[PATCH] usb: kbd: allow probing even if usbkbd not in stdin
For now the driver does not probe if usbkbd was not present in stdin. This presents two issues, we can not probe the driver before setting stdin and we can not use this driver in other manner than stdin console.
This patch fixes this by adding an else statement. It simply probes the driver without console management in the case "usbkbd" is not in stdin.
Signed-off-by: Kory Maincent kory.maincent@bootlin.com --- common/usb_kbd.c | 25 +++++++++++++------------ 1 file changed, 13 insertions(+), 12 deletions(-)
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index 352d86fb2e..d385bea532 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -581,21 +581,22 @@ static int probe_usb_keyboard(struct usb_device *dev)
stdinname = env_get("stdin"); #if CONFIG_IS_ENABLED(CONSOLE_MUX) - error = iomux_doenv(stdin, stdinname); - if (error) - return error; + if (strstr(stdinname, DEVNAME) != NULL) { + error = iomux_doenv(stdin, stdinname); + if (error) + return error; + } #else /* Check if this is the standard input device. */ - if (strcmp(stdinname, DEVNAME)) - return 1; - - /* Reassign the console */ - if (overwrite_console()) - return 1; + if (!strcmp(stdinname, DEVNAME)) { + /* Reassign the console */ + if (overwrite_console()) + return 1;
- error = console_assign(stdin, DEVNAME); - if (error) - return error; + error = console_assign(stdin, DEVNAME); + if (error) + return error; + } #endif
Environment should be up and running before USB, so this is likely not a problem.
Can you document the usecase in a bit more detail ? What exactly is the problem you are solving here ?
- if (error)
return error;
- if (strstr(stdinname, DEVNAME) != NULL) {
if (error)
return error;
- } #else /* Check if this is the standard input device. */
return 1;
return 1;
- if (!strcmp(stdinname, DEVNAME)) {
Maybe use strcmp() == NULL to be consistent with the != NULL check above ?
Hello Marek,
Having a driver probing only in this specific state is weird? It should probe whatever the state of stdin.
My usecase is to get a key press from the USB keyboard and do some thing about it in board_init. I do not want to multiplex the keyboard input to stdin but I still want to read character from it.
- if (error)
return error;
if (error)
return error;
return 1;
return 1;
Yes, you are right.
Regards, Köry
On 6/27/22 12:03, Köry Maincent wrote:
Hello Marek,
All right, understood, both. Thanks for clarification.
I applied this to usb/next , I hope that's OK ?
Great! Thanks!
Köry
Köry Maincent
