[U-Boot-Users] Booting from 4MB flash on Walnut derived board
Hi all, I have custom board built based on IBM walnut demo board. It worked well when I was using 512KB flash. Since I want to burn all my application on the flash, I installed 4MB flash and u-boot no longer works.
According to README file, I should set CFG_FLASH_BASE, CFG_MONITOR_BASE and TEXT_BASE to the beginning of the flash. When I did this, the processor was not able to pick up the instruction on the beginning of the flash. Probably because the EBC is not configured to access 4MB of flash when it boots up.
Is there a way to make it come up with 4MB of flash? I'm using u-Boot 0.3.0
I tried changing the CFG_FLASH_BASE only but I get bus error when u-Boot tries to access the flash. I did setup pb0cr so that it can access 4MB address space.
U-Boot 0.3.0 (Jun 26 2003 - 19:43:08)
CPU: IBM PowerPC 405GP Rev. E at 200 MHz (PLB=100, OPB=50, EBC=50 MHz) PCI sync clock at 100 MHz, external PCI arbiter enabled 16 kB I-Cache 8 kB D-Cache Board: ### No HW ID - assuming WALNUT405 I2C: ready DRAM: 128 MB FLASH: Bus Fault @ 0x07fd2954, fixup 0x00000000 Machine check in kernel mode. Caused by (from msr): regs 07fadd08 Machine check signal - probably due to mm ft with mmu off NIP: 07FD2954 XER: 00000000 LR: 07FD219C REGS: 07fadd08 TRAP: 0200 DAR: 00000800 MSR: 00001000 EE: 0 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 00000090 07FADDF8 40000000 07FADE08 07FF1194 00000000 00000000 0110795E GPR08: 07FD9C84 FFC00000 00000002 0000051C 28000004 00000000 07FEF300 08050000 GPR16: 00000000 00000000 00000000 00000000 00001000 07FADDF8 00000000 07FD219C GPR24: 07FD2954 07FADF64 07FADF90 07FF1194 07FADF90 07FADF64 07FF0110 0000FFFF Call backtrace: machine check
Any help will be appreciated.
Thank you.
Brian
=============================================================== Brian S. Park brian@corelis.com (562) 926-6727 x143 --------------------------------------------------------------- Everything we do helps our customers get to market FASTER with HIGHER quality and LOWER cost ===============================================================
Oops, Never mind. I did not configure pb0cr properly. After fixing the bug, it does not get a bus error.
However, the flash is not detected properly even after I define CFG_FLASH_CFI. Is there something special I need to do use CFI compliant flash working with u-Boot? I'm using AM29LV320DT.
Thanks.
You will, of course, have to adapt the flash driver for your board.
Brian S. Park
