[U-Boot] [PATCH] [MPC837x v2] Make it work again with USB.
USB register range IMMR+0x00-0xff is reserved and hangs the CPU.
Signed-off-by: Andre Schwarz andre.schwarz@matrix-vision.de --- arch/powerpc/cpu/mpc83xx/cpu_init.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 7a1cae7..cfead18 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -327,7 +327,7 @@ void cpu_init_f (volatile immap_t * im) im->gpio[1].dir = CONFIG_SYS_GPIO2_DIR; #endif #ifdef CONFIG_USB_EHCI_FSL -#ifndef CONFIG_MPC834x +#if !defined(CONFIG_MPC834x) && !defined(CONFIG_MPC837x) uint32_t temp; struct usb_ehci *ehci = (struct usb_ehci *)CONFIG_SYS_FSL_USB_ADDR;
On Tue, 16 Nov 2010 13:37:50 +0100 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
nack, 837x has a usb controller at IMMR+0x23000. Check to see whether there is an invalid USB clock setting in the SCCR?
Thanks,
Kim
Kim,
yes - but offset 0x00-0xff is explicitly reserved regarding to the manual. Don't know whether it is a "should not" or "must not be touched". All I can see is a CPU hang with arbiter event register reporting a timeout on 0xe0023000.
Check to see whether there is an invalid USB clock setting in the SCCR? All clocks are turned on except SEC and 2nd TSEC. After all USB is running fine with this patch, i.e. there can hardly be a missing clock.
Please re-think you NAK. -- Gruß, André Schwarz
MATRIX VISION GmbH, Talstrasse 16, DE-71570 Oppenweiler Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschaeftsfuehrer: Gerhard Thullner, Werner Armingeon, Uwe Furtner
On Mon, 29 Nov 2010 08:59:21 +0100 "Schwarz,Andre" andre.schwarz@matrix-vision.de wrote:
Kim,
afaik, 834x and 837x don't have any special USB settings in common, so, this patch, at least in it's current form, is not on.
0xe0023500 should be the address of the config register being accessed here; please check the code isn't accessing 0xe0023000, as you mention above.
If that's correct, try something like the following so we can determine what setting the USB controller didn't agree with:
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 7a1cae7..cbc4157 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -332,7 +332,7 @@ void cpu_init_f (volatile immap_t * im) struct usb_ehci *ehci = (struct usb_ehci *)CONFIG_SYS_FSL_USB_ADDR;
/* Configure interface. */ - setbits_be32(&ehci->control, REFSEL_16MHZ | UTMI_PHY_EN); + setbits_be32(&ehci->control, 0);
/* Wait for clock to stabilize */ do {
Thanks,
Kim
Kim,
finally found some time to re-work my 8377 board code for submission.
sorry to bother you again, but I again stumbled over the discussed USB init issue :
ok - this was some kind of misunderstanding. ehci regs are based at immr + 0x23000 with the "config" pointing to offset 0x500 inside ehci. This looks sane to me.
MPC837x has only 2 working bits inside the control register :
Bit29: USB_EN -> should be set to 1 before USB can be used. Bit31: ULPI_INT_EN -> enables an ULPI wake-up irq.
Both "REFSEL_16MHZ" and "UTMI_PHY_EN" are completely out of scope for MPC837x.
This loop never returns on MPC837x because "PHY_CLK_VALID" isn't valid.
do { temp = __raw_readl(&ehci->control); udelay(1000); } while (!(temp& PHY_CLK_VALID));
I still wonder how there can be a single working MPC837x board with CONFIG_USB_EHCI_FSL set.
Some pending patches on your side ? What kind of patch might get an ACK from your side ?
On Mon, 28 Feb 2011 17:18:38 +0100 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
ok, as long as it's confirmed.
that's why I'm suggesting we confirm that touching the REFSEL_16MHZ and UTMI_PHY_EN bits aren't sending the 837x controller into oblivion - did you test the patch?
right, we need to narrow down the reason for this.
nothing that suggests 834x and 837x have any special USB settings in common - because it's not true and therefore misleading.
Kim
Kim,
On Mon, 28 Feb 2011 17:18:38 +0100 Andre Schwarzandre.schwarz@matrix-vision.de wrote:
yes - writing those bits or not makes no difference ...
... it is this loop that *can not* return since ehci->control[PHY_CLK_VALID] is always 0 on 837x. This can be seen by having a look at the reference manual (Rev. 1 page 20-46 / Chapter 20.3.2.28).
I never ever said that 834x and 837x have anything in common regarding USB. All I say is that they both must not run into this loop.
If you see any problems or'ing 837x into the #ifndef I suggest you come up with a positive #ifdef being valid for only those chips that need it. Honestly I don't know which SoC's will need it.
All I want is to skip this loop on 837x.
Regards, André
i.e, to those parts that have PHY_CLK_VALID bits in their USB CONTROL registers:
mpc8308 WU_INT, PHY_CLK_SEL, USB_EN, WU_INT_EN, ULPI_INT_EN mpc831x PHY_CLK_VALID, WU_INT, CLKIN_SEL, PHY_CLK_SEL, UTMI_PHY_EN, PLL_RESET, REFSEL, OTG_PORT, KEEP_OTG_ON, LSF_EN, USB_EN, ULPI_INT_EN mpc834x USB_EN, ULPI_INT1_EN (MPH only), ULPI_INT0_EN mpc837x USB_EN, ULPI_INT_EN
(mpc832x, mpc8360 don't have a USB_EHCI_FSL compatible controller)
this prevents non-831x parts from never completing cpu_init_f(), because the (non-existent) PHY_CLK_VALID bit never gets set.
Reported-by: Andre Schwarz andre.schwarz@matrix-vision.de Signed-off-by: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/cpu/mpc83xx/cpu_init.c | 4 +--- 1 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 7a1cae7..76afba5 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -326,8 +326,7 @@ void cpu_init_f (volatile immap_t * im) im->gpio[1].dat = CONFIG_SYS_GPIO2_DAT; im->gpio[1].dir = CONFIG_SYS_GPIO2_DIR; #endif -#ifdef CONFIG_USB_EHCI_FSL -#ifndef CONFIG_MPC834x +#if defined(CONFIG_USB_EHCI_FSL) && defined(CONFIG_MPC831x) uint32_t temp; struct usb_ehci *ehci = (struct usb_ehci *)CONFIG_SYS_FSL_USB_ADDR;
@@ -340,7 +339,6 @@ void cpu_init_f (volatile immap_t * im) udelay(1000); } while (!(temp & PHY_CLK_VALID)); #endif -#endif }
int cpu_init_r (void)
Kim,
excellent - thanks.
Reported-by: Andre Schwarzandre.schwarz@matrix-vision.de Signed-off-by: Kim Phillipskim.phillips@freescale.com
Tested-by: Andre Schwarz andre.schwarz@matrix-vision.de
Works on MPC8343 and MPC8377.
diff --git a/arch/powerpc/cpu/mpc83xx/cpu_init.c b/arch/powerpc/cpu/mpc83xx/cpu_init.c index 7a1cae7..76afba5 100644 --- a/arch/powerpc/cpu/mpc83xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc83xx/cpu_init.c @@ -326,8 +326,7 @@ void cpu_init_f (volatile immap_t * im) im->gpio[1].dat = CONFIG_SYS_GPIO2_DAT; im->gpio[1].dir = CONFIG_SYS_GPIO2_DIR; #endif -#ifdef CONFIG_USB_EHCI_FSL -#ifndef CONFIG_MPC834x +#if defined(CONFIG_USB_EHCI_FSL)&& defined(CONFIG_MPC831x) uint32_t temp; struct usb_ehci *ehci = (struct usb_ehci *)CONFIG_SYS_FSL_USB_ADDR;
@@ -340,7 +339,6 @@ void cpu_init_f (volatile immap_t * im) udelay(1000); } while (!(temp& PHY_CLK_VALID)); #endif -#endif }
Cheers, André
On Mon, 4 Apr 2011 12:52:25 +0200 Andre Schwarz andre.schwarz@matrix-vision.de wrote:
applied to mpc83xx/master.
thanks for testing!
Kim
Andre Schwarz
Kim Phillips
Schwarz,Andre
