110-1301 USA
- EHCI host controller init
- utmi_init();
- hccr = (struct ehci_hccr *)(ARMD1_USB_HOST_BASE + 0x100);
- hcor = (struct ehci_hcor *)((uint32_t) hccr
- printf("Kirkwood-ehci: init hccr %x and hcor %x hc_length %d\n",
Wrong printf message, it's not Kirkwood.
Regards.. Prafulla . . .
----- "Prafulla Wadaskar" prafulla@marvell.com wrote: [...snip...]
I don't know how I missed that.. though, I did changed it :/ Any other comments on patches?
Regards, Ajay Bhargav
This patch adds support for USB commands and USB storage device for Marvell gplugD
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- include/configs/gplugd.h | 17 +++++++++++++++++ 1 files changed, 17 insertions(+), 0 deletions(-)
diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 9813309..f8dc74f 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -134,4 +134,21 @@ #define CONFIG_CMD_EDITENV #define CONFIG_CMD_SAVEENV
+#define CONFIG_CMD_USB + +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_ARMADA100 +#define CONFIG_EHCI_IS_TDI +#define CONFIG_USB_STORAGE + +#ifndef CONFIG_DOS_PARTITION +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_DOS_PARTITION */ + +#define CONFIG_ISO_PARTITION +#define CONFIG_SUPPORT_VFAT +#define CONFIG_CMD_EXT2 +#endif /* CONFIG_CMD_USB */ + #endif /* __CONFIG_GPLUGD_H */
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: 25 January 2012 17:50 To: linux@bohmer.net Cc: Prafulla Wadaskar; marek.vasut@gmail.com; u-boot@lists.denx.de; Ajay Bhargav Subject: [PATCH 3/3] Armada100: gplugD: Add USB command support
This line should be moved up where all the commands are defined (below config_cmd_default.h)
Does this undef needed? remove it you can.
[...snip...]
I will review it again and remove it if not needed.
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: 25 January 2012 17:50 To: linux@bohmer.net Cc: Prafulla Wadaskar; marek.vasut@gmail.com; u-boot@lists.denx.de; Ajay Bhargav Subject: [PATCH 1/3] USB: Armada100: Add UTMI PHY interface driver
Turning on all clocks is not logical to enable this support, only relevant clock necessary for this components SHOULD BE enabled.
Enabling clocks for unused peripherals/components may result in unnecessarily extra power consumption
Otherwise ack for rest of the patch
what's the status of this patch/patchset?
Thanks M
Ajay Bhargav
Prafulla Wadaskar
