[U-Boot] [PATCH 00/18] Third step towards Kbuild: Convert rest of makefiles
This series uses the followings as prerequisites: - First step towards Kbuild: Use Kbuild style makefiles (19 patch files) - Second step towards Kbuild: Descend down like Kbuild (6 patch files)
In 'First step towards Kbuild' series, I changed more than 150 makefiles. And in this series, I have changed the remainders, more than 600 makefiles.
After applying first step thru third step, all makefiles under arch/, board/, drivers/, api/, common/, disk/, dts/, fs/, lib/, net/, post/, test/ are converted to Kbuild style.
( doc/, tools/, nand_spl/, example/ have not been changed yet. I'm planning to convert these directories. But I need something prepared before that: hostprogs-y, etc.)
Before converting makefiles to Kbuild style, I want to fix some makefile. This is done in 01/18 and 02/18.
01/18 fixes the link error of sparc architecture. Please see the snippet of arch/sparc/lib/Makefile:
LIB = $(obj)lib$(ARCH).o
SOBJS =
COBJS = board.o cache.o interrupts.o time.o COBJS-$(CONFIG_CMD_BOOTM) += bootm.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
$(LIB): $(obj).depend $(OBJS) $(call cmd_link_o_target, $(OBJS))
Both COBJS and COBJS-y are used. But this makefile missed to add $(COBJS-y) to OBJS. So, bootm.o is never compiled.
Here, you will notice the advantage of switching to Kbuild style.
Makefiles in sub-directories have very similar form. But there exists a slight difference for each Makefile.
For ex. some makefiles use COBJS and the others use COBJS-y. Some use both of them mixed, and sometimes a mistake like above happens. We should use consistently use obj-y, for both C and Assembler objects.
02/18 fixes arch/sh/cpu/{sh2,sh3,sh4}/Makefile. The snippet is as follows:
LIB = $(obj)lib$(CPU).o
SOBJS = start.o COBJS = cpu.o interrupts.o watchdog.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS))
$(LIB): $(OBJS) $(SOBJS) $(call cmd_link_o_target, $(OBJS) $(SOBJS))
start.o is linked into lib$(CPU).o, but it shouldn't.
03/18 thru 15/18 convert arch-specific, board-specific makefiles.
16/18, 17/18 convert commonly used directories.
16/18 shows another big advantage of switching to Kbuild style. Check how simply post/Makefile was re-written by using obj-$(CONFIG-FOO) += foo/ systax.
18/18 convert the rest of makefiles and abolishes the support for U-Boot conventional makefile. After this commit, we cannot use U-Boot style makefiles any more. (exception: doc/, tools/, nand_spl/, example/ directory) Going forward, we must use only Kbuild style makefiles. Take care when you add a new makefile!
Of course, I tested carefully this series. I built as many boards as possible over all architectures.
Here is the site I downloaded the prebuilt crosstools from:
- arm, avr32, m68k, mips, openrisc, powerpc, x86: ftp://ftp.kernel.org/pub/tools/crosstool/files/bin/x86_64/
- blackfin, microblaze, nds32, nios2, sh, sparc: http://dev.gentoo.org/~vapier/u-boot/
I could not build some boards because the boards are already broken before this series or the crosstools are not suitable. But I could build more than 1100 target boards and I confirmed this series does no harm.
- 02 thru 18 did not break any boards. - 02 thru 15 and 17, 18 did not change output ELF files at all. This was check by comparing md5sum. - It was difficult to simply compare md5sum for patch 16 because it changes how the objects are linked under post/ directory. But I confirmed 16 did not change the section size.
Note: For comparing md5sum, there are some items you should take into account: Disabling time stamp, version, compiling in the same path, linking the objects in the same order... For detailed, refer to [U-Boot] [PATCH 00/19] First step towards Kbuild: Use Kbuild style makefiles Message-Id: 20130917093533.738A.AA925319@jp.panasonic.com
Note2: I confirmed this series can be applied on v2013.10 tag + First step towards Kbuild: Use Kbuild style makefiles (19 patch files) + Second step towards Kbuild: Descend down like Kbuild (6 patch files)
Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com Cc: Wolfgang Denk wd@denx.de Cc: Gerhard Sittig gsi@denx.de
Masahiro Yamada (18): sparc: fix a link error sh: Do not include start.o in lib$(CPU).o sparc: convert makefiles to Kbuild style sh: convert makefiles to Kbuild style avr32: convert makefiles to Kbuild style openrisc: convert makefiles to Kbuild style microblaze: convert makefiles to Kbuild style mips: convert makefiles to Kbuild style nds32: convert makefiles to Kbuild style nios2: convert makefiles to Kbuild style x86: convert makefiles to Kbuild style m68k: convert makefiles to Kbuild style blackfin: convert makefiles to Kbuild style board: arm: convert makefiles to Kbuild style board: powerpc: convert makefiles to Kbuild style post: convert makefiles to Kbuild style dts,api,test: convert makefiles to Kbuild style Makefile: convert makefiles to Kbuild style and delete grep switch
Makefile | 40 +++---------- api/Makefile | 18 +----- arch/avr32/cpu/Makefile | 40 +++---------- arch/avr32/cpu/at32ap700x/Makefile | 22 +------ arch/avr32/lib/Makefile | 28 ++------- arch/blackfin/cpu/Makefile | 54 +++++------------ arch/blackfin/lib/Makefile | 52 +++++----------- arch/m68k/cpu/mcf5227x/Makefile | 25 +------- arch/m68k/cpu/mcf523x/Makefile | 25 +------- arch/m68k/cpu/mcf52x2/Makefile | 26 +------- arch/m68k/cpu/mcf532x/Makefile | 25 +------- arch/m68k/cpu/mcf5445x/Makefile | 25 +------- arch/m68k/cpu/mcf547x_8x/Makefile | 25 +------- arch/m68k/lib/Makefile | 33 ++-------- arch/microblaze/cpu/Makefile | 28 +-------- arch/microblaze/lib/Makefile | 27 +-------- arch/mips/cpu/mips32/Makefile | 28 +-------- arch/mips/cpu/mips32/au1x00/Makefile | 23 +------ arch/mips/cpu/mips32/incaip/Makefile | 25 +------- arch/mips/cpu/mips64/Makefile | 24 +------- arch/mips/cpu/xburst/Makefile | 30 +--------- arch/mips/lib/Makefile | 44 ++------------ arch/nds32/cpu/n1213/Makefile | 24 +------- arch/nds32/cpu/n1213/ag101/Makefile | 27 +-------- arch/nds32/cpu/n1213/ag102/Makefile | 27 +-------- arch/nds32/lib/Makefile | 27 ++------- arch/nios2/cpu/Makefile | 30 ++-------- arch/nios2/lib/Makefile | 30 ++-------- arch/openrisc/cpu/Makefile | 26 +------- arch/openrisc/lib/Makefile | 27 +-------- arch/sh/cpu/sh2/Makefile | 24 +------- arch/sh/cpu/sh3/Makefile | 24 +------- arch/sh/cpu/sh4/Makefile | 24 +------- arch/sh/lib/Makefile | 56 ++++------------- arch/sparc/cpu/leon2/Makefile | 27 +-------- arch/sparc/cpu/leon3/Makefile | 27 +-------- arch/sparc/lib/Makefile | 25 +------- arch/x86/config.mk | 2 +- arch/x86/cpu/Makefile | 28 +-------- arch/x86/cpu/coreboot/Makefile | 35 +++-------- arch/x86/lib/Makefile | 56 ++++++----------- board/8dtech/eco5pk/Makefile | 19 +----- board/AndesTech/adp-ag101/Makefile | 21 +------ board/AndesTech/adp-ag101p/Makefile | 21 +------ board/AndesTech/adp-ag102/Makefile | 21 +------ board/Barix/ipam390/Makefile | 21 +------ board/BuS/eb_cpu5282/Makefile | 22 +------ board/BuS/eb_cpux9k2/Makefile | 22 +------ board/BuS/vl_ma2sc/Makefile | 22 +------ board/CarMediaLab/flea3/Makefile | 30 +--------- board/LEOX/elpt860/Makefile | 22 +------ board/LaCie/edminiv2/Makefile | 20 +------ board/LaCie/net2big_v2/Makefile | 29 +-------- board/LaCie/netspace_v2/Makefile | 21 +------ board/LaCie/wireless_space/Makefile | 21 +------ board/Marvell/aspenite/Makefile | 22 +------ board/Marvell/db64360/Makefile | 25 +------- board/Marvell/db64460/Makefile | 25 +------- board/Marvell/dkb/Makefile | 22 +------ board/Marvell/dreamplug/Makefile | 28 +-------- board/Marvell/gplugd/Makefile | 22 +------ board/Marvell/guruplug/Makefile | 22 +------ board/Marvell/mv88f6281gtw_ge/Makefile | 22 +------ board/Marvell/openrd/Makefile | 22 +------ board/Marvell/rd6281a/Makefile | 22 +------ board/Marvell/sheevaplug/Makefile | 22 +------ board/RPXClassic/Makefile | 22 +------ board/RPXlite/Makefile | 22 +------ board/RPXlite_dw/Makefile | 22 +------ board/RRvision/Makefile | 22 +------ board/Seagate/dockstar/Makefile | 22 +------ board/Seagate/goflexhome/Makefile | 22 +------ board/a3000/Makefile | 22 +------ board/a3m071/Makefile | 22 +------ board/a4m072/Makefile | 22 +------ board/actux1/Makefile | 22 +------ board/actux2/Makefile | 22 +------ board/actux3/Makefile | 22 +------ board/actux4/Makefile | 22 +------ board/adder/Makefile | 22 +------ board/afeb9260/Makefile | 24 +------- board/ait/cam_enc_4xx/Makefile | 22 +------ board/alphaproject/ap_sh4a_4a/Makefile | 24 +------- board/altera/nios2-generic/Makefile | 30 ++-------- board/altera/socfpga/Makefile | 30 +--------- board/amcc/acadia/Makefile | 23 +------ board/amcc/bamboo/Makefile | 26 +------- board/amcc/bluestone/Makefile | 27 +-------- board/amcc/bubinga/Makefile | 22 +------ board/amcc/canyonlands/Makefile | 29 +-------- board/amcc/ebony/Makefile | 24 +------- board/amcc/katmai/Makefile | 27 +-------- board/amcc/kilauea/Makefile | 24 +------- board/amcc/luan/Makefile | 24 +------- board/amcc/makalu/Makefile | 23 +------ board/amcc/ocotea/Makefile | 24 +------- board/amcc/redwood/Makefile | 23 +------ board/amcc/sequoia/Makefile | 29 +-------- board/amcc/taihu/Makefile | 21 +------ board/amcc/taishan/Makefile | 24 +------- board/amcc/walnut/Makefile | 22 +------ board/amcc/yosemite/Makefile | 24 +------- board/amcc/yucca/Makefile | 24 +------- board/armadeus/apf27/Makefile | 27 +-------- board/armltd/integrator/Makefile | 28 ++------- board/armltd/versatile/Makefile | 24 +------- board/armltd/vexpress/Makefile | 21 +------ board/astro/mcf5373l/Makefile | 22 +------ board/atc/Makefile | 22 +------ board/atmark-techno/armadillo-800eva/Makefile | 27 +-------- board/atmel/at91rm9200ek/Makefile | 24 +------- board/atmel/at91sam9260ek/Makefile | 26 +------- board/atmel/at91sam9261ek/Makefile | 26 +------- board/atmel/at91sam9263ek/Makefile | 26 +------- board/atmel/at91sam9m10g45ek/Makefile | 24 +------- board/atmel/at91sam9n12ek/Makefile | 22 +------ board/atmel/at91sam9rlek/Makefile | 26 +------- board/atmel/at91sam9x5ek/Makefile | 22 +------ board/atmel/atngw100/Makefile | 21 +------ board/atmel/atngw100mkii/Makefile | 21 +------ board/atmel/atstk1000/Makefile | 21 +------ board/atmel/sama5d3xek/Makefile | 22 +------ board/avionic-design/medcom-wide/Makefile | 22 +------ board/avionic-design/plutux/Makefile | 22 +------ board/avionic-design/tec/Makefile | 22 +------ board/avnet/fx12mm/Makefile | 2 +- board/avnet/v5fx30teval/Makefile | 2 +- board/balloon3/Makefile | 21 +------ board/bc3450/Makefile | 22 +------ board/bct-brettl2/Makefile | 20 +------ board/bf506f-ezkit/Makefile | 22 +------ board/bf518f-ezbrd/Makefile | 22 +------ board/bf525-ucr2/Makefile | 22 +------ board/bf526-ezbrd/Makefile | 22 +------ board/bf527-ad7160-eval/Makefile | 22 +------ board/bf527-ezkit/Makefile | 24 +------- board/bf527-sdp/Makefile | 22 +------ board/bf533-ezkit/Makefile | 22 +------ board/bf533-stamp/Makefile | 26 +------- board/bf537-minotaur/Makefile | 22 +------ board/bf537-pnav/Makefile | 22 +------ board/bf537-srv1/Makefile | 22 +------ board/bf537-stamp/Makefile | 26 +------- board/bf538f-ezkit/Makefile | 22 +------ board/bf548-ezkit/Makefile | 24 +------- board/bf561-acvilon/Makefile | 22 +------ board/bf561-ezkit/Makefile | 22 +------ board/bf609-ezkit/Makefile | 30 +--------- board/blackstamp/Makefile | 22 +------ board/blackvme/Makefile | 22 +------ board/bluegiga/apx4devkit/Makefile | 23 +------ board/bluewater/snapper9260/Makefile | 22 +------ board/boundary/nitrogen6x/Makefile | 21 +------ board/br4/Makefile | 22 +------ board/buffalo/lsxl/Makefile | 22 +------ board/calao/sbc35_a9g20/Makefile | 24 +------- board/calao/tny_a9260/Makefile | 24 +------- board/canmb/Makefile | 25 +------- board/chromebook-x86/coreboot/Makefile | 21 +------ board/cloudengines/pogo_e02/Makefile | 22 +------ board/cm-bf527/Makefile | 22 +------ board/cm-bf533/Makefile | 22 +------ board/cm-bf537e/Makefile | 22 +------ board/cm-bf537u/Makefile | 22 +------ board/cm-bf548/Makefile | 24 +------- board/cm-bf561/Makefile | 22 +------ board/cm4008/Makefile | 22 +------ board/cm41xx/Makefile | 22 +------ board/cm5200/Makefile | 22 +------ board/cmi/Makefile | 22 +------ board/cobra5272/Makefile | 22 +------ board/cogent/Makefile | 22 +------ board/comelit/dig297/Makefile | 21 +------ board/compal/paz00/Makefile | 22 +------ board/compulab/cm_t35/Makefile | 25 +------- board/compulab/trimslice/Makefile | 22 +------ board/congatec/cgtqmx6eval/Makefile | 21 +------ board/corscience/tricorder/Makefile | 21 +------ board/cpc45/Makefile | 22 +------ board/cpu86/Makefile | 22 +------ board/cpu87/Makefile | 22 +------ board/cray/L1/Makefile | 30 +--------- board/creative/xfi3/Makefile | 23 +------ board/csb272/Makefile | 27 +-------- board/csb472/Makefile | 27 +-------- board/cu824/Makefile | 22 +------ board/d-link/dns325/Makefile | 22 +------ board/dave/PPChameleonEVB/Makefile | 22 +------ board/davedenx/aria/Makefile | 23 +------ board/davedenx/qong/Makefile | 24 +------- board/davinci/da8xxevm/Makefile | 27 +-------- board/davinci/dm355evm/Makefile | 22 +------ board/davinci/dm355leopard/Makefile | 22 +------ board/davinci/dm365evm/Makefile | 22 +------ board/davinci/dm6467evm/Makefile | 22 +------ board/davinci/dvevm/Makefile | 23 +------ board/davinci/ea20/Makefile | 23 +------ board/davinci/schmoogie/Makefile | 23 +------ board/davinci/sffsdr/Makefile | 23 +------ board/davinci/sonata/Makefile | 23 +------ board/dbau1x00/Makefile | 24 +------- board/denx/m28evk/Makefile | 23 +------ board/denx/m53evk/Makefile | 21 +------ board/dnp5370/Makefile | 22 +------ board/dvlhost/Makefile | 22 +------ board/eXalion/Makefile | 22 +------ board/earthlcd/favr-32-ezkit/Makefile | 21 +------ board/egnite/ethernut5/Makefile | 24 +------- board/eltec/elppc/Makefile | 25 +------- board/eltec/mhpc/Makefile | 22 +------ board/emk/top5200/Makefile | 21 +------ board/emk/top860/Makefile | 22 +------ board/emk/top9000/Makefile | 24 +------- board/enbw/enbw_cmc/Makefile | 21 +------ board/ep8248/Makefile | 22 +------ board/ep8260/Makefile | 22 +------ board/ep82xxm/Makefile | 21 +------ board/esd/adciop/Makefile | 21 +------ board/esd/apc405/Makefile | 21 +------ board/esd/ar405/Makefile | 21 +------ board/esd/ash405/Makefile | 21 +------ board/esd/cms700/Makefile | 21 +------ board/esd/cpci2dp/Makefile | 21 +------ board/esd/cpci405/Makefile | 23 +------ board/esd/cpci5200/Makefile | 23 +------ board/esd/cpci750/Makefile | 24 +------- board/esd/cpciiser4/Makefile | 21 +------ board/esd/dasa_sim/Makefile | 21 +------ board/esd/dp405/Makefile | 21 +------ board/esd/du405/Makefile | 21 +------ board/esd/du440/Makefile | 26 +------- board/esd/hh405/Makefile | 21 +------ board/esd/hub405/Makefile | 21 +------ board/esd/mecp5123/Makefile | 23 +------ board/esd/mecp5200/Makefile | 22 +------ board/esd/meesc/Makefile | 24 +------- board/esd/ocrtc/Makefile | 21 +------ board/esd/otc570/Makefile | 24 +------- board/esd/pci405/Makefile | 24 +------- board/esd/pf5200/Makefile | 23 +------ board/esd/plu405/Makefile | 21 +------ board/esd/pmc405/Makefile | 21 +------ board/esd/pmc405de/Makefile | 26 +------- board/esd/pmc440/Makefile | 26 +------- board/esd/tasreg/Makefile | 22 +------ board/esd/vme8349/Makefile | 25 +------- board/esd/voh405/Makefile | 21 +------ board/esd/vom405/Makefile | 21 +------ board/esd/wuh405/Makefile | 21 +------ board/esg/ima3-mx53/Makefile | 21 +------ board/espt/Makefile | 24 +------- board/esteem192e/Makefile | 22 +------ board/etin/debris/Makefile | 22 +------ board/etin/kvme080/Makefile | 22 +------ board/eukrea/cpu9260/Makefile | 24 +------- board/eukrea/cpuat91/Makefile | 22 +------ board/evb64260/Makefile | 24 +------- board/exmeritus/hww1u1a/Makefile | 28 ++------- board/fads/Makefile | 22 +------ board/faraday/a320evb/Makefile | 24 +------- board/flagadm/Makefile | 22 +------ board/freescale/b4860qds/Makefile | 38 ++---------- board/freescale/bsc9131rdb/Makefile | 38 ++---------- board/freescale/bsc9132qds/Makefile | 37 ++---------- board/freescale/c29xpcie/Makefile | 30 ++-------- board/freescale/common/Makefile | 86 +++++++++------------------ board/freescale/common/p_corenet/Makefile | 11 ++-- board/freescale/corenet_ds/Makefile | 40 ++++--------- board/freescale/m5208evbe/Makefile | 22 +------ board/freescale/m52277evb/Makefile | 22 +------ board/freescale/m5235evb/Makefile | 22 +------ board/freescale/m5249evb/Makefile | 22 +------ board/freescale/m5253demo/Makefile | 22 +------ board/freescale/m5253evbe/Makefile | 22 +------ board/freescale/m5271evb/Makefile | 22 +------ board/freescale/m5272c3/Makefile | 22 +------ board/freescale/m5275evb/Makefile | 22 +------ board/freescale/m5282evb/Makefile | 22 +------ board/freescale/m53017evb/Makefile | 22 +------ board/freescale/m5329evb/Makefile | 22 +------ board/freescale/m5373evb/Makefile | 22 +------ board/freescale/m54418twr/Makefile | 22 +------ board/freescale/m54451evb/Makefile | 22 +------ board/freescale/m54455evb/Makefile | 22 +------ board/freescale/m547xevb/Makefile | 22 +------ board/freescale/m548xevb/Makefile | 22 +------ board/freescale/mpc5121ads/Makefile | 25 +------- board/freescale/mpc7448hpc2/Makefile | 24 +------- board/freescale/mpc8260ads/Makefile | 22 +------ board/freescale/mpc8266ads/Makefile | 22 +------ board/freescale/mpc8308rdb/Makefile | 22 +------ board/freescale/mpc8313erdb/Makefile | 22 +------ board/freescale/mpc8315erdb/Makefile | 22 +------ board/freescale/mpc8323erdb/Makefile | 22 +------ board/freescale/mpc832xemds/Makefile | 25 +------- board/freescale/mpc8349emds/Makefile | 27 +-------- board/freescale/mpc8349itx/Makefile | 24 +------- board/freescale/mpc8360emds/Makefile | 25 +------- board/freescale/mpc8360erdk/Makefile | 25 +------- board/freescale/mpc837xemds/Makefile | 25 +------- board/freescale/mpc837xerdb/Makefile | 25 +------- board/freescale/mpc8536ds/Makefile | 28 ++------- board/freescale/mpc8540ads/Makefile | 28 ++------- board/freescale/mpc8541cds/Makefile | 28 ++------- board/freescale/mpc8544ds/Makefile | 28 ++------- board/freescale/mpc8548cds/Makefile | 28 ++------- board/freescale/mpc8555cds/Makefile | 28 ++------- board/freescale/mpc8560ads/Makefile | 28 ++------- board/freescale/mpc8568mds/Makefile | 30 ++-------- board/freescale/mpc8569mds/Makefile | 30 ++-------- board/freescale/mpc8572ds/Makefile | 28 ++------- board/freescale/mpc8610hpcd/Makefile | 29 ++------- board/freescale/mpc8641hpcn/Makefile | 26 +------- board/freescale/mx23evk/Makefile | 23 +------ board/freescale/mx25pdk/Makefile | 24 +------- board/freescale/mx28evk/Makefile | 23 +------ board/freescale/mx31ads/Makefile | 24 +------- board/freescale/mx31pdk/Makefile | 24 +------- board/freescale/mx35pdk/Makefile | 24 +------- board/freescale/mx51evk/Makefile | 24 +------- board/freescale/mx53ard/Makefile | 21 +------ board/freescale/mx53evk/Makefile | 21 +------ board/freescale/mx53loco/Makefile | 24 +------- board/freescale/mx53smd/Makefile | 21 +------ board/freescale/mx6qarm2/Makefile | 21 +------ board/freescale/mx6qsabreauto/Makefile | 21 +------ board/freescale/mx6sabresd/Makefile | 21 +------ board/freescale/mx6slevk/Makefile | 21 +------ board/freescale/p1010rdb/Makefile | 30 ++-------- board/freescale/p1022ds/Makefile | 34 +++-------- board/freescale/p1023rdb/Makefile | 28 ++------- board/freescale/p1023rds/Makefile | 26 +------- board/freescale/p1_p2_rdb/Makefile | 30 ++-------- board/freescale/p1_p2_rdb_pc/Makefile | 30 ++-------- board/freescale/p1_twr/Makefile | 34 ++--------- board/freescale/p2020come/Makefile | 28 ++------- board/freescale/p2020ds/Makefile | 28 ++------- board/freescale/p2041rdb/Makefile | 28 ++------- board/freescale/t4qds/Makefile | 40 +++---------- board/freescale/titanium/Makefile | 21 +------ board/freescale/vf610twr/Makefile | 21 +------ board/friendlyarm/mini2440/Makefile | 22 +------ board/funkwerk/vovpn-gw/Makefile | 22 +------ board/g2000/Makefile | 22 +------ board/gaisler/gr_cpci_ax2000/Makefile | 23 +------ board/gaisler/gr_ep2s60/Makefile | 23 +------ board/gaisler/gr_xc3s_1500/Makefile | 23 +------ board/gaisler/grsim/Makefile | 22 +------ board/gaisler/grsim_leon2/Makefile | 22 +------ board/galaxy5200/Makefile | 22 +------ board/gdsys/405ep/Makefile | 32 ++-------- board/gdsys/405ex/Makefile | 33 +--------- board/gdsys/common/Makefile | 40 ++----------- board/gdsys/dlvision/Makefile | 23 +------ board/gdsys/gdppc440etx/Makefile | 24 +------- board/gdsys/intip/Makefile | 29 +-------- board/gdsys/p1022/Makefile | 34 ++--------- board/gen860t/Makefile | 22 +------ board/genesi/mx51_efikamx/Makefile | 21 +------ board/genietv/Makefile | 22 +------ board/gw8260/Makefile | 23 +------ board/h2200/Makefile | 23 +------ board/hale/tt01/Makefile | 29 +-------- board/hermes/Makefile | 22 +------ board/hidden_dragon/Makefile | 22 +------ board/highbank/Makefile | 27 +-------- board/htkw/mcx/Makefile | 19 +----- board/hymod/Makefile | 22 +------ board/ibf-dsp561/Makefile | 22 +------ board/icecube/Makefile | 22 +------ board/icpdas/lp8x4x/Makefile | 21 +------ board/icu862/Makefile | 22 +------ board/idmr/Makefile | 22 +------ board/ids8247/Makefile | 22 +------ board/ifm/ac14xx/Makefile | 23 +------ board/ifm/o2dnt2/Makefile | 22 +------ board/imx31_phycore/Makefile | 24 +------- board/in-circuit/grasshopper/Makefile | 21 +------ board/incaip/Makefile | 24 +------- board/inka4x0/Makefile | 22 +------ board/intercontrol/digsy_mtc/Makefile | 24 +------- board/iomega/iconnect/Makefile | 22 +------ board/ip04/Makefile | 22 +------ board/ip860/Makefile | 22 +------ board/ipek01/Makefile | 22 +------ board/iphase4539/Makefile | 22 +------ board/isee/igep0033/Makefile | 29 +-------- board/isee/igep00x0/Makefile | 21 +------ board/ispan/Makefile | 22 +------ board/ivm/Makefile | 22 +------ board/jornada/Makefile | 24 +------- board/jse/Makefile | 24 +------- board/jupiter/Makefile | 22 +------ board/karo/tk71/Makefile | 22 +------ board/karo/tx25/Makefile | 23 +------ board/keymile/km82xx/Makefile | 22 +------ board/keymile/km83xx/Makefile | 21 +------ board/keymile/km_arm/Makefile | 23 +------ board/kmc/kzm9g/Makefile | 28 +-------- board/korat/Makefile | 26 +------- board/kup/kup4k/Makefile | 21 +------ board/kup/kup4x/Makefile | 21 +------ board/linkstation/Makefile | 21 +------ board/logicpd/am3517evm/Makefile | 19 +----- board/logicpd/imx27lite/Makefile | 23 +------ board/logicpd/imx31_litekit/Makefile | 24 +------- board/logicpd/omap3som/Makefile | 20 +------ board/logicpd/zoom1/Makefile | 21 +------ board/logicpd/zoom2/Makefile | 28 ++------- board/lubbock/Makefile | 21 +------ board/lwmon/Makefile | 22 +------ board/lwmon5/Makefile | 26 +------- board/manroland/hmi1001/Makefile | 22 +------ board/manroland/mucmc52/Makefile | 22 +------ board/manroland/uc100/Makefile | 23 +------ board/manroland/uc101/Makefile | 22 +------ board/matrix_vision/common/Makefile | 26 +------- board/matrix_vision/mergerbox/Makefile | 23 +------ board/matrix_vision/mvbc_p/Makefile | 19 +----- board/matrix_vision/mvblm7/Makefile | 23 ++----- board/matrix_vision/mvblx/Makefile | 24 +------- board/matrix_vision/mvsmr/Makefile | 21 ++----- board/mbx8xx/Makefile | 22 +------ board/mcc200/Makefile | 22 +------ board/micronas/vct/Makefile | 37 +++--------- board/mimc/mimc200/Makefile | 21 +------ board/miromico/hammerhead/Makefile | 21 +------ board/mosaixtech/icon/Makefile | 27 +-------- board/motionpro/Makefile | 22 +------ board/mousse/Makefile | 21 +------ board/mpc8308_p1m/Makefile | 22 +------ board/mpl/mip405/Makefile | 24 +------- board/mpl/pati/Makefile | 21 +------ board/mpl/pip405/Makefile | 24 +------- board/mpl/vcma9/Makefile | 25 +------- board/mpr2/Makefile | 24 +------- board/ms7720se/Makefile | 24 +------- board/ms7722se/Makefile | 24 +------- board/ms7750se/Makefile | 23 +------ board/muas3001/Makefile | 22 +------ board/munices/Makefile | 22 +------ board/musenki/Makefile | 22 +------ board/mvblue/Makefile | 22 +------ board/mx1ads/Makefile | 24 +------- board/netphone/Makefile | 22 +------ board/netta/Makefile | 22 +------ board/netta2/Makefile | 22 +------ board/netvia/Makefile | 22 +------ board/nokia/rx51/Makefile | 25 +------- board/nvidia/beaver/Makefile | 21 +------ board/nvidia/cardhu/Makefile | 21 +------ board/nvidia/common/Makefile | 26 -------- board/nvidia/common/common.mk | 4 +- board/nvidia/dalmore/Makefile | 21 +------ board/nvidia/harmony/Makefile | 21 +------ board/nvidia/seaboard/Makefile | 21 +------ board/nvidia/ventana/Makefile | 21 +------ board/nvidia/whistler/Makefile | 21 +------ board/nx823/Makefile | 22 +------ board/olimex/mx23_olinuxino/Makefile | 23 +------ board/omicron/calimain/Makefile | 21 +------ board/openrisc/openrisc-generic/Makefile | 21 +------ board/overo/Makefile | 20 +------ board/palmld/Makefile | 21 +------ board/palmtc/Makefile | 22 +------ board/palmtreo680/Makefile | 27 +-------- board/pandora/Makefile | 21 +------ board/pb1x00/Makefile | 24 +------- board/pcs440ep/Makefile | 24 +------- board/pdm360ng/Makefile | 23 +------ board/phytec/pcm030/Makefile | 22 +------ board/phytec/pcm051/Makefile | 29 +-------- board/pm520/Makefile | 22 +------ board/pm826/Makefile | 22 +------ board/pm828/Makefile | 22 +------ board/pn62/Makefile | 22 +------ board/ppmc7xx/Makefile | 25 +------- board/ppmc8260/Makefile | 22 +------ board/pr1/Makefile | 22 +------ board/prodrive/alpr/Makefile | 24 +------- board/prodrive/p3mx/Makefile | 23 +------ board/prodrive/p3p440/Makefile | 24 +------- board/prodrive/pdnb3/Makefile | 22 +------ board/psyent/pci5441/Makefile | 23 +------ board/psyent/pk1c20/Makefile | 23 +------ board/pxa255_idp/Makefile | 21 +------ board/qemu-malta/Makefile | 24 +------- board/qemu-mips/Makefile | 24 +------- board/quad100hd/Makefile | 23 +------ board/quantum/Makefile | 22 +------ board/r360mpi/Makefile | 22 +------ board/raidsonic/ib62x0/Makefile | 22 +------ board/raspberrypi/rpi_b/Makefile | 21 +------ board/rattler/Makefile | 22 +------ board/rbc823/Makefile | 22 +------ board/renesas/MigoR/Makefile | 24 +------- board/renesas/ap325rxa/Makefile | 24 +------- board/renesas/ecovec/Makefile | 25 +------- board/renesas/r0p7734/Makefile | 24 +------- board/renesas/r2dplus/Makefile | 23 +------ board/renesas/r7780mp/Makefile | 24 +------- board/renesas/rsk7203/Makefile | 24 +------- board/renesas/rsk7264/Makefile | 22 +------ board/renesas/rsk7269/Makefile | 22 +------ board/renesas/sh7752evb/Makefile | 20 +------ board/renesas/sh7757lcr/Makefile | 20 +------ board/renesas/sh7763rdp/Makefile | 24 +------- board/renesas/sh7785lcr/Makefile | 24 +------- board/ronetix/pm9261/Makefile | 26 +------- board/ronetix/pm9263/Makefile | 26 +------- board/ronetix/pm9g45/Makefile | 22 +------ board/rpxsuper/Makefile | 22 +------ board/rsdproto/Makefile | 24 +------- board/sacsng/Makefile | 22 +------ board/samsung/arndale/Makefile | 27 +-------- board/samsung/common/Makefile | 21 +------ board/samsung/goni/Makefile | 24 +------- board/samsung/origen/Makefile | 28 +-------- board/samsung/smdk2410/Makefile | 24 +------- board/samsung/smdk5250/Makefile | 29 +-------- board/samsung/smdkc100/Makefile | 26 +------- board/samsung/smdkv310/Makefile | 28 +-------- board/samsung/trats/Makefile | 21 +------ board/samsung/trats2/Makefile | 28 +-------- board/samsung/universal_c210/Makefile | 22 +------ board/sandburst/karef/Makefile | 27 +-------- board/sandburst/metrobox/Makefile | 26 +------- board/sandisk/sansa_fuze_plus/Makefile | 23 +------ board/sandpoint/Makefile | 22 +------ board/sbc405/Makefile | 22 +------ board/sbc8349/Makefile | 25 +------- board/sbc8548/Makefile | 28 ++------- board/sbc8641d/Makefile | 26 +------- board/sc3/Makefile | 24 +------- board/scb9328/Makefile | 24 +------- board/schulercontrol/sc_sps_1/Makefile | 23 +------ board/sheldon/simpc8313/Makefile | 22 +------ board/shmin/Makefile | 24 +------- board/siemens/dxr2/Makefile | 30 +--------- board/siemens/pxm2/Makefile | 30 +--------- board/siemens/rut/Makefile | 30 +--------- board/sixnet/Makefile | 22 +------ board/snmc/qs850/Makefile | 22 +------ board/snmc/qs860t/Makefile | 22 +------ board/socrates/Makefile | 33 ++-------- board/spc1920/Makefile | 22 +------ board/spd8xx/Makefile | 22 +------ board/spear/common/Makefile | 27 +-------- board/spear/spear300/Makefile | 23 +------ board/spear/spear310/Makefile | 23 +------ board/spear/spear320/Makefile | 23 +------ board/spear/spear600/Makefile | 23 +------ board/spear/x600/Makefile | 23 +------ board/st-ericsson/snowball/Makefile | 26 +------- board/st-ericsson/u8500/Makefile | 21 +------ board/st/nhk8815/Makefile | 23 +------ board/stx/stxgp3/Makefile | 30 ++-------- board/stx/stxssa/Makefile | 28 ++------- board/stx/stxxtc/Makefile | 22 +------ board/svm_sc8xx/Makefile | 22 +------ board/syteco/jadecpu/Makefile | 24 +------- board/syteco/zmx25/Makefile | 24 +------- board/t3corp/Makefile | 29 +-------- board/taskit/stamp9g20/Makefile | 24 +------- board/tcm-bf518/Makefile | 22 +------ board/tcm-bf537/Makefile | 22 +------ board/technexion/twister/Makefile | 19 +----- board/teejet/mt_ventoux/Makefile | 19 +----- board/timll/devkit3250/Makefile | 22 +------ board/timll/devkit8000/Makefile | 21 +------ board/toradex/colibri_pxa270/Makefile | 21 +------ board/toradex/colibri_t20_iris/Makefile | 25 +------- board/total5200/Makefile | 22 +------ board/tqc/tqm5200/Makefile | 24 +------- board/tqc/tqm8260/Makefile | 21 +------ board/tqc/tqm8272/Makefile | 21 +------ board/tqc/tqm834x/Makefile | 25 +------- board/tqc/tqm8xx/Makefile | 22 +------ board/trizepsiv/Makefile | 21 +------ board/ttcontrol/vision2/Makefile | 21 +------ board/utx8245/Makefile | 22 +------ board/v37/Makefile | 22 +------ board/v38b/Makefile | 22 +------ board/ve8313/Makefile | 22 +------ board/vpac270/Makefile | 23 +------ board/w7o/Makefile | 24 +------- board/wandboard/Makefile | 21 +------ board/woodburn/Makefile | 24 +------- board/xaeniax/Makefile | 21 +------ board/xes/common/Makefile | 38 +++--------- board/xes/xpedite1000/Makefile | 24 +------- board/xes/xpedite517x/Makefile | 26 +------- board/xes/xpedite520x/Makefile | 28 ++------- board/xes/xpedite537x/Makefile | 28 ++------- board/xes/xpedite550x/Makefile | 28 ++------- board/xilinx/microblaze-generic/Makefile | 22 +------ board/xilinx/ml507/Makefile | 2 +- board/xilinx/ppc405-generic/Makefile | 21 +------ board/xilinx/ppc440-generic/Makefile | 23 +------ board/xilinx/zynq/Makefile | 29 +-------- board/zeus/Makefile | 23 +------ board/zipitz2/Makefile | 21 +------ board/zpc1900/Makefile | 22 +------ dts/Makefile | 24 +------- post/Makefile | 65 ++++---------------- post/board/lwmon/Makefile | 7 +-- post/board/lwmon5/Makefile | 7 +-- post/board/netta/Makefile | 7 +-- post/board/pdm360ng/Makefile | 7 +-- post/cpu/mpc83xx/Makefile | 8 +-- post/cpu/mpc8xx/Makefile | 9 +-- post/cpu/ppc4xx/Makefile | 23 ++++--- post/drivers/Makefile | 7 +-- post/lib_powerpc/Makefile | 13 ++-- post/lib_powerpc/fpu/Makefile | 24 ++++---- post/rules.mk | 30 ---------- spl/Makefile | 25 ++------ test/Makefile | 26 +------- 618 files changed, 1209 insertions(+), 13474 deletions(-) delete mode 100644 post/rules.mk
Before this commit, arch/sparc/lib/Makefile used both COBJS and COBJS-y. And it missed to add COBJS-y into OBJS. This means bootm.o was never compiled even if CONFIG_CMD_BOOTM=y
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Daniel Hellstrom daniel@gaisler.com --- arch/sparc/lib/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/sparc/lib/Makefile b/arch/sparc/lib/Makefile index 7e78d44..9914e35 100644 --- a/arch/sparc/lib/Makefile +++ b/arch/sparc/lib/Makefile @@ -14,6 +14,8 @@ SOBJS = COBJS = board.o cache.o interrupts.o time.o COBJS-$(CONFIG_CMD_BOOTM) += bootm.o
+COBJS := $(COBJS) $(COBJS-y) + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/sh/cpu/sh2/Makefile | 4 +++- arch/sh/cpu/sh3/Makefile | 4 +++- arch/sh/cpu/sh4/Makefile | 4 +++- 3 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/sh/cpu/sh2/Makefile b/arch/sh/cpu/sh2/Makefile index 1cc0031..686bb79 100644 --- a/arch/sh/cpu/sh2/Makefile +++ b/arch/sh/cpu/sh2/Makefile @@ -12,13 +12,15 @@ include $(TOPDIR)/config.mk
-SOBJS = start.o +START = start.o COBJS = cpu.o interrupts.o watchdog.o
+all: $(START) $(LIB) + $(LIB): $(OBJS) $(SOBJS) $(call cmd_link_o_target, $(OBJS) $(SOBJS))
diff --git a/arch/sh/cpu/sh3/Makefile b/arch/sh/cpu/sh3/Makefile index e707de3..26cb1ce 100644 --- a/arch/sh/cpu/sh3/Makefile +++ b/arch/sh/cpu/sh3/Makefile @@ -15,13 +15,15 @@ include $(TOPDIR)/config.mk
-SOBJS = start.o +START = start.o COBJS = cpu.o interrupts.o watchdog.o cache.o
diff --git a/arch/sh/cpu/sh4/Makefile b/arch/sh/cpu/sh4/Makefile index e7d8903..5680d61 100644 --- a/arch/sh/cpu/sh4/Makefile +++ b/arch/sh/cpu/sh4/Makefile @@ -12,13 +12,15 @@ include $(TOPDIR)/config.mk
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Daniel Hellstrom daniel@gaisler.com --- arch/sparc/cpu/leon2/Makefile | 27 ++------------------------- arch/sparc/cpu/leon3/Makefile | 27 ++------------------------- arch/sparc/lib/Makefile | 27 ++------------------------- board/gaisler/gr_cpci_ax2000/Makefile | 23 +---------------------- board/gaisler/gr_ep2s60/Makefile | 23 +---------------------- board/gaisler/gr_xc3s_1500/Makefile | 23 +---------------------- board/gaisler/grsim/Makefile | 22 +--------------------- board/gaisler/grsim_leon2/Makefile | 22 +--------------------- 8 files changed, 11 insertions(+), 183 deletions(-)
diff --git a/arch/sparc/cpu/leon2/Makefile b/arch/sparc/cpu/leon2/Makefile index f43d3d2..8c95ca5 100644 --- a/arch/sparc/cpu/leon2/Makefile +++ b/arch/sparc/cpu/leon2/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS = -COBJS = cpu_init.o serial.o cpu.o interrupts.o prom.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu_init.o serial.o cpu.o interrupts.o prom.o diff --git a/arch/sparc/cpu/leon3/Makefile b/arch/sparc/cpu/leon3/Makefile index 95bbfc9..4f13ec3 100644 --- a/arch/sparc/cpu/leon3/Makefile +++ b/arch/sparc/cpu/leon3/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS = -COBJS = cpu_init.o serial.o cpu.o ambapp.o interrupts.o prom.o usb_uhci.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu_init.o serial.o cpu.o ambapp.o interrupts.o prom.o usb_uhci.o diff --git a/arch/sparc/lib/Makefile b/arch/sparc/lib/Makefile index 9914e35..e69b9ba 100644 --- a/arch/sparc/lib/Makefile +++ b/arch/sparc/lib/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -SOBJS = - -COBJS = board.o cache.o interrupts.o time.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o - -COBJS := $(COBJS) $(COBJS-y) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = board.o cache.o interrupts.o time.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o diff --git a/board/gaisler/gr_cpci_ax2000/Makefile b/board/gaisler/gr_cpci_ax2000/Makefile index baa067d..1cef4d5 100644 --- a/board/gaisler/gr_cpci_ax2000/Makefile +++ b/board/gaisler/gr_cpci_ax2000/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -#flash.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := gr_cpci_ax2000.o diff --git a/board/gaisler/gr_ep2s60/Makefile b/board/gaisler/gr_ep2s60/Makefile index baa067d..a8b3e6a 100644 --- a/board/gaisler/gr_ep2s60/Makefile +++ b/board/gaisler/gr_ep2s60/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -#flash.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := gr_ep2s60.o diff --git a/board/gaisler/gr_xc3s_1500/Makefile b/board/gaisler/gr_xc3s_1500/Makefile index baa067d..2ca473d 100644 --- a/board/gaisler/gr_xc3s_1500/Makefile +++ b/board/gaisler/gr_xc3s_1500/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -#flash.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := gr_xc3s_1500.o diff --git a/board/gaisler/grsim/Makefile b/board/gaisler/grsim/Makefile index 2c0119e..4c93bda 100644 --- a/board/gaisler/grsim/Makefile +++ b/board/gaisler/grsim/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := grsim.o diff --git a/board/gaisler/grsim_leon2/Makefile b/board/gaisler/grsim_leon2/Makefile index 2c0119e..5468305 100644 --- a/board/gaisler/grsim_leon2/Makefile +++ b/board/gaisler/grsim_leon2/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := grsim_leon2.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/sh/cpu/sh2/Makefile | 26 ++-------------- arch/sh/cpu/sh3/Makefile | 26 ++-------------- arch/sh/cpu/sh4/Makefile | 26 ++-------------- arch/sh/lib/Makefile | 56 ++++++++-------------------------- board/alphaproject/ap_sh4a_4a/Makefile | 24 ++------------- board/espt/Makefile | 24 ++------------- board/mpr2/Makefile | 24 ++------------- board/ms7720se/Makefile | 24 ++------------- board/ms7722se/Makefile | 24 ++------------- board/ms7750se/Makefile | 23 ++------------ board/renesas/MigoR/Makefile | 24 ++------------- board/renesas/ap325rxa/Makefile | 24 ++------------- board/renesas/ecovec/Makefile | 25 ++------------- board/renesas/r0p7734/Makefile | 24 ++------------- board/renesas/r2dplus/Makefile | 23 ++------------ board/renesas/r7780mp/Makefile | 24 ++------------- board/renesas/rsk7203/Makefile | 24 ++------------- board/renesas/rsk7264/Makefile | 22 ++----------- board/renesas/rsk7269/Makefile | 22 ++----------- board/renesas/sh7752evb/Makefile | 20 ++---------- board/renesas/sh7757lcr/Makefile | 20 ++---------- board/renesas/sh7763rdp/Makefile | 24 ++------------- board/renesas/sh7785lcr/Makefile | 24 ++------------- board/shmin/Makefile | 24 ++------------- 24 files changed, 58 insertions(+), 543 deletions(-)
diff --git a/arch/sh/cpu/sh2/Makefile b/arch/sh/cpu/sh2/Makefile index 686bb79..a19ed5e 100644 --- a/arch/sh/cpu/sh2/Makefile +++ b/arch/sh/cpu/sh2/Makefile @@ -8,27 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o interrupts.o watchdog.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(START) $(LIB) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o interrupts.o watchdog.o diff --git a/arch/sh/cpu/sh3/Makefile b/arch/sh/cpu/sh3/Makefile index 26cb1ce..1dccaf9 100644 --- a/arch/sh/cpu/sh3/Makefile +++ b/arch/sh/cpu/sh3/Makefile @@ -11,27 +11,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o interrupts.o watchdog.o cache.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(START) $(LIB) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o interrupts.o watchdog.o cache.o diff --git a/arch/sh/cpu/sh4/Makefile b/arch/sh/cpu/sh4/Makefile index 5680d61..38c6188 100644 --- a/arch/sh/cpu/sh4/Makefile +++ b/arch/sh/cpu/sh4/Makefile @@ -8,27 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o interrupts.o watchdog.o cache.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(START) $(LIB) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o interrupts.o watchdog.o cache.o diff --git a/arch/sh/lib/Makefile b/arch/sh/lib/Makefile index 8165963..5fc9d9d 100644 --- a/arch/sh/lib/Makefile +++ b/arch/sh/lib/Makefile @@ -5,57 +5,25 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(ARCH).o -LIBGCC = $(obj)libgcc.o - -SOBJS-y += -GLSOBJS += ashiftrt.o -GLSOBJS += ashiftlt.o -GLSOBJS += lshiftrt.o -GLSOBJS += ashldi3.o -GLSOBJS += ashrsi3.o -GLSOBJS += lshrdi3.o -GLSOBJS += movmem.o - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o ifeq ($(CONFIG_SH2),y) -COBJS-y += time_sh2.o +obj-y += time_sh2.o else -COBJS-y += time.o -endif -ifeq ($(CONFIG_CMD_SH_ZIMAGEBOOT),y) -COBJS-y += zimageboot.o +obj-y += time.o endif +obj-$(CONFIG_CMD_SH_ZIMAGEBOOT) += zimageboot.o
-SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -LGOBJS := $(addprefix $(obj),$(GLSOBJS)) \ - $(addprefix $(obj),$(GLCOBJS))
-# Always build libsh.o -TARGETS := $(LIB)
# Build private libgcc only when asked for ifdef USE_PRIVATE_LIBGCC -TARGETS += $(LIBGCC) +lib-y += ashiftrt.o +lib-y += ashiftlt.o +lib-y += lshiftrt.o +lib-y += ashldi3.o +lib-y += ashrsi3.o +lib-y += lshrdi3.o +lib-y += movmem.o endif - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(LIBGCC): $(obj).depend $(LGOBJS) - $(call cmd_link_o_target, $(LGOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/alphaproject/ap_sh4a_4a/Makefile b/board/alphaproject/ap_sh4a_4a/Makefile index a9ba175..486d0ac 100644 --- a/board/alphaproject/ap_sh4a_4a/Makefile +++ b/board/alphaproject/ap_sh4a_4a/Makefile @@ -3,25 +3,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ap_sh4a_4a.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ap_sh4a_4a.o +obj-y += lowlevel_init.o diff --git a/board/espt/Makefile b/board/espt/Makefile index 107e544..8a8a2c9 100644 --- a/board/espt/Makefile +++ b/board/espt/Makefile @@ -7,25 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := espt.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := espt.o +obj-y += lowlevel_init.o diff --git a/board/mpr2/Makefile b/board/mpr2/Makefile index 7920b01..b6cdeb4 100644 --- a/board/mpr2/Makefile +++ b/board/mpr2/Makefile @@ -15,25 +15,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mpr2.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpr2.o +obj-y += lowlevel_init.o diff --git a/board/ms7720se/Makefile b/board/ms7720se/Makefile index 219649c..1819c4c 100644 --- a/board/ms7720se/Makefile +++ b/board/ms7720se/Makefile @@ -12,25 +12,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ms7720se.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ms7720se.o +obj-y += lowlevel_init.o diff --git a/board/ms7722se/Makefile b/board/ms7722se/Makefile index e73ceb2..9f7af78 100644 --- a/board/ms7722se/Makefile +++ b/board/ms7722se/Makefile @@ -9,25 +9,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ms7722se.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ms7722se.o +obj-y += lowlevel_init.o diff --git a/board/ms7750se/Makefile b/board/ms7750se/Makefile index 481c8bb..a8e3ca0 100644 --- a/board/ms7750se/Makefile +++ b/board/ms7750se/Makefile @@ -4,25 +4,6 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = $(obj)lib$(BOARD).o - -COBJS := ms7750se.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ms7750se.o +obj-y += lowlevel_init.o diff --git a/board/renesas/MigoR/Makefile b/board/renesas/MigoR/Makefile index 7725c44..b4691a1 100644 --- a/board/renesas/MigoR/Makefile +++ b/board/renesas/MigoR/Makefile @@ -9,25 +9,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := migo_r.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := migo_r.o +obj-y += lowlevel_init.o diff --git a/board/renesas/ap325rxa/Makefile b/board/renesas/ap325rxa/Makefile index 0597d0f..ff72de9 100644 --- a/board/renesas/ap325rxa/Makefile +++ b/board/renesas/ap325rxa/Makefile @@ -8,25 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ap325rxa.o cpld-ap325rxa.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ap325rxa.o cpld-ap325rxa.o +obj-y += lowlevel_init.o diff --git a/board/renesas/ecovec/Makefile b/board/renesas/ecovec/Makefile index f2a02f8..943fa47 100644 --- a/board/renesas/ecovec/Makefile +++ b/board/renesas/ecovec/Makefile @@ -4,26 +4,5 @@ # # SPDX-License-Identifier: GPL-2.0+
- -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ecovec.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ecovec.o +obj-y += lowlevel_init.o diff --git a/board/renesas/r0p7734/Makefile b/board/renesas/r0p7734/Makefile index 24933cc..1f24d92 100644 --- a/board/renesas/r0p7734/Makefile +++ b/board/renesas/r0p7734/Makefile @@ -3,25 +3,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := r0p7734.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := r0p7734.o +obj-y += lowlevel_init.o diff --git a/board/renesas/r2dplus/Makefile b/board/renesas/r2dplus/Makefile index f0023ab..acffb6d 100644 --- a/board/renesas/r2dplus/Makefile +++ b/board/renesas/r2dplus/Makefile @@ -4,25 +4,6 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = $(obj)lib$(BOARD).o - -COBJS := r2dplus.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := r2dplus.o +obj-y += lowlevel_init.o diff --git a/board/renesas/r7780mp/Makefile b/board/renesas/r7780mp/Makefile index c95ac12..8dab435 100644 --- a/board/renesas/r7780mp/Makefile +++ b/board/renesas/r7780mp/Makefile @@ -5,25 +5,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := r7780mp.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := r7780mp.o +obj-y += lowlevel_init.o diff --git a/board/renesas/rsk7203/Makefile b/board/renesas/rsk7203/Makefile index 13ffa4f..16acfaf 100644 --- a/board/renesas/rsk7203/Makefile +++ b/board/renesas/rsk7203/Makefile @@ -6,25 +6,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = lib$(BOARD).o - -OBJS := rsk7203.o -SOBJS := lowlevel_init.o - -LIB := $(addprefix $(obj),$(LIB)) -OBJS := $(addprefix $(obj),$(OBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rsk7203.o +obj-y += lowlevel_init.o diff --git a/board/renesas/rsk7264/Makefile b/board/renesas/rsk7264/Makefile index 476de43..7ada697 100644 --- a/board/renesas/rsk7264/Makefile +++ b/board/renesas/rsk7264/Makefile @@ -3,23 +3,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = lib$(BOARD).o - -OBJS := rsk7264.o -SOBJS := lowlevel_init.o - -LIB := $(addprefix $(obj),$(LIB)) -OBJS := $(addprefix $(obj),$(OBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := rsk7264.o +obj-y += lowlevel_init.o diff --git a/board/renesas/rsk7269/Makefile b/board/renesas/rsk7269/Makefile index 1a01557..0f053d8 100644 --- a/board/renesas/rsk7269/Makefile +++ b/board/renesas/rsk7269/Makefile @@ -4,23 +4,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = lib$(BOARD).o - -OBJS := rsk7269.o -SOBJS := lowlevel_init.o - -LIB := $(addprefix $(obj),$(LIB)) -OBJS := $(addprefix $(obj),$(OBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := rsk7269.o +obj-y += lowlevel_init.o diff --git a/board/renesas/sh7752evb/Makefile b/board/renesas/sh7752evb/Makefile index 70009ec..856af81 100644 --- a/board/renesas/sh7752evb/Makefile +++ b/board/renesas/sh7752evb/Makefile @@ -3,21 +3,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sh7752evb.o spi-boot.o -SOBJS := lowlevel_init.o - -$(LIB): $(obj).depend $(COBJS) $(SOBJS) - $(call cmd_link_o_target, $(COBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sh7752evb.o spi-boot.o +obj-y += lowlevel_init.o diff --git a/board/renesas/sh7757lcr/Makefile b/board/renesas/sh7757lcr/Makefile index 4bb6068..1fa3992 100644 --- a/board/renesas/sh7757lcr/Makefile +++ b/board/renesas/sh7757lcr/Makefile @@ -3,21 +3,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sh7757lcr.o spi-boot.o -SOBJS := lowlevel_init.o - -$(LIB): $(obj).depend $(COBJS) $(SOBJS) - $(call cmd_link_o_target, $(COBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sh7757lcr.o spi-boot.o +obj-y += lowlevel_init.o diff --git a/board/renesas/sh7763rdp/Makefile b/board/renesas/sh7763rdp/Makefile index b311bcd..cbf38bb 100644 --- a/board/renesas/sh7763rdp/Makefile +++ b/board/renesas/sh7763rdp/Makefile @@ -8,25 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sh7763rdp.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sh7763rdp.o +obj-y += lowlevel_init.o diff --git a/board/renesas/sh7785lcr/Makefile b/board/renesas/sh7785lcr/Makefile index e577d56..e8cfb05 100644 --- a/board/renesas/sh7785lcr/Makefile +++ b/board/renesas/sh7785lcr/Makefile @@ -3,25 +3,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sh7785lcr.o selfcheck.o rtl8169_mac.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sh7785lcr.o selfcheck.o rtl8169_mac.o +obj-y += lowlevel_init.o diff --git a/board/shmin/Makefile b/board/shmin/Makefile index 0377723..daf36de 100644 --- a/board/shmin/Makefile +++ b/board/shmin/Makefile @@ -6,25 +6,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = lib$(BOARD).o - -OBJS := shmin.o -SOBJS := lowlevel_init.o - -LIB := $(addprefix $(obj),$(LIB)) -OBJS := $(addprefix $(obj),$(OBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := shmin.o +obj-y += lowlevel_init.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Andreas Bießmann andreas.devel@googlemail.com --- arch/avr32/cpu/Makefile | 40 ++++++++--------------------------- arch/avr32/cpu/at32ap700x/Makefile | 22 +------------------ arch/avr32/lib/Makefile | 28 ++++-------------------- board/atmel/atngw100/Makefile | 21 +----------------- board/atmel/atngw100mkii/Makefile | 21 +----------------- board/atmel/atstk1000/Makefile | 21 +----------------- board/earthlcd/favr-32-ezkit/Makefile | 21 +----------------- board/in-circuit/grasshopper/Makefile | 21 +----------------- board/mimc/mimc200/Makefile | 21 +----------------- board/miromico/hammerhead/Makefile | 21 +----------------- 10 files changed, 21 insertions(+), 216 deletions(-)
diff --git a/arch/avr32/cpu/Makefile b/arch/avr32/cpu/Makefile index 7e648fd..5e11721 100644 --- a/arch/avr32/cpu/Makefile +++ b/arch/avr32/cpu/Makefile @@ -7,34 +7,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(CPU).o - -START-y += start.o - -COBJS-y += cpu.o -COBJS-$(CONFIG_SYS_HSDRAMC) += hsdramc.o -COBJS-y += exception.o -COBJS-y += cache.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_PORTMUX_PIO) += portmux-pio.o -COBJS-$(CONFIG_PORTMUX_GPIO) += portmux-gpio.o - -SRCS := $(START-y:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(START-y)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y += start.o + +obj-y += cpu.o +obj-$(CONFIG_SYS_HSDRAMC) += hsdramc.o +obj-y += exception.o +obj-y += cache.o +obj-y += interrupts.o +obj-$(CONFIG_PORTMUX_PIO) += portmux-pio.o +obj-$(CONFIG_PORTMUX_GPIO) += portmux-gpio.o diff --git a/arch/avr32/cpu/at32ap700x/Makefile b/arch/avr32/cpu/at32ap700x/Makefile index 8be8c1d..06f1896 100644 --- a/arch/avr32/cpu/at32ap700x/Makefile +++ b/arch/avr32/cpu/at32ap700x/Makefile @@ -4,24 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(SOC).o - -COBJS := portmux.o clk.o mmu.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := portmux.o clk.o mmu.o diff --git a/arch/avr32/lib/Makefile b/arch/avr32/lib/Makefile index d5245d3..bb45cbe 100644 --- a/arch/avr32/lib/Makefile +++ b/arch/avr32/lib/Makefile @@ -7,27 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -SOBJS-y += memset.o - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += interrupts.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += memset.o +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += interrupts.o diff --git a/board/atmel/atngw100/Makefile b/board/atmel/atngw100/Makefile index 955a9c5..f9b93c9 100644 --- a/board/atmel/atngw100/Makefile +++ b/board/atmel/atngw100/Makefile @@ -3,23 +3,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := atngw100.o diff --git a/board/atmel/atngw100mkii/Makefile b/board/atmel/atngw100mkii/Makefile index 955a9c5..90bf5bc 100644 --- a/board/atmel/atngw100mkii/Makefile +++ b/board/atmel/atngw100mkii/Makefile @@ -3,23 +3,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := atngw100mkii.o diff --git a/board/atmel/atstk1000/Makefile b/board/atmel/atstk1000/Makefile index 4eab5a7..ad76631 100644 --- a/board/atmel/atstk1000/Makefile +++ b/board/atmel/atstk1000/Makefile @@ -6,23 +6,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += atstk1000.o diff --git a/board/earthlcd/favr-32-ezkit/Makefile b/board/earthlcd/favr-32-ezkit/Makefile index 0b3ebe3..f712ab9 100644 --- a/board/earthlcd/favr-32-ezkit/Makefile +++ b/board/earthlcd/favr-32-ezkit/Makefile @@ -6,23 +6,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := favr-32-ezkit.o flash.o diff --git a/board/in-circuit/grasshopper/Makefile b/board/in-circuit/grasshopper/Makefile index 1930e89..0457635 100644 --- a/board/in-circuit/grasshopper/Makefile +++ b/board/in-circuit/grasshopper/Makefile @@ -7,23 +7,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += grasshopper.o diff --git a/board/mimc/mimc200/Makefile b/board/mimc/mimc200/Makefile index 955a9c5..5c30c0d 100644 --- a/board/mimc/mimc200/Makefile +++ b/board/mimc/mimc200/Makefile @@ -3,23 +3,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mimc200.o diff --git a/board/miromico/hammerhead/Makefile b/board/miromico/hammerhead/Makefile index 3a2a8eb..638a9df 100644 --- a/board/miromico/hammerhead/Makefile +++ b/board/miromico/hammerhead/Makefile @@ -3,23 +3,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := hammerhead.o
Reviewed-by: Andreas Bießmann andreas.devel@googlemail.com
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Stefan Kristiansson stefan.kristiansson@saunalahti.fi --- arch/openrisc/cpu/Makefile | 26 ++------------------------ arch/openrisc/lib/Makefile | 27 +++------------------------ board/openrisc/openrisc-generic/Makefile | 21 +-------------------- 3 files changed, 6 insertions(+), 68 deletions(-)
diff --git a/arch/openrisc/cpu/Makefile b/arch/openrisc/cpu/Makefile index 863d9b3..fc47d66 100644 --- a/arch/openrisc/cpu/Makefile +++ b/arch/openrisc/cpu/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS-y = cache.o cpu.o exceptions.o interrupts.o - -SRCS := $(START:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cache.o cpu.o exceptions.o interrupts.o diff --git a/arch/openrisc/lib/Makefile b/arch/openrisc/lib/Makefile index b2218c9..dfa72d9 100644 --- a/arch/openrisc/lib/Makefile +++ b/arch/openrisc/lib/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -SOBJS-y += - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += timer.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += timer.o diff --git a/board/openrisc/openrisc-generic/Makefile b/board/openrisc/openrisc-generic/Makefile index bd15345..342bc80 100644 --- a/board/openrisc/openrisc-generic/Makefile +++ b/board/openrisc/openrisc-generic/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := openrisc-generic.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Michal Simek michal.simek@xilinx.com --- arch/microblaze/cpu/Makefile | 28 +++------------------------- arch/microblaze/lib/Makefile | 27 +++------------------------ board/xilinx/microblaze-generic/Makefile | 22 +--------------------- 3 files changed, 7 insertions(+), 70 deletions(-)
diff --git a/arch/microblaze/cpu/Makefile b/arch/microblaze/cpu/Makefile index d0931f8..6e201f2 100644 --- a/arch/microblaze/cpu/Makefile +++ b/arch/microblaze/cpu/Makefile @@ -5,28 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS = irq.o -COBJS = cpu.o interrupts.o cache.o exception.o timer.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = irq.o +obj-y += cpu.o interrupts.o cache.o exception.o timer.o diff --git a/arch/microblaze/lib/Makefile b/arch/microblaze/lib/Makefile index b86f980..339dd15 100644 --- a/arch/microblaze/lib/Makefile +++ b/arch/microblaze/lib/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -SOBJS-y += - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += muldi3.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += muldi3.o diff --git a/board/xilinx/microblaze-generic/Makefile b/board/xilinx/microblaze-generic/Makefile index 6a25ce6..22c8bef 100644 --- a/board/xilinx/microblaze-generic/Makefile +++ b/board/xilinx/microblaze-generic/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = microblaze-generic.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Daniel Schwierzeck daniel.schwierzeck@googlemail.com --- arch/mips/cpu/mips32/Makefile | 28 +++-------------------- arch/mips/cpu/mips32/au1x00/Makefile | 23 +------------------ arch/mips/cpu/mips32/incaip/Makefile | 25 ++------------------ arch/mips/cpu/mips64/Makefile | 24 ++------------------ arch/mips/cpu/xburst/Makefile | 30 +++--------------------- arch/mips/lib/Makefile | 44 ++++-------------------------------- board/dbau1x00/Makefile | 24 ++------------------ board/incaip/Makefile | 24 ++------------------ board/micronas/vct/Makefile | 37 +++++++----------------------- board/pb1x00/Makefile | 24 ++------------------ board/qemu-malta/Makefile | 24 ++------------------ board/qemu-mips/Makefile | 24 ++------------------ 12 files changed, 34 insertions(+), 297 deletions(-)
diff --git a/arch/mips/cpu/mips32/Makefile b/arch/mips/cpu/mips32/Makefile index 1974034..e0e6309 100644 --- a/arch/mips/cpu/mips32/Makefile +++ b/arch/mips/cpu/mips32/Makefile @@ -5,28 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS-y = cache.o -COBJS-y = cpu.o interrupts.o time.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cache.o +obj-y += cpu.o interrupts.o time.o diff --git a/arch/mips/cpu/mips32/au1x00/Makefile b/arch/mips/cpu/mips32/au1x00/Makefile index 4a045e3..c5643e7 100644 --- a/arch/mips/cpu/mips32/au1x00/Makefile +++ b/arch/mips/cpu/mips32/au1x00/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o au1x00_ide.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = au1x00_eth.o au1x00_serial.o au1x00_usb_ohci.o au1x00_ide.o diff --git a/arch/mips/cpu/mips32/incaip/Makefile b/arch/mips/cpu/mips32/incaip/Makefile index 6368d57..7341a4a 100644 --- a/arch/mips/cpu/mips32/incaip/Makefile +++ b/arch/mips/cpu/mips32/incaip/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS = incaip_wdt.o -COBJS = incaip_clock.o asc_serial.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = incaip_wdt.o +obj-y += incaip_clock.o asc_serial.o diff --git a/arch/mips/cpu/mips64/Makefile b/arch/mips/cpu/mips64/Makefile index b4adb95..899c319 100644 --- a/arch/mips/cpu/mips64/Makefile +++ b/arch/mips/cpu/mips64/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS-y = cpu.o interrupts.o time.o cache.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +extra-y = start.o +obj-y = cpu.o interrupts.o time.o cache.o diff --git a/arch/mips/cpu/xburst/Makefile b/arch/mips/cpu/xburst/Makefile index bf58e04..57714d0 100644 --- a/arch/mips/cpu/xburst/Makefile +++ b/arch/mips/cpu/xburst/Makefile @@ -4,30 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS-y = -COBJS-y = cpu.o timer.o jz_serial.o - -COBJS-$(CONFIG_JZ4740) += jz4740.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o timer.o jz_serial.o +obj-$(CONFIG_JZ4740) += jz4740.o diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index f91406c..3705926 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -5,46 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -## Build a couple of necessary functions into a private libgcc -LIBGCC = $(obj)libgcc.o -GLSOBJS += ashldi3.o -GLSOBJS += ashrdi3.o -GLSOBJS += lshrdi3.o -LGOBJS := $(addprefix $(obj),$(GLSOBJS)) - -SOBJS-y += - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -# Always build libmips.o -TARGETS := $(LIB) +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o
# Build private libgcc only when asked for ifdef USE_PRIVATE_LIBGCC -TARGETS += $(LIBGCC) +lib-y += ashldi3.o +lib-y += ashrdi3.o +lib-y += lshrdi3.o endif - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(LIBGCC): $(obj).depend $(LGOBJS) - $(call cmd_link_o_target, $(LGOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/dbau1x00/Makefile b/board/dbau1x00/Makefile index 9024919..2f14402 100644 --- a/board/dbau1x00/Makefile +++ b/board/dbau1x00/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = dbau1x00.o +obj-y += lowlevel_init.o diff --git a/board/incaip/Makefile b/board/incaip/Makefile index ed7370f..602d30e 100644 --- a/board/incaip/Makefile +++ b/board/incaip/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = incaip.o flash.o +obj-y += lowlevel_init.o diff --git a/board/micronas/vct/Makefile b/board/micronas/vct/Makefile index ff35a5a..ed28cb8 100644 --- a/board/micronas/vct/Makefile +++ b/board/micronas/vct/Makefile @@ -4,32 +4,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-y += ebi.o -COBJS-$(CONFIG_VCT_NOR) += ebi_nor_flash.o -COBJS-$(CONFIG_VCT_ONENAND) += ebi_onenand.o -COBJS-$(CONFIG_DRIVER_SMC911X) += ebi_smc911x.o smc_eeprom.o -COBJS-y += gpio.o -COBJS-y += top.o -COBJS-$(CONFIG_USB_EHCI_VCT) += dcgu.o ehci.o scc.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := vct.o +obj-y += ebi.o +obj-$(CONFIG_VCT_NOR) += ebi_nor_flash.o +obj-$(CONFIG_VCT_ONENAND) += ebi_onenand.o +obj-$(CONFIG_DRIVER_SMC911X) += ebi_smc911x.o smc_eeprom.o +obj-y += gpio.o +obj-y += top.o +obj-$(CONFIG_USB_EHCI_VCT) += dcgu.o ehci.o scc.o diff --git a/board/pb1x00/Makefile b/board/pb1x00/Makefile index ed7370f..647eb85 100644 --- a/board/pb1x00/Makefile +++ b/board/pb1x00/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pb1x00.o flash.o +obj-y += lowlevel_init.o diff --git a/board/qemu-malta/Makefile b/board/qemu-malta/Makefile index 7060341..5d727f6 100644 --- a/board/qemu-malta/Makefile +++ b/board/qemu-malta/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = qemu-malta.o +obj-y += lowlevel_init.o diff --git a/board/qemu-mips/Makefile b/board/qemu-mips/Makefile index 7060341..8040573 100644 --- a/board/qemu-mips/Makefile +++ b/board/qemu-mips/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = qemu-mips.o +obj-y += lowlevel_init.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Macpaul Lin macpaul@gmail.com --- arch/nds32/cpu/n1213/Makefile | 24 +----------------------- arch/nds32/cpu/n1213/ag101/Makefile | 27 +++------------------------ arch/nds32/cpu/n1213/ag102/Makefile | 27 +++------------------------ arch/nds32/lib/Makefile | 27 ++++----------------------- board/AndesTech/adp-ag101/Makefile | 21 +-------------------- board/AndesTech/adp-ag101p/Makefile | 21 +-------------------- board/AndesTech/adp-ag102/Makefile | 21 +-------------------- 7 files changed, 14 insertions(+), 154 deletions(-)
diff --git a/arch/nds32/cpu/n1213/Makefile b/arch/nds32/cpu/n1213/Makefile index b8e0d72..bb3550e 100644 --- a/arch/nds32/cpu/n1213/Makefile +++ b/arch/nds32/cpu/n1213/Makefile @@ -9,26 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o diff --git a/arch/nds32/cpu/n1213/ag101/Makefile b/arch/nds32/cpu/n1213/ag101/Makefile index b53a3eb..c21ce02 100644 --- a/arch/nds32/cpu/n1213/ag101/Makefile +++ b/arch/nds32/cpu/n1213/ag101/Makefile @@ -10,33 +10,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y := cpu.o timer.o +obj-y := cpu.o timer.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS-y := lowlevel_init.o +obj-y += lowlevel_init.o endif
ifndef CONFIG_SKIP_TRUNOFF_WATCHDOG -SOBJS-y += watchdog.o +obj-y += watchdog.o endif - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/nds32/cpu/n1213/ag102/Makefile b/arch/nds32/cpu/n1213/ag102/Makefile index b53a3eb..c21ce02 100644 --- a/arch/nds32/cpu/n1213/ag102/Makefile +++ b/arch/nds32/cpu/n1213/ag102/Makefile @@ -10,33 +10,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifndef CONFIG_SKIP_TRUNOFF_WATCHDOG -SOBJS-y += watchdog.o +obj-y += watchdog.o endif - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/nds32/lib/Makefile b/arch/nds32/lib/Makefile index 2f7e155..6ea96db 100644 --- a/arch/nds32/lib/Makefile +++ b/arch/nds32/lib/Makefile @@ -9,26 +9,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -COBJS-y += board.o -COBJS-y += cache.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += interrupts.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o +obj-y += cache.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += interrupts.o diff --git a/board/AndesTech/adp-ag101/Makefile b/board/AndesTech/adp-ag101/Makefile index 826414f..4cc590f 100644 --- a/board/AndesTech/adp-ag101/Makefile +++ b/board/AndesTech/adp-ag101/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := adp-ag101.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := adp-ag101.o diff --git a/board/AndesTech/adp-ag101p/Makefile b/board/AndesTech/adp-ag101p/Makefile index 875fb92..2ba7da4 100644 --- a/board/AndesTech/adp-ag101p/Makefile +++ b/board/AndesTech/adp-ag101p/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := adp-ag101p.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := adp-ag101p.o diff --git a/board/AndesTech/adp-ag102/Makefile b/board/AndesTech/adp-ag102/Makefile index 6c18719..fc4bf88 100644 --- a/board/AndesTech/adp-ag102/Makefile +++ b/board/AndesTech/adp-ag102/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := adp-ag102.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := adp-ag102.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Thomas Chou thomas@wytron.com.tw --- arch/nios2/cpu/Makefile | 30 ++++-------------------------- arch/nios2/lib/Makefile | 30 +++++------------------------- board/altera/nios2-generic/Makefile | 30 +++++------------------------- board/psyent/pci5441/Makefile | 23 +---------------------- board/psyent/pk1c20/Makefile | 23 +---------------------- 5 files changed, 16 insertions(+), 120 deletions(-)
diff --git a/arch/nios2/cpu/Makefile b/arch/nios2/cpu/Makefile index 0834476..bdd983d 100644 --- a/arch/nios2/cpu/Makefile +++ b/arch/nios2/cpu/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS = exceptions.o -COBJS = cpu.o interrupts.o sysid.o traps.o epcs.o -COBJS += fdt.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = exceptions.o +obj-y += cpu.o interrupts.o sysid.o traps.o epcs.o +obj-y += fdt.o diff --git a/arch/nios2/lib/Makefile b/arch/nios2/lib/Makefile index d5dce67..7cb25c0 100644 --- a/arch/nios2/lib/Makefile +++ b/arch/nios2/lib/Makefile @@ -5,28 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -SOBJS-y += cache.o - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += libgcc.o -COBJS-y += time.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cache.o +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += libgcc.o +obj-y += time.o diff --git a/board/altera/nios2-generic/Makefile b/board/altera/nios2-generic/Makefile index ceaf45e..84c7bff 100644 --- a/board/altera/nios2-generic/Makefile +++ b/board/altera/nios2-generic/Makefile @@ -6,32 +6,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_IDE) += ../common/cfide.o -COBJS-$(CONFIG_EPLED) += ../common/epled.o -COBJS-$(CONFIG_SEVENSEG) += ../common/sevenseg.o - -SOBJS-y := text_base.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := nios2-generic.o +obj-$(CONFIG_CMD_IDE) += ../common/cfide.o +obj-$(CONFIG_EPLED) += ../common/epled.o +obj-$(CONFIG_SEVENSEG) += ../common/sevenseg.o +obj-y += text_base.o diff --git a/board/psyent/pci5441/Makefile b/board/psyent/pci5441/Makefile index 68c18b9..9a66cfd 100644 --- a/board/psyent/pci5441/Makefile +++ b/board/psyent/pci5441/Makefile @@ -5,29 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COMOBJS := ../common/AMDLV065D.o - -COBJS := $(BOARD).o $(COMOBJS) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pci5441.o ../common/AMDLV065D.o diff --git a/board/psyent/pk1c20/Makefile b/board/psyent/pk1c20/Makefile index 0e704a5..286db94 100644 --- a/board/psyent/pk1c20/Makefile +++ b/board/psyent/pk1c20/Makefile @@ -5,29 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COMOBJS := ../common/AMDLV065D.o - -COBJS := $(BOARD).o led.o $(COMOBJS) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pk1c20.o led.o ../common/AMDLV065D.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org --- arch/x86/config.mk | 2 +- arch/x86/cpu/Makefile | 28 ++--------------- arch/x86/cpu/coreboot/Makefile | 35 +++++---------------- arch/x86/lib/Makefile | 56 ++++++++++++---------------------- board/chromebook-x86/coreboot/Makefile | 21 +------------ 5 files changed, 31 insertions(+), 111 deletions(-)
diff --git a/arch/x86/config.mk b/arch/x86/config.mk index b22959f..4a4ad80 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -31,7 +31,7 @@ LDFLAGS_FINAL += --gc-sections -pie LDFLAGS_FINAL += --wrap=__divdi3 --wrap=__udivdi3 LDFLAGS_FINAL += --wrap=__moddi3 --wrap=__umoddi3
-NORMAL_LIBGCC = $(shell $(CC) $(CFLAGS) -print-libgcc-file-name) +export NORMAL_LIBGCC = $(shell $(CC) $(CFLAGS) -print-libgcc-file-name) PREFIXED_LIBGCC = $(OBJTREE)/arch/$(ARCH)/lib/$(shell basename $(NORMAL_LIBGCC))
export USE_PRIVATE_LIBGCC=$(shell dirname $(PREFIXED_LIBGCC)) diff --git a/arch/x86/cpu/Makefile b/arch/x86/cpu/Makefile index 41555ab..415bc24 100644 --- a/arch/x86/cpu/Makefile +++ b/arch/x86/cpu/Makefile @@ -8,28 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START-y = start.o -START-$(CONFIG_X86_RESET_VECTOR) += resetvec.o start16.o -COBJS = interrupts.o cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START-y)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +extra-$(CONFIG_X86_RESET_VECTOR) += resetvec.o start16.o +obj-y = interrupts.o cpu.o diff --git a/arch/x86/cpu/coreboot/Makefile b/arch/x86/cpu/coreboot/Makefile index 18fa115..cd0bf4e 100644 --- a/arch/x86/cpu/coreboot/Makefile +++ b/arch/x86/cpu/coreboot/Makefile @@ -13,31 +13,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)lib$(SOC).o - -SOBJS-$(CONFIG_SYS_COREBOOT) += car.o -COBJS-$(CONFIG_SYS_COREBOOT) += coreboot.o -COBJS-$(CONFIG_SYS_COREBOOT) += tables.o -COBJS-$(CONFIG_SYS_COREBOOT) += ipchecksum.o -COBJS-$(CONFIG_SYS_COREBOOT) += sdram.o -COBJS-$(CONFIG_SYS_COREBOOT) += timestamp.o -COBJS-$(CONFIG_PCI) += pci.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SYS_COREBOOT) += car.o +obj-$(CONFIG_SYS_COREBOOT) += coreboot.o +obj-$(CONFIG_SYS_COREBOOT) += tables.o +obj-$(CONFIG_SYS_COREBOOT) += ipchecksum.o +obj-$(CONFIG_SYS_COREBOOT) += sdram.o +obj-$(CONFIG_SYS_COREBOOT) += timestamp.o +obj-$(CONFIG_PCI) += pci.o diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index f389767..638f790 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -5,41 +5,23 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += cmd_boot.o -COBJS-y += gcc.o -COBJS-y += init_helpers.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_SYS_PCAT_INTERRUPTS) += pcat_interrupts.o -COBJS-$(CONFIG_SYS_PCAT_TIMER) += pcat_timer.o -COBJS-$(CONFIG_PCI) += pci_type1.o -COBJS-y += relocate.o -COBJS-y += physmem.o -COBJS-y += string.o -COBJS-$(CONFIG_SYS_X86_TSC_TIMER) += tsc_timer.o -COBJS-$(CONFIG_VIDEO_VGA) += video.o -COBJS-$(CONFIG_CMD_ZBOOT) += zimage.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(PREFIXED_LIBGCC): $(NORMAL_LIBGCC) +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += cmd_boot.o +obj-y += gcc.o +obj-y += init_helpers.o +obj-y += interrupts.o +obj-$(CONFIG_SYS_PCAT_INTERRUPTS) += pcat_interrupts.o +obj-$(CONFIG_SYS_PCAT_TIMER) += pcat_timer.o +obj-$(CONFIG_PCI) += pci_type1.o +obj-y += relocate.o +obj-y += physmem.o +obj-y += string.o +obj-$(CONFIG_SYS_X86_TSC_TIMER) += tsc_timer.o +obj-$(CONFIG_VIDEO_VGA) += video.o +obj-$(CONFIG_CMD_ZBOOT) += zimage.o + +LIBGCC := $(notdir $(NORMAL_LIBGCC)) +extra-y := $(LIBGCC) + +$(obj)$(LIBGCC): $(NORMAL_LIBGCC) $(OBJCOPY) $< $@ --prefix-symbols=__normal_ - -$(LIB): $(PREFIXED_LIBGCC) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/chromebook-x86/coreboot/Makefile b/board/chromebook-x86/coreboot/Makefile index e2222ab..4f2ac89 100644 --- a/board/chromebook-x86/coreboot/Makefile +++ b/board/chromebook-x86/coreboot/Makefile @@ -12,23 +12,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -SOBJS-y += coreboot_start.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += coreboot_start.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Jason Jin Jason.jin@freescale.com --- arch/m68k/cpu/mcf5227x/Makefile | 25 ++----------------------- arch/m68k/cpu/mcf523x/Makefile | 25 ++----------------------- arch/m68k/cpu/mcf52x2/Makefile | 26 ++------------------------ arch/m68k/cpu/mcf532x/Makefile | 25 ++----------------------- arch/m68k/cpu/mcf5445x/Makefile | 25 ++----------------------- arch/m68k/cpu/mcf547x_8x/Makefile | 25 ++----------------------- arch/m68k/lib/Makefile | 33 ++++++--------------------------- board/BuS/eb_cpu5282/Makefile | 22 +--------------------- board/astro/mcf5373l/Makefile | 22 +--------------------- board/cobra5272/Makefile | 22 +--------------------- board/esd/tasreg/Makefile | 22 +--------------------- board/freescale/m5208evbe/Makefile | 22 +--------------------- board/freescale/m52277evb/Makefile | 22 +--------------------- board/freescale/m5235evb/Makefile | 22 +--------------------- board/freescale/m5249evb/Makefile | 22 +--------------------- board/freescale/m5253demo/Makefile | 22 +--------------------- board/freescale/m5253evbe/Makefile | 22 +--------------------- board/freescale/m5271evb/Makefile | 22 +--------------------- board/freescale/m5272c3/Makefile | 22 +--------------------- board/freescale/m5275evb/Makefile | 22 +--------------------- board/freescale/m5282evb/Makefile | 22 +--------------------- board/freescale/m53017evb/Makefile | 22 +--------------------- board/freescale/m5329evb/Makefile | 22 +--------------------- board/freescale/m5373evb/Makefile | 22 +--------------------- board/freescale/m54418twr/Makefile | 22 +--------------------- board/freescale/m54451evb/Makefile | 22 +--------------------- board/freescale/m54455evb/Makefile | 22 +--------------------- board/freescale/m547xevb/Makefile | 22 +--------------------- board/freescale/m548xevb/Makefile | 22 +--------------------- board/idmr/Makefile | 22 +--------------------- 30 files changed, 41 insertions(+), 649 deletions(-)
diff --git a/arch/m68k/cpu/mcf5227x/Makefile b/arch/m68k/cpu/mcf5227x/Makefile index e5384cc..a47fd56 100644 --- a/arch/m68k/cpu/mcf5227x/Makefile +++ b/arch/m68k/cpu/mcf5227x/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # CFLAGS += -DET_DEBUG
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o speed.o cpu_init.o interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o speed.o cpu_init.o interrupts.o diff --git a/arch/m68k/cpu/mcf523x/Makefile b/arch/m68k/cpu/mcf523x/Makefile index e5384cc..a47fd56 100644 --- a/arch/m68k/cpu/mcf523x/Makefile +++ b/arch/m68k/cpu/mcf523x/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o speed.o cpu_init.o interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o speed.o cpu_init.o interrupts.o diff --git a/arch/m68k/cpu/mcf52x2/Makefile b/arch/m68k/cpu/mcf52x2/Makefile index 3a22aee..d9bf900 100644 --- a/arch/m68k/cpu/mcf52x2/Makefile +++ b/arch/m68k/cpu/mcf52x2/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = interrupts.o cpu.o speed.o cpu_init.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = interrupts.o cpu.o speed.o cpu_init.o diff --git a/arch/m68k/cpu/mcf532x/Makefile b/arch/m68k/cpu/mcf532x/Makefile index 7d71dd9..97aa3f1 100644 --- a/arch/m68k/cpu/mcf532x/Makefile +++ b/arch/m68k/cpu/mcf532x/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = -COBJS = cpu.o speed.o cpu_init.o interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y := start.o +obj-y = cpu.o speed.o cpu_init.o interrupts.o diff --git a/arch/m68k/cpu/mcf5445x/Makefile b/arch/m68k/cpu/mcf5445x/Makefile index b76d0ed..b506719 100644 --- a/arch/m68k/cpu/mcf5445x/Makefile +++ b/arch/m68k/cpu/mcf5445x/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o speed.o cpu_init.o interrupts.o pci.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o speed.o cpu_init.o interrupts.o pci.o diff --git a/arch/m68k/cpu/mcf547x_8x/Makefile b/arch/m68k/cpu/mcf547x_8x/Makefile index 13d3c9b..0fa50bf 100644 --- a/arch/m68k/cpu/mcf547x_8x/Makefile +++ b/arch/m68k/cpu/mcf547x_8x/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = -COBJS = cpu.o speed.o cpu_init.o pci.o interrupts.o slicetimer.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o speed.o cpu_init.o pci.o interrupts.o slicetimer.o diff --git a/arch/m68k/lib/Makefile b/arch/m68k/lib/Makefile index 48973fd..65867d6 100644 --- a/arch/m68k/lib/Makefile +++ b/arch/m68k/lib/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o - -SOBJS-y += - -COBJS-y += board.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += cache.o -COBJS-y += interrupts.o -COBJS-y += time.o -COBJS-y += traps.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += cache.o +obj-y += interrupts.o +obj-y += time.o +obj-y += traps.o diff --git a/board/BuS/eb_cpu5282/Makefile b/board/BuS/eb_cpu5282/Makefile index e7f4fb6..3eb7278 100644 --- a/board/BuS/eb_cpu5282/Makefile +++ b/board/BuS/eb_cpu5282/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = eb_cpu5282.o diff --git a/board/astro/mcf5373l/Makefile b/board/astro/mcf5373l/Makefile index b7497a0..005d036 100644 --- a/board/astro/mcf5373l/Makefile +++ b/board/astro/mcf5373l/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o fpga.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mcf5373l.o fpga.o diff --git a/board/cobra5272/Makefile b/board/cobra5272/Makefile index 871865b..fbbbb87 100644 --- a/board/cobra5272/Makefile +++ b/board/cobra5272/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cobra5272.o flash.o diff --git a/board/esd/tasreg/Makefile b/board/esd/tasreg/Makefile index 871865b..46f2550 100644 --- a/board/esd/tasreg/Makefile +++ b/board/esd/tasreg/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = tasreg.o flash.o diff --git a/board/freescale/m5208evbe/Makefile b/board/freescale/m5208evbe/Makefile index d6be84f..1cb17fe 100644 --- a/board/freescale/m5208evbe/Makefile +++ b/board/freescale/m5208evbe/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5208evbe.o diff --git a/board/freescale/m52277evb/Makefile b/board/freescale/m52277evb/Makefile index d6be84f..6b3b8ae 100644 --- a/board/freescale/m52277evb/Makefile +++ b/board/freescale/m52277evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m52277evb.o diff --git a/board/freescale/m5235evb/Makefile b/board/freescale/m5235evb/Makefile index d6be84f..e77d9d9 100644 --- a/board/freescale/m5235evb/Makefile +++ b/board/freescale/m5235evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5235evb.o diff --git a/board/freescale/m5249evb/Makefile b/board/freescale/m5249evb/Makefile index e7f4fb6..4267633 100644 --- a/board/freescale/m5249evb/Makefile +++ b/board/freescale/m5249evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5249evb.o diff --git a/board/freescale/m5253demo/Makefile b/board/freescale/m5253demo/Makefile index 871865b..62f3146 100644 --- a/board/freescale/m5253demo/Makefile +++ b/board/freescale/m5253demo/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5253demo.o flash.o diff --git a/board/freescale/m5253evbe/Makefile b/board/freescale/m5253evbe/Makefile index e7f4fb6..8c55075 100644 --- a/board/freescale/m5253evbe/Makefile +++ b/board/freescale/m5253evbe/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5253evbe.o diff --git a/board/freescale/m5271evb/Makefile b/board/freescale/m5271evb/Makefile index e7f4fb6..77138c6 100644 --- a/board/freescale/m5271evb/Makefile +++ b/board/freescale/m5271evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5271evb.o diff --git a/board/freescale/m5272c3/Makefile b/board/freescale/m5272c3/Makefile index e7f4fb6..10a45f1 100644 --- a/board/freescale/m5272c3/Makefile +++ b/board/freescale/m5272c3/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5272c3.o diff --git a/board/freescale/m5275evb/Makefile b/board/freescale/m5275evb/Makefile index d6be84f..d285c14 100644 --- a/board/freescale/m5275evb/Makefile +++ b/board/freescale/m5275evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5275evb.o diff --git a/board/freescale/m5282evb/Makefile b/board/freescale/m5282evb/Makefile index e7f4fb6..dab8f72 100644 --- a/board/freescale/m5282evb/Makefile +++ b/board/freescale/m5282evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5282evb.o diff --git a/board/freescale/m53017evb/Makefile b/board/freescale/m53017evb/Makefile index d6be84f..bc4bf4a 100644 --- a/board/freescale/m53017evb/Makefile +++ b/board/freescale/m53017evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m53017evb.o diff --git a/board/freescale/m5329evb/Makefile b/board/freescale/m5329evb/Makefile index 79aa836..d8dbafa 100644 --- a/board/freescale/m5329evb/Makefile +++ b/board/freescale/m5329evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o nand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5329evb.o nand.o diff --git a/board/freescale/m5373evb/Makefile b/board/freescale/m5373evb/Makefile index 79aa836..d34e327 100644 --- a/board/freescale/m5373evb/Makefile +++ b/board/freescale/m5373evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o nand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m5373evb.o nand.o diff --git a/board/freescale/m54418twr/Makefile b/board/freescale/m54418twr/Makefile index dc40f30..371c04a 100644 --- a/board/freescale/m54418twr/Makefile +++ b/board/freescale/m54418twr/Makefile @@ -4,24 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m54418twr.o diff --git a/board/freescale/m54451evb/Makefile b/board/freescale/m54451evb/Makefile index d6be84f..700ea2a 100644 --- a/board/freescale/m54451evb/Makefile +++ b/board/freescale/m54451evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m54451evb.o diff --git a/board/freescale/m54455evb/Makefile b/board/freescale/m54455evb/Makefile index d6be84f..1c775fa 100644 --- a/board/freescale/m54455evb/Makefile +++ b/board/freescale/m54455evb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m54455evb.o diff --git a/board/freescale/m547xevb/Makefile b/board/freescale/m547xevb/Makefile index d6be84f..8169177 100644 --- a/board/freescale/m547xevb/Makefile +++ b/board/freescale/m547xevb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m547xevb.o diff --git a/board/freescale/m548xevb/Makefile b/board/freescale/m548xevb/Makefile index d6be84f..4483d15 100644 --- a/board/freescale/m548xevb/Makefile +++ b/board/freescale/m548xevb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = m548xevb.o diff --git a/board/idmr/Makefile b/board/idmr/Makefile index 871865b..67c2384 100644 --- a/board/idmr/Makefile +++ b/board/idmr/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = idmr.o flash.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/cpu/Makefile | 54 ++++++++++++---------------------------- arch/blackfin/lib/Makefile | 52 ++++++++++++-------------------------- board/bct-brettl2/Makefile | 20 ++------------- board/bf506f-ezkit/Makefile | 22 +--------------- board/bf518f-ezbrd/Makefile | 22 +--------------- board/bf525-ucr2/Makefile | 22 +--------------- board/bf526-ezbrd/Makefile | 22 +--------------- board/bf527-ad7160-eval/Makefile | 22 +--------------- board/bf527-ezkit/Makefile | 24 ++---------------- board/bf527-sdp/Makefile | 22 +--------------- board/bf533-ezkit/Makefile | 22 +--------------- board/bf533-stamp/Makefile | 26 +++---------------- board/bf537-minotaur/Makefile | 22 +--------------- board/bf537-pnav/Makefile | 22 +--------------- board/bf537-srv1/Makefile | 22 +--------------- board/bf537-stamp/Makefile | 26 +++---------------- board/bf538f-ezkit/Makefile | 22 +--------------- board/bf548-ezkit/Makefile | 24 ++---------------- board/bf561-acvilon/Makefile | 22 +--------------- board/bf561-ezkit/Makefile | 22 +--------------- board/bf609-ezkit/Makefile | 30 ++-------------------- board/blackstamp/Makefile | 22 +--------------- board/blackvme/Makefile | 22 +--------------- board/br4/Makefile | 22 +--------------- board/cm-bf527/Makefile | 22 +--------------- board/cm-bf533/Makefile | 22 +--------------- board/cm-bf537e/Makefile | 22 +--------------- board/cm-bf537u/Makefile | 22 +--------------- board/cm-bf548/Makefile | 24 ++---------------- board/cm-bf561/Makefile | 22 +--------------- board/dnp5370/Makefile | 22 +--------------- board/ibf-dsp561/Makefile | 22 +--------------- board/ip04/Makefile | 22 +--------------- board/pr1/Makefile | 22 +--------------- board/tcm-bf518/Makefile | 22 +--------------- board/tcm-bf537/Makefile | 22 +--------------- 36 files changed, 75 insertions(+), 799 deletions(-)
diff --git a/arch/blackfin/cpu/Makefile b/arch/blackfin/cpu/Makefile index 1421cb2..9bf544d 100644 --- a/arch/blackfin/cpu/Makefile +++ b/arch/blackfin/cpu/Makefile @@ -9,34 +9,21 @@ # Licensed under the GPL-2 or later. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -EXTRA := init.elf -CEXTRA := initcode.o -SEXTRA := start.o -SOBJS := interrupt.o cache.o -COBJS-y += cpu.o -COBJS-$(CONFIG_ADI_GPIO1) += gpio.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_JTAG_CONSOLE) += jtag-console.o -COBJS-y += os_log.o -COBJS-y += reset.o -COBJS-y += traps.o - -SRCS := $(SEXTRA:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) -EXTRA := $(addprefix $(obj),$(EXTRA)) -CEXTRA := $(addprefix $(obj),$(CEXTRA)) -SEXTRA := $(addprefix $(obj),$(SEXTRA)) - -all: $(obj).depend $(LIB) $(obj).depend $(EXTRA) $(CEXTRA) $(SEXTRA) check_initcode - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(OBJS): $(obj)bootrom-asm-offsets.h +extra-y := init.elf +extra-y += initcode.o +extra-y += start.o +obj-y := interrupt.o cache.o +obj-y += cpu.o +obj-$(CONFIG_ADI_GPIO1) += gpio.o +obj-y += interrupts.o +obj-$(CONFIG_JTAG_CONSOLE) += jtag-console.o +obj-y += os_log.o +obj-y += reset.o +obj-y += traps.o + +extra-y += check_initcode + +extra-y += bootrom-asm-offsets.h $(obj)bootrom-asm-offsets.c: bootrom-asm-offsets.c.in bootrom-asm-offsets.awk echo '#include <asm/mach-common/bits/bootrom.h>' | $(CPP) $(CPPFLAGS) - | gawk -f ./bootrom-asm-offsets.awk > $@.tmp mv $@.tmp $@ @@ -50,7 +37,7 @@ $(obj)bootrom-asm-offsets.h: $(obj)bootrom-asm-offsets.s # have relocs or external references $(obj)initcode.o: CFLAGS += -fno-function-sections -fno-data-sections READINIT = env LC_ALL=C $(CROSS_COMPILE)readelf -s $< -check_initcode: $(obj)initcode.o +$(obj)check_initcode: $(obj)initcode.o ifneq ($(CONFIG_BFIN_BOOT_MODE),BFIN_BOOT_BYPASS) @if $(READINIT) | grep '<GLOBAL>.*<UND>' ; then \ echo "$< contains external references!" 1>&2 ; \ @@ -62,12 +49,3 @@ $(obj)init.lds: init.lds.S $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P $^ -o $@ $(obj)init.elf: $(obj)init.lds $(obj)init.o $(obj)initcode.o $(LD) $(LDFLAGS) -T $^ -o $@ - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/blackfin/lib/Makefile b/arch/blackfin/lib/Makefile index 5603eb9..a5c552f 100644 --- a/arch/blackfin/lib/Makefile +++ b/arch/blackfin/lib/Makefile @@ -9,41 +9,21 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - CFLAGS += -DBFIN_BOARD_NAME='"$(BOARD)"'
-LIB = $(obj)lib$(ARCH).o - -SOBJS-y += ins.o -SOBJS-y += memcmp.o -SOBJS-y += memcpy.o -SOBJS-y += memmove.o -SOBJS-y += memset.o -SOBJS-y += outs.o -SOBJS-$(CONFIG_CMD_KGDB) += __kgdb.o - -COBJS-y += board.o -COBJS-y += boot.o -COBJS-y += cache.o -COBJS-y += clocks.o -COBJS-$(CONFIG_CMD_CACHE_DUMP) += cmd_cache_dump.o -COBJS-$(CONFIG_CMD_KGDB) += kgdb.o -COBJS-y += muldi3.o -COBJS-$(CONFIG_HAS_POST) += post.o -COBJS-y += string.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += ins.o +obj-y += memcmp.o +obj-y += memcpy.o +obj-y += memmove.o +obj-y += memset.o +obj-y += outs.o +obj-$(CONFIG_CMD_KGDB) += __kgdb.o +obj-y += board.o +obj-y += boot.o +obj-y += cache.o +obj-y += clocks.o +obj-$(CONFIG_CMD_CACHE_DUMP) += cmd_cache_dump.o +obj-$(CONFIG_CMD_KGDB) += kgdb.o +obj-y += muldi3.o +obj-$(CONFIG_HAS_POST) += post.o +obj-y += string.o diff --git a/board/bct-brettl2/Makefile b/board/bct-brettl2/Makefile index 6f9f701..12154b6 100644 --- a/board/bct-brettl2/Makefile +++ b/board/bct-brettl2/Makefile @@ -9,21 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o gpio_cfi_flash.o cled.o -COBJS-$(CONFIG_BFIN_MAC) += smsc9303.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := bct-brettl2.o gpio_cfi_flash.o cled.o +obj-$(CONFIG_BFIN_MAC) += smsc9303.o diff --git a/board/bf506f-ezkit/Makefile b/board/bf506f-ezkit/Makefile index b7275f4..0f134f9 100644 --- a/board/bf506f-ezkit/Makefile +++ b/board/bf506f-ezkit/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf506f-ezkit.o diff --git a/board/bf518f-ezbrd/Makefile b/board/bf518f-ezbrd/Makefile index b7275f4..3a6abaa 100644 --- a/board/bf518f-ezbrd/Makefile +++ b/board/bf518f-ezbrd/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf518f-ezbrd.o diff --git a/board/bf525-ucr2/Makefile b/board/bf525-ucr2/Makefile index b7275f4..8de71a1 100644 --- a/board/bf525-ucr2/Makefile +++ b/board/bf525-ucr2/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf525-ucr2.o diff --git a/board/bf526-ezbrd/Makefile b/board/bf526-ezbrd/Makefile index b7275f4..34ac563 100644 --- a/board/bf526-ezbrd/Makefile +++ b/board/bf526-ezbrd/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf526-ezbrd.o diff --git a/board/bf527-ad7160-eval/Makefile b/board/bf527-ad7160-eval/Makefile index b7275f4..9d8ecf1 100644 --- a/board/bf527-ad7160-eval/Makefile +++ b/board/bf527-ad7160-eval/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf527-ad7160-eval.o diff --git a/board/bf527-ezkit/Makefile b/board/bf527-ezkit/Makefile index 1a6ca64..cedd821 100644 --- a/board/bf527-ezkit/Makefile +++ b/board/bf527-ezkit/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_VIDEO) += video.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf527-ezkit.o +obj-$(CONFIG_VIDEO) += video.o diff --git a/board/bf527-sdp/Makefile b/board/bf527-sdp/Makefile index b7275f4..1ddb026 100644 --- a/board/bf527-sdp/Makefile +++ b/board/bf527-sdp/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf527-sdp.o diff --git a/board/bf533-ezkit/Makefile b/board/bf533-ezkit/Makefile index 63a48b2..6838cf0 100644 --- a/board/bf533-ezkit/Makefile +++ b/board/bf533-ezkit/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o flash.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf533-ezkit.o flash.o diff --git a/board/bf533-stamp/Makefile b/board/bf533-stamp/Makefile index d2bc49a..244f9e0 100644 --- a/board/bf533-stamp/Makefile +++ b/board/bf533-stamp/Makefile @@ -9,26 +9,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_STAMP_CF) += ide-cf.o -COBJS-$(CONFIG_VIDEO) += video.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf533-stamp.o +obj-$(CONFIG_STAMP_CF) += ide-cf.o +obj-$(CONFIG_VIDEO) += video.o diff --git a/board/bf537-minotaur/Makefile b/board/bf537-minotaur/Makefile index b7275f4..66d2f05 100644 --- a/board/bf537-minotaur/Makefile +++ b/board/bf537-minotaur/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf537-minotaur.o diff --git a/board/bf537-pnav/Makefile b/board/bf537-pnav/Makefile index b7275f4..ffcdf1f 100644 --- a/board/bf537-pnav/Makefile +++ b/board/bf537-pnav/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf537-pnav.o diff --git a/board/bf537-srv1/Makefile b/board/bf537-srv1/Makefile index b7275f4..cd0da27 100644 --- a/board/bf537-srv1/Makefile +++ b/board/bf537-srv1/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf537-srv1.o diff --git a/board/bf537-stamp/Makefile b/board/bf537-stamp/Makefile index 3e267ed..234119a 100644 --- a/board/bf537-stamp/Makefile +++ b/board/bf537-stamp/Makefile @@ -9,26 +9,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_BFIN_IDE) += ide-cf.o -COBJS-$(CONFIG_HAS_POST) += post-memory.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf537-stamp.o +obj-$(CONFIG_BFIN_IDE) += ide-cf.o +obj-$(CONFIG_HAS_POST) += post-memory.o diff --git a/board/bf538f-ezkit/Makefile b/board/bf538f-ezkit/Makefile index b7275f4..7c8cda0 100644 --- a/board/bf538f-ezkit/Makefile +++ b/board/bf538f-ezkit/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf538f-ezkit.o diff --git a/board/bf548-ezkit/Makefile b/board/bf548-ezkit/Makefile index 1a6ca64..6f4200b 100644 --- a/board/bf548-ezkit/Makefile +++ b/board/bf548-ezkit/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_VIDEO) += video.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf548-ezkit.o +obj-$(CONFIG_VIDEO) += video.o diff --git a/board/bf561-acvilon/Makefile b/board/bf561-acvilon/Makefile index 988cdd8..48bec28 100644 --- a/board/bf561-acvilon/Makefile +++ b/board/bf561-acvilon/Makefile @@ -11,24 +11,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf561-acvilon.o diff --git a/board/bf561-ezkit/Makefile b/board/bf561-ezkit/Makefile index 099bcaf..23c7101 100644 --- a/board/bf561-ezkit/Makefile +++ b/board/bf561-ezkit/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf561-ezkit.o diff --git a/board/bf609-ezkit/Makefile b/board/bf609-ezkit/Makefile index cd2fdc7..3bfd088 100644 --- a/board/bf609-ezkit/Makefile +++ b/board/bf609-ezkit/Makefile @@ -9,31 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_BFIN_SOFT_SWITCH) += soft_switch.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bf609-ezkit.o +obj-$(CONFIG_BFIN_SOFT_SWITCH) += soft_switch.o diff --git a/board/blackstamp/Makefile b/board/blackstamp/Makefile index b7275f4..38e5da7 100644 --- a/board/blackstamp/Makefile +++ b/board/blackstamp/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := blackstamp.o diff --git a/board/blackvme/Makefile b/board/blackvme/Makefile index b7275f4..4ff989a 100644 --- a/board/blackvme/Makefile +++ b/board/blackvme/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := blackvme.o diff --git a/board/br4/Makefile b/board/br4/Makefile index f023abf..68e24ab 100644 --- a/board/br4/Makefile +++ b/board/br4/Makefile @@ -11,24 +11,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := br4.o diff --git a/board/cm-bf527/Makefile b/board/cm-bf527/Makefile index 57b0a7c..ff8ad43 100644 --- a/board/cm-bf527/Makefile +++ b/board/cm-bf527/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o gpio_cfi_flash.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm-bf527.o gpio_cfi_flash.o diff --git a/board/cm-bf533/Makefile b/board/cm-bf533/Makefile index b7275f4..ec99638 100644 --- a/board/cm-bf533/Makefile +++ b/board/cm-bf533/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm-bf533.o diff --git a/board/cm-bf537e/Makefile b/board/cm-bf537e/Makefile index 57b0a7c..be8056f 100644 --- a/board/cm-bf537e/Makefile +++ b/board/cm-bf537e/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o gpio_cfi_flash.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm-bf537e.o gpio_cfi_flash.o diff --git a/board/cm-bf537u/Makefile b/board/cm-bf537u/Makefile index 57b0a7c..38dd3fb 100644 --- a/board/cm-bf537u/Makefile +++ b/board/cm-bf537u/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o gpio_cfi_flash.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm-bf537u.o gpio_cfi_flash.o diff --git a/board/cm-bf548/Makefile b/board/cm-bf548/Makefile index 1a6ca64..98aca32 100644 --- a/board/cm-bf548/Makefile +++ b/board/cm-bf548/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_VIDEO) += video.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm-bf548.o +obj-$(CONFIG_VIDEO) += video.o diff --git a/board/cm-bf561/Makefile b/board/cm-bf561/Makefile index b7275f4..c8764fb 100644 --- a/board/cm-bf561/Makefile +++ b/board/cm-bf561/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm-bf561.o diff --git a/board/dnp5370/Makefile b/board/dnp5370/Makefile index 099bcaf..865522f 100644 --- a/board/dnp5370/Makefile +++ b/board/dnp5370/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dnp5370.o diff --git a/board/ibf-dsp561/Makefile b/board/ibf-dsp561/Makefile index 099bcaf..5b05ba8 100644 --- a/board/ibf-dsp561/Makefile +++ b/board/ibf-dsp561/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ibf-dsp561.o diff --git a/board/ip04/Makefile b/board/ip04/Makefile index 1d23b23..caba16f 100644 --- a/board/ip04/Makefile +++ b/board/ip04/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ip04.o diff --git a/board/pr1/Makefile b/board/pr1/Makefile index f023abf..4f375a8 100644 --- a/board/pr1/Makefile +++ b/board/pr1/Makefile @@ -11,24 +11,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pr1.o diff --git a/board/tcm-bf518/Makefile b/board/tcm-bf518/Makefile index b7275f4..2e029f5 100644 --- a/board/tcm-bf518/Makefile +++ b/board/tcm-bf518/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := tcm-bf518.o diff --git a/board/tcm-bf537/Makefile b/board/tcm-bf537/Makefile index 57b0a7c..93a01e4 100644 --- a/board/tcm-bf537/Makefile +++ b/board/tcm-bf537/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o gpio_cfi_flash.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := tcm-bf537.o gpio_cfi_flash.o
Hi Masahiro,
You patch doesn't pass the building for blackfin architecture.
sonic@nine:~/projects/release/u-boot$ make for dir in tools examples/standalone examples/api arch/blackfin/cpu /home/sonic/projects/release/u-boot/arch/blackfin/cpu/ ; do \ make -C $dir _depend ; done make[1]: Entering directory `/home/sonic/projects/release/u-boot/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/sonic/projects/release/u-boot/tools' make[1]: Entering directory `/home/sonic/projects/release/u-boot/examples/standalone' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/sonic/projects/release/u-boot/examples/standalone' make[1]: Entering directory `/home/sonic/projects/release/u-boot/examples/api' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/sonic/projects/release/u-boot/examples/api' make[1]: Entering directory `/home/sonic/projects/release/u-boot/arch/blackfin/cpu' make[1]: *** No rule to make target `_depend'. Stop. make[1]: Leaving directory `/home/sonic/projects/release/u-boot/arch/blackfin/cpu' make[1]: Entering directory `/home/sonic/projects/release/u-boot/arch/blackfin/cpu' make[1]: *** No rule to make target `_depend'. Stop. make[1]: Leaving directory `/home/sonic/projects/release/u-boot/arch/blackfin/cpu' make: *** [depend] Error 2
Regards,
Sonic
On Mon, Oct 21, 2013 at 10:53 AM, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
-$(LIB): $(OBJS)
-clean:
-distclean: clean
1.8.1.2
Hello Sonic.
On Tue, 22 Oct 2013 15:30:19 +0800 Sonic Zhang sonic.adi@gmail.com wrote:
Hi Masahiro,
This patch file alone does not work.
I wrote in the cover letter as follows: This series uses the followings as prerequisites: - First step towards Kbuild: Use Kbuild style makefiles (19 patch files) - Second step towards Kbuild: Descend down like Kbuild (6 patch files)
Those series have not been applied to u-boot/master yet. Did you apply them beforehand?
Best Regards Masahiro Yamada
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Andreas Bießmann andreas.devel@googlemail.com Cc: Stefano Babic sbabic@denx.de Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Vipin Kumar vipin.kumar@st.com Cc: Tom Warren twarren@nvidia.com Cc: Tom Rini trini@ti.com --- board/8dtech/eco5pk/Makefile | 19 +---------------- board/Barix/ipam390/Makefile | 21 +------------------ board/BuS/eb_cpux9k2/Makefile | 22 +------------------- board/BuS/vl_ma2sc/Makefile | 22 +------------------- board/CarMediaLab/flea3/Makefile | 30 ++------------------------- board/LaCie/edminiv2/Makefile | 20 +----------------- board/LaCie/net2big_v2/Makefile | 29 ++------------------------ board/LaCie/netspace_v2/Makefile | 21 +------------------ board/LaCie/wireless_space/Makefile | 21 +------------------ board/Marvell/aspenite/Makefile | 22 +------------------- board/Marvell/dkb/Makefile | 22 +------------------- board/Marvell/dreamplug/Makefile | 28 +------------------------ board/Marvell/gplugd/Makefile | 22 +------------------- board/Marvell/guruplug/Makefile | 22 +------------------- board/Marvell/mv88f6281gtw_ge/Makefile | 22 +------------------- board/Marvell/openrd/Makefile | 22 +------------------- board/Marvell/rd6281a/Makefile | 22 +------------------- board/Marvell/sheevaplug/Makefile | 22 +------------------- board/Seagate/dockstar/Makefile | 22 +------------------- board/Seagate/goflexhome/Makefile | 22 +------------------- board/actux1/Makefile | 22 +------------------- board/actux2/Makefile | 22 +------------------- board/actux3/Makefile | 22 +------------------- board/actux4/Makefile | 22 +------------------- board/afeb9260/Makefile | 24 ++------------------- board/ait/cam_enc_4xx/Makefile | 22 +------------------- board/altera/socfpga/Makefile | 30 ++------------------------- board/armadeus/apf27/Makefile | 27 +++--------------------- board/armltd/integrator/Makefile | 28 ++++--------------------- board/armltd/versatile/Makefile | 24 ++------------------- board/armltd/vexpress/Makefile | 21 +------------------ board/atmark-techno/armadillo-800eva/Makefile | 27 +----------------------- board/atmel/at91rm9200ek/Makefile | 24 ++------------------- board/atmel/at91sam9260ek/Makefile | 26 +++-------------------- board/atmel/at91sam9261ek/Makefile | 26 +++-------------------- board/atmel/at91sam9263ek/Makefile | 26 +++-------------------- board/atmel/at91sam9m10g45ek/Makefile | 24 ++------------------- board/atmel/at91sam9n12ek/Makefile | 22 +------------------- board/atmel/at91sam9rlek/Makefile | 26 +++-------------------- board/atmel/at91sam9x5ek/Makefile | 22 +------------------- board/atmel/sama5d3xek/Makefile | 22 +------------------- board/balloon3/Makefile | 21 +------------------ board/bluegiga/apx4devkit/Makefile | 23 ++------------------ board/bluewater/snapper9260/Makefile | 22 +------------------- board/boundary/nitrogen6x/Makefile | 21 +------------------ board/buffalo/lsxl/Makefile | 22 +------------------- board/calao/sbc35_a9g20/Makefile | 24 ++------------------- board/calao/tny_a9260/Makefile | 24 ++------------------- board/cloudengines/pogo_e02/Makefile | 22 +------------------- board/cm4008/Makefile | 22 +------------------- board/cm41xx/Makefile | 22 +------------------- board/comelit/dig297/Makefile | 21 +------------------ board/compulab/cm_t35/Makefile | 25 +++------------------- board/congatec/cgtqmx6eval/Makefile | 21 +------------------ board/corscience/tricorder/Makefile | 21 +------------------ board/creative/xfi3/Makefile | 23 ++------------------ board/d-link/dns325/Makefile | 22 +------------------- board/davedenx/qong/Makefile | 24 ++------------------- board/davinci/da8xxevm/Makefile | 27 +++--------------------- board/davinci/dm355evm/Makefile | 22 +------------------- board/davinci/dm355leopard/Makefile | 22 +------------------- board/davinci/dm365evm/Makefile | 22 +------------------- board/davinci/dm6467evm/Makefile | 22 +------------------- board/davinci/dvevm/Makefile | 23 ++------------------ board/davinci/ea20/Makefile | 23 +------------------- board/davinci/schmoogie/Makefile | 23 ++------------------ board/davinci/sffsdr/Makefile | 23 ++------------------ board/davinci/sonata/Makefile | 23 ++------------------ board/denx/m28evk/Makefile | 23 ++------------------ board/denx/m53evk/Makefile | 21 +------------------ board/dvlhost/Makefile | 22 +------------------- board/egnite/ethernut5/Makefile | 24 ++------------------- board/emk/top9000/Makefile | 24 ++------------------- board/enbw/enbw_cmc/Makefile | 21 +------------------ board/esd/meesc/Makefile | 24 ++------------------- board/esd/otc570/Makefile | 24 ++------------------- board/esg/ima3-mx53/Makefile | 21 +------------------ board/eukrea/cpu9260/Makefile | 24 ++------------------- board/eukrea/cpuat91/Makefile | 22 +------------------- board/faraday/a320evb/Makefile | 24 ++------------------- board/freescale/mx23evk/Makefile | 23 ++------------------ board/freescale/mx25pdk/Makefile | 24 ++------------------- board/freescale/mx28evk/Makefile | 23 ++------------------ board/freescale/mx31ads/Makefile | 24 ++------------------- board/freescale/mx31pdk/Makefile | 24 ++------------------- board/freescale/mx35pdk/Makefile | 24 ++------------------- board/freescale/mx51evk/Makefile | 24 ++------------------- board/freescale/mx53ard/Makefile | 21 +------------------ board/freescale/mx53evk/Makefile | 21 +------------------ board/freescale/mx53loco/Makefile | 24 ++------------------- board/freescale/mx53smd/Makefile | 21 +------------------ board/freescale/mx6qarm2/Makefile | 21 +------------------ board/freescale/mx6qsabreauto/Makefile | 21 +------------------ board/freescale/mx6sabresd/Makefile | 21 +------------------ board/freescale/mx6slevk/Makefile | 21 +------------------ board/freescale/titanium/Makefile | 21 +------------------ board/freescale/vf610twr/Makefile | 21 +------------------ board/friendlyarm/mini2440/Makefile | 22 +------------------- board/genesi/mx51_efikamx/Makefile | 21 +------------------ board/h2200/Makefile | 23 ++------------------ board/hale/tt01/Makefile | 29 ++------------------------ board/highbank/Makefile | 27 +----------------------- board/htkw/mcx/Makefile | 19 +---------------- board/icpdas/lp8x4x/Makefile | 21 +------------------ board/imx31_phycore/Makefile | 24 ++------------------- board/iomega/iconnect/Makefile | 22 +------------------- board/isee/igep0033/Makefile | 29 ++------------------------ board/isee/igep00x0/Makefile | 21 +------------------ board/jornada/Makefile | 24 ++------------------- board/karo/tk71/Makefile | 22 +------------------- board/karo/tx25/Makefile | 23 ++------------------ board/keymile/km_arm/Makefile | 23 ++------------------ board/kmc/kzm9g/Makefile | 28 +------------------------ board/logicpd/am3517evm/Makefile | 19 +---------------- board/logicpd/imx27lite/Makefile | 23 ++------------------ board/logicpd/imx31_litekit/Makefile | 24 ++------------------- board/logicpd/omap3som/Makefile | 20 +----------------- board/logicpd/zoom1/Makefile | 21 +------------------ board/logicpd/zoom2/Makefile | 28 ++++--------------------- board/lubbock/Makefile | 21 +------------------ board/matrix_vision/mvblx/Makefile | 24 ++------------------- board/mpl/vcma9/Makefile | 25 +++------------------- board/mx1ads/Makefile | 24 ++------------------- board/nokia/rx51/Makefile | 25 ++-------------------- board/nvidia/beaver/Makefile | 21 +------------------ board/nvidia/cardhu/Makefile | 21 +------------------ board/nvidia/dalmore/Makefile | 21 +------------------ board/nvidia/harmony/Makefile | 21 +------------------ board/nvidia/seaboard/Makefile | 21 +------------------ board/nvidia/ventana/Makefile | 21 +------------------ board/nvidia/whistler/Makefile | 21 +------------------ board/olimex/mx23_olinuxino/Makefile | 23 ++------------------ board/omicron/calimain/Makefile | 21 +------------------ board/overo/Makefile | 20 +----------------- board/palmld/Makefile | 21 +------------------ board/palmtc/Makefile | 22 +------------------- board/palmtreo680/Makefile | 27 +----------------------- board/pandora/Makefile | 21 +------------------ board/phytec/pcm051/Makefile | 29 ++------------------------ board/prodrive/pdnb3/Makefile | 22 +------------------- board/pxa255_idp/Makefile | 21 +------------------ board/raidsonic/ib62x0/Makefile | 22 +------------------- board/raspberrypi/rpi_b/Makefile | 21 +------------------ board/ronetix/pm9261/Makefile | 26 +++-------------------- board/ronetix/pm9263/Makefile | 26 +++-------------------- board/ronetix/pm9g45/Makefile | 22 +------------------- board/samsung/arndale/Makefile | 27 ++---------------------- board/samsung/common/Makefile | 21 +------------------ board/samsung/goni/Makefile | 24 ++------------------- board/samsung/origen/Makefile | 28 +++---------------------- board/samsung/smdk2410/Makefile | 24 ++------------------- board/samsung/smdk5250/Makefile | 29 +++----------------------- board/samsung/smdkc100/Makefile | 26 +++-------------------- board/samsung/smdkv310/Makefile | 28 +++---------------------- board/samsung/trats/Makefile | 21 +------------------ board/samsung/trats2/Makefile | 28 +------------------------ board/samsung/universal_c210/Makefile | 22 +------------------- board/sandisk/sansa_fuze_plus/Makefile | 23 ++------------------ board/scb9328/Makefile | 24 ++------------------- board/schulercontrol/sc_sps_1/Makefile | 23 ++------------------ board/siemens/dxr2/Makefile | 30 +++------------------------ board/siemens/pxm2/Makefile | 30 +++------------------------ board/siemens/rut/Makefile | 30 +++------------------------ board/spear/common/Makefile | 27 ++---------------------- board/spear/spear300/Makefile | 23 +------------------- board/spear/spear310/Makefile | 23 +------------------- board/spear/spear320/Makefile | 23 +------------------- board/spear/spear600/Makefile | 23 +------------------- board/spear/x600/Makefile | 23 +------------------- board/st-ericsson/snowball/Makefile | 26 +---------------------- board/st-ericsson/u8500/Makefile | 21 +------------------ board/st/nhk8815/Makefile | 23 +------------------- board/syteco/jadecpu/Makefile | 24 ++------------------- board/syteco/zmx25/Makefile | 24 ++------------------- board/taskit/stamp9g20/Makefile | 24 ++------------------- board/technexion/twister/Makefile | 19 +---------------- board/teejet/mt_ventoux/Makefile | 19 +---------------- board/timll/devkit3250/Makefile | 22 +------------------- board/timll/devkit8000/Makefile | 21 +------------------ board/toradex/colibri_pxa270/Makefile | 21 +------------------ board/toradex/colibri_t20_iris/Makefile | 25 +++------------------- board/trizepsiv/Makefile | 21 +------------------ board/ttcontrol/vision2/Makefile | 21 +------------------ board/vpac270/Makefile | 23 ++------------------ board/wandboard/Makefile | 21 +------------------ board/woodburn/Makefile | 24 ++------------------- board/xaeniax/Makefile | 21 +------------------ board/xilinx/zynq/Makefile | 29 +------------------------- board/zipitz2/Makefile | 21 +------------------ 189 files changed, 288 insertions(+), 4090 deletions(-)
diff --git a/board/8dtech/eco5pk/Makefile b/board/8dtech/eco5pk/Makefile index 2fafcb8..3333781 100644 --- a/board/8dtech/eco5pk/Makefile +++ b/board/8dtech/eco5pk/Makefile @@ -7,21 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := eco5pk.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := eco5pk.o diff --git a/board/Barix/ipam390/Makefile b/board/Barix/ipam390/Makefile index c84ee05..1cb4b57 100644 --- a/board/Barix/ipam390/Makefile +++ b/board/Barix/ipam390/Makefile @@ -7,23 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS += ipam390.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += ipam390.o diff --git a/board/BuS/eb_cpux9k2/Makefile b/board/BuS/eb_cpux9k2/Makefile index d69195e..b2ec389 100644 --- a/board/BuS/eb_cpux9k2/Makefile +++ b/board/BuS/eb_cpux9k2/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := cpux9k2.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cpux9k2.o diff --git a/board/BuS/vl_ma2sc/Makefile b/board/BuS/vl_ma2sc/Makefile index 821c1a0..d4b24ac 100644 --- a/board/BuS/vl_ma2sc/Makefile +++ b/board/BuS/vl_ma2sc/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS += vl_ma2sc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += vl_ma2sc.o diff --git a/board/CarMediaLab/flea3/Makefile b/board/CarMediaLab/flea3/Makefile index 82a2208..f34be74 100644 --- a/board/CarMediaLab/flea3/Makefile +++ b/board/CarMediaLab/flea3/Makefile @@ -6,31 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := flea3.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := flea3.o +obj-y += lowlevel_init.o diff --git a/board/LaCie/edminiv2/Makefile b/board/LaCie/edminiv2/Makefile index 482f118..7ca06f5 100644 --- a/board/LaCie/edminiv2/Makefile +++ b/board/LaCie/edminiv2/Makefile @@ -9,26 +9,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS := edminiv2.o ../common/common.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := edminiv2.o ../common/common.o diff --git a/board/LaCie/net2big_v2/Makefile b/board/LaCie/net2big_v2/Makefile index ad40231..4fa08c5 100644 --- a/board/LaCie/net2big_v2/Makefile +++ b/board/LaCie/net2big_v2/Makefile @@ -9,36 +9,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ../common/common.o +obj-y := net2big_v2.o ../common/common.o ifneq ($(and $(CONFIG_KIRKWOOD_GPIO),$(CONFIG_NET2BIG_V2)),) -COBJS += ../common/cpld-gpio-bus.o +obj-y += ../common/cpld-gpio-bus.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/LaCie/netspace_v2/Makefile b/board/LaCie/netspace_v2/Makefile index a65b965..e5357e4 100644 --- a/board/LaCie/netspace_v2/Makefile +++ b/board/LaCie/netspace_v2/Makefile @@ -9,27 +9,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ../common/common.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := netspace_v2.o ../common/common.o diff --git a/board/LaCie/wireless_space/Makefile b/board/LaCie/wireless_space/Makefile index a65b965..11c535e 100644 --- a/board/LaCie/wireless_space/Makefile +++ b/board/LaCie/wireless_space/Makefile @@ -9,27 +9,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ../common/common.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := wireless_space.o ../common/common.o diff --git a/board/Marvell/aspenite/Makefile b/board/Marvell/aspenite/Makefile index 1ba7e2a..726d0e4 100644 --- a/board/Marvell/aspenite/Makefile +++ b/board/Marvell/aspenite/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := aspenite.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := aspenite.o diff --git a/board/Marvell/dkb/Makefile b/board/Marvell/dkb/Makefile index 9173154..9d88579 100644 --- a/board/Marvell/dkb/Makefile +++ b/board/Marvell/dkb/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := dkb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dkb.o diff --git a/board/Marvell/dreamplug/Makefile b/board/Marvell/dreamplug/Makefile index ef09f3b..23e6c53 100644 --- a/board/Marvell/dreamplug/Makefile +++ b/board/Marvell/dreamplug/Makefile @@ -9,30 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := dreamplug.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dreamplug.o diff --git a/board/Marvell/gplugd/Makefile b/board/Marvell/gplugd/Makefile index 139f316..b384578 100644 --- a/board/Marvell/gplugd/Makefile +++ b/board/Marvell/gplugd/Makefile @@ -12,24 +12,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := gplugd.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := gplugd.o diff --git a/board/Marvell/guruplug/Makefile b/board/Marvell/guruplug/Makefile index f835762..974497a 100644 --- a/board/Marvell/guruplug/Makefile +++ b/board/Marvell/guruplug/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := guruplug.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := guruplug.o diff --git a/board/Marvell/mv88f6281gtw_ge/Makefile b/board/Marvell/mv88f6281gtw_ge/Makefile index ceb3349..e83bbf7 100644 --- a/board/Marvell/mv88f6281gtw_ge/Makefile +++ b/board/Marvell/mv88f6281gtw_ge/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mv88f6281gtw_ge.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mv88f6281gtw_ge.o diff --git a/board/Marvell/openrd/Makefile b/board/Marvell/openrd/Makefile index f87fe7a..8f95b79 100644 --- a/board/Marvell/openrd/Makefile +++ b/board/Marvell/openrd/Makefile @@ -11,24 +11,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := openrd.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := openrd.o diff --git a/board/Marvell/rd6281a/Makefile b/board/Marvell/rd6281a/Makefile index 67f7162..cb77370 100644 --- a/board/Marvell/rd6281a/Makefile +++ b/board/Marvell/rd6281a/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := rd6281a.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rd6281a.o diff --git a/board/Marvell/sheevaplug/Makefile b/board/Marvell/sheevaplug/Makefile index 6ce57ab..e812545 100644 --- a/board/Marvell/sheevaplug/Makefile +++ b/board/Marvell/sheevaplug/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sheevaplug.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sheevaplug.o diff --git a/board/Seagate/dockstar/Makefile b/board/Seagate/dockstar/Makefile index 1754c81..2ef5093 100644 --- a/board/Seagate/dockstar/Makefile +++ b/board/Seagate/dockstar/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := dockstar.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dockstar.o diff --git a/board/Seagate/goflexhome/Makefile b/board/Seagate/goflexhome/Makefile index d97eb02..e56230c 100644 --- a/board/Seagate/goflexhome/Makefile +++ b/board/Seagate/goflexhome/Makefile @@ -12,24 +12,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := goflexhome.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := goflexhome.o diff --git a/board/actux1/Makefile b/board/actux1/Makefile index 9e581e3..05a8669 100644 --- a/board/actux1/Makefile +++ b/board/actux1/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := actux1.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := actux1.o diff --git a/board/actux2/Makefile b/board/actux2/Makefile index dcb2bda..24cbff1 100644 --- a/board/actux2/Makefile +++ b/board/actux2/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := actux2.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := actux2.o diff --git a/board/actux3/Makefile b/board/actux3/Makefile index effa9a1..f628f26 100644 --- a/board/actux3/Makefile +++ b/board/actux3/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := actux3.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := actux3.o diff --git a/board/actux4/Makefile b/board/actux4/Makefile index b96d385..b949b60 100644 --- a/board/actux4/Makefile +++ b/board/actux4/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := actux4.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := actux4.o diff --git a/board/afeb9260/Makefile b/board/afeb9260/Makefile index dcf926c..e0c3cd5 100644 --- a/board/afeb9260/Makefile +++ b/board/afeb9260/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += afeb9260.o -COBJS-y += partition.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += afeb9260.o +obj-y += partition.o diff --git a/board/ait/cam_enc_4xx/Makefile b/board/ait/cam_enc_4xx/Makefile index 81eb7e7..0d03ce0 100644 --- a/board/ait/cam_enc_4xx/Makefile +++ b/board/ait/cam_enc_4xx/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cam_enc_4xx.o diff --git a/board/altera/socfpga/Makefile b/board/altera/socfpga/Makefile index 9dc45a9..de339ec 100644 --- a/board/altera/socfpga/Makefile +++ b/board/altera/socfpga/Makefile @@ -6,31 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := socfpga_cyclone5.o -COBJS-$(CONFIG_SPL_BUILD) += pinmux_config.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := socfpga_cyclone5.o +obj-$(CONFIG_SPL_BUILD) += pinmux_config.o diff --git a/board/armadeus/apf27/Makefile b/board/armadeus/apf27/Makefile index 5fcda6e..5712971 100644 --- a/board/armadeus/apf27/Makefile +++ b/board/armadeus/apf27/Makefile @@ -7,27 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := apf27.o -SOBJS := lowlevel_init.o -ifdef CONFIG_FPGA -COBJS += fpga.o -endif - -SRCS := $(COBJS:.o=.c) $(SOBJS:.o=.S) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := apf27.o +obj-y += lowlevel_init.o +obj-$(CONFIG_FPGA) += fpga.o diff --git a/board/armltd/integrator/Makefile b/board/armltd/integrator/Makefile index b86fbfb..7e5f6b0 100644 --- a/board/armltd/integrator/Makefile +++ b/board/armltd/integrator/Makefile @@ -9,28 +9,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := lowlevel_init.o
-LIB = $(obj)lib$(BOARD).o - -SOBJS-y := lowlevel_init.o - -COBJS-y := integrator.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-y += timer.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -COBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(COBJS) $(SOBJS) - $(call cmd_link_o_target, $(COBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += integrator.o +obj-$(CONFIG_PCI) += pci.o +obj-y += timer.o diff --git a/board/armltd/versatile/Makefile b/board/armltd/versatile/Makefile index 89ae01f..a09a0ae 100644 --- a/board/armltd/versatile/Makefile +++ b/board/armltd/versatile/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := versatile.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := versatile.o +obj-y += lowlevel_init.o diff --git a/board/armltd/vexpress/Makefile b/board/armltd/vexpress/Makefile index e7dc312..1dd6780 100644 --- a/board/armltd/vexpress/Makefile +++ b/board/armltd/vexpress/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := vexpress_common.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := vexpress_common.o diff --git a/board/atmark-techno/armadillo-800eva/Makefile b/board/atmark-techno/armadillo-800eva/Makefile index a81e40b..2743809 100644 --- a/board/atmark-techno/armadillo-800eva/Makefile +++ b/board/atmark-techno/armadillo-800eva/Makefile @@ -16,30 +16,5 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA
-include $(TOPDIR)/config.mk +obj-y += armadillo-800eva.o
-LIB = $(obj)lib$(BOARD).o - -COBJS-y += armadillo-800eva.o -COBJS := $(COBJS-y) - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/atmel/at91rm9200ek/Makefile b/board/atmel/at91rm9200ek/Makefile index 3179209..0530830 100644 --- a/board/atmel/at91rm9200ek/Makefile +++ b/board/atmel/at91rm9200ek/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += led.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91rm9200ek.o +obj-y += led.o diff --git a/board/atmel/at91sam9260ek/Makefile b/board/atmel/at91sam9260ek/Makefile index a949000..c6edbee 100644 --- a/board/atmel/at91sam9260ek/Makefile +++ b/board/atmel/at91sam9260ek/Makefile @@ -9,26 +9,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9260ek.o -COBJS-y += led.o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9260ek.o +obj-y += led.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/atmel/at91sam9261ek/Makefile b/board/atmel/at91sam9261ek/Makefile index 1551aa2..c547fed 100644 --- a/board/atmel/at91sam9261ek/Makefile +++ b/board/atmel/at91sam9261ek/Makefile @@ -9,26 +9,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9261ek.o -COBJS-y += led.o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9261ek.o +obj-y += led.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/atmel/at91sam9263ek/Makefile b/board/atmel/at91sam9263ek/Makefile index fdb53d3..7b31f18 100644 --- a/board/atmel/at91sam9263ek/Makefile +++ b/board/atmel/at91sam9263ek/Makefile @@ -9,26 +9,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9263ek.o -COBJS-y += led.o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9263ek.o +obj-y += led.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/atmel/at91sam9m10g45ek/Makefile b/board/atmel/at91sam9m10g45ek/Makefile index 84f613b..e5448ec 100644 --- a/board/atmel/at91sam9m10g45ek/Makefile +++ b/board/atmel/at91sam9m10g45ek/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9m10g45ek.o -COBJS-y += led.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9m10g45ek.o +obj-y += led.o diff --git a/board/atmel/at91sam9n12ek/Makefile b/board/atmel/at91sam9n12ek/Makefile index 859817f..9f069ca 100644 --- a/board/atmel/at91sam9n12ek/Makefile +++ b/board/atmel/at91sam9n12ek/Makefile @@ -13,24 +13,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9n12ek.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9n12ek.o diff --git a/board/atmel/at91sam9rlek/Makefile b/board/atmel/at91sam9rlek/Makefile index 7f6ea90..51daf8d 100644 --- a/board/atmel/at91sam9rlek/Makefile +++ b/board/atmel/at91sam9rlek/Makefile @@ -9,26 +9,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9rlek.o -COBJS-y += led.o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9rlek.o +obj-y += led.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/atmel/at91sam9x5ek/Makefile b/board/atmel/at91sam9x5ek/Makefile index e8f19ea..5c42b6f 100644 --- a/board/atmel/at91sam9x5ek/Makefile +++ b/board/atmel/at91sam9x5ek/Makefile @@ -13,24 +13,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += at91sam9x5ek.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += at91sam9x5ek.o diff --git a/board/atmel/sama5d3xek/Makefile b/board/atmel/sama5d3xek/Makefile index 384ca3f..7ff7481 100644 --- a/board/atmel/sama5d3xek/Makefile +++ b/board/atmel/sama5d3xek/Makefile @@ -12,24 +12,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += sama5d3xek.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sama5d3xek.o diff --git a/board/balloon3/Makefile b/board/balloon3/Makefile index 34e2542..d7fb5e0 100644 --- a/board/balloon3/Makefile +++ b/board/balloon3/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := balloon3.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := balloon3.o diff --git a/board/bluegiga/apx4devkit/Makefile b/board/bluegiga/apx4devkit/Makefile index 9c05b61..a7fcb63 100644 --- a/board/bluegiga/apx4devkit/Makefile +++ b/board/bluegiga/apx4devkit/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := apx4devkit.o +obj-y := apx4devkit.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/bluewater/snapper9260/Makefile b/board/bluewater/snapper9260/Makefile index d050473..af7f0da 100644 --- a/board/bluewater/snapper9260/Makefile +++ b/board/bluewater/snapper9260/Makefile @@ -8,24 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += snapper9260.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += snapper9260.o diff --git a/board/boundary/nitrogen6x/Makefile b/board/boundary/nitrogen6x/Makefile index 066f60d..f875d68 100644 --- a/board/boundary/nitrogen6x/Makefile +++ b/board/boundary/nitrogen6x/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := nitrogen6x.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := nitrogen6x.o diff --git a/board/buffalo/lsxl/Makefile b/board/buffalo/lsxl/Makefile index a8700e8..1b01b40 100644 --- a/board/buffalo/lsxl/Makefile +++ b/board/buffalo/lsxl/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := lsxl.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lsxl.o diff --git a/board/calao/sbc35_a9g20/Makefile b/board/calao/sbc35_a9g20/Makefile index e385f8d..9ae2d24 100644 --- a/board/calao/sbc35_a9g20/Makefile +++ b/board/calao/sbc35_a9g20/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += sbc35_a9g20.o -COBJS-$(CONFIG_ATMEL_SPI) += spi.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sbc35_a9g20.o +obj-$(CONFIG_ATMEL_SPI) += spi.o diff --git a/board/calao/tny_a9260/Makefile b/board/calao/tny_a9260/Makefile index 8a95ce2..55a6157 100644 --- a/board/calao/tny_a9260/Makefile +++ b/board/calao/tny_a9260/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += tny_a9260.o -COBJS-$(CONFIG_ATMEL_SPI) += spi.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += tny_a9260.o +obj-$(CONFIG_ATMEL_SPI) += spi.o diff --git a/board/cloudengines/pogo_e02/Makefile b/board/cloudengines/pogo_e02/Makefile index 3bda5e1..8ff0f45 100644 --- a/board/cloudengines/pogo_e02/Makefile +++ b/board/cloudengines/pogo_e02/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := pogo_e02.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pogo_e02.o diff --git a/board/cm4008/Makefile b/board/cm4008/Makefile index d8f9d54..04b1529 100644 --- a/board/cm4008/Makefile +++ b/board/cm4008/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := cm4008.o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm4008.o flash.o diff --git a/board/cm41xx/Makefile b/board/cm41xx/Makefile index 752bfdb..b71ea05 100644 --- a/board/cm41xx/Makefile +++ b/board/cm41xx/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := cm41xx.o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm41xx.o flash.o diff --git a/board/comelit/dig297/Makefile b/board/comelit/dig297/Makefile index 1a5b598..1c85b63 100644 --- a/board/comelit/dig297/Makefile +++ b/board/comelit/dig297/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := dig297.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dig297.o diff --git a/board/compulab/cm_t35/Makefile b/board/compulab/cm_t35/Makefile index 6d07947..66b264a 100644 --- a/board/compulab/cm_t35/Makefile +++ b/board/compulab/cm_t35/Makefile @@ -7,26 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-$(CONFIG_DRIVER_OMAP34XX_I2C) += eeprom.o +obj-$(CONFIG_LCD) += display.o
-LIB = $(obj)lib$(BOARD).o - -COBJS-$(CONFIG_DRIVER_OMAP34XX_I2C) += eeprom.o -COBJS-$(CONFIG_LCD) += display.o - -COBJS := cm_t35.o leds.o $(COBJS-y) - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cm_t35.o leds.o diff --git a/board/congatec/cgtqmx6eval/Makefile b/board/congatec/cgtqmx6eval/Makefile index 8668d97..1bce473 100644 --- a/board/congatec/cgtqmx6eval/Makefile +++ b/board/congatec/cgtqmx6eval/Makefile @@ -7,23 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := cgtqmx6eval.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cgtqmx6eval.o diff --git a/board/corscience/tricorder/Makefile b/board/corscience/tricorder/Makefile index 2ab12bb..d5316f8 100644 --- a/board/corscience/tricorder/Makefile +++ b/board/corscience/tricorder/Makefile @@ -8,23 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := tricorder.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := tricorder.o diff --git a/board/creative/xfi3/Makefile b/board/creative/xfi3/Makefile index 4dc2b48..e8eb9ab 100644 --- a/board/creative/xfi3/Makefile +++ b/board/creative/xfi3/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := xfi3.o +obj-y := xfi3.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/d-link/dns325/Makefile b/board/d-link/dns325/Makefile index 8a8ec0b..b8a5ea1 100644 --- a/board/d-link/dns325/Makefile +++ b/board/d-link/dns325/Makefile @@ -10,24 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := dns325.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dns325.o diff --git a/board/davedenx/qong/Makefile b/board/davedenx/qong/Makefile index 06f63a7..48c443d 100644 --- a/board/davedenx/qong/Makefile +++ b/board/davedenx/qong/Makefile @@ -7,25 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := qong.o fpga.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := qong.o fpga.o +obj-y += lowlevel_init.o diff --git a/board/davinci/da8xxevm/Makefile b/board/davinci/da8xxevm/Makefile index 26dc72c..d3acacc 100644 --- a/board/davinci/da8xxevm/Makefile +++ b/board/davinci/da8xxevm/Makefile @@ -7,27 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-$(CONFIG_MACH_DAVINCI_DA830_EVM) += da830evm.o -COBJS-$(CONFIG_MACH_DAVINCI_DA850_EVM) += da850evm.o -COBJS-$(CONFIG_MACH_DAVINCI_HAWK) += hawkboard.o - -COBJS := $(COBJS-y) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MACH_DAVINCI_DA830_EVM) += da830evm.o +obj-$(CONFIG_MACH_DAVINCI_DA850_EVM) += da850evm.o +obj-$(CONFIG_MACH_DAVINCI_HAWK) += hawkboard.o diff --git a/board/davinci/dm355evm/Makefile b/board/davinci/dm355evm/Makefile index 81eb7e7..bcb7e6f 100644 --- a/board/davinci/dm355evm/Makefile +++ b/board/davinci/dm355evm/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dm355evm.o diff --git a/board/davinci/dm355leopard/Makefile b/board/davinci/dm355leopard/Makefile index 81eb7e7..7035429 100644 --- a/board/davinci/dm355leopard/Makefile +++ b/board/davinci/dm355leopard/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dm355leopard.o diff --git a/board/davinci/dm365evm/Makefile b/board/davinci/dm365evm/Makefile index 81eb7e7..d35d81c 100644 --- a/board/davinci/dm365evm/Makefile +++ b/board/davinci/dm365evm/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dm365evm.o diff --git a/board/davinci/dm6467evm/Makefile b/board/davinci/dm6467evm/Makefile index 81eb7e7..acbbdd5 100644 --- a/board/davinci/dm6467evm/Makefile +++ b/board/davinci/dm6467evm/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dm6467evm.o diff --git a/board/davinci/dvevm/Makefile b/board/davinci/dvevm/Makefile index 870314a..7ade325 100644 --- a/board/davinci/dvevm/Makefile +++ b/board/davinci/dvevm/Makefile @@ -7,24 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := board_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dvevm.o +obj-y += board_init.o diff --git a/board/davinci/ea20/Makefile b/board/davinci/ea20/Makefile index 9bdfa7c..a5311c4 100644 --- a/board/davinci/ea20/Makefile +++ b/board/davinci/ea20/Makefile @@ -7,25 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += ea20.o - -COBJS := $(COBJS-y) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += ea20.o diff --git a/board/davinci/schmoogie/Makefile b/board/davinci/schmoogie/Makefile index 870314a..e170d55 100644 --- a/board/davinci/schmoogie/Makefile +++ b/board/davinci/schmoogie/Makefile @@ -7,24 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := board_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := schmoogie.o +obj-y += board_init.o diff --git a/board/davinci/sffsdr/Makefile b/board/davinci/sffsdr/Makefile index 870314a..4ab30a4 100644 --- a/board/davinci/sffsdr/Makefile +++ b/board/davinci/sffsdr/Makefile @@ -7,24 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := board_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sffsdr.o +obj-y += board_init.o diff --git a/board/davinci/sonata/Makefile b/board/davinci/sonata/Makefile index 870314a..92e1a18 100644 --- a/board/davinci/sonata/Makefile +++ b/board/davinci/sonata/Makefile @@ -7,24 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -SOBJS := board_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sonata.o +obj-y += board_init.o diff --git a/board/denx/m28evk/Makefile b/board/denx/m28evk/Makefile index 8bdeece..5e890b1 100644 --- a/board/denx/m28evk/Makefile +++ b/board/denx/m28evk/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := m28evk.o +obj-y := m28evk.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/denx/m53evk/Makefile b/board/denx/m53evk/Makefile index 1ae71df..19b8977 100644 --- a/board/denx/m53evk/Makefile +++ b/board/denx/m53evk/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := m53evk.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := m53evk.o diff --git a/board/dvlhost/Makefile b/board/dvlhost/Makefile index 19753b5..8b48936 100644 --- a/board/dvlhost/Makefile +++ b/board/dvlhost/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := dvlhost.o watchdog.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dvlhost.o watchdog.o diff --git a/board/egnite/ethernut5/Makefile b/board/egnite/ethernut5/Makefile index 275be0a..2513873 100644 --- a/board/egnite/ethernut5/Makefile +++ b/board/egnite/ethernut5/Makefile @@ -8,25 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += $(BOARD)_pwrman.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += ethernut5.o +obj-y += ethernut5_pwrman.o diff --git a/board/emk/top9000/Makefile b/board/emk/top9000/Makefile index 3125164..8725a6c 100644 --- a/board/emk/top9000/Makefile +++ b/board/emk/top9000/Makefile @@ -8,25 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_ATMEL_SPI) += spi.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += top9000.o +obj-$(CONFIG_ATMEL_SPI) += spi.o diff --git a/board/enbw/enbw_cmc/Makefile b/board/enbw/enbw_cmc/Makefile index 16e390d..054d6e7 100644 --- a/board/enbw/enbw_cmc/Makefile +++ b/board/enbw/enbw_cmc/Makefile @@ -7,23 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := enbw_cmc.o diff --git a/board/esd/meesc/Makefile b/board/esd/meesc/Makefile index a7a16fe..5d16738 100644 --- a/board/esd/meesc/Makefile +++ b/board/esd/meesc/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += meesc.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/esd/otc570/Makefile b/board/esd/otc570/Makefile index 5317913..740bb0a 100644 --- a/board/esd/otc570/Makefile +++ b/board/esd/otc570/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += otc570.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/esg/ima3-mx53/Makefile b/board/esg/ima3-mx53/Makefile index f2cb873..afb8925 100644 --- a/board/esg/ima3-mx53/Makefile +++ b/board/esg/ima3-mx53/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ima3-mx53.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ima3-mx53.o diff --git a/board/eukrea/cpu9260/Makefile b/board/eukrea/cpu9260/Makefile index bd89fe1..e34792a 100644 --- a/board/eukrea/cpu9260/Makefile +++ b/board/eukrea/cpu9260/Makefile @@ -13,25 +13,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += led.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu9260.o +obj-y += led.o diff --git a/board/eukrea/cpuat91/Makefile b/board/eukrea/cpuat91/Makefile index ed9d3e7..59b80c2 100644 --- a/board/eukrea/cpuat91/Makefile +++ b/board/eukrea/cpuat91/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cpuat91.o diff --git a/board/faraday/a320evb/Makefile b/board/faraday/a320evb/Makefile index 7446945..518ce3f 100644 --- a/board/faraday/a320evb/Makefile +++ b/board/faraday/a320evb/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := a320evb.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := a320evb.o +obj-y += lowlevel_init.o diff --git a/board/freescale/mx23evk/Makefile b/board/freescale/mx23evk/Makefile index 01e7de1..c3a79ee 100644 --- a/board/freescale/mx23evk/Makefile +++ b/board/freescale/mx23evk/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := mx23evk.o +obj-y := mx23evk.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/mx25pdk/Makefile b/board/freescale/mx25pdk/Makefile index a01a27d..0b288f2 100644 --- a/board/freescale/mx25pdk/Makefile +++ b/board/freescale/mx25pdk/Makefile @@ -6,25 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx25pdk.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx25pdk.o +obj-y += lowlevel_init.o diff --git a/board/freescale/mx28evk/Makefile b/board/freescale/mx28evk/Makefile index d3634c1..5956d34 100644 --- a/board/freescale/mx28evk/Makefile +++ b/board/freescale/mx28evk/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := mx28evk.o +obj-y := mx28evk.o else -COBJS := iomux.o +obj-y := iomux.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/mx31ads/Makefile b/board/freescale/mx31ads/Makefile index b6c70b0..5e1440d 100644 --- a/board/freescale/mx31ads/Makefile +++ b/board/freescale/mx31ads/Makefile @@ -4,25 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx31ads.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx31ads.o +obj-y += lowlevel_init.o diff --git a/board/freescale/mx31pdk/Makefile b/board/freescale/mx31pdk/Makefile index 860a8a6..754b3ea 100644 --- a/board/freescale/mx31pdk/Makefile +++ b/board/freescale/mx31pdk/Makefile @@ -7,27 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifdef CONFIG_SPL_BUILD -SOBJS := lowlevel_init.o +obj-y += lowlevel_init.o endif -COBJS := mx31pdk.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mx31pdk.o diff --git a/board/freescale/mx35pdk/Makefile b/board/freescale/mx35pdk/Makefile index 7caf52f..5fa1219 100644 --- a/board/freescale/mx35pdk/Makefile +++ b/board/freescale/mx35pdk/Makefile @@ -6,25 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx35pdk.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx35pdk.o +obj-y += lowlevel_init.o diff --git a/board/freescale/mx51evk/Makefile b/board/freescale/mx51evk/Makefile index c9b1455..b2de2d8 100644 --- a/board/freescale/mx51evk/Makefile +++ b/board/freescale/mx51evk/Makefile @@ -6,25 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += mx51evk.o -COBJS-$(CONFIG_VIDEO) += mx51evk_video.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mx51evk.o +obj-$(CONFIG_VIDEO) += mx51evk_video.o diff --git a/board/freescale/mx53ard/Makefile b/board/freescale/mx53ard/Makefile index 8bcb21c..0b7d839 100644 --- a/board/freescale/mx53ard/Makefile +++ b/board/freescale/mx53ard/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx53ard.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx53ard.o diff --git a/board/freescale/mx53evk/Makefile b/board/freescale/mx53evk/Makefile index f244069..e03ac79 100644 --- a/board/freescale/mx53evk/Makefile +++ b/board/freescale/mx53evk/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx53evk.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx53evk.o diff --git a/board/freescale/mx53loco/Makefile b/board/freescale/mx53loco/Makefile index 176a8b6..70ac6db 100644 --- a/board/freescale/mx53loco/Makefile +++ b/board/freescale/mx53loco/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += mx53loco.o -COBJS-$(CONFIG_VIDEO) += mx53loco_video.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mx53loco.o +obj-$(CONFIG_VIDEO) += mx53loco_video.o diff --git a/board/freescale/mx53smd/Makefile b/board/freescale/mx53smd/Makefile index 488b2c8..5da34c0 100644 --- a/board/freescale/mx53smd/Makefile +++ b/board/freescale/mx53smd/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx53smd.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx53smd.o diff --git a/board/freescale/mx6qarm2/Makefile b/board/freescale/mx6qarm2/Makefile index bd37558..79401f4 100644 --- a/board/freescale/mx6qarm2/Makefile +++ b/board/freescale/mx6qarm2/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx6qarm2.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx6qarm2.o diff --git a/board/freescale/mx6qsabreauto/Makefile b/board/freescale/mx6qsabreauto/Makefile index e9c2eb4..ac5bc81 100644 --- a/board/freescale/mx6qsabreauto/Makefile +++ b/board/freescale/mx6qsabreauto/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx6qsabreauto.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx6qsabreauto.o diff --git a/board/freescale/mx6sabresd/Makefile b/board/freescale/mx6sabresd/Makefile index 240fce9..cfca2ef 100644 --- a/board/freescale/mx6sabresd/Makefile +++ b/board/freescale/mx6sabresd/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx6sabresd.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx6sabresd.o diff --git a/board/freescale/mx6slevk/Makefile b/board/freescale/mx6slevk/Makefile index bcd8e4a..6e1971e 100644 --- a/board/freescale/mx6slevk/Makefile +++ b/board/freescale/mx6slevk/Makefile @@ -3,23 +3,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx6slevk.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx6slevk.o diff --git a/board/freescale/titanium/Makefile b/board/freescale/titanium/Makefile index 29a98f6..0ad4cb9 100644 --- a/board/freescale/titanium/Makefile +++ b/board/freescale/titanium/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := titanium.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := titanium.o diff --git a/board/freescale/vf610twr/Makefile b/board/freescale/vf610twr/Makefile index 1541fd6..20b4a6b 100644 --- a/board/freescale/vf610twr/Makefile +++ b/board/freescale/vf610twr/Makefile @@ -4,23 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := vf610twr.o diff --git a/board/friendlyarm/mini2440/Makefile b/board/friendlyarm/mini2440/Makefile index d0d2add..f367107 100644 --- a/board/friendlyarm/mini2440/Makefile +++ b/board/friendlyarm/mini2440/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mini2440.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mini2440.o diff --git a/board/genesi/mx51_efikamx/Makefile b/board/genesi/mx51_efikamx/Makefile index 7ede567..87f5f9e 100644 --- a/board/genesi/mx51_efikamx/Makefile +++ b/board/genesi/mx51_efikamx/Makefile @@ -10,23 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := efikamx.o efikamx-usb.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := efikamx.o efikamx-usb.o diff --git a/board/h2200/Makefile b/board/h2200/Makefile index 26bf144..b654a96 100644 --- a/board/h2200/Makefile +++ b/board/h2200/Makefile @@ -6,31 +6,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := h2200.o
-LIB = $(obj)lib$(BOARD).o - -COBJS := h2200.o - -SRCS := $(COBJS:.o=.c) h2200-header.S -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) $(obj)h2200-header.bin +extra-y := h2200-header.bin
$(obj)h2200-header.o: h2200-header.S $(CC) $(CFLAGS) -c -o $@ $<
$(obj)h2200-header.bin: $(obj)h2200-header.o $(OBJCOPY) -O binary $< $@ - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/hale/tt01/Makefile b/board/hale/tt01/Makefile index afdc2c1..e06a040 100644 --- a/board/hale/tt01/Makefile +++ b/board/hale/tt01/Makefile @@ -6,30 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o -COBJS := tt01.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := tt01.o +obj-y += lowlevel_init.o diff --git a/board/highbank/Makefile b/board/highbank/Makefile index 3aa134a..d3eb232 100644 --- a/board/highbank/Makefile +++ b/board/highbank/Makefile @@ -5,29 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := highbank.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := highbank.o diff --git a/board/htkw/mcx/Makefile b/board/htkw/mcx/Makefile index 641e61e..20149ba 100644 --- a/board/htkw/mcx/Makefile +++ b/board/htkw/mcx/Makefile @@ -6,21 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := mcx.o diff --git a/board/icpdas/lp8x4x/Makefile b/board/icpdas/lp8x4x/Makefile index 270bcac..88e0606 100644 --- a/board/icpdas/lp8x4x/Makefile +++ b/board/icpdas/lp8x4x/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := lp8x4x.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lp8x4x.o diff --git a/board/imx31_phycore/Makefile b/board/imx31_phycore/Makefile index 5aaf766..e781c13 100644 --- a/board/imx31_phycore/Makefile +++ b/board/imx31_phycore/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := imx31_phycore.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := imx31_phycore.o +obj-y += lowlevel_init.o diff --git a/board/iomega/iconnect/Makefile b/board/iomega/iconnect/Makefile index 8809c46..65e357a 100644 --- a/board/iomega/iconnect/Makefile +++ b/board/iomega/iconnect/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := iconnect.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := iconnect.o diff --git a/board/isee/igep0033/Makefile b/board/isee/igep0033/Makefile index 75f1b85..fc985b4 100644 --- a/board/isee/igep0033/Makefile +++ b/board/isee/igep0033/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifdef CONFIG_SPL_BUILD -COBJS := mux.o +obj-y += mux.o endif
-COBJS += board.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o diff --git a/board/isee/igep00x0/Makefile b/board/isee/igep00x0/Makefile index 9ad0213..68b151c 100644 --- a/board/isee/igep00x0/Makefile +++ b/board/isee/igep00x0/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := igep00x0.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := igep00x0.o diff --git a/board/jornada/Makefile b/board/jornada/Makefile index 57cc460..6a6fbf3 100644 --- a/board/jornada/Makefile +++ b/board/jornada/Makefile @@ -7,25 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := jornada.o -SOBJS := setup.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := jornada.o +obj-y += setup.o diff --git a/board/karo/tk71/Makefile b/board/karo/tk71/Makefile index f23b56d..0e0df77 100644 --- a/board/karo/tk71/Makefile +++ b/board/karo/tk71/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := tk71.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := tk71.o diff --git a/board/karo/tx25/Makefile b/board/karo/tx25/Makefile index 257cdd2..add5dd3 100644 --- a/board/karo/tx25/Makefile +++ b/board/karo/tx25/Makefile @@ -5,26 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifdef CONFIG_SPL_BUILD -SOBJS := lowlevel_init.o +obj-y += lowlevel_init.o endif -COBJS := tx25.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += tx25.o diff --git a/board/keymile/km_arm/Makefile b/board/keymile/km_arm/Makefile index 0f2018d..32eaa93 100644 --- a/board/keymile/km_arm/Makefile +++ b/board/keymile/km_arm/Makefile @@ -6,31 +6,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ../common/common.o ../common/ivm.o +obj-y := km_arm.o ../common/common.o ../common/ivm.o
ifdef CONFIG_KM_FPGA_CONFIG -COBJS += fpga_config.o +obj-y += fpga_config.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/kmc/kzm9g/Makefile b/board/kmc/kzm9g/Makefile index 62fb377..7989884 100644 --- a/board/kmc/kzm9g/Makefile +++ b/board/kmc/kzm9g/Makefile @@ -5,30 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := kzm9g.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj) .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := kzm9g.o diff --git a/board/logicpd/am3517evm/Makefile b/board/logicpd/am3517evm/Makefile index 2b4f0b6..73b11df 100644 --- a/board/logicpd/am3517evm/Makefile +++ b/board/logicpd/am3517evm/Makefile @@ -8,21 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := am3517evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := am3517evm.o diff --git a/board/logicpd/imx27lite/Makefile b/board/logicpd/imx27lite/Makefile index c42bd4c..50a3da6 100644 --- a/board/logicpd/imx27lite/Makefile +++ b/board/logicpd/imx27lite/Makefile @@ -5,24 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := imx27lite.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := imx27lite.o +obj-y += lowlevel_init.o diff --git a/board/logicpd/imx31_litekit/Makefile b/board/logicpd/imx31_litekit/Makefile index 33cacac..3fd71c8 100644 --- a/board/logicpd/imx31_litekit/Makefile +++ b/board/logicpd/imx31_litekit/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := imx31_litekit.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := imx31_litekit.o +obj-y += lowlevel_init.o diff --git a/board/logicpd/omap3som/Makefile b/board/logicpd/omap3som/Makefile index f8393fa..87b86ad 100644 --- a/board/logicpd/omap3som/Makefile +++ b/board/logicpd/omap3som/Makefile @@ -5,22 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := omap3logic.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := omap3logic.o diff --git a/board/logicpd/zoom1/Makefile b/board/logicpd/zoom1/Makefile index 4afca20..7da0da0 100644 --- a/board/logicpd/zoom1/Makefile +++ b/board/logicpd/zoom1/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := zoom1.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := zoom1.o diff --git a/board/logicpd/zoom2/Makefile b/board/logicpd/zoom2/Makefile index b1fbbbd..8ec5f25 100644 --- a/board/logicpd/zoom2/Makefile +++ b/board/logicpd/zoom2/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-y += debug_board.o -COBJS-y += zoom2_serial.o -COBJS-$(CONFIG_STATUS_LED) += led.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := zoom2.o +obj-y += debug_board.o +obj-y += zoom2_serial.o +obj-$(CONFIG_STATUS_LED) += led.o diff --git a/board/lubbock/Makefile b/board/lubbock/Makefile index 7b7f51a..2648380 100644 --- a/board/lubbock/Makefile +++ b/board/lubbock/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := lubbock.o flash.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lubbock.o flash.o diff --git a/board/matrix_vision/mvblx/Makefile b/board/matrix_vision/mvblx/Makefile index 1693761..c6c0933 100644 --- a/board/matrix_vision/mvblx/Makefile +++ b/board/matrix_vision/mvblx/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += mvblx.o fpga.o -COBJS-$(CONFIG_ID_EEPROM) += sys_eeprom.o -COBJS := $(COBJS-y) - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) +obj-y += mvblx.o fpga.o +obj-$(CONFIG_ID_EEPROM) += sys_eeprom.o
CFLAGS += -Werror - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/mpl/vcma9/Makefile b/board/mpl/vcma9/Makefile index a6f924d..e0e9669 100644 --- a/board/mpl/vcma9/Makefile +++ b/board/mpl/vcma9/Makefile @@ -5,30 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o +obj-y := ../common/common_util.o +obj-y += vcma9.o cmd_vcma9.o
-COBJS := ../common/common_util.o -COBJS += $(BOARD).o cmd_$(BOARD).o - -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += lowlevel_init.o diff --git a/board/mx1ads/Makefile b/board/mx1ads/Makefile index e34e182..6dfd18e 100644 --- a/board/mx1ads/Makefile +++ b/board/mx1ads/Makefile @@ -12,25 +12,5 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mx1ads.o syncflash.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mx1ads.o syncflash.o +obj-y += lowlevel_init.o diff --git a/board/nokia/rx51/Makefile b/board/nokia/rx51/Makefile index 2772a24..8d4d97b 100644 --- a/board/nokia/rx51/Makefile +++ b/board/nokia/rx51/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -SOBJS-y := lowlevel_init.o - -COBJS := $(sort $(COBJS-y)) -SOBJS := $(sort $(SOBJS-y)) -SRCS := $(COBJS:.o=.c) $(SOBJS:.o=.S) -OBJS := $(addprefix $(obj),$(COBJS)) $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rx51.o +obj-y += lowlevel_init.o diff --git a/board/nvidia/beaver/Makefile b/board/nvidia/beaver/Makefile index 9510f60..f828f52 100644 --- a/board/nvidia/beaver/Makefile +++ b/board/nvidia/beaver/Makefile @@ -14,25 +14,6 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(obj)../cardhu)
-LIB = $(obj)lib$(BOARD).o - -COBJS = ../cardhu/cardhu.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ../cardhu/cardhu.o diff --git a/board/nvidia/cardhu/Makefile b/board/nvidia/cardhu/Makefile index 4a92d7a..3f9b55f 100644 --- a/board/nvidia/cardhu/Makefile +++ b/board/nvidia/cardhu/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cardhu.o diff --git a/board/nvidia/dalmore/Makefile b/board/nvidia/dalmore/Makefile index 699b9f6..7cdff9c 100644 --- a/board/nvidia/dalmore/Makefile +++ b/board/nvidia/dalmore/Makefile @@ -14,23 +14,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := dalmore.o diff --git a/board/nvidia/harmony/Makefile b/board/nvidia/harmony/Makefile index a55c1f9..222b025 100644 --- a/board/nvidia/harmony/Makefile +++ b/board/nvidia/harmony/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := harmony.o diff --git a/board/nvidia/seaboard/Makefile b/board/nvidia/seaboard/Makefile index a55c1f9..9171418 100644 --- a/board/nvidia/seaboard/Makefile +++ b/board/nvidia/seaboard/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := seaboard.o diff --git a/board/nvidia/ventana/Makefile b/board/nvidia/ventana/Makefile index 9c2349d..7265cfc 100644 --- a/board/nvidia/ventana/Makefile +++ b/board/nvidia/ventana/Makefile @@ -5,25 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(obj)../seaboard)
-LIB = $(obj)lib$(BOARD).o - -COBJS = ../seaboard/seaboard.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ../seaboard/seaboard.o diff --git a/board/nvidia/whistler/Makefile b/board/nvidia/whistler/Makefile index 4a92d7a..b54c5fd 100644 --- a/board/nvidia/whistler/Makefile +++ b/board/nvidia/whistler/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := whistler.o diff --git a/board/olimex/mx23_olinuxino/Makefile b/board/olimex/mx23_olinuxino/Makefile index c735e35..133114c 100644 --- a/board/olimex/mx23_olinuxino/Makefile +++ b/board/olimex/mx23_olinuxino/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := mx23_olinuxino.o +obj-y := mx23_olinuxino.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/omicron/calimain/Makefile b/board/omicron/calimain/Makefile index 16e390d..59c118d 100644 --- a/board/omicron/calimain/Makefile +++ b/board/omicron/calimain/Makefile @@ -7,23 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := calimain.o diff --git a/board/overo/Makefile b/board/overo/Makefile index 694f317..9109484 100644 --- a/board/overo/Makefile +++ b/board/overo/Makefile @@ -5,22 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := overo.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -######################################################################### -sinclude $(obj).depend +obj-y := overo.o diff --git a/board/palmld/Makefile b/board/palmld/Makefile index 44a8ad8..ea93ca8 100644 --- a/board/palmld/Makefile +++ b/board/palmld/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := palmld.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := palmld.o diff --git a/board/palmtc/Makefile b/board/palmtc/Makefile index a87eb81..b4a682d 100644 --- a/board/palmtc/Makefile +++ b/board/palmtc/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := palmtc.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := palmtc.o diff --git a/board/palmtreo680/Makefile b/board/palmtreo680/Makefile index 34ffb99..4f79e4b 100644 --- a/board/palmtreo680/Makefile +++ b/board/palmtreo680/Makefile @@ -6,29 +6,4 @@ # This file is released under the terms of GPL v2 and any later version. # See the file COPYING in the root directory of the source tree for details.
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := palmtreo680.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := palmtreo680.o diff --git a/board/pandora/Makefile b/board/pandora/Makefile index 6e75133..918b656 100644 --- a/board/pandora/Makefile +++ b/board/pandora/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := pandora.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pandora.o diff --git a/board/phytec/pcm051/Makefile b/board/phytec/pcm051/Makefile index cb2b999..ecb1d61 100644 --- a/board/phytec/pcm051/Makefile +++ b/board/phytec/pcm051/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += board.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o diff --git a/board/prodrive/pdnb3/Makefile b/board/prodrive/pdnb3/Makefile index 5e4a909..06120f3 100644 --- a/board/prodrive/pdnb3/Makefile +++ b/board/prodrive/pdnb3/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := flash.o pdnb3.o nand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := flash.o pdnb3.o nand.o diff --git a/board/pxa255_idp/Makefile b/board/pxa255_idp/Makefile index a57165c..7b063bd 100644 --- a/board/pxa255_idp/Makefile +++ b/board/pxa255_idp/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := pxa_idp.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pxa_idp.o diff --git a/board/raidsonic/ib62x0/Makefile b/board/raidsonic/ib62x0/Makefile index 9d24ad0..c3b4e69 100644 --- a/board/raidsonic/ib62x0/Makefile +++ b/board/raidsonic/ib62x0/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ib62x0.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ib62x0.o diff --git a/board/raspberrypi/rpi_b/Makefile b/board/raspberrypi/rpi_b/Makefile index 9d0c377..7e9bfbf 100644 --- a/board/raspberrypi/rpi_b/Makefile +++ b/board/raspberrypi/rpi_b/Makefile @@ -12,23 +12,4 @@ # GNU General Public License for more details. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rpi_b.o diff --git a/board/ronetix/pm9261/Makefile b/board/ronetix/pm9261/Makefile index f627eaa..3860283 100644 --- a/board/ronetix/pm9261/Makefile +++ b/board/ronetix/pm9261/Makefile @@ -10,26 +10,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += led.o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += pm9261.o +obj-y += led.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/ronetix/pm9263/Makefile b/board/ronetix/pm9263/Makefile index 7cb6f0f..43ea599 100644 --- a/board/ronetix/pm9263/Makefile +++ b/board/ronetix/pm9263/Makefile @@ -10,26 +10,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += pm9263.o -COBJS-y += led.o -COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += pm9263.o +obj-y += led.o +obj-$(CONFIG_HAS_DATAFLASH) += partition.o diff --git a/board/ronetix/pm9g45/Makefile b/board/ronetix/pm9g45/Makefile index 2810fcf..0a00279 100644 --- a/board/ronetix/pm9g45/Makefile +++ b/board/ronetix/pm9g45/Makefile @@ -9,24 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += pm9g45.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += pm9g45.o diff --git a/board/samsung/arndale/Makefile b/board/samsung/arndale/Makefile index afd8db3..be2b366 100644 --- a/board/samsung/arndale/Makefile +++ b/board/samsung/arndale/Makefile @@ -4,31 +4,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS += arndale_spl.o +obj-y += arndale_spl.o
ifndef CONFIG_SPL_BUILD -COBJS += arndale.o +obj-y += arndale.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -ALL := $(obj).depend $(LIB) - -all: $(ALL) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/samsung/common/Makefile b/board/samsung/common/Makefile index 9e48a7b..f3d0970 100644 --- a/board/samsung/common/Makefile +++ b/board/samsung/common/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libsamsung.o - -COBJS-$(CONFIG_SOFT_I2C_MULTI_BUS) += multi_i2c.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SOFT_I2C_MULTI_BUS) += multi_i2c.o diff --git a/board/samsung/goni/Makefile b/board/samsung/goni/Makefile index cd91d66..2cdc21d 100644 --- a/board/samsung/goni/Makefile +++ b/board/samsung/goni/Makefile @@ -8,25 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := goni.o onenand.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(SOBJS) $(OBJS) - $(call cmd_link_o_target, $(SOBJS) $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := goni.o onenand.o +obj-y += lowlevel_init.o diff --git a/board/samsung/origen/Makefile b/board/samsung/origen/Makefile index 0b1ae1b..e8818bf 100644 --- a/board/samsung/origen/Makefile +++ b/board/samsung/origen/Makefile @@ -4,38 +4,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS += origen.o +obj-y += origen.o endif
-SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -ALL +=$(obj).depend $(LIB) - ifdef CONFIG_SPL_BUILD -ALL += $(OBJTREE)/tools/mk$(BOARD)spl +all: $(OBJTREE)/tools/mk$(BOARD)spl endif
-all: $(ALL) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - +# Fix ME after we implement hostprogs-y. ifdef CONFIG_SPL_BUILD $(OBJTREE)/tools/mk$(BOARD)spl: tools/mkv310_image.c $(HOSTCC) tools/mkv310_image.c -o $(OBJTREE)/tools/mk$(BOARD)spl endif - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/samsung/smdk2410/Makefile b/board/samsung/smdk2410/Makefile index f52d0cd..1939a21 100644 --- a/board/samsung/smdk2410/Makefile +++ b/board/samsung/smdk2410/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := smdk2410.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := smdk2410.o +obj-y += lowlevel_init.o diff --git a/board/samsung/smdk5250/Makefile b/board/samsung/smdk5250/Makefile index 0463079..6a58655 100644 --- a/board/samsung/smdk5250/Makefile +++ b/board/samsung/smdk5250/Makefile @@ -4,35 +4,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS += smdk5250_spl.o +obj-y += smdk5250_spl.o
ifndef CONFIG_SPL_BUILD ifdef CONFIG_OF_CONTROL -COBJS += exynos5-dt.o +obj-y += exynos5-dt.o else -COBJS += smdk5250.o +obj-y += smdk5250.o endif endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -ALL := $(obj).depend $(LIB) - -all: $(ALL) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/samsung/smdkc100/Makefile b/board/samsung/smdkc100/Makefile index 7d4e984..0bcf4e5 100644 --- a/board/samsung/smdkc100/Makefile +++ b/board/samsung/smdkc100/Makefile @@ -8,26 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := smdkc100.o -COBJS-$(CONFIG_SAMSUNG_ONENAND) += onenand.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(SOBJS) $(OBJS) - $(call cmd_link_o_target, $(SOBJS) $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := smdkc100.o +obj-$(CONFIG_SAMSUNG_ONENAND) += onenand.o +obj-y += lowlevel_init.o diff --git a/board/samsung/smdkv310/Makefile b/board/samsung/smdkv310/Makefile index 5806f0e..dbc621b 100644 --- a/board/samsung/smdkv310/Makefile +++ b/board/samsung/smdkv310/Makefile @@ -4,38 +4,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS += smdkv310.o +obj-y += smdkv310.o endif
-SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -ALL := $(obj).depend $(LIB) - ifdef CONFIG_SPL_BUILD -ALL += $(OBJTREE)/tools/mk$(BOARD)spl +all: $(OBJTREE)/tools/mk$(BOARD)spl endif
-all: $(ALL) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - +# Fix ME after we implement hostprogs-y. ifdef CONFIG_SPL_BUILD $(OBJTREE)/tools/mk$(BOARD)spl: tools/mkv310_image.c $(HOSTCC) tools/mkv310_image.c -o $(OBJTREE)/tools/mk$(BOARD)spl endif - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/samsung/trats/Makefile b/board/samsung/trats/Makefile index 5c78517..5dc8a1f 100644 --- a/board/samsung/trats/Makefile +++ b/board/samsung/trats/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += trats.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += trats.o diff --git a/board/samsung/trats2/Makefile b/board/samsung/trats2/Makefile index 805fb81..f501761 100644 --- a/board/samsung/trats2/Makefile +++ b/board/samsung/trats2/Makefile @@ -5,30 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := trats2.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := trats2.o diff --git a/board/samsung/universal_c210/Makefile b/board/samsung/universal_c210/Makefile index 42bde81..4ceeeb6 100644 --- a/board/samsung/universal_c210/Makefile +++ b/board/samsung/universal_c210/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := universal.o onenand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(SOBJS) $(OBJS) - $(call cmd_link_o_target, $(SOBJS) $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := universal.o onenand.o diff --git a/board/sandisk/sansa_fuze_plus/Makefile b/board/sandisk/sansa_fuze_plus/Makefile index 571cc07..667600d 100644 --- a/board/sandisk/sansa_fuze_plus/Makefile +++ b/board/sandisk/sansa_fuze_plus/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := sfp.o +obj-y := sfp.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/scb9328/Makefile b/board/scb9328/Makefile index 779507d..0b08f1a 100644 --- a/board/scb9328/Makefile +++ b/board/scb9328/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := scb9328.o flash.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := scb9328.o flash.o +obj-y += lowlevel_init.o diff --git a/board/schulercontrol/sc_sps_1/Makefile b/board/schulercontrol/sc_sps_1/Makefile index 81482e3..df72fc9 100644 --- a/board/schulercontrol/sc_sps_1/Makefile +++ b/board/schulercontrol/sc_sps_1/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := sc_sps_1.o +obj-y := sc_sps_1.o else -COBJS := spl_boot.o +obj-y := spl_boot.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/siemens/dxr2/Makefile b/board/siemens/dxr2/Makefile index a09b467..5129c6e 100644 --- a/board/siemens/dxr2/Makefile +++ b/board/siemens/dxr2/Makefile @@ -11,39 +11,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - ifdef CONFIG_SPL_BUILD -COBJS := mux.o +obj-y := mux.o endif
-COBJS += board.o +obj-y += board.o ifndef CONFIG_SPL_BUILD -COBJS += ../common/factoryset.o +obj-y += ../common/factoryset.o endif -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/siemens/pxm2/Makefile b/board/siemens/pxm2/Makefile index a09b467..5129c6e 100644 --- a/board/siemens/pxm2/Makefile +++ b/board/siemens/pxm2/Makefile @@ -11,39 +11,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += board.o +obj-y += board.o ifndef CONFIG_SPL_BUILD -COBJS += ../common/factoryset.o +obj-y += ../common/factoryset.o endif -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/siemens/rut/Makefile b/board/siemens/rut/Makefile index a09b467..5129c6e 100644 --- a/board/siemens/rut/Makefile +++ b/board/siemens/rut/Makefile @@ -11,39 +11,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += board.o +obj-y += board.o ifndef CONFIG_SPL_BUILD -COBJS += ../common/factoryset.o +obj-y += ../common/factoryset.o endif -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/spear/common/Makefile b/board/spear/common/Makefile index 6e397ee..08dc09f 100644 --- a/board/spear/common/Makefile +++ b/board/spear/common/Makefile @@ -5,30 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)board/$(VENDOR)/common) -endif - -LIB = $(obj)lib$(VENDOR).o - ifndef CONFIG_SPL_BUILD -COBJS := spr_misc.o -SOBJS := spr_lowlevel_init.o +obj-y := spr_misc.o +obj-y += spr_lowlevel_init.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/spear/spear300/Makefile b/board/spear/spear300/Makefile index 63ff1d5..84d05e3 100644 --- a/board/spear/spear300/Makefile +++ b/board/spear/spear300/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := spear300.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := spear300.o diff --git a/board/spear/spear310/Makefile b/board/spear/spear310/Makefile index 5664097..3a2e3ac 100644 --- a/board/spear/spear310/Makefile +++ b/board/spear/spear310/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := spear310.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := spear310.o diff --git a/board/spear/spear320/Makefile b/board/spear/spear320/Makefile index 986e495..f01116e 100644 --- a/board/spear/spear320/Makefile +++ b/board/spear/spear320/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := spear320.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := spear320.o diff --git a/board/spear/spear600/Makefile b/board/spear/spear600/Makefile index 123512b..7abfb9a 100644 --- a/board/spear/spear600/Makefile +++ b/board/spear/spear600/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := spear600.o +obj-y := spear600.o endif -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/spear/x600/Makefile b/board/spear/x600/Makefile index 5524e4f..f9053fe 100644 --- a/board/spear/x600/Makefile +++ b/board/spear/x600/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := fpga.o $(BOARD).o +obj-y := fpga.o x600.o endif -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/st-ericsson/snowball/Makefile b/board/st-ericsson/snowball/Makefile index d6f45df..6867a70 100644 --- a/board/st-ericsson/snowball/Makefile +++ b/board/st-ericsson/snowball/Makefile @@ -4,30 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - CFLAGS += -D__RELEASE -D__STN_8500 -LIB = $(obj)lib$(BOARD).o - -COBJS := snowball.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend
-######################################################################### +obj-y := snowball.o diff --git a/board/st-ericsson/u8500/Makefile b/board/st-ericsson/u8500/Makefile index 4b901d2..b9dfbe9 100644 --- a/board/st-ericsson/u8500/Makefile +++ b/board/st-ericsson/u8500/Makefile @@ -4,25 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - CFLAGS += -D__RELEASE -D__STN_8500 -LIB = $(obj)lib$(BOARD).o - -COBJS := u8500_href.o gpio.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend
-######################################################################### +obj-y := u8500_href.o gpio.o diff --git a/board/st/nhk8815/Makefile b/board/st/nhk8815/Makefile index b1c6197..dd56944 100644 --- a/board/st/nhk8815/Makefile +++ b/board/st/nhk8815/Makefile @@ -9,25 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := nhk8815.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := nhk8815.o diff --git a/board/syteco/jadecpu/Makefile b/board/syteco/jadecpu/Makefile index 8e96c5e..7426436 100644 --- a/board/syteco/jadecpu/Makefile +++ b/board/syteco/jadecpu/Makefile @@ -9,25 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += jadecpu.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += jadecpu.o +obj-y += lowlevel_init.o diff --git a/board/syteco/zmx25/Makefile b/board/syteco/zmx25/Makefile index 8c289bd..d5edb48 100644 --- a/board/syteco/zmx25/Makefile +++ b/board/syteco/zmx25/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += zmx25.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += zmx25.o +obj-y += lowlevel_init.o diff --git a/board/taskit/stamp9g20/Makefile b/board/taskit/stamp9g20/Makefile index 3909447..d015e0f 100644 --- a/board/taskit/stamp9g20/Makefile +++ b/board/taskit/stamp9g20/Makefile @@ -13,25 +13,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += stamp9g20.o -COBJS-y += led.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += stamp9g20.o +obj-y += led.o diff --git a/board/technexion/twister/Makefile b/board/technexion/twister/Makefile index 641e61e..2a91021 100644 --- a/board/technexion/twister/Makefile +++ b/board/technexion/twister/Makefile @@ -6,21 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := twister.o diff --git a/board/teejet/mt_ventoux/Makefile b/board/teejet/mt_ventoux/Makefile index 641e61e..66f56fd 100644 --- a/board/teejet/mt_ventoux/Makefile +++ b/board/teejet/mt_ventoux/Makefile @@ -6,21 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := mt_ventoux.o diff --git a/board/timll/devkit3250/Makefile b/board/timll/devkit3250/Makefile index a1e69ad..4722986 100644 --- a/board/timll/devkit3250/Makefile +++ b/board/timll/devkit3250/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := devkit3250.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := devkit3250.o diff --git a/board/timll/devkit8000/Makefile b/board/timll/devkit8000/Makefile index 553e699..104b63b 100644 --- a/board/timll/devkit8000/Makefile +++ b/board/timll/devkit8000/Makefile @@ -8,23 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := devkit8000.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := devkit8000.o diff --git a/board/toradex/colibri_pxa270/Makefile b/board/toradex/colibri_pxa270/Makefile index 60f4097..57cfe9b 100644 --- a/board/toradex/colibri_pxa270/Makefile +++ b/board/toradex/colibri_pxa270/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := colibri_pxa270.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := colibri_pxa270.o diff --git a/board/toradex/colibri_t20_iris/Makefile b/board/toradex/colibri_t20_iris/Makefile index 40789f8..7ca3fe5 100644 --- a/board/toradex/colibri_t20_iris/Makefile +++ b/board/toradex/colibri_t20_iris/Makefile @@ -4,28 +4,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(obj)../../nvidia/common) $(shell mkdir -p $(obj)../colibri_t20-common)
-LIB = $(obj)lib$(BOARD).o - -COBJS := ../../nvidia/common/board.o -COBJS += ../colibri_t20-common/colibri_t20-common.o -COBJS += $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ../../nvidia/common/board.o +obj-y += ../colibri_t20-common/colibri_t20-common.o +obj-y += colibri_t20_iris.o diff --git a/board/trizepsiv/Makefile b/board/trizepsiv/Makefile index e71625e..c49686f 100644 --- a/board/trizepsiv/Makefile +++ b/board/trizepsiv/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := conxs.o eeprom.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := conxs.o eeprom.o diff --git a/board/ttcontrol/vision2/Makefile b/board/ttcontrol/vision2/Makefile index dc4bbf2..c3e1e87 100644 --- a/board/ttcontrol/vision2/Makefile +++ b/board/ttcontrol/vision2/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := vision2.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := vision2.o diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile index a138aa4..ad7f7d8 100644 --- a/board/vpac270/Makefile +++ b/board/vpac270/Makefile @@ -6,27 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifndef CONFIG_SPL_BUILD -COBJS := vpac270.o +obj-y := vpac270.o else -COBJS := onenand.o +obj-y := onenand.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/wandboard/Makefile b/board/wandboard/Makefile index d4782e0..5b50eca 100644 --- a/board/wandboard/Makefile +++ b/board/wandboard/Makefile @@ -4,23 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := wandboard.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := wandboard.o diff --git a/board/woodburn/Makefile b/board/woodburn/Makefile index 89e1f24..db2b2d5 100644 --- a/board/woodburn/Makefile +++ b/board/woodburn/Makefile @@ -6,25 +6,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := woodburn.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := woodburn.o +obj-y += lowlevel_init.o diff --git a/board/xaeniax/Makefile b/board/xaeniax/Makefile index 1081eb4..e5f116d 100644 --- a/board/xaeniax/Makefile +++ b/board/xaeniax/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := xaeniax.o flash.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := xaeniax.o flash.o diff --git a/board/xilinx/zynq/Makefile b/board/xilinx/zynq/Makefile index 98a5046..6301a8c 100644 --- a/board/xilinx/zynq/Makefile +++ b/board/xilinx/zynq/Makefile @@ -5,31 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := board.o - -COBJS := $(sort $(COBJS-y)) - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := board.o diff --git a/board/zipitz2/Makefile b/board/zipitz2/Makefile index eed343b..1f7614d 100644 --- a/board/zipitz2/Makefile +++ b/board/zipitz2/Makefile @@ -8,23 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := zipitz2.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := zipitz2.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Kim Phillips kim.phillips@freescale.com Cc: York Sun yorksun@freescale.com Cc: Stefan Roese sr@denx.de --- board/LEOX/elpt860/Makefile | 22 +------- board/Marvell/db64360/Makefile | 25 +-------- board/Marvell/db64460/Makefile | 25 +-------- board/RPXClassic/Makefile | 22 +------- board/RPXlite/Makefile | 22 +------- board/RPXlite_dw/Makefile | 22 +------- board/RRvision/Makefile | 22 +------- board/a3000/Makefile | 22 +------- board/a3m071/Makefile | 22 +------- board/a4m072/Makefile | 22 +------- board/adder/Makefile | 22 +------- board/amcc/acadia/Makefile | 23 +-------- board/amcc/bamboo/Makefile | 26 +--------- board/amcc/bluestone/Makefile | 27 +--------- board/amcc/bubinga/Makefile | 22 +------- board/amcc/canyonlands/Makefile | 29 ++--------- board/amcc/ebony/Makefile | 24 +-------- board/amcc/katmai/Makefile | 27 ++-------- board/amcc/kilauea/Makefile | 24 +-------- board/amcc/luan/Makefile | 24 +-------- board/amcc/makalu/Makefile | 23 +-------- board/amcc/ocotea/Makefile | 24 +-------- board/amcc/redwood/Makefile | 23 +-------- board/amcc/sequoia/Makefile | 29 ++--------- board/amcc/taihu/Makefile | 21 +------- board/amcc/taishan/Makefile | 24 +-------- board/amcc/walnut/Makefile | 22 +------- board/amcc/yosemite/Makefile | 24 +-------- board/amcc/yucca/Makefile | 24 +-------- board/atc/Makefile | 22 +------- board/bc3450/Makefile | 22 +------- board/canmb/Makefile | 25 +-------- board/cm5200/Makefile | 22 +------- board/cmi/Makefile | 22 +------- board/cogent/Makefile | 22 +------- board/cpc45/Makefile | 22 +------- board/cpu86/Makefile | 22 +------- board/cpu87/Makefile | 22 +------- board/cray/L1/Makefile | 30 ++--------- board/csb272/Makefile | 27 +--------- board/csb472/Makefile | 27 +--------- board/cu824/Makefile | 22 +------- board/dave/PPChameleonEVB/Makefile | 22 +------- board/davedenx/aria/Makefile | 23 +-------- board/eXalion/Makefile | 22 +------- board/eltec/elppc/Makefile | 25 +-------- board/eltec/mhpc/Makefile | 22 +------- board/emk/top5200/Makefile | 21 +------- board/emk/top860/Makefile | 22 +------- board/ep8248/Makefile | 22 +------- board/ep8260/Makefile | 22 +------- board/ep82xxm/Makefile | 21 +------- board/esd/adciop/Makefile | 21 +------- board/esd/apc405/Makefile | 21 +------- board/esd/ar405/Makefile | 21 +------- board/esd/ash405/Makefile | 21 +------- board/esd/cms700/Makefile | 21 +------- board/esd/cpci2dp/Makefile | 21 +------- board/esd/cpci405/Makefile | 23 +-------- board/esd/cpci5200/Makefile | 23 +-------- board/esd/cpci750/Makefile | 24 +-------- board/esd/cpciiser4/Makefile | 21 +------- board/esd/dasa_sim/Makefile | 21 +------- board/esd/dp405/Makefile | 21 +------- board/esd/du405/Makefile | 21 +------- board/esd/du440/Makefile | 26 +--------- board/esd/hh405/Makefile | 21 +------- board/esd/hub405/Makefile | 21 +------- board/esd/mecp5123/Makefile | 23 +-------- board/esd/mecp5200/Makefile | 22 +------- board/esd/ocrtc/Makefile | 21 +------- board/esd/pci405/Makefile | 24 +-------- board/esd/pf5200/Makefile | 23 +-------- board/esd/plu405/Makefile | 21 +------- board/esd/pmc405/Makefile | 21 +------- board/esd/pmc405de/Makefile | 26 ++-------- board/esd/pmc440/Makefile | 26 +--------- board/esd/vme8349/Makefile | 25 +-------- board/esd/voh405/Makefile | 21 +------- board/esd/vom405/Makefile | 21 +------- board/esd/wuh405/Makefile | 21 +------- board/esteem192e/Makefile | 22 +------- board/etin/debris/Makefile | 22 +------- board/etin/kvme080/Makefile | 22 +------- board/evb64260/Makefile | 24 +-------- board/exmeritus/hww1u1a/Makefile | 28 ++-------- board/fads/Makefile | 22 +------- board/flagadm/Makefile | 22 +------- board/freescale/b4860qds/Makefile | 38 +++----------- board/freescale/bsc9131rdb/Makefile | 38 +++----------- board/freescale/bsc9132qds/Makefile | 37 ++----------- board/freescale/c29xpcie/Makefile | 30 ++--------- board/freescale/common/Makefile | 86 +++++++++++-------------------- board/freescale/common/p_corenet/Makefile | 11 ++-- board/freescale/corenet_ds/Makefile | 40 ++++---------- board/freescale/mpc5121ads/Makefile | 25 +-------- board/freescale/mpc7448hpc2/Makefile | 24 +-------- board/freescale/mpc8260ads/Makefile | 22 +------- board/freescale/mpc8266ads/Makefile | 22 +------- board/freescale/mpc8308rdb/Makefile | 22 +------- board/freescale/mpc8313erdb/Makefile | 22 +------- board/freescale/mpc8315erdb/Makefile | 22 +------- board/freescale/mpc8323erdb/Makefile | 22 +------- board/freescale/mpc832xemds/Makefile | 25 +-------- board/freescale/mpc8349emds/Makefile | 27 ++-------- board/freescale/mpc8349itx/Makefile | 24 +-------- board/freescale/mpc8360emds/Makefile | 25 +-------- board/freescale/mpc8360erdk/Makefile | 25 +-------- board/freescale/mpc837xemds/Makefile | 25 +-------- board/freescale/mpc837xerdb/Makefile | 25 +-------- board/freescale/mpc8536ds/Makefile | 28 ++-------- board/freescale/mpc8540ads/Makefile | 28 ++-------- board/freescale/mpc8541cds/Makefile | 28 ++-------- board/freescale/mpc8544ds/Makefile | 28 ++-------- board/freescale/mpc8548cds/Makefile | 28 ++-------- board/freescale/mpc8555cds/Makefile | 28 ++-------- board/freescale/mpc8560ads/Makefile | 28 ++-------- board/freescale/mpc8568mds/Makefile | 30 ++--------- board/freescale/mpc8569mds/Makefile | 30 ++--------- board/freescale/mpc8572ds/Makefile | 28 ++-------- board/freescale/mpc8610hpcd/Makefile | 29 ++--------- board/freescale/mpc8641hpcn/Makefile | 26 ++-------- board/freescale/p1010rdb/Makefile | 30 ++--------- board/freescale/p1022ds/Makefile | 34 +++--------- board/freescale/p1023rdb/Makefile | 28 ++-------- board/freescale/p1023rds/Makefile | 26 ++-------- board/freescale/p1_p2_rdb/Makefile | 30 ++--------- board/freescale/p1_p2_rdb_pc/Makefile | 30 ++--------- board/freescale/p1_twr/Makefile | 34 ++---------- board/freescale/p2020come/Makefile | 28 ++-------- board/freescale/p2020ds/Makefile | 28 ++-------- board/freescale/p2041rdb/Makefile | 28 ++-------- board/freescale/t4qds/Makefile | 40 +++----------- board/funkwerk/vovpn-gw/Makefile | 22 +------- board/g2000/Makefile | 22 +------- board/galaxy5200/Makefile | 22 +------- board/gdsys/405ep/Makefile | 32 ++---------- board/gdsys/405ex/Makefile | 33 ++---------- board/gdsys/common/Makefile | 40 +++----------- board/gdsys/dlvision/Makefile | 23 +-------- board/gdsys/gdppc440etx/Makefile | 24 +-------- board/gdsys/intip/Makefile | 29 ++--------- board/gdsys/p1022/Makefile | 34 +++--------- board/gen860t/Makefile | 22 +------- board/genietv/Makefile | 22 +------- board/gw8260/Makefile | 23 +-------- board/hermes/Makefile | 22 +------- board/hidden_dragon/Makefile | 22 +------- board/hymod/Makefile | 22 +------- board/icecube/Makefile | 22 +------- board/icu862/Makefile | 22 +------- board/ids8247/Makefile | 22 +------- board/ifm/ac14xx/Makefile | 23 +-------- board/ifm/o2dnt2/Makefile | 22 +------- board/inka4x0/Makefile | 22 +------- board/intercontrol/digsy_mtc/Makefile | 24 +-------- board/ip860/Makefile | 22 +------- board/ipek01/Makefile | 22 +------- board/iphase4539/Makefile | 22 +------- board/ispan/Makefile | 22 +------- board/ivm/Makefile | 22 +------- board/jse/Makefile | 24 +-------- board/jupiter/Makefile | 22 +------- board/keymile/km82xx/Makefile | 22 +------- board/keymile/km83xx/Makefile | 21 +------- board/korat/Makefile | 26 +--------- board/kup/kup4k/Makefile | 21 +------- board/kup/kup4x/Makefile | 21 +------- board/linkstation/Makefile | 21 +------- board/lwmon/Makefile | 22 +------- board/lwmon5/Makefile | 26 +--------- board/manroland/hmi1001/Makefile | 22 +------- board/manroland/mucmc52/Makefile | 22 +------- board/manroland/uc100/Makefile | 23 +-------- board/manroland/uc101/Makefile | 22 +------- board/matrix_vision/common/Makefile | 26 +--------- board/matrix_vision/mergerbox/Makefile | 23 +-------- board/matrix_vision/mvbc_p/Makefile | 19 +------ board/matrix_vision/mvblm7/Makefile | 23 ++------- board/matrix_vision/mvsmr/Makefile | 21 ++------ board/mbx8xx/Makefile | 22 +------- board/mcc200/Makefile | 22 +------- board/mosaixtech/icon/Makefile | 27 ++-------- board/motionpro/Makefile | 22 +------- board/mousse/Makefile | 21 +------- board/mpc8308_p1m/Makefile | 22 +------- board/mpl/mip405/Makefile | 24 +-------- board/mpl/pati/Makefile | 21 +------- board/mpl/pip405/Makefile | 24 +-------- board/muas3001/Makefile | 22 +------- board/munices/Makefile | 22 +------- board/musenki/Makefile | 22 +------- board/mvblue/Makefile | 22 +------- board/netphone/Makefile | 22 +------- board/netta/Makefile | 22 +------- board/netta2/Makefile | 22 +------- board/netvia/Makefile | 22 +------- board/nx823/Makefile | 22 +------- board/pcs440ep/Makefile | 24 +-------- board/pdm360ng/Makefile | 23 +-------- board/phytec/pcm030/Makefile | 22 +------- board/pm520/Makefile | 22 +------- board/pm826/Makefile | 22 +------- board/pm828/Makefile | 22 +------- board/pn62/Makefile | 22 +------- board/ppmc7xx/Makefile | 25 +-------- board/ppmc8260/Makefile | 22 +------- board/prodrive/alpr/Makefile | 24 +-------- board/prodrive/p3mx/Makefile | 23 +-------- board/prodrive/p3p440/Makefile | 24 +-------- board/quad100hd/Makefile | 23 +-------- board/quantum/Makefile | 22 +------- board/r360mpi/Makefile | 22 +------- board/rattler/Makefile | 22 +------- board/rbc823/Makefile | 22 +------- board/rpxsuper/Makefile | 22 +------- board/rsdproto/Makefile | 24 +-------- board/sacsng/Makefile | 22 +------- board/sandburst/karef/Makefile | 27 ++-------- board/sandburst/metrobox/Makefile | 26 ++-------- board/sandpoint/Makefile | 22 +------- board/sbc405/Makefile | 22 +------- board/sbc8349/Makefile | 25 +-------- board/sbc8548/Makefile | 28 ++-------- board/sbc8641d/Makefile | 26 ++-------- board/sc3/Makefile | 24 +-------- board/sheldon/simpc8313/Makefile | 22 +------- board/sixnet/Makefile | 22 +------- board/snmc/qs850/Makefile | 22 +------- board/snmc/qs860t/Makefile | 22 +------- board/socrates/Makefile | 33 +++--------- board/spc1920/Makefile | 22 +------- board/spd8xx/Makefile | 22 +------- board/stx/stxgp3/Makefile | 30 ++--------- board/stx/stxssa/Makefile | 28 ++-------- board/stx/stxxtc/Makefile | 22 +------- board/svm_sc8xx/Makefile | 22 +------- board/t3corp/Makefile | 29 ++--------- board/total5200/Makefile | 22 +------- board/tqc/tqm5200/Makefile | 24 +-------- board/tqc/tqm8260/Makefile | 21 +------- board/tqc/tqm8272/Makefile | 21 +------- board/tqc/tqm834x/Makefile | 25 +-------- board/tqc/tqm8xx/Makefile | 22 +------- board/utx8245/Makefile | 22 +------- board/v37/Makefile | 22 +------- board/v38b/Makefile | 22 +------- board/ve8313/Makefile | 22 +------- board/w7o/Makefile | 24 +-------- board/xes/common/Makefile | 38 +++----------- board/xes/xpedite1000/Makefile | 24 +-------- board/xes/xpedite517x/Makefile | 26 ++-------- board/xes/xpedite520x/Makefile | 28 ++-------- board/xes/xpedite537x/Makefile | 28 ++-------- board/xes/xpedite550x/Makefile | 28 ++-------- board/zeus/Makefile | 23 +-------- board/zpc1900/Makefile | 22 +------- 257 files changed, 525 insertions(+), 5734 deletions(-)
diff --git a/board/LEOX/elpt860/Makefile b/board/LEOX/elpt860/Makefile index 0268f9c..80f5efe 100644 --- a/board/LEOX/elpt860/Makefile +++ b/board/LEOX/elpt860/Makefile @@ -19,24 +19,4 @@ # #######################################################################
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = elpt860.o flash.o diff --git a/board/Marvell/db64360/Makefile b/board/Marvell/db64360/Makefile index a5f2c54..aad4776 100644 --- a/board/Marvell/db64360/Makefile +++ b/board/Marvell/db64360/Makefile @@ -8,31 +8,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif
-LIB = $(obj)lib$(BOARD).o - -SOBJS = ../common/misc.o - -COBJS = $(BOARD).o ../common/flash.o ../common/serial.o ../common/memory.o pci.o \ +obj-y = db64360.o ../common/flash.o ../common/serial.o ../common/memory.o pci.o \ mv_eth.o ../common/ns16550.o mpsc.o ../common/i2c.o \ - sdram_init.o ../common/intel_flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### + sdram_init.o ../common/intel_flash.o ../common/misc.o diff --git a/board/Marvell/db64460/Makefile b/board/Marvell/db64460/Makefile index a5f2c54..ea9e570 100644 --- a/board/Marvell/db64460/Makefile +++ b/board/Marvell/db64460/Makefile @@ -8,31 +8,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -SOBJS = ../common/misc.o - -COBJS = $(BOARD).o ../common/flash.o ../common/serial.o ../common/memory.o pci.o \ +obj-y += db64460.o ../common/flash.o ../common/serial.o ../common/memory.o pci.o \ mv_eth.o ../common/ns16550.o mpsc.o ../common/i2c.o \ - sdram_init.o ../common/intel_flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### + sdram_init.o ../common/intel_flash.o ../common/misc.o diff --git a/board/RPXClassic/Makefile b/board/RPXClassic/Makefile index c7c05a1..87db754 100644 --- a/board/RPXClassic/Makefile +++ b/board/RPXClassic/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o eccx.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = RPXClassic.o flash.o eccx.o diff --git a/board/RPXlite/Makefile b/board/RPXlite/Makefile index 871865b..c17cbac 100644 --- a/board/RPXlite/Makefile +++ b/board/RPXlite/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = RPXlite.o flash.o diff --git a/board/RPXlite_dw/Makefile b/board/RPXlite_dw/Makefile index 871865b..eff33cf 100644 --- a/board/RPXlite_dw/Makefile +++ b/board/RPXlite_dw/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = RPXlite_dw.o flash.o diff --git a/board/RRvision/Makefile b/board/RRvision/Makefile index 871865b..908e8f8 100644 --- a/board/RRvision/Makefile +++ b/board/RRvision/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = RRvision.o flash.o diff --git a/board/a3000/Makefile b/board/a3000/Makefile index e955841..9b9b048 100644 --- a/board/a3000/Makefile +++ b/board/a3000/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = a3000.o flash.o diff --git a/board/a3m071/Makefile b/board/a3m071/Makefile index 5d2e4d1..4e31e33 100644 --- a/board/a3m071/Makefile +++ b/board/a3m071/Makefile @@ -2,24 +2,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := a3m071.o diff --git a/board/a4m072/Makefile b/board/a4m072/Makefile index 3acd06b..2a40e57 100644 --- a/board/a4m072/Makefile +++ b/board/a4m072/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := a4m072.o diff --git a/board/adder/Makefile b/board/adder/Makefile index 07fa3f3..8dc505a 100644 --- a/board/adder/Makefile +++ b/board/adder/Makefile @@ -8,24 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := adder.o diff --git a/board/amcc/acadia/Makefile b/board/amcc/acadia/Makefile index 06f5c6a..035f407 100644 --- a/board/amcc/acadia/Makefile +++ b/board/amcc/acadia/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cmd_acadia.o memory.o pll.o -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = acadia.o cmd_acadia.o memory.o pll.o diff --git a/board/amcc/bamboo/Makefile b/board/amcc/bamboo/Makefile index 6a5464d..4c0a125 100644 --- a/board/amcc/bamboo/Makefile +++ b/board/amcc/bamboo/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = bamboo.o flash.o +extra-y += init.o diff --git a/board/amcc/bluestone/Makefile b/board/amcc/bluestone/Makefile index 289b379..07320ce 100644 --- a/board/amcc/bluestone/Makefile +++ b/board/amcc/bluestone/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -SOBJS := init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bluestone.o +extra-y += init.o diff --git a/board/amcc/bubinga/Makefile b/board/amcc/bubinga/Makefile index bea58a7..0e7ebca 100644 --- a/board/amcc/bubinga/Makefile +++ b/board/amcc/bubinga/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = bubinga.o flash.o diff --git a/board/amcc/canyonlands/Makefile b/board/amcc/canyonlands/Makefile index 415ec32..ba0765f 100644 --- a/board/amcc/canyonlands/Makefile +++ b/board/amcc/canyonlands/Makefile @@ -5,29 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -SOBJS := init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := canyonlands.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +extra-y += init.o diff --git a/board/amcc/ebony/Makefile b/board/amcc/ebony/Makefile index 553fc6b..5876486 100644 --- a/board/amcc/ebony/Makefile +++ b/board/amcc/ebony/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ebony.o flash.o +extra-y += init.o diff --git a/board/amcc/katmai/Makefile b/board/amcc/katmai/Makefile index b190eba..b738def 100644 --- a/board/amcc/katmai/Makefile +++ b/board/amcc/katmai/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -SOBJS = init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := katmai.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +extra-y += init.o diff --git a/board/amcc/kilauea/Makefile b/board/amcc/kilauea/Makefile index 7e7ff27..754dadc 100644 --- a/board/amcc/kilauea/Makefile +++ b/board/amcc/kilauea/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := kilauea.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o diff --git a/board/amcc/luan/Makefile b/board/amcc/luan/Makefile index 553fc6b..345ad56 100644 --- a/board/amcc/luan/Makefile +++ b/board/amcc/luan/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = luan.o flash.o +extra-y += init.o diff --git a/board/amcc/makalu/Makefile b/board/amcc/makalu/Makefile index efc4bf8..dcf162c 100644 --- a/board/amcc/makalu/Makefile +++ b/board/amcc/makalu/Makefile @@ -5,24 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cmd_pll.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = makalu.o cmd_pll.o +obj-y += init.o diff --git a/board/amcc/ocotea/Makefile b/board/amcc/ocotea/Makefile index 553fc6b..7646bbb 100644 --- a/board/amcc/ocotea/Makefile +++ b/board/amcc/ocotea/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ocotea.o flash.o +extra-y += init.o diff --git a/board/amcc/redwood/Makefile b/board/amcc/redwood/Makefile index 2ab3b20..2bc632b 100644 --- a/board/amcc/redwood/Makefile +++ b/board/amcc/redwood/Makefile @@ -5,24 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = redwood.o +extra-y += init.o diff --git a/board/amcc/sequoia/Makefile b/board/amcc/sequoia/Makefile index c2a4c4b..b4ab5da 100644 --- a/board/amcc/sequoia/Makefile +++ b/board/amcc/sequoia/Makefile @@ -5,29 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y = $(BOARD).o sdram.o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -SOBJS = init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = sequoia.o sdram.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +extra-y += init.o diff --git a/board/amcc/taihu/Makefile b/board/amcc/taihu/Makefile index 8a7bf4a..65606fe 100644 --- a/board/amcc/taihu/Makefile +++ b/board/amcc/taihu/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o lcd.o update.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = taihu.o flash.o lcd.o update.o diff --git a/board/amcc/taishan/Makefile b/board/amcc/taishan/Makefile index 4bb14fe..04e93cc 100644 --- a/board/amcc/taishan/Makefile +++ b/board/amcc/taishan/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o lcd.o update.o showinfo.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = taishan.o lcd.o update.o showinfo.o +extra-y += init.o diff --git a/board/amcc/walnut/Makefile b/board/amcc/walnut/Makefile index bea58a7..9228170 100644 --- a/board/amcc/walnut/Makefile +++ b/board/amcc/walnut/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = walnut.o flash.o diff --git a/board/amcc/yosemite/Makefile b/board/amcc/yosemite/Makefile index 1d80df8..daf020a 100644 --- a/board/amcc/yosemite/Makefile +++ b/board/amcc/yosemite/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = yosemite.o +extra-y += init.o diff --git a/board/amcc/yucca/Makefile b/board/amcc/yucca/Makefile index eaeb387..5b1af32 100644 --- a/board/amcc/yucca/Makefile +++ b/board/amcc/yucca/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o cmd_yucca.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = yucca.o flash.o cmd_yucca.o +extra-y += init.o diff --git a/board/atc/Makefile b/board/atc/Makefile index aa100e4..3a163c4 100644 --- a/board/atc/Makefile +++ b/board/atc/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ti113x.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = atc.o flash.o ti113x.o diff --git a/board/bc3450/Makefile b/board/bc3450/Makefile index 07970c6..b8d22ba 100644 --- a/board/bc3450/Makefile +++ b/board/bc3450/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o cmd_bc3450.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := bc3450.o cmd_bc3450.o diff --git a/board/canmb/Makefile b/board/canmb/Makefile index 4698706..4286a91 100644 --- a/board/canmb/Makefile +++ b/board/canmb/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk -#ifneq ($(OBJTREE),$(SRCTREE)) -#$(shell mkdir -p $(obj)../common) -#endif +obj-y := canmb.o
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o -#../common/flash.o ../common/vpd.o ../common/am79c874.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/cm5200/Makefile b/board/cm5200/Makefile index 59353e9..76f8b9f 100644 --- a/board/cm5200/Makefile +++ b/board/cm5200/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o cmd_cm5200.o fwupdate.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := cm5200.o cmd_cm5200.o fwupdate.o diff --git a/board/cmi/Makefile b/board/cmi/Makefile index 0d1c6fb..cd3bb0d 100644 --- a/board/cmi/Makefile +++ b/board/cmi/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := flash.o cmi.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := flash.o cmi.o diff --git a/board/cogent/Makefile b/board/cogent/Makefile index e7d69df..30fe98d 100644 --- a/board/cogent/Makefile +++ b/board/cogent/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mb.o flash.o dipsw.o lcd.o serial.o # pci.o rtc.o par.o kbm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mb.o flash.o dipsw.o lcd.o serial.o # pci.o rtc.o par.o kbm.o diff --git a/board/cpc45/Makefile b/board/cpc45/Makefile index 446585f..1310f93 100644 --- a/board/cpc45/Makefile +++ b/board/cpc45/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o plx9030.o pd67290.o ide.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpc45.o flash.o plx9030.o pd67290.o ide.o diff --git a/board/cpu86/Makefile b/board/cpu86/Makefile index e955841..da83afd 100644 --- a/board/cpu86/Makefile +++ b/board/cpu86/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu86.o flash.o diff --git a/board/cpu87/Makefile b/board/cpu87/Makefile index e955841..0d59bbb 100644 --- a/board/cpu87/Makefile +++ b/board/cpu87/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu87.o flash.o diff --git a/board/cray/L1/Makefile b/board/cray/L1/Makefile index 9e6461a..5f6c690 100644 --- a/board/cray/L1/Makefile +++ b/board/cray/L1/Makefile @@ -5,36 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = init.o - - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -# HACK: depend needs bootscript.c, which needs tools/mkimage, which is not -# built in the depend stage. So... put bootscript.o here, not in OBJS -$(LIB): $(OBJS) $(SOBJS) $(obj)bootscript.o - $(call cmd_link_o_target, $^) - -$(obj)$(BOARD).o : $(src)$(BOARD).c $(obj)bootscript.o +obj-y = L1.o flash.o +obj-y += init.o +obj-y += bootscript.o
$(obj)bootscript.c: $(obj)bootscript.image od -t x1 -v -A x $^ | awk -f x2c.awk > $@
$(obj)bootscript.image: $(src)bootscript.hush $(src)Makefile -$(OBJTREE)/tools/mkimage -A ppc -O linux -T script -C none -a 0 -e 0 -n bootscript -d $(src)bootscript.hush $@ - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/csb272/Makefile b/board/csb272/Makefile index fdcbb43..36ec9b6 100644 --- a/board/csb272/Makefile +++ b/board/csb272/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -#COBJS = $(BOARD).o flash.o -#COBJS = $(BOARD).o strataflash.o -COBJS = $(BOARD).o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = csb272.o +obj-y += init.o diff --git a/board/csb472/Makefile b/board/csb472/Makefile index fdcbb43..5f7e8b5 100644 --- a/board/csb472/Makefile +++ b/board/csb472/Makefile @@ -5,28 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -#COBJS = $(BOARD).o flash.o -#COBJS = $(BOARD).o strataflash.o -COBJS = $(BOARD).o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = csb472.o +obj-y += init.o diff --git a/board/cu824/Makefile b/board/cu824/Makefile index e955841..e7bd7ca 100644 --- a/board/cu824/Makefile +++ b/board/cu824/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cu824.o flash.o diff --git a/board/dave/PPChameleonEVB/Makefile b/board/dave/PPChameleonEVB/Makefile index eafe6e3..31edc4a 100644 --- a/board/dave/PPChameleonEVB/Makefile +++ b/board/dave/PPChameleonEVB/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o nand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = PPChameleonEVB.o flash.o nand.o diff --git a/board/davedenx/aria/Makefile b/board/davedenx/aria/Makefile index f78fe13..dd38b7f 100644 --- a/board/davedenx/aria/Makefile +++ b/board/davedenx/aria/Makefile @@ -4,25 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := aria.o diff --git a/board/eXalion/Makefile b/board/eXalion/Makefile index 5fd8780..9192e28 100644 --- a/board/eXalion/Makefile +++ b/board/eXalion/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = eXalion.o diff --git a/board/eltec/elppc/Makefile b/board/eltec/elppc/Makefile index 51179c0..791f2fb 100644 --- a/board/eltec/elppc/Makefile +++ b/board/eltec/elppc/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o pci.o misc.o mpc107_i2c.o eepro100_srom.o - -SOBJS = asm_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = elppc.o flash.o pci.o misc.o mpc107_i2c.o eepro100_srom.o +obj-y += asm_init.o diff --git a/board/eltec/mhpc/Makefile b/board/eltec/mhpc/Makefile index 871865b..f3fcc2f 100644 --- a/board/eltec/mhpc/Makefile +++ b/board/eltec/mhpc/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mhpc.o flash.o diff --git a/board/emk/top5200/Makefile b/board/emk/top5200/Makefile index 4b15bb6..eb626a6 100644 --- a/board/emk/top5200/Makefile +++ b/board/emk/top5200/Makefile @@ -6,27 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ../common/flash.o ../common/vpd.o ../common/am79c874.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := top5200.o ../common/flash.o ../common/vpd.o ../common/am79c874.o diff --git a/board/emk/top860/Makefile b/board/emk/top860/Makefile index a45f0ef..b2645f6 100644 --- a/board/emk/top860/Makefile +++ b/board/emk/top860/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../common/flash.o ../common/vpd.o ../common/am79c874.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = top860.o ../common/flash.o ../common/vpd.o ../common/am79c874.o diff --git a/board/ep8248/Makefile b/board/ep8248/Makefile index c573be9..bfaf1c8 100644 --- a/board/ep8248/Makefile +++ b/board/ep8248/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ep8248.o diff --git a/board/ep8260/Makefile b/board/ep8260/Makefile index 0a716f9..dd08b74 100644 --- a/board/ep8260/Makefile +++ b/board/ep8260/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o mii_phy.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ep8260.o flash.o mii_phy.o diff --git a/board/ep82xxm/Makefile b/board/ep82xxm/Makefile index 459d7b8..f9d3891 100644 --- a/board/ep82xxm/Makefile +++ b/board/ep82xxm/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ep82xxm.o diff --git a/board/esd/adciop/Makefile b/board/esd/adciop/Makefile index cbe2987..9635189 100644 --- a/board/esd/adciop/Makefile +++ b/board/esd/adciop/Makefile @@ -6,27 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o ../common/pci.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = adciop.o flash.o ../common/misc.o ../common/pci.o diff --git a/board/esd/apc405/Makefile b/board/esd/apc405/Makefile index b84e662..c6ab1a5 100644 --- a/board/esd/apc405/Makefile +++ b/board/esd/apc405/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o \ +obj-y = apc405.o \ ../common/misc.o \ ../common/auto_update.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/ar405/Makefile b/board/esd/ar405/Makefile index e5caf23..2d16313 100644 --- a/board/esd/ar405/Makefile +++ b/board/esd/ar405/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ar405.o flash.o ../common/misc.o diff --git a/board/esd/ash405/Makefile b/board/esd/ash405/Makefile index 17dd097..4c866ee 100644 --- a/board/esd/ash405/Makefile +++ b/board/esd/ash405/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o \ +obj-y = ash405.o flash.o \ ../common/misc.o \ ../common/esd405ep_nand.o \ - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/cms700/Makefile b/board/esd/cms700/Makefile index 4ae7727..8cfe3ba 100644 --- a/board/esd/cms700/Makefile +++ b/board/esd/cms700/Makefile @@ -5,35 +5,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common/xilinx_jtag) endif
-LIB = $(obj)lib$(BOARD).o - # Objects for Xilinx JTAG programming (CPLD) CPLD = ../common/xilinx_jtag/lenval.o \ ../common/xilinx_jtag/micro.o \ ../common/xilinx_jtag/ports.o
-COBJS = $(BOARD).o flash.o \ +obj-y = cms700.o flash.o \ ../common/misc.o \ $(CPLD) \ ../common/esd405ep_nand.o \ - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/cpci2dp/Makefile b/board/esd/cpci2dp/Makefile index a6edac0..1d15020 100644 --- a/board/esd/cpci2dp/Makefile +++ b/board/esd/cpci2dp/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o ../common/cmd_loadpci.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpci2dp.o flash.o ../common/misc.o ../common/cmd_loadpci.o diff --git a/board/esd/cpci405/Makefile b/board/esd/cpci405/Makefile index 6868e68..1af7e94 100644 --- a/board/esd/cpci405/Makefile +++ b/board/esd/cpci405/Makefile @@ -5,28 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o ../common/auto_update.o -COBJS += ../common/cmd_loadpci.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpci405.o flash.o ../common/misc.o ../common/auto_update.o +obj-y += ../common/cmd_loadpci.o diff --git a/board/esd/cpci5200/Makefile b/board/esd/cpci5200/Makefile index 80eb23d..fb6c0e2 100644 --- a/board/esd/cpci5200/Makefile +++ b/board/esd/cpci5200/Makefile @@ -5,33 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk # ifneq ($(OBJTREE),$(SRCTREE)) # $(shell mkdir -p $(obj)../common/xilinx_jtag) # endif
-LIB = $(obj)lib$(BOARD).o - # Objects for Xilinx JTAG programming (CPLD) # CPLD = ../common/xilinx_jtag/lenval.o \ # ../common/xilinx_jtag/micro.o \ # ../common/xilinx_jtag/ports.o
-# COBJS = $(BOARD).o flash.o $(CPLD) -COBJS = $(BOARD).o strataflash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +# obj-y = cpci5200.o flash.o $(CPLD) +obj-y = cpci5200.o strataflash.o diff --git a/board/esd/cpci750/Makefile b/board/esd/cpci750/Makefile index 0be10fe..8b3dc33 100644 --- a/board/esd/cpci750/Makefile +++ b/board/esd/cpci750/Makefile @@ -8,31 +8,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../../Marvell/common) endif
-LIB = $(obj)lib$(BOARD).o - -SOBJS = misc.o - -COBJS = $(BOARD).o serial.o ../../Marvell/common/memory.o pci.o \ +obj-y = misc.o +obj-y += cpci750.o serial.o ../../Marvell/common/memory.o pci.o \ mv_eth.o mpsc.o i2c.o \ sdram_init.o ide.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/cpciiser4/Makefile b/board/esd/cpciiser4/Makefile index e5caf23..4d3c34a 100644 --- a/board/esd/cpciiser4/Makefile +++ b/board/esd/cpciiser4/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpciiser4.o flash.o ../common/misc.o diff --git a/board/esd/dasa_sim/Makefile b/board/esd/dasa_sim/Makefile index 3190a11..7dc48ba 100644 --- a/board/esd/dasa_sim/Makefile +++ b/board/esd/dasa_sim/Makefile @@ -6,27 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o cmd_dasa_sim.o eeprom.o ../common/pci.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = dasa_sim.o flash.o cmd_dasa_sim.o eeprom.o ../common/pci.o diff --git a/board/esd/dp405/Makefile b/board/esd/dp405/Makefile index 0fd6fe5..6809c67 100644 --- a/board/esd/dp405/Makefile +++ b/board/esd/dp405/Makefile @@ -5,32 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS = $(BOARD).o flash.o ../common/misc.o $(CPLD) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = dp405.o flash.o ../common/misc.o $(CPLD) diff --git a/board/esd/du405/Makefile b/board/esd/du405/Makefile index e5caf23..12ce41a 100644 --- a/board/esd/du405/Makefile +++ b/board/esd/du405/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = du405.o flash.o ../common/misc.o diff --git a/board/esd/du440/Makefile b/board/esd/du440/Makefile index 7ccd9a8..ef41d94 100644 --- a/board/esd/du440/Makefile +++ b/board/esd/du440/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = du440.o +extra-y += init.o diff --git a/board/esd/hh405/Makefile b/board/esd/hh405/Makefile index fdae010..0507f1b 100644 --- a/board/esd/hh405/Makefile +++ b/board/esd/hh405/Makefile @@ -5,30 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o \ +obj-y = hh405.o flash.o \ ../common/misc.o \ ../common/esd405ep_nand.o \ ../common/auto_update.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/hub405/Makefile b/board/esd/hub405/Makefile index 17dd097..5447a95 100644 --- a/board/esd/hub405/Makefile +++ b/board/esd/hub405/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o \ +obj-y = hub405.o flash.o \ ../common/misc.o \ ../common/esd405ep_nand.o \ - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/mecp5123/Makefile b/board/esd/mecp5123/Makefile index f78fe13..f5ebb01 100644 --- a/board/esd/mecp5123/Makefile +++ b/board/esd/mecp5123/Makefile @@ -4,25 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mecp5123.o diff --git a/board/esd/mecp5200/Makefile b/board/esd/mecp5200/Makefile index c852233..19f0055 100644 --- a/board/esd/mecp5200/Makefile +++ b/board/esd/mecp5200/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mecp5200.o diff --git a/board/esd/ocrtc/Makefile b/board/esd/ocrtc/Makefile index b845258..0d9a6fd 100644 --- a/board/esd/ocrtc/Makefile +++ b/board/esd/ocrtc/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o cmd_ocrtc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ocrtc.o flash.o ../common/misc.o cmd_ocrtc.o diff --git a/board/esd/pci405/Makefile b/board/esd/pci405/Makefile index 9f01c56..2f8706b 100644 --- a/board/esd/pci405/Makefile +++ b/board/esd/pci405/Makefile @@ -5,29 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o ../common/misc.o cmd_pci405.o -SOBJS = writeibm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) -# $(call cmd_link_o_target, $(OBJS)) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pci405.o flash.o ../common/misc.o cmd_pci405.o +obj-y += writeibm.o diff --git a/board/esd/pf5200/Makefile b/board/esd/pf5200/Makefile index 121f772..24abbaf 100644 --- a/board/esd/pf5200/Makefile +++ b/board/esd/pf5200/Makefile @@ -6,33 +6,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# COBJS = $(BOARD).o flash.o $(CPLD) -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +# obj-y = pf5200.o flash.o $(CPLD) +obj-y = pf5200.o flash.o diff --git a/board/esd/plu405/Makefile b/board/esd/plu405/Makefile index 17dd097..45b962f 100644 --- a/board/esd/plu405/Makefile +++ b/board/esd/plu405/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o \ +obj-y = plu405.o flash.o \ ../common/misc.o \ ../common/esd405ep_nand.o \ - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/pmc405/Makefile b/board/esd/pmc405/Makefile index 225974d..f4aa1c9 100644 --- a/board/esd/pmc405/Makefile +++ b/board/esd/pmc405/Makefile @@ -5,32 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS = $(BOARD).o ../common/misc.o ../common/cmd_loadpci.o $(CPLD) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pmc405.o ../common/misc.o ../common/cmd_loadpci.o $(CPLD) diff --git a/board/esd/pmc405de/Makefile b/board/esd/pmc405de/Makefile index 997f07e..7d5b273 100644 --- a/board/esd/pmc405de/Makefile +++ b/board/esd/pmc405de/Makefile @@ -5,30 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS-y = $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -COBJS-y += ../common/cmd_loadpci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pmc405de.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +obj-y += ../common/cmd_loadpci.o diff --git a/board/esd/pmc440/Makefile b/board/esd/pmc440/Makefile index 6d6690a..b1318c7 100644 --- a/board/esd/pmc440/Makefile +++ b/board/esd/pmc440/Makefile @@ -5,32 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cmd_pmc440.o sdram.o fpga.o \ +obj-y = pmc440.o cmd_pmc440.o sdram.o fpga.o \ ../common/cmd_loadpci.o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y += init.o diff --git a/board/esd/vme8349/Makefile b/board/esd/vme8349/Makefile index 4dd47b7..fa11d5d 100644 --- a/board/esd/vme8349/Makefile +++ b/board/esd/vme8349/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o caddy.o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += vme8349.o caddy.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/esd/voh405/Makefile b/board/esd/voh405/Makefile index 17dd097..8fcfa37 100644 --- a/board/esd/voh405/Makefile +++ b/board/esd/voh405/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o \ +obj-y = voh405.o flash.o \ ../common/misc.o \ ../common/esd405ep_nand.o \ - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esd/vom405/Makefile b/board/esd/vom405/Makefile index 0fd6fe5..c8a4a4e 100644 --- a/board/esd/vom405/Makefile +++ b/board/esd/vom405/Makefile @@ -5,32 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS = $(BOARD).o flash.o ../common/misc.o $(CPLD) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = vom405.o flash.o ../common/misc.o $(CPLD) diff --git a/board/esd/wuh405/Makefile b/board/esd/wuh405/Makefile index 17dd097..046ebad 100644 --- a/board/esd/wuh405/Makefile +++ b/board/esd/wuh405/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o \ +obj-y = wuh405.o flash.o \ ../common/misc.o \ ../common/esd405ep_nand.o \ - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/esteem192e/Makefile b/board/esteem192e/Makefile index 871865b..55d80b6 100644 --- a/board/esteem192e/Makefile +++ b/board/esteem192e/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = esteem192e.o flash.o diff --git a/board/etin/debris/Makefile b/board/etin/debris/Makefile index d7da042..2e74823 100644 --- a/board/etin/debris/Makefile +++ b/board/etin/debris/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o phantom.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = debris.o flash.o phantom.o diff --git a/board/etin/kvme080/Makefile b/board/etin/kvme080/Makefile index c0271d0..d1b6f30 100644 --- a/board/etin/kvme080/Makefile +++ b/board/etin/kvme080/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o multiverse.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = kvme080.o multiverse.o diff --git a/board/evb64260/Makefile b/board/evb64260/Makefile index 512f6d7..ae2ebed 100644 --- a/board/evb64260/Makefile +++ b/board/evb64260/Makefile @@ -8,27 +8,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -SOBJS = misc.o -COBJS = $(BOARD).o flash.o serial.o memory.o pci.o \ +obj-y = misc.o +obj-y += evb64260.o flash.o serial.o memory.o pci.o \ eth.o eth_addrtbl.o mpsc.o i2c.o \ sdram_init.o zuma_pbb.o intel_flash.o zuma_pbb_mbox.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/exmeritus/hww1u1a/Makefile b/board/exmeritus/hww1u1a/Makefile index e441c14..d0cd878 100644 --- a/board/exmeritus/hww1u1a/Makefile +++ b/board/exmeritus/hww1u1a/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += tlb.o -COBJS-$(CONFIG_DDR_SPD) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += hww1u1a.o +obj-y += law.o +obj-y += tlb.o +obj-$(CONFIG_DDR_SPD) += ddr.o diff --git a/board/fads/Makefile b/board/fads/Makefile index 4c70032..ea8b5c0 100644 --- a/board/fads/Makefile +++ b/board/fads/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o lamp.o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = fads.o flash.o lamp.o pcmcia.o diff --git a/board/flagadm/Makefile b/board/flagadm/Makefile index e955841..f2377c8 100644 --- a/board/flagadm/Makefile +++ b/board/flagadm/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = flagadm.o flash.o diff --git a/board/freescale/b4860qds/Makefile b/board/freescale/b4860qds/Makefile index a864c0b..e5cc054 100644 --- a/board/freescale/b4860qds/Makefile +++ b/board/freescale/b4860qds/Makefile @@ -4,35 +4,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-$(CONFIG_B4860QDS)+= eth_b4860qds.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += b4860qds.o +obj-y += ddr.o +obj-$(CONFIG_B4860QDS)+= eth_b4860qds.o +obj-$(CONFIG_PCI) += pci.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/bsc9131rdb/Makefile b/board/freescale/bsc9131rdb/Makefile index e1a7d8b..b26d3a1 100644 --- a/board/freescale/bsc9131rdb/Makefile +++ b/board/freescale/bsc9131rdb/Makefile @@ -4,10 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -18,36 +14,14 @@ endif
ifdef MINIMAL
-COBJS-y += spl_minimal.o tlb.o law.o +obj-y += spl_minimal.o tlb.o law.o
else
-COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o -#COBJS-y += bsc9131rdb_mux.o +obj-y += bsc9131rdb.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o +#obj-y += bsc9131rdb_mux.o
endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/bsc9132qds/Makefile b/board/freescale/bsc9132qds/Makefile index 330d353..2e4170f 100644 --- a/board/freescale/bsc9132qds/Makefile +++ b/board/freescale/bsc9132qds/Makefile @@ -4,10 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifdef CONFIG_SPL_BUILD @@ -18,36 +14,13 @@ endif
ifdef MINIMAL
else
- -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o +obj-y += bsc9132qds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o
endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/c29xpcie/Makefile b/board/freescale/c29xpcie/Makefile index ab8eb8f..626d48a 100644 --- a/board/freescale/c29xpcie/Makefile +++ b/board/freescale/c29xpcie/Makefile @@ -3,28 +3,8 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += cpld.o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += c29xpcie.o +obj-y += cpld.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index f9550c4..25f063d 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -5,14 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)board/freescale/common) -endif - -LIB = $(obj)libfreescale.o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -22,62 +14,42 @@ endif endif
ifndef MINIMAL -COBJS-$(CONFIG_FSL_CADMUS) += cadmus.o -COBJS-$(CONFIG_FSL_VIA) += cds_via.o -COBJS-$(CONFIG_FMAN_ENET) += fman.o -COBJS-$(CONFIG_FSL_PIXIS) += pixis.o +obj-$(CONFIG_FSL_CADMUS) += cadmus.o +obj-$(CONFIG_FSL_VIA) += cds_via.o +obj-$(CONFIG_FMAN_ENET) += fman.o +obj-$(CONFIG_FSL_PIXIS) += pixis.o ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_FSL_NGPIXIS) += ngpixis.o +obj-$(CONFIG_FSL_NGPIXIS) += ngpixis.o endif -COBJS-$(CONFIG_FSL_QIXIS) += qixis.o -COBJS-$(CONFIG_PQ_MDS_PIB) += pq-mds-pib.o +obj-$(CONFIG_FSL_QIXIS) += qixis.o +obj-$(CONFIG_PQ_MDS_PIB) += pq-mds-pib.o ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_ID_EEPROM) += sys_eeprom.o +obj-$(CONFIG_ID_EEPROM) += sys_eeprom.o endif -COBJS-$(CONFIG_FSL_SGMII_RISER) += sgmii_riser.o +obj-$(CONFIG_FSL_SGMII_RISER) += sgmii_riser.o ifndef CONFIG_RAMBOOT_PBL -COBJS-$(CONFIG_FSL_FIXED_MMC_LOCATION) += sdhc_boot.o +obj-$(CONFIG_FSL_FIXED_MMC_LOCATION) += sdhc_boot.o endif
-COBJS-$(CONFIG_MPC8541CDS) += cds_pci_ft.o -COBJS-$(CONFIG_MPC8548CDS) += cds_pci_ft.o -COBJS-$(CONFIG_MPC8555CDS) += cds_pci_ft.o - -COBJS-$(CONFIG_MPC8536DS) += ics307_clk.o -COBJS-$(CONFIG_MPC8572DS) += ics307_clk.o -COBJS-$(CONFIG_P1022DS) += ics307_clk.o -COBJS-$(CONFIG_P2020DS) += ics307_clk.o -COBJS-$(CONFIG_P3041DS) += ics307_clk.o -COBJS-$(CONFIG_P4080DS) += ics307_clk.o -COBJS-$(CONFIG_P5020DS) += ics307_clk.o -COBJS-$(CONFIG_P5040DS) += ics307_clk.o -COBJS-$(CONFIG_VSC_CROSSBAR) += vsc3316_3308.o -COBJS-$(CONFIG_IDT8T49N222A) += idt8t49n222a_serdes_clk.o +obj-$(CONFIG_MPC8541CDS) += cds_pci_ft.o +obj-$(CONFIG_MPC8548CDS) += cds_pci_ft.o +obj-$(CONFIG_MPC8555CDS) += cds_pci_ft.o + +obj-$(CONFIG_MPC8536DS) += ics307_clk.o +obj-$(CONFIG_MPC8572DS) += ics307_clk.o +obj-$(CONFIG_P1022DS) += ics307_clk.o +obj-$(CONFIG_P2020DS) += ics307_clk.o +obj-$(CONFIG_P3041DS) += ics307_clk.o +obj-$(CONFIG_P4080DS) += ics307_clk.o +obj-$(CONFIG_P5020DS) += ics307_clk.o +obj-$(CONFIG_P5040DS) += ics307_clk.o +obj-$(CONFIG_VSC_CROSSBAR) += vsc3316_3308.o +obj-$(CONFIG_IDT8T49N222A) += idt8t49n222a_serdes_clk.o
# deal with common files for P-series corenet based devices -SUBLIB-$(CONFIG_P2041RDB) += p_corenet/libp_corenet.o -SUBLIB-$(CONFIG_P3041DS) += p_corenet/libp_corenet.o -SUBLIB-$(CONFIG_P4080DS) += p_corenet/libp_corenet.o -SUBLIB-$(CONFIG_P5020DS) += p_corenet/libp_corenet.o -SUBLIB-$(CONFIG_P5040DS) += p_corenet/libp_corenet.o +obj-$(CONFIG_P2041RDB) += p_corenet/ +obj-$(CONFIG_P3041DS) += p_corenet/ +obj-$(CONFIG_P4080DS) += p_corenet/ +obj-$(CONFIG_P5020DS) += p_corenet/ +obj-$(CONFIG_P5040DS) += p_corenet/ endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) -SUBLIB := $(addprefix $(obj),$(SUBLIB-y)) - -$(LIB): $(obj).depend $(OBJS) $(SUBLIB) - $(call cmd_link_o_target, $(OBJS) $(SUBLIB)) - -$(SUBLIB): $(obj).depend - $(MAKE) -C $(dir $(subst $(obj),,$@)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/common/p_corenet/Makefile b/board/freescale/common/p_corenet/Makefile index f37b25c..889c493 100644 --- a/board/freescale/common/p_corenet/Makefile +++ b/board/freescale/common/p_corenet/Makefile @@ -4,12 +4,9 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = libp_corenet.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-y += law.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-y += tlb.o - -include $(TOPDIR)/post/rules.mk +obj-y += law.o +obj-$(CONFIG_PCI) += pci.o +obj-y += tlb.o diff --git a/board/freescale/corenet_ds/Makefile b/board/freescale/corenet_ds/Makefile index 36813cb..9ade947 100644 --- a/board/freescale/corenet_ds/Makefile +++ b/board/freescale/corenet_ds/Makefile @@ -6,33 +6,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-$(CONFIG_P3041DS) += eth_hydra.o -COBJS-$(CONFIG_P4080DS) += eth_p4080.o -COBJS-$(CONFIG_P5020DS) += eth_hydra.o -COBJS-$(CONFIG_P5040DS) += eth_superhydra.o -COBJS-$(CONFIG_P3041DS) += p3041ds_ddr.o -COBJS-$(CONFIG_P4080DS) += p4080ds_ddr.o -COBJS-$(CONFIG_P5020DS) += p5020ds_ddr.o -COBJS-$(CONFIG_P5040DS) += p5040ds_ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += corenet_ds.o +obj-y += ddr.o +obj-$(CONFIG_P3041DS) += eth_hydra.o +obj-$(CONFIG_P4080DS) += eth_p4080.o +obj-$(CONFIG_P5020DS) += eth_hydra.o +obj-$(CONFIG_P5040DS) += eth_superhydra.o +obj-$(CONFIG_P3041DS) += p3041ds_ddr.o +obj-$(CONFIG_P4080DS) += p4080ds_ddr.o +obj-$(CONFIG_P5020DS) += p5020ds_ddr.o +obj-$(CONFIG_P5040DS) += p5040ds_ddr.o diff --git a/board/freescale/mpc5121ads/Makefile b/board/freescale/mpc5121ads/Makefile index b5cd5f7..67cf555 100644 --- a/board/freescale/mpc5121ads/Makefile +++ b/board/freescale/mpc5121ads/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -$(shell mkdir -p $(OBJTREE)/board/freescale/common) - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc5121ads.o diff --git a/board/freescale/mpc7448hpc2/Makefile b/board/freescale/mpc7448hpc2/Makefile index 0391746..2cc211b 100644 --- a/board/freescale/mpc7448hpc2/Makefile +++ b/board/freescale/mpc7448hpc2/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o tsi108_init.o -SOBJS := asm_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude ($obj).depend - -######################################################################### +obj-y := mpc7448hpc2.o tsi108_init.o +obj-y += asm_init.o diff --git a/board/freescale/mpc8260ads/Makefile b/board/freescale/mpc8260ads/Makefile index c91b088..9b7e287 100644 --- a/board/freescale/mpc8260ads/Makefile +++ b/board/freescale/mpc8260ads/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8260ads.o flash.o diff --git a/board/freescale/mpc8266ads/Makefile b/board/freescale/mpc8266ads/Makefile index d1d2ecb..ee63dc0 100644 --- a/board/freescale/mpc8266ads/Makefile +++ b/board/freescale/mpc8266ads/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8266ads.o flash.o diff --git a/board/freescale/mpc8308rdb/Makefile b/board/freescale/mpc8308rdb/Makefile index 31127f0..ec2b85d 100644 --- a/board/freescale/mpc8308rdb/Makefile +++ b/board/freescale/mpc8308rdb/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8308rdb.o sdram.o diff --git a/board/freescale/mpc8313erdb/Makefile b/board/freescale/mpc8313erdb/Makefile index b9fa864..77fad75 100644 --- a/board/freescale/mpc8313erdb/Makefile +++ b/board/freescale/mpc8313erdb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8313erdb.o sdram.o diff --git a/board/freescale/mpc8315erdb/Makefile b/board/freescale/mpc8315erdb/Makefile index b9fa864..fbb68c5 100644 --- a/board/freescale/mpc8315erdb/Makefile +++ b/board/freescale/mpc8315erdb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8315erdb.o sdram.o diff --git a/board/freescale/mpc8323erdb/Makefile b/board/freescale/mpc8323erdb/Makefile index ff0dbf8..f2e7497 100644 --- a/board/freescale/mpc8323erdb/Makefile +++ b/board/freescale/mpc8323erdb/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8323erdb.o diff --git a/board/freescale/mpc832xemds/Makefile b/board/freescale/mpc832xemds/Makefile index 0c6e556..6676351 100644 --- a/board/freescale/mpc832xemds/Makefile +++ b/board/freescale/mpc832xemds/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc832xemds.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/mpc8349emds/Makefile b/board/freescale/mpc8349emds/Makefile index 9549bad..23880f5 100644 --- a/board/freescale/mpc8349emds/Makefile +++ b/board/freescale/mpc8349emds/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-$(CONFIG_FSL_DDR2) += ddr.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8349emds.o +obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_FSL_DDR2) += ddr.o diff --git a/board/freescale/mpc8349itx/Makefile b/board/freescale/mpc8349itx/Makefile index 9e3c891..e9092ad 100644 --- a/board/freescale/mpc8349itx/Makefile +++ b/board/freescale/mpc8349itx/Makefile @@ -4,25 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8349itx.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/mpc8360emds/Makefile b/board/freescale/mpc8360emds/Makefile index 0c6e556..e8332ce 100644 --- a/board/freescale/mpc8360emds/Makefile +++ b/board/freescale/mpc8360emds/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8360emds.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/mpc8360erdk/Makefile b/board/freescale/mpc8360erdk/Makefile index 8895cd0..e2235c2 100644 --- a/board/freescale/mpc8360erdk/Makefile +++ b/board/freescale/mpc8360erdk/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_CMD_NAND) += nand.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8360erdk.o +obj-$(CONFIG_CMD_NAND) += nand.o diff --git a/board/freescale/mpc837xemds/Makefile b/board/freescale/mpc837xemds/Makefile index 0c6e556..70b2147 100644 --- a/board/freescale/mpc837xemds/Makefile +++ b/board/freescale/mpc837xemds/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc837xemds.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/mpc837xerdb/Makefile b/board/freescale/mpc837xerdb/Makefile index 0c6e556..c2d0bc4 100644 --- a/board/freescale/mpc837xerdb/Makefile +++ b/board/freescale/mpc837xerdb/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc837xerdb.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/mpc8536ds/Makefile b/board/freescale/mpc8536ds/Makefile index bbb492d..e36492f 100644 --- a/board/freescale/mpc8536ds/Makefile +++ b/board/freescale/mpc8536ds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8536ds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8540ads/Makefile b/board/freescale/mpc8540ads/Makefile index 08dd14b..6f82c7f 100644 --- a/board/freescale/mpc8540ads/Makefile +++ b/board/freescale/mpc8540ads/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8540ads.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8541cds/Makefile b/board/freescale/mpc8541cds/Makefile index 4f524b7..78af4b8 100644 --- a/board/freescale/mpc8541cds/Makefile +++ b/board/freescale/mpc8541cds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8541cds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8544ds/Makefile b/board/freescale/mpc8544ds/Makefile index 009cceb..3359eea 100644 --- a/board/freescale/mpc8544ds/Makefile +++ b/board/freescale/mpc8544ds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8544ds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8548cds/Makefile b/board/freescale/mpc8548cds/Makefile index 4f524b7..f797df2 100644 --- a/board/freescale/mpc8548cds/Makefile +++ b/board/freescale/mpc8548cds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8548cds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8555cds/Makefile b/board/freescale/mpc8555cds/Makefile index 4f524b7..d32d005 100644 --- a/board/freescale/mpc8555cds/Makefile +++ b/board/freescale/mpc8555cds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8555cds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8560ads/Makefile b/board/freescale/mpc8560ads/Makefile index 46e412b..685168e 100644 --- a/board/freescale/mpc8560ads/Makefile +++ b/board/freescale/mpc8560ads/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8560ads.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8568mds/Makefile b/board/freescale/mpc8568mds/Makefile index 4cd711f..612fb51 100644 --- a/board/freescale/mpc8568mds/Makefile +++ b/board/freescale/mpc8568mds/Makefile @@ -6,28 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += bcsr.o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8568mds.o +obj-y += bcsr.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8569mds/Makefile b/board/freescale/mpc8569mds/Makefile index ec318f0..5f6e021 100644 --- a/board/freescale/mpc8569mds/Makefile +++ b/board/freescale/mpc8569mds/Makefile @@ -6,28 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += bcsr.o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8569mds.o +obj-y += bcsr.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8572ds/Makefile b/board/freescale/mpc8572ds/Makefile index 009cceb..902c900 100644 --- a/board/freescale/mpc8572ds/Makefile +++ b/board/freescale/mpc8572ds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8572ds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/mpc8610hpcd/Makefile b/board/freescale/mpc8610hpcd/Makefile index 2009914..933ea17 100644 --- a/board/freescale/mpc8610hpcd/Makefile +++ b/board/freescale/mpc8610hpcd/Makefile @@ -3,28 +3,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_FSL_DDR2) += ddr.o -COBJS-y += law.o - -COBJS-$(CONFIG_FSL_DIU_FB) += mpc8610hpcd_diu.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mpc8610hpcd.o +obj-$(CONFIG_FSL_DDR2) += ddr.o +obj-y += law.o +obj-$(CONFIG_FSL_DIU_FB) += mpc8610hpcd_diu.o diff --git a/board/freescale/mpc8641hpcn/Makefile b/board/freescale/mpc8641hpcn/Makefile index 0cbc0d0..8d53af8 100644 --- a/board/freescale/mpc8641hpcn/Makefile +++ b/board/freescale/mpc8641hpcn/Makefile @@ -5,26 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-$(CONFIG_FSL_DDR2) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude ($obj).depend - -######################################################################### +obj-y += mpc8641hpcn.o +obj-y += law.o +obj-$(CONFIG_FSL_DDR2) += ddr.o diff --git a/board/freescale/p1010rdb/Makefile b/board/freescale/p1010rdb/Makefile index bdd7d68..d6f05f3 100644 --- a/board/freescale/p1010rdb/Makefile +++ b/board/freescale/p1010rdb/Makefile @@ -4,10 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifdef CONFIG_SPL_BUILD @@ -18,29 +14,13 @@ endif
ifdef MINIMAL
else
-COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o +obj-y += p1010rdb.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o
endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/p1022ds/Makefile b/board/freescale/p1022ds/Makefile index 3bc4f43..a582127 100644 --- a/board/freescale/p1022ds/Makefile +++ b/board/freescale/p1022ds/Makefile @@ -4,10 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifdef CONFIG_SPL_BUILD @@ -18,32 +14,16 @@ endif
ifdef MINIMAL
else ifdef CONFIG_SPL_BUILD -COBJS-y += spl.o +obj-y += spl.o endif -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o +obj-y += p1022ds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o
-COBJS-$(CONFIG_FSL_DIU_FB) += diu.o +obj-$(CONFIG_FSL_DIU_FB) += diu.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/p1023rdb/Makefile b/board/freescale/p1023rdb/Makefile index edd2e6d..e4f1edf 100644 --- a/board/freescale/p1023rdb/Makefile +++ b/board/freescale/p1023rdb/Makefile @@ -4,27 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p1023rdb.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/p1023rds/Makefile b/board/freescale/p1023rds/Makefile index f987dc5..fdbf365 100644 --- a/board/freescale/p1023rds/Makefile +++ b/board/freescale/p1023rds/Makefile @@ -4,26 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p1023rds.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/p1_p2_rdb/Makefile b/board/freescale/p1_p2_rdb/Makefile index 36df225..f7b568a 100644 --- a/board/freescale/p1_p2_rdb/Makefile +++ b/board/freescale/p1_p2_rdb/Makefile @@ -4,28 +4,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p1_p2_rdb.o +obj-y += ddr.o +obj-y += law.o +obj-$(CONFIG_PCI) += pci.o +obj-y += tlb.o diff --git a/board/freescale/p1_p2_rdb_pc/Makefile b/board/freescale/p1_p2_rdb_pc/Makefile index f8d0b35..fbb9774 100644 --- a/board/freescale/p1_p2_rdb_pc/Makefile +++ b/board/freescale/p1_p2_rdb_pc/Makefile @@ -4,10 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifdef MINIMAL
else
-COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o +obj-y += p1_p2_rdb_pc.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o
endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/p1_twr/Makefile b/board/freescale/p1_twr/Makefile index 915b9bc..70afac4 100644 --- a/board/freescale/p1_twr/Makefile +++ b/board/freescale/p1_twr/Makefile @@ -3,33 +3,7 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p1_twr.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/p2020come/Makefile b/board/freescale/p2020come/Makefile index 2e6b6f6..4857136 100644 --- a/board/freescale/p2020come/Makefile +++ b/board/freescale/p2020come/Makefile @@ -4,27 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p2020come.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/p2020ds/Makefile b/board/freescale/p2020ds/Makefile index 0967b28..ee00806 100644 --- a/board/freescale/p2020ds/Makefile +++ b/board/freescale/p2020ds/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p2020ds.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/freescale/p2041rdb/Makefile b/board/freescale/p2041rdb/Makefile index 147f658..c74f4c6 100644 --- a/board/freescale/p2041rdb/Makefile +++ b/board/freescale/p2041rdb/Makefile @@ -6,27 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += cpld.o -COBJS-y += ddr.o -COBJS-y += eth.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += p2041rdb.o +obj-y += cpld.o +obj-y += ddr.o +obj-y += eth.o diff --git a/board/freescale/t4qds/Makefile b/board/freescale/t4qds/Makefile index a2167b3..2b1f7aa 100644 --- a/board/freescale/t4qds/Makefile +++ b/board/freescale/t4qds/Makefile @@ -4,36 +4,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-$(CONFIG_T4240QDS) += t4240qds.o -COBJS-$(CONFIG_T4240EMU) += t4240emu.o -COBJS-y += ddr.o -COBJS-$(CONFIG_T4240QDS)+= eth.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_T4240QDS) += t4240qds.o +obj-$(CONFIG_T4240EMU) += t4240emu.o +obj-y += ddr.o +obj-$(CONFIG_T4240QDS)+= eth.o +obj-$(CONFIG_PCI) += pci.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/funkwerk/vovpn-gw/Makefile b/board/funkwerk/vovpn-gw/Makefile index 677a021..3253247 100644 --- a/board/funkwerk/vovpn-gw/Makefile +++ b/board/funkwerk/vovpn-gw/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o m88e6060.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := vovpn-gw.o flash.o m88e6060.o diff --git a/board/g2000/Makefile b/board/g2000/Makefile index 0d202ac..74c8053 100644 --- a/board/g2000/Makefile +++ b/board/g2000/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o strataflash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = g2000.o strataflash.o diff --git a/board/galaxy5200/Makefile b/board/galaxy5200/Makefile index 4a7d872..e0fcd39 100644 --- a/board/galaxy5200/Makefile +++ b/board/galaxy5200/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := galaxy5200.o diff --git a/board/gdsys/405ep/Makefile b/board/gdsys/405ep/Makefile index 81d23c5..857ec04 100644 --- a/board/gdsys/405ep/Makefile +++ b/board/gdsys/405ep/Makefile @@ -5,30 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-$(CONFIG_NEO) += neo.o -COBJS-$(CONFIG_IO) += io.o -COBJS-$(CONFIG_IOCON) += iocon.o -COBJS-$(CONFIG_DLVISION_10G) += dlvision-10g.o - -COBJS := $(BOARD).o $(COBJS-y) -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := 405ep.o +obj-$(CONFIG_NEO) += neo.o +obj-$(CONFIG_IO) += io.o +obj-$(CONFIG_IOCON) += iocon.o +obj-$(CONFIG_DLVISION_10G) += dlvision-10g.o diff --git a/board/gdsys/405ex/Makefile b/board/gdsys/405ex/Makefile index 9846823..a668460 100644 --- a/board/gdsys/405ex/Makefile +++ b/board/gdsys/405ex/Makefile @@ -5,33 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-$(CONFIG_IO64) += io64.o - -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o - -COBJS := $(BOARD).o $(COBJS-y) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := 405ex.o +obj-$(CONFIG_IO64) += io64.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o diff --git a/board/gdsys/common/Makefile b/board/gdsys/common/Makefile index 216ad96..fb841e0 100644 --- a/board/gdsys/common/Makefile +++ b/board/gdsys/common/Makefile @@ -5,37 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)board/$(VENDOR)/common) -endif - -LIB = $(obj)lib$(VENDOR).o - -COBJS-$(CONFIG_SYS_FPGA_COMMON) += fpga.o - -COBJS-$(CONFIG_IO) += miiphybb.o -COBJS-$(CONFIG_IO64) += miiphybb.o -COBJS-$(CONFIG_IOCON) += osd.o mclink.o -COBJS-$(CONFIG_DLVISION_10G) += osd.o -COBJS-$(CONFIG_CONTROLCENTERD) += dp501.o - -COBJS := $(COBJS-y) -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SYS_FPGA_COMMON) += fpga.o +obj-$(CONFIG_IO) += miiphybb.o +obj-$(CONFIG_IO64) += miiphybb.o +obj-$(CONFIG_IOCON) += osd.o mclink.o +obj-$(CONFIG_DLVISION_10G) += osd.o +obj-$(CONFIG_CONTROLCENTERD) += dp501.o diff --git a/board/gdsys/dlvision/Makefile b/board/gdsys/dlvision/Makefile index 126365b..755eb4c 100644 --- a/board/gdsys/dlvision/Makefile +++ b/board/gdsys/dlvision/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = dlvision.o diff --git a/board/gdsys/gdppc440etx/Makefile b/board/gdsys/gdppc440etx/Makefile index 1d80df8..7e3fc38 100644 --- a/board/gdsys/gdppc440etx/Makefile +++ b/board/gdsys/gdppc440etx/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = gdppc440etx.o +extra-y += init.o diff --git a/board/gdsys/intip/Makefile b/board/gdsys/intip/Makefile index 415ec32..2fbc983 100644 --- a/board/gdsys/intip/Makefile +++ b/board/gdsys/intip/Makefile @@ -5,29 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -SOBJS := init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := intip.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +extra-y += init.o diff --git a/board/gdsys/p1022/Makefile b/board/gdsys/p1022/Makefile index 17f602f..6e02447 100644 --- a/board/gdsys/p1022/Makefile +++ b/board/gdsys/p1022/Makefile @@ -7,31 +7,9 @@ # any later version. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -# COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += ddr.o -COBJS-y += tlb.o -COBJS-y += sdhc_boot.o -COBJS-$(CONFIG_CONTROLCENTERD) += controlcenterd.o controlcenterd-id.o - -COBJS-$(CONFIG_FSL_DIU_FB) += diu.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += law.o +obj-y += ddr.o +obj-y += tlb.o +obj-y += sdhc_boot.o +obj-$(CONFIG_CONTROLCENTERD) += controlcenterd.o controlcenterd-id.o +obj-$(CONFIG_FSL_DIU_FB) += diu.o diff --git a/board/gen860t/Makefile b/board/gen860t/Makefile index 0355185..86ae5e8 100644 --- a/board/gen860t/Makefile +++ b/board/gen860t/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o beeper.o fpga.o ioport.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = gen860t.o flash.o beeper.o fpga.o ioport.o diff --git a/board/genietv/Makefile b/board/genietv/Makefile index 871865b..fd11f14 100644 --- a/board/genietv/Makefile +++ b/board/genietv/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = genietv.o flash.o diff --git a/board/gw8260/Makefile b/board/gw8260/Makefile index ff9bd0f..2e23f39 100644 --- a/board/gw8260/Makefile +++ b/board/gw8260/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := gw8260.o flash.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := gw8260.o flash.o diff --git a/board/hermes/Makefile b/board/hermes/Makefile index 871865b..ccca520 100644 --- a/board/hermes/Makefile +++ b/board/hermes/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = hermes.o flash.o diff --git a/board/hidden_dragon/Makefile b/board/hidden_dragon/Makefile index 9d46b9b..eb1c5fd 100644 --- a/board/hidden_dragon/Makefile +++ b/board/hidden_dragon/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = hidden_dragon.o flash.o diff --git a/board/hymod/Makefile b/board/hymod/Makefile index 6e9f436..b9080b0 100644 --- a/board/hymod/Makefile +++ b/board/hymod/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o bsp.o eeprom.o fetch.o input.o env.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = hymod.o flash.o bsp.o eeprom.o fetch.o input.o env.o diff --git a/board/icecube/Makefile b/board/icecube/Makefile index 4ff6b2d..373f753 100644 --- a/board/icecube/Makefile +++ b/board/icecube/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := icecube.o flash.o diff --git a/board/icu862/Makefile b/board/icu862/Makefile index e1ac275..263f21b 100644 --- a/board/icu862/Makefile +++ b/board/icu862/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = icu862.o flash.o pcmcia.o diff --git a/board/ids8247/Makefile b/board/ids8247/Makefile index b2009e6..99c47b6 100644 --- a/board/ids8247/Makefile +++ b/board/ids8247/Makefile @@ -8,24 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ids8247.o diff --git a/board/ifm/ac14xx/Makefile b/board/ifm/ac14xx/Makefile index f78fe13..55def60 100644 --- a/board/ifm/ac14xx/Makefile +++ b/board/ifm/ac14xx/Makefile @@ -4,25 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ac14xx.o diff --git a/board/ifm/o2dnt2/Makefile b/board/ifm/o2dnt2/Makefile index 1dd3fe9..64d6ba8 100644 --- a/board/ifm/o2dnt2/Makefile +++ b/board/ifm/o2dnt2/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := o2dnt2.o diff --git a/board/inka4x0/Makefile b/board/inka4x0/Makefile index 14ddfa5..c9a3540 100644 --- a/board/inka4x0/Makefile +++ b/board/inka4x0/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o inkadiag.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := inka4x0.o inkadiag.o diff --git a/board/intercontrol/digsy_mtc/Makefile b/board/intercontrol/digsy_mtc/Makefile index 877be48..be216d5 100644 --- a/board/intercontrol/digsy_mtc/Makefile +++ b/board/intercontrol/digsy_mtc/Makefile @@ -3,25 +3,5 @@ # Author: Grzegorz Bernacki, Semihalf, gjb@semihalf.com #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o cmd_mtc.o -COBJS-$(CONFIG_VIDEO) += cmd_disp.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := digsy_mtc.o cmd_mtc.o +obj-$(CONFIG_VIDEO) += cmd_disp.o diff --git a/board/ip860/Makefile b/board/ip860/Makefile index 871865b..3c60006 100644 --- a/board/ip860/Makefile +++ b/board/ip860/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ip860.o flash.o diff --git a/board/ipek01/Makefile b/board/ipek01/Makefile index 3acd06b..a786ab2 100644 --- a/board/ipek01/Makefile +++ b/board/ipek01/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ipek01.o diff --git a/board/iphase4539/Makefile b/board/iphase4539/Makefile index 52c0319..9197b84 100644 --- a/board/iphase4539/Makefile +++ b/board/iphase4539/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := iphase4539.o flash.o diff --git a/board/ispan/Makefile b/board/ispan/Makefile index 07fa3f3..39931fd 100644 --- a/board/ispan/Makefile +++ b/board/ispan/Makefile @@ -8,24 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ispan.o diff --git a/board/ivm/Makefile b/board/ivm/Makefile index 871865b..e53a276 100644 --- a/board/ivm/Makefile +++ b/board/ivm/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = ivm.o flash.o diff --git a/board/jse/Makefile b/board/jse/Makefile index c891040..feac3a8 100644 --- a/board/jse/Makefile +++ b/board/jse/Makefile @@ -8,25 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o sdram.o flash.o host_bridge.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = jse.o sdram.o flash.o host_bridge.o +obj-y += init.o diff --git a/board/jupiter/Makefile b/board/jupiter/Makefile index ea0b9b4..49dff99 100644 --- a/board/jupiter/Makefile +++ b/board/jupiter/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := jupiter.o diff --git a/board/keymile/km82xx/Makefile b/board/keymile/km82xx/Makefile index bc428df..b44582f 100644 --- a/board/keymile/km82xx/Makefile +++ b/board/keymile/km82xx/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ../common/common.o ../common/ivm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := km82xx.o ../common/common.o ../common/ivm.o diff --git a/board/keymile/km83xx/Makefile b/board/keymile/km83xx/Makefile index 073a783..7bdddf3 100644 --- a/board/keymile/km83xx/Makefile +++ b/board/keymile/km83xx/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS += $(BOARD).o ../common/common.o ../common/ivm.o $(BOARD)_i2c.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += km83xx.o ../common/common.o ../common/ivm.o km83xx_i2c.o diff --git a/board/korat/Makefile b/board/korat/Makefile index 0e95230..63914bc 100644 --- a/board/korat/Makefile +++ b/board/korat/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = korat.o +extra-y += init.o diff --git a/board/kup/kup4k/Makefile b/board/kup/kup4k/Makefile index 8ab0664..b3ad86c 100644 --- a/board/kup/kup4k/Makefile +++ b/board/kup/kup4k/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../common/flash.o ../common/kup.o ../common/load_sernum_ethaddr.o ../common/pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = kup4k.o ../common/flash.o ../common/kup.o ../common/load_sernum_ethaddr.o ../common/pcmcia.o diff --git a/board/kup/kup4x/Makefile b/board/kup/kup4x/Makefile index 8ab0664..05a1afc 100644 --- a/board/kup/kup4x/Makefile +++ b/board/kup/kup4x/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../common/flash.o ../common/kup.o ../common/load_sernum_ethaddr.o ../common/pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = kup4x.o ../common/flash.o ../common/kup.o ../common/load_sernum_ethaddr.o ../common/pcmcia.o diff --git a/board/linkstation/Makefile b/board/linkstation/Makefile index 98f283e..3eeba7d 100644 --- a/board/linkstation/Makefile +++ b/board/linkstation/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -OBJS = $(BOARD).o ide.o hwctl.o avr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(OBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = linkstation.o ide.o hwctl.o avr.o diff --git a/board/lwmon/Makefile b/board/lwmon/Makefile index e1ac275..599a613 100644 --- a/board/lwmon/Makefile +++ b/board/lwmon/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = lwmon.o flash.o pcmcia.o diff --git a/board/lwmon5/Makefile b/board/lwmon5/Makefile index 05cb635..02478ca 100644 --- a/board/lwmon5/Makefile +++ b/board/lwmon5/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o kbd.o sdram.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = lwmon5.o kbd.o sdram.o +extra-y += init.o diff --git a/board/manroland/hmi1001/Makefile b/board/manroland/hmi1001/Makefile index 3acd06b..c29a665 100644 --- a/board/manroland/hmi1001/Makefile +++ b/board/manroland/hmi1001/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := hmi1001.o diff --git a/board/manroland/mucmc52/Makefile b/board/manroland/mucmc52/Makefile index 0bec8af..927fc32 100644 --- a/board/manroland/mucmc52/Makefile +++ b/board/manroland/mucmc52/Makefile @@ -8,24 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mucmc52.o diff --git a/board/manroland/uc100/Makefile b/board/manroland/uc100/Makefile index fe15aef..8e69c52 100644 --- a/board/manroland/uc100/Makefile +++ b/board/manroland/uc100/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -#COBJS = $(BOARD).o flash.o pcmcia.o -COBJS = $(BOARD).o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = uc100.o pcmcia.o diff --git a/board/manroland/uc101/Makefile b/board/manroland/uc101/Makefile index 3acd06b..9289d91 100644 --- a/board/manroland/uc101/Makefile +++ b/board/manroland/uc101/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := uc101.o diff --git a/board/matrix_vision/common/Makefile b/board/matrix_vision/common/Makefile index 8593a86..699da1c 100644 --- a/board/matrix_vision/common/Makefile +++ b/board/matrix_vision/common/Makefile @@ -5,28 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)board/$(VENDOR)/common) -endif - -LIB = $(obj)lib$(VENDOR).o - -COBJS-y = mv_common.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mv_common.o diff --git a/board/matrix_vision/mergerbox/Makefile b/board/matrix_vision/mergerbox/Makefile index 4df8ce2..11a7fd2 100644 --- a/board/matrix_vision/mergerbox/Makefile +++ b/board/matrix_vision/mergerbox/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o pci.o fpga.o sm107.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += mergerbox.o pci.o fpga.o sm107.o diff --git a/board/matrix_vision/mvbc_p/Makefile b/board/matrix_vision/mvbc_p/Makefile index 61474aa..4c19941 100644 --- a/board/matrix_vision/mvbc_p/Makefile +++ b/board/matrix_vision/mvbc_p/Makefile @@ -8,21 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o fpga.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := mvbc_p.o fpga.o diff --git a/board/matrix_vision/mvblm7/Makefile b/board/matrix_vision/mvblm7/Makefile index b657280..879d794 100644 --- a/board/matrix_vision/mvblm7/Makefile +++ b/board/matrix_vision/mvblm7/Makefile @@ -4,24 +4,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := mvblm7.o pci.o fpga.o
-LIB = $(obj)lib$(BOARD).o +extra-y := bootscript.img
-COBJS := $(BOARD).o pci.o fpga.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - @mkimage -T script -C none -n M7_script -d bootscript $(obj)bootscript.img - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +$(obj)bootscript.img: + @mkimage -T script -C none -n M7_script -d bootscript $@ diff --git a/board/matrix_vision/mvsmr/Makefile b/board/matrix_vision/mvsmr/Makefile index ef768fe..b6a4f67 100644 --- a/board/matrix_vision/mvsmr/Makefile +++ b/board/matrix_vision/mvsmr/Makefile @@ -8,22 +8,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := mvsmr.o fpga.o
-COBJS := $(BOARD).o fpga.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - @mkimage -T script -C none -n mvSMR_Script -d bootscript $(obj)bootscript.img - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +$(obj)bootscript.img: bootscript + @mkimage -T script -C none -n mvSMR_Script -d $< $@ diff --git a/board/mbx8xx/Makefile b/board/mbx8xx/Makefile index 1097314..2074b6b 100644 --- a/board/mbx8xx/Makefile +++ b/board/mbx8xx/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o vpd.o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mbx8xx.o flash.o vpd.o pcmcia.o diff --git a/board/mcc200/Makefile b/board/mcc200/Makefile index 5019b31..db3b396 100644 --- a/board/mcc200/Makefile +++ b/board/mcc200/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o lcd.o auto_update.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mcc200.o lcd.o auto_update.o diff --git a/board/mosaixtech/icon/Makefile b/board/mosaixtech/icon/Makefile index 23a8631..d554a8b 100644 --- a/board/mosaixtech/icon/Makefile +++ b/board/mosaixtech/icon/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -SOBJS = init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := icon.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +extra-y += init.o diff --git a/board/motionpro/Makefile b/board/motionpro/Makefile index 4a7d872..898a384 100644 --- a/board/motionpro/Makefile +++ b/board/motionpro/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := motionpro.o diff --git a/board/mousse/Makefile b/board/mousse/Makefile index 9566cc8..0a2eb10 100644 --- a/board/mousse/Makefile +++ b/board/mousse/Makefile @@ -6,23 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o m48t59y.o pci.o flash.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mousse.o m48t59y.o pci.o flash.o diff --git a/board/mpc8308_p1m/Makefile b/board/mpc8308_p1m/Makefile index 31127f0..fb8ca3a 100644 --- a/board/mpc8308_p1m/Makefile +++ b/board/mpc8308_p1m/Makefile @@ -7,24 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := mpc8308_p1m.o sdram.o diff --git a/board/mpl/mip405/Makefile b/board/mpl/mip405/Makefile index 4eb997f..509eb59 100644 --- a/board/mpl/mip405/Makefile +++ b/board/mpl/mip405/Makefile @@ -5,32 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cmd_mip405.o \ +obj-y = mip405.o cmd_mip405.o \ ../common/pci.o \ ../common/usb_uhci.o \ ../common/common_util.o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += init.o diff --git a/board/mpl/pati/Makefile b/board/mpl/pati/Makefile index bddf012..67381c1 100644 --- a/board/mpl/pati/Makefile +++ b/board/mpl/pati/Makefile @@ -5,28 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o cmd_pati.o \ +obj-y := pati.o cmd_pati.o \ ../common/common_util.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/mpl/pip405/Makefile b/board/mpl/pip405/Makefile index 0d40d3a..3d73cc3 100644 --- a/board/mpl/pip405/Makefile +++ b/board/mpl/pip405/Makefile @@ -5,34 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cmd_pip405.o \ +obj-y = pip405.o cmd_pip405.o \ ../common/pci.o \ ../common/isa.o \ ../common/kbd.o \ ../common/usb_uhci.o \ ../common/common_util.o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += init.o diff --git a/board/muas3001/Makefile b/board/muas3001/Makefile index b4b784a..ef04960 100644 --- a/board/muas3001/Makefile +++ b/board/muas3001/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := muas3001.o diff --git a/board/munices/Makefile b/board/munices/Makefile index 97fc2b6..d16e2a1 100644 --- a/board/munices/Makefile +++ b/board/munices/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := munices.o diff --git a/board/musenki/Makefile b/board/musenki/Makefile index e955841..d2b79ff 100644 --- a/board/musenki/Makefile +++ b/board/musenki/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = musenki.o flash.o diff --git a/board/mvblue/Makefile b/board/mvblue/Makefile index e955841..76c10f8 100644 --- a/board/mvblue/Makefile +++ b/board/mvblue/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = mvblue.o flash.o diff --git a/board/netphone/Makefile b/board/netphone/Makefile index 4d86589..ba34605 100644 --- a/board/netphone/Makefile +++ b/board/netphone/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o phone_console.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = netphone.o flash.o phone_console.o diff --git a/board/netta/Makefile b/board/netta/Makefile index 3b54088..98bac7e 100644 --- a/board/netta/Makefile +++ b/board/netta/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o dsp.o codec.o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = netta.o flash.o dsp.o codec.o pcmcia.o diff --git a/board/netta2/Makefile b/board/netta2/Makefile index 871865b..c3bfb0d 100644 --- a/board/netta2/Makefile +++ b/board/netta2/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = netta2.o flash.o diff --git a/board/netvia/Makefile b/board/netvia/Makefile index 871865b..b667bc9 100644 --- a/board/netvia/Makefile +++ b/board/netvia/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = netvia.o flash.o diff --git a/board/nx823/Makefile b/board/nx823/Makefile index e955841..a22be5c 100644 --- a/board/nx823/Makefile +++ b/board/nx823/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = nx823.o flash.o diff --git a/board/pcs440ep/Makefile b/board/pcs440ep/Makefile index 851859d..4fc24d6 100644 --- a/board/pcs440ep/Makefile +++ b/board/pcs440ep/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pcs440ep.o flash.o +extra-y += init.o diff --git a/board/pdm360ng/Makefile b/board/pdm360ng/Makefile index 76f5be4..99201a4 100644 --- a/board/pdm360ng/Makefile +++ b/board/pdm360ng/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pdm360ng.o diff --git a/board/phytec/pcm030/Makefile b/board/phytec/pcm030/Makefile index 4a7d872..2bb49dc 100644 --- a/board/phytec/pcm030/Makefile +++ b/board/phytec/pcm030/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pcm030.o diff --git a/board/pm520/Makefile b/board/pm520/Makefile index 4ff6b2d..3bcba23 100644 --- a/board/pm520/Makefile +++ b/board/pm520/Makefile @@ -6,24 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := pm520.o flash.o diff --git a/board/pm826/Makefile b/board/pm826/Makefile index e955841..c515f81 100644 --- a/board/pm826/Makefile +++ b/board/pm826/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pm826.o flash.o diff --git a/board/pm828/Makefile b/board/pm828/Makefile index e955841..0afffb7 100644 --- a/board/pm828/Makefile +++ b/board/pm828/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pm828.o flash.o diff --git a/board/pn62/Makefile b/board/pn62/Makefile index 5fa6fc8..7572ed8 100644 --- a/board/pn62/Makefile +++ b/board/pn62/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cmd_pn62.o misc.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = pn62.o cmd_pn62.o misc.o diff --git a/board/ppmc7xx/Makefile b/board/ppmc7xx/Makefile index c6abc77..f8957f3 100644 --- a/board/ppmc7xx/Makefile +++ b/board/ppmc7xx/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -SOBJS := init.o - -COBJS := ppmc7xx.o pci.o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := init.o +obj-y += ppmc7xx.o pci.o flash.o diff --git a/board/ppmc8260/Makefile b/board/ppmc8260/Makefile index d0e543c..3072fb4 100644 --- a/board/ppmc8260/Makefile +++ b/board/ppmc8260/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := ppmc8260.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ppmc8260.o diff --git a/board/prodrive/alpr/Makefile b/board/prodrive/alpr/Makefile index 5345df8..812d041 100644 --- a/board/prodrive/alpr/Makefile +++ b/board/prodrive/alpr/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o fpga.o nand.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = alpr.o fpga.o nand.o +extra-y += init.o diff --git a/board/prodrive/p3mx/Makefile b/board/prodrive/p3mx/Makefile index 63ee945..43caffb 100644 --- a/board/prodrive/p3mx/Makefile +++ b/board/prodrive/p3mx/Makefile @@ -5,29 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../../Marvell/common) endif
-LIB = $(obj)lib$(BOARD).o - -SOBJS = misc.o -COBJS = $(BOARD).o mpsc.o mv_eth.o pci.o sdram_init.o serial.o \ +obj-y = misc.o +obj-y += p3mx.o mpsc.o mv_eth.o pci.o sdram_init.o serial.o \ ../../Marvell/common/i2c.o ../../Marvell/common/memory.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/prodrive/p3p440/Makefile b/board/prodrive/p3p440/Makefile index 1d80df8..d62f75d 100644 --- a/board/prodrive/p3p440/Makefile +++ b/board/prodrive/p3p440/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = p3p440.o +extra-y += init.o diff --git a/board/quad100hd/Makefile b/board/quad100hd/Makefile index 9b936d0..b65e5ad 100644 --- a/board/quad100hd/Makefile +++ b/board/quad100hd/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o nand.o -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = quad100hd.o nand.o diff --git a/board/quantum/Makefile b/board/quantum/Makefile index b7497a0..6918f63 100644 --- a/board/quantum/Makefile +++ b/board/quantum/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o fpga.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = quantum.o fpga.o diff --git a/board/r360mpi/Makefile b/board/r360mpi/Makefile index 4720ac8..f8f7fe7 100644 --- a/board/r360mpi/Makefile +++ b/board/r360mpi/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o pcmcia.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = r360mpi.o flash.o pcmcia.o diff --git a/board/rattler/Makefile b/board/rattler/Makefile index c573be9..9de89c8 100644 --- a/board/rattler/Makefile +++ b/board/rattler/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rattler.o diff --git a/board/rbc823/Makefile b/board/rbc823/Makefile index 6e47cb5..060a144 100644 --- a/board/rbc823/Makefile +++ b/board/rbc823/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o kbd.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = rbc823.o flash.o kbd.o diff --git a/board/rpxsuper/Makefile b/board/rpxsuper/Makefile index 3c08959..239b419 100644 --- a/board/rpxsuper/Makefile +++ b/board/rpxsuper/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := rpxsuper.o flash.o mii_phy.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rpxsuper.o flash.o mii_phy.o diff --git a/board/rsdproto/Makefile b/board/rsdproto/Makefile index 8799b50..9351e94 100644 --- a/board/rsdproto/Makefile +++ b/board/rsdproto/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := rsdproto.o flash.o -SOBJS := flash_asm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := rsdproto.o flash.o +obj-y += flash_asm.o diff --git a/board/sacsng/Makefile b/board/sacsng/Makefile index 940a016..95e6b8d 100644 --- a/board/sacsng/Makefile +++ b/board/sacsng/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sacsng.o flash.o clkinit.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sacsng.o flash.o clkinit.o diff --git a/board/sandburst/karef/Makefile b/board/sandburst/karef/Makefile index af758f9..05c8187 100644 --- a/board/sandburst/karef/Makefile +++ b/board/sandburst/karef/Makefile @@ -9,37 +9,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
# TBS: add for debugging purposes BUILDUSER := $(shell whoami) -FORCEBUILD := $(shell rm -f $(LIB) $(BOARD).o) +FORCEBUILD := $(shell rm -f karef.o)
CFLAGS += -DBUILDUSER='"$(BUILDUSER)"' # TBS: end debugging
- -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../common/flash.o ../common/sb_common.o - -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = karef.o ../common/flash.o ../common/sb_common.o +extra-y += init.o diff --git a/board/sandburst/metrobox/Makefile b/board/sandburst/metrobox/Makefile index 163f2b9..76dfffc 100644 --- a/board/sandburst/metrobox/Makefile +++ b/board/sandburst/metrobox/Makefile @@ -8,36 +8,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
# TBS: add for debugging purposes BUILDUSER := $(shell whoami) -FORCEBUILD := $(shell rm -f $(LIB) $(BOARD).o) +FORCEBUILD := $(shell rm -f metrobox.o)
- -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../common/flash.o ../common/sb_common.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = metrobox.o ../common/flash.o ../common/sb_common.o +extra-y += init.o diff --git a/board/sandpoint/Makefile b/board/sandpoint/Makefile index 871865b..58f5a89 100644 --- a/board/sandpoint/Makefile +++ b/board/sandpoint/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = sandpoint.o flash.o diff --git a/board/sbc405/Makefile b/board/sbc405/Makefile index 0d202ac..3f2b0e2 100644 --- a/board/sbc405/Makefile +++ b/board/sbc405/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o strataflash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = sbc405.o strataflash.o diff --git a/board/sbc8349/Makefile b/board/sbc8349/Makefile index 9a5b84a..3b2c389 100644 --- a/board/sbc8349/Makefile +++ b/board/sbc8349/Makefile @@ -4,26 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sbc8349.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/sbc8548/Makefile b/board/sbc8548/Makefile index ecffaa9..b1e32a6 100644 --- a/board/sbc8548/Makefile +++ b/board/sbc8548/Makefile @@ -8,27 +8,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += tlb.o -COBJS-$(CONFIG_FSL_DDR2) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sbc8548.o +obj-y += law.o +obj-y += tlb.o +obj-$(CONFIG_FSL_DDR2) += ddr.o diff --git a/board/sbc8641d/Makefile b/board/sbc8641d/Makefile index 0cbc0d0..9626b06 100644 --- a/board/sbc8641d/Makefile +++ b/board/sbc8641d/Makefile @@ -5,26 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-$(CONFIG_FSL_DDR2) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude ($obj).depend - -######################################################################### +obj-y += sbc8641d.o +obj-y += law.o +obj-$(CONFIG_FSL_DDR2) += ddr.o diff --git a/board/sc3/Makefile b/board/sc3/Makefile index 7369072..c1d163e 100644 --- a/board/sc3/Makefile +++ b/board/sc3/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o sc3nand.o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = sc3.o sc3nand.o +obj-y += init.o diff --git a/board/sheldon/simpc8313/Makefile b/board/sheldon/simpc8313/Makefile index b9fa864..a824c41 100644 --- a/board/sheldon/simpc8313/Makefile +++ b/board/sheldon/simpc8313/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := simpc8313.o sdram.o diff --git a/board/sixnet/Makefile b/board/sixnet/Makefile index 871865b..25a8d69 100644 --- a/board/sixnet/Makefile +++ b/board/sixnet/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = sixnet.o flash.o diff --git a/board/snmc/qs850/Makefile b/board/snmc/qs850/Makefile index 871865b..5867d90 100644 --- a/board/snmc/qs850/Makefile +++ b/board/snmc/qs850/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = qs850.o flash.o diff --git a/board/snmc/qs860t/Makefile b/board/snmc/qs860t/Makefile index 871865b..802f67e 100644 --- a/board/snmc/qs860t/Makefile +++ b/board/snmc/qs860t/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = qs860t.o flash.o diff --git a/board/socrates/Makefile b/board/socrates/Makefile index c2e282b..0a08810 100644 --- a/board/socrates/Makefile +++ b/board/socrates/Makefile @@ -7,30 +7,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o -# - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += tlb.o -COBJS-y += nand.o -COBJS-y += sdram.o -COBJS-$(CONFIG_FSL_DDR2) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += socrates.o +obj-y += law.o +obj-y += tlb.o +obj-y += nand.o +obj-y += sdram.o +obj-$(CONFIG_FSL_DDR2) += ddr.o diff --git a/board/spc1920/Makefile b/board/spc1920/Makefile index cadacee..c0c9a32 100644 --- a/board/spc1920/Makefile +++ b/board/spc1920/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o hpi.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = spc1920.o hpi.o diff --git a/board/spd8xx/Makefile b/board/spd8xx/Makefile index 871865b..c393f06 100644 --- a/board/spd8xx/Makefile +++ b/board/spd8xx/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = spd8xx.o flash.o diff --git a/board/stx/stxgp3/Makefile b/board/stx/stxgp3/Makefile index 0b0f26e..9b72434 100644 --- a/board/stx/stxgp3/Makefile +++ b/board/stx/stxgp3/Makefile @@ -5,28 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += tlb.o -COBJS-y += flash.o -COBJS-$(CONFIG_FSL_DDR1) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += stxgp3.o +obj-y += law.o +obj-y += tlb.o +obj-y += flash.o +obj-$(CONFIG_FSL_DDR1) += ddr.o diff --git a/board/stx/stxssa/Makefile b/board/stx/stxssa/Makefile index 8757a71..17e0aae 100644 --- a/board/stx/stxssa/Makefile +++ b/board/stx/stxssa/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += law.o -COBJS-y += tlb.o -COBJS-$(CONFIG_FSL_DDR1) += ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += stxssa.o +obj-y += law.o +obj-y += tlb.o +obj-$(CONFIG_FSL_DDR1) += ddr.o diff --git a/board/stx/stxxtc/Makefile b/board/stx/stxxtc/Makefile index e7f4fb6..6738d4e 100644 --- a/board/stx/stxxtc/Makefile +++ b/board/stx/stxxtc/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = stxxtc.o diff --git a/board/svm_sc8xx/Makefile b/board/svm_sc8xx/Makefile index 871865b..4c0b4a3 100644 --- a/board/svm_sc8xx/Makefile +++ b/board/svm_sc8xx/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = svm_sc8xx.o flash.o diff --git a/board/t3corp/Makefile b/board/t3corp/Makefile index 093457f..928d895 100644 --- a/board/t3corp/Makefile +++ b/board/t3corp/Makefile @@ -5,29 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o -SOBJS := init.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) $(SOBJS) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := t3corp.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += chip_config.o +extra-y += init.o diff --git a/board/total5200/Makefile b/board/total5200/Makefile index 5c22b70..527557c 100644 --- a/board/total5200/Makefile +++ b/board/total5200/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := total5200.o sdram.o diff --git a/board/tqc/tqm5200/Makefile b/board/tqc/tqm5200/Makefile index 619e43f..757f472 100644 --- a/board/tqc/tqm5200/Makefile +++ b/board/tqc/tqm5200/Makefile @@ -5,27 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := tqm5200.o cmd_stk52xx.o cmd_tb5200.o cam5200_flash.o
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o cmd_stk52xx.o cmd_tb5200.o cam5200_flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -cam5200_flash.o: cam5200_flash.c +$(obj)cam5200_flash.o: cam5200_flash.c $(CC) $(CFLAGS) -c -o $@ $< - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/tqc/tqm8260/Makefile b/board/tqc/tqm8260/Makefile index b92acdb..dc4a528 100644 --- a/board/tqc/tqm8260/Makefile +++ b/board/tqc/tqm8260/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../tqm8xx/) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../tqm8xx/load_sernum_ethaddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = tqm8260.o ../tqm8xx/load_sernum_ethaddr.o diff --git a/board/tqc/tqm8272/Makefile b/board/tqc/tqm8272/Makefile index 58f1b65..09af765 100644 --- a/board/tqc/tqm8272/Makefile +++ b/board/tqc/tqm8272/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o ../tqm8xx/load_sernum_ethaddr.o nand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = tqm8272.o ../tqm8xx/load_sernum_ethaddr.o nand.o diff --git a/board/tqc/tqm834x/Makefile b/board/tqc/tqm834x/Makefile index 0692bb1..12edc9a 100644 --- a/board/tqc/tqm834x/Makefile +++ b/board/tqc/tqm834x/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-$(CONFIG_PCI) += pci.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += tqm834x.o +obj-$(CONFIG_PCI) += pci.o diff --git a/board/tqc/tqm8xx/Makefile b/board/tqc/tqm8xx/Makefile index 787ecc2..2651a2f 100644 --- a/board/tqc/tqm8xx/Makefile +++ b/board/tqc/tqm8xx/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o load_sernum_ethaddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = tqm8xx.o load_sernum_ethaddr.o diff --git a/board/utx8245/Makefile b/board/utx8245/Makefile index 4cf57ce..f12e545 100644 --- a/board/utx8245/Makefile +++ b/board/utx8245/Makefile @@ -10,24 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = utx8245.o flash.o diff --git a/board/v37/Makefile b/board/v37/Makefile index 1284818..2df4b82 100644 --- a/board/v37/Makefile +++ b/board/v37/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = v37.o flash.o diff --git a/board/v38b/Makefile b/board/v38b/Makefile index 5c8bb6f..a20a5ef 100644 --- a/board/v38b/Makefile +++ b/board/v38b/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ethaddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := v38b.o ethaddr.o diff --git a/board/ve8313/Makefile b/board/ve8313/Makefile index ff0dbf8..41258f9 100644 --- a/board/ve8313/Makefile +++ b/board/ve8313/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := ve8313.o diff --git a/board/w7o/Makefile b/board/w7o/Makefile index 85bebac..955de50 100644 --- a/board/w7o/Makefile +++ b/board/w7o/Makefile @@ -8,26 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o flash.o fpga.o fsboot.o post2.o vpd.o cmd_vpd.o \ +obj-y = w7o.o flash.o fpga.o fsboot.o post2.o vpd.o cmd_vpd.o \ watchdog.o -SOBJS = init.o post1.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += init.o post1.o diff --git a/board/xes/common/Makefile b/board/xes/common/Makefile index 2e5f1c5..65d321a 100644 --- a/board/xes/common/Makefile +++ b/board/xes/common/Makefile @@ -5,34 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)board/$(VENDOR)/common) -endif - -LIB = $(obj)lib$(VENDOR).o - -COBJS-$(CONFIG_FSL_PCI_INIT) += fsl_8xxx_pci.o -COBJS-$(CONFIG_MPC8572) += fsl_8xxx_clk.o -COBJS-$(CONFIG_MPC86xx) += fsl_8xxx_clk.o -COBJS-$(CONFIG_P2020) += fsl_8xxx_clk.o -COBJS-$(CONFIG_MPC85xx) += fsl_8xxx_misc.o board.o -COBJS-$(CONFIG_MPC86xx) += fsl_8xxx_misc.o board.o -COBJS-$(CONFIG_NAND_ACTL) += actl_nand.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FSL_PCI_INIT) += fsl_8xxx_pci.o +obj-$(CONFIG_MPC8572) += fsl_8xxx_clk.o +obj-$(CONFIG_MPC86xx) += fsl_8xxx_clk.o +obj-$(CONFIG_P2020) += fsl_8xxx_clk.o +obj-$(CONFIG_MPC85xx) += fsl_8xxx_misc.o board.o +obj-$(CONFIG_MPC86xx) += fsl_8xxx_misc.o board.o +obj-$(CONFIG_NAND_ACTL) += actl_nand.o diff --git a/board/xes/xpedite1000/Makefile b/board/xes/xpedite1000/Makefile index 1d80df8..308de91 100644 --- a/board/xes/xpedite1000/Makefile +++ b/board/xes/xpedite1000/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o -SOBJS = init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = xpedite1000.o +extra-y += init.o diff --git a/board/xes/xpedite517x/Makefile b/board/xes/xpedite517x/Makefile index 0105aa1..d88c3d4 100644 --- a/board/xes/xpedite517x/Makefile +++ b/board/xes/xpedite517x/Makefile @@ -5,26 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude ($obj).depend - -######################################################################### +obj-y += xpedite517x.o +obj-y += ddr.o +obj-y += law.o diff --git a/board/xes/xpedite520x/Makefile b/board/xes/xpedite520x/Makefile index 6c1b85b..14841b9 100644 --- a/board/xes/xpedite520x/Makefile +++ b/board/xes/xpedite520x/Makefile @@ -7,27 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += xpedite520x.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/xes/xpedite537x/Makefile b/board/xes/xpedite537x/Makefile index 64f996f..2dca0d7 100644 --- a/board/xes/xpedite537x/Makefile +++ b/board/xes/xpedite537x/Makefile @@ -7,27 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += xpedite537x.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/xes/xpedite550x/Makefile b/board/xes/xpedite550x/Makefile index c9b2dea..1a3fe76 100644 --- a/board/xes/xpedite550x/Makefile +++ b/board/xes/xpedite550x/Makefile @@ -4,27 +4,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS-y)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += xpedite550x.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/zeus/Makefile b/board/zeus/Makefile index 8d133e2..aa3658a 100644 --- a/board/zeus/Makefile +++ b/board/zeus/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o update.o -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = zeus.o update.o diff --git a/board/zpc1900/Makefile b/board/zpc1900/Makefile index c573be9..e636365 100644 --- a/board/zpc1900/Makefile +++ b/board/zpc1900/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := zpc1900.o
Cc: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Kim Phillips kim.phillips@freescale.com Cc: York Sun yorksun@freescale.com Signed-off-by: Tom Rini trini@ti.com --- board/freescale/t1040qds/Makefile | 36 +++++------------------------------- board/keymile/kmp204x/Makefile | 21 +-------------------- 2 files changed, 6 insertions(+), 51 deletions(-)
diff --git a/board/freescale/t1040qds/Makefile b/board/freescale/t1040qds/Makefile index 8f0057b..a2dba6f 100644 --- a/board/freescale/t1040qds/Makefile +++ b/board/freescale/t1040qds/Makefile @@ -4,34 +4,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-y += law.o -COBJS-y += tlb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += $(BOARD).o +obj-y += ddr.o +obj-$(CONFIG_PCI) += pci.o +obj-y += law.o +obj-y += tlb.o diff --git a/board/keymile/kmp204x/Makefile b/board/keymile/kmp204x/Makefile index 35d17ce..1fdb346 100644 --- a/board/keymile/kmp204x/Makefile +++ b/board/keymile/kmp204x/Makefile @@ -21,28 +21,9 @@ # MA 02111-1307 USA #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../common) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS := $(BOARD).o ddr.o eth.o tlb.o pci.o law.o \ +obj-y := $(BOARD).o ddr.o eth.o tlb.o pci.o law.o \ ../common/common.o ../common/ivm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
-clean:
-distclean: clean
Applied to u-boot/master.
This commit also deletes post/rules.mk, which in not necessary any more.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- post/Makefile | 65 +++++++++---------------------------------- post/board/lwmon/Makefile | 7 ++--- post/board/lwmon5/Makefile | 7 ++--- post/board/netta/Makefile | 7 ++--- post/board/pdm360ng/Makefile | 7 ++--- post/cpu/mpc83xx/Makefile | 8 ++---- post/cpu/mpc8xx/Makefile | 9 ++---- post/cpu/ppc4xx/Makefile | 23 +++++++-------- post/drivers/Makefile | 7 ++--- post/lib_powerpc/Makefile | 13 ++++----- post/lib_powerpc/fpu/Makefile | 24 +++++++--------- post/rules.mk | 30 -------------------- 12 files changed, 54 insertions(+), 153 deletions(-) delete mode 100644 post/rules.mk
diff --git a/post/Makefile b/post/Makefile index 0ecae5b..1439244 100644 --- a/post/Makefile +++ b/post/Makefile @@ -5,55 +5,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk -include $(OBJTREE)/include/autoconf.mk - -LIB = libpost.o -GPLIB-$(CONFIG_HAS_POST) += libgenpost.o -COBJS-$(CONFIG_HAS_POST) += post.o -COBJS-$(CONFIG_POST_STD_LIST) += tests.o - -SPLIB-$(CONFIG_HAS_POST) = drivers/libpostdrivers.o -SPLIB-$(CONFIG_HAS_POST) += $(shell if [ -d lib_$(ARCH) ]; then echo \ - "lib_$(ARCH)/libpost$(ARCH).o"; fi) -SPLIB-$(CONFIG_HAS_POST) += $(shell if [ -d lib_$(ARCH)/fpu ]; then echo \ - "lib_$(ARCH)/fpu/libpost$(ARCH)fpu.o"; fi) -SPLIB-$(CONFIG_HAS_POST) += $(shell if [ -d cpu/$(CPU) ]; then echo \ - "cpu/$(CPU)/libpost$(CPU).o"; fi) -SPLIB-$(CONFIG_HAS_POST) += $(shell if [ -d board/$(BOARD) ]; then echo \ - "board/$(BOARD)/libpost$(BOARD).o"; fi) - -GPLIB := $(addprefix $(obj),$(GPLIB-y)) -SPLIB := $(addprefix $(obj),$(SPLIB-y)) -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -LIB := $(obj)$(LIB) - -all: $(LIB) - -postdeps: - @for lib in $(SPLIB-y) ; do \ - $(MAKE) -C `dirname $$lib` all ; \ - done - -# generic POST library -$(GPLIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -# specific POST libraries -$(SPLIB): $(obj).depend postdeps - $(MAKE) -C $(dir $(subst $(obj),,$@)) - -# the POST lib archive -$(LIB): $(GPLIB) $(SPLIB) - $(call cmd_link_o_target, $^) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_HAS_POST) += post.o +obj-$(CONFIG_POST_STD_LIST) += tests.o + +obj-$(CONFIG_HAS_POST) += drivers/ +ifeq ($(ARCH),powerpc) +obj-$(CONFIG_HAS_POST) += lib_powerpc/ +endif +ifneq ($(filter mpc83xx mpc8xx ppc4xx,$(CPU)),) +obj-$(CONFIG_HAS_POST) += cpu/$(CPU)/ +endif +ifneq ($(filter lwmon lwmon5 netta pdm360ng,$(BOARD)),) +obj-$(CONFIG_HAS_POST) += board/$(BOARD)/ +endif diff --git a/post/board/lwmon/Makefile b/post/board/lwmon/Makefile index d38498b..1ac7aa5 100644 --- a/post/board/lwmon/Makefile +++ b/post/board/lwmon/Makefile @@ -4,10 +4,7 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostlwmon.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-$(CONFIG_HAS_POST) += sysmon.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += sysmon.o diff --git a/post/board/lwmon5/Makefile b/post/board/lwmon5/Makefile index b410dbb..d8b1952 100644 --- a/post/board/lwmon5/Makefile +++ b/post/board/lwmon5/Makefile @@ -4,10 +4,7 @@ # Developed for DENX Software Engineering GmbH # # SPDX-License-Identifier: GPL-2.0+ -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostlwmon5.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-$(CONFIG_HAS_POST) += sysmon.o watchdog.o dspic.o fpga.o dsp.o gdc.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += sysmon.o watchdog.o dspic.o fpga.o dsp.o gdc.o diff --git a/post/board/netta/Makefile b/post/board/netta/Makefile index 2d73f55..cd27a5c 100644 --- a/post/board/netta/Makefile +++ b/post/board/netta/Makefile @@ -4,10 +4,7 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostnetta.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-$(CONFIG_HAS_POST) += codec.o dsp.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += codec.o dsp.o diff --git a/post/board/pdm360ng/Makefile b/post/board/pdm360ng/Makefile index cb03e58..3f74889 100644 --- a/post/board/pdm360ng/Makefile +++ b/post/board/pdm360ng/Makefile @@ -4,10 +4,7 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostpdm360ng.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-$(CONFIG_HAS_POST) += coproc_com.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += coproc_com.o diff --git a/post/cpu/mpc83xx/Makefile b/post/cpu/mpc83xx/Makefile index 6ac56dc..0643d01 100644 --- a/post/cpu/mpc83xx/Makefile +++ b/post/cpu/mpc83xx/Makefile @@ -4,11 +4,7 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostmpc83xx.o +CPPFLAGS += -I$(TOPDIR)
-AOBJS-$(CONFIG_HAS_POST) += -COBJS-$(CONFIG_HAS_POST) += ecc.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += ecc.o diff --git a/post/cpu/mpc8xx/Makefile b/post/cpu/mpc8xx/Makefile index efde1fb..7a2930a 100644 --- a/post/cpu/mpc8xx/Makefile +++ b/post/cpu/mpc8xx/Makefile @@ -4,11 +4,8 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostmpc8xx.o +CPPFLAGS += -I$(TOPDIR)
-AOBJS-$(CONFIG_HAS_POST) += cache_8xx.o -COBJS-$(CONFIG_HAS_POST) += cache.o ether.o spr.o uart.o usb.o watchdog.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += cache_8xx.o +obj-$(CONFIG_HAS_POST) += cache.o ether.o spr.o uart.o usb.o watchdog.o diff --git a/post/cpu/ppc4xx/Makefile b/post/cpu/ppc4xx/Makefile index 614cef0..b7435c8 100644 --- a/post/cpu/ppc4xx/Makefile +++ b/post/cpu/ppc4xx/Makefile @@ -4,18 +4,15 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(OBJTREE)/include/autoconf.mk
-LIB = libpostppc4xx.o +CPPFLAGS += -I$(TOPDIR)
-AOBJS-$(CONFIG_HAS_POST) += cache_4xx.o -COBJS-$(CONFIG_HAS_POST) += cache.o -COBJS-$(CONFIG_HAS_POST) += denali_ecc.o -COBJS-$(CONFIG_HAS_POST) += ether.o -COBJS-$(CONFIG_HAS_POST) += fpu.o -COBJS-$(CONFIG_HAS_POST) += ocm.o -COBJS-$(CONFIG_HAS_POST) += spr.o -COBJS-$(CONFIG_HAS_POST) += uart.o -COBJS-$(CONFIG_HAS_POST) += watchdog.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += cache_4xx.o +obj-$(CONFIG_HAS_POST) += cache.o +obj-$(CONFIG_HAS_POST) += denali_ecc.o +obj-$(CONFIG_HAS_POST) += ether.o +obj-$(CONFIG_HAS_POST) += fpu.o +obj-$(CONFIG_HAS_POST) += ocm.o +obj-$(CONFIG_HAS_POST) += spr.o +obj-$(CONFIG_HAS_POST) += uart.o +obj-$(CONFIG_HAS_POST) += watchdog.o diff --git a/post/drivers/Makefile b/post/drivers/Makefile index 6720f85..2f6844c 100644 --- a/post/drivers/Makefile +++ b/post/drivers/Makefile @@ -4,10 +4,7 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = libpostdrivers.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-$(CONFIG_HAS_POST) += flash.o i2c.o memory.o rtc.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += flash.o i2c.o memory.o rtc.o diff --git a/post/lib_powerpc/Makefile b/post/lib_powerpc/Makefile index efa1fb2..f19fea3 100644 --- a/post/lib_powerpc/Makefile +++ b/post/lib_powerpc/Makefile @@ -4,13 +4,12 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = libpost$(ARCH).o +CPPFLAGS += -I$(TOPDIR)
-AOBJS-$(CONFIG_HAS_POST) += asm.o -COBJS-$(CONFIG_HAS_POST) += cpu.o cmp.o cmpi.o two.o twox.o three.o threex.o -COBJS-$(CONFIG_HAS_POST) += threei.o andi.o srawi.o rlwnm.o rlwinm.o rlwimi.o -COBJS-$(CONFIG_HAS_POST) += store.o load.o cr.o b.o multi.o string.o complex.o +obj-$(CONFIG_HAS_POST) += asm.o +obj-$(CONFIG_HAS_POST) += cpu.o cmp.o cmpi.o two.o twox.o three.o threex.o +obj-$(CONFIG_HAS_POST) += threei.o andi.o srawi.o rlwnm.o rlwinm.o rlwimi.o +obj-$(CONFIG_HAS_POST) += store.o load.o cr.o b.o multi.o string.o complex.o
-include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += fpu/ diff --git a/post/lib_powerpc/fpu/Makefile b/post/lib_powerpc/fpu/Makefile index eff7e6b..6aec96c 100644 --- a/post/lib_powerpc/fpu/Makefile +++ b/post/lib_powerpc/fpu/Makefile @@ -4,22 +4,18 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = libpost$(ARCH)fpu.o +CPPFLAGS += -I$(TOPDIR)
-COBJS-$(CONFIG_HAS_POST) += 20001122-1.o -COBJS-$(CONFIG_HAS_POST) += 20010114-2.o -COBJS-$(CONFIG_HAS_POST) += 20010226-1.o -COBJS-$(CONFIG_HAS_POST) += 980619-1.o -COBJS-$(CONFIG_HAS_POST) += acc1.o -COBJS-$(CONFIG_HAS_POST) += compare-fp-1.o -COBJS-$(CONFIG_HAS_POST) += fpu.o -COBJS-$(CONFIG_HAS_POST) += mul-subnormal-single-1.o - -COBJS-$(CONFIG_HAS_POST) += darwin-ldouble.o - -include $(TOPDIR)/post/rules.mk +obj-$(CONFIG_HAS_POST) += 20001122-1.o +obj-$(CONFIG_HAS_POST) += 20010114-2.o +obj-$(CONFIG_HAS_POST) += 20010226-1.o +obj-$(CONFIG_HAS_POST) += 980619-1.o +obj-$(CONFIG_HAS_POST) += acc1.o +obj-$(CONFIG_HAS_POST) += compare-fp-1.o +obj-$(CONFIG_HAS_POST) += fpu.o +obj-$(CONFIG_HAS_POST) += mul-subnormal-single-1.o +obj-$(CONFIG_HAS_POST) += darwin-ldouble.o
CFLAGS := $(shell echo $(CFLAGS) | sed s/-msoft-float//) CFLAGS += -mhard-float -fkeep-inline-functions diff --git a/post/rules.mk b/post/rules.mk deleted file mode 100644 index b25ebbf..0000000 --- a/post/rules.mk +++ /dev/null @@ -1,30 +0,0 @@ -# -# (C) Copyright 2002-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -include $(TOPDIR)/config.mk - -COBJS := $(COBJS-y) -AOBJS := $(AOBJS-y) -SRCS := $(AOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS)) -LIB := $(obj)$(LIB) - -CPPFLAGS += -I$(TOPDIR) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- Makefile | 2 +- api/Makefile | 18 +----------------- dts/Makefile | 24 +----------------------- test/Makefile | 26 ++------------------------ 4 files changed, 5 insertions(+), 65 deletions(-)
diff --git a/Makefile b/Makefile index 63f6440..0d27b5b 100644 --- a/Makefile +++ b/Makefile @@ -382,7 +382,7 @@ build := -f $(TOPDIR)/scripts/Makefile.build -C all: $(ALL-y) $(SUBDIR_EXAMPLES)
$(obj)u-boot.dtb: checkdtc $(obj)u-boot - $(MAKE) -C dts binary + $(MAKE) $(build) dts binary mv $(obj)dts/dt.dtb $@
$(obj)u-boot-dtb.bin: $(obj)u-boot.bin $(obj)u-boot.dtb diff --git a/api/Makefile b/api/Makefile index 87b8eb2..fb130ff 100644 --- a/api/Makefile +++ b/api/Makefile @@ -4,21 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libapi.o - -COBJS-$(CONFIG_API) += api.o api_display.o api_net.o api_storage.o \ +obj-$(CONFIG_API) += api.o api_display.o api_net.o api_storage.o \ api_platform-$(ARCH).o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend diff --git a/dts/Makefile b/dts/Makefile index 3cf991e..140c8bc 100644 --- a/dts/Makefile +++ b/dts/Makefile @@ -7,10 +7,6 @@ # This Makefile builds the internal U-Boot fdt if CONFIG_OF_CONTROL is # enabled. See doc/README.fdt-control for more details.
-include $(TOPDIR)/config.mk - -LIB = $(obj)libdts.o - ifeq ($(DEVICE_TREE),) $(if $(CONFIG_DEFAULT_DEVICE_TREE),,\ $(error Please define CONFIG_DEFAULT_DEVICE_TREE in your board header file)) @@ -27,8 +23,6 @@ DTS_CPPFLAGS := -x assembler-with-cpp -undef -D__DTS__ \ DTC_FLAGS := -R 4 -p 0x1000 \ $(addprefix -i ,$(DTS_INCDIRS))
-all: $(obj).depend $(LIB) - # Use a constant name for this so we can access it from C code. # objcopy doesn't seem to allow us to set the symbol name independently of # the filename. @@ -71,22 +65,6 @@ $(obj)dt.o: $(DT_BIN) $(notdir ${DT_BIN}) $@ rm $(DT_BIN)
-OBJS-$(CONFIG_OF_EMBED) := dt.o - -COBJS := $(OBJS-y) - -OBJS := $(addprefix $(obj),$(COBJS)) +obj-$(CONFIG_OF_EMBED) := dt.o
binary: $(DT_BIN) - -$(LIB): $(OBJS) $(DTB) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/test/Makefile b/test/Makefile index a68613d..9c95805 100644 --- a/test/Makefile +++ b/test/Makefile @@ -4,27 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtest.o - -COBJS-$(CONFIG_SANDBOX) += command_ut.o -COBJS-$(CONFIG_SANDBOX) += compression.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) $(XOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SANDBOX) += command_ut.o +obj-$(CONFIG_SANDBOX) += compression.o
We have converted all makefiles needed to build $(LIBS).
Until this commit we used to grep switch so that U-Boot style and Kbuild style makefiles coexist. But we do not need any more.
Goint forward, use always Kbuild style Makefile when adding a new Makefile
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- Makefile | 38 +++++-------------------------- board/avionic-design/medcom-wide/Makefile | 22 +----------------- board/avionic-design/plutux/Makefile | 22 +----------------- board/avionic-design/tec/Makefile | 22 +----------------- board/avnet/fx12mm/Makefile | 2 +- board/avnet/v5fx30teval/Makefile | 2 +- board/compal/paz00/Makefile | 22 +----------------- board/compulab/trimslice/Makefile | 22 +----------------- board/nvidia/common/Makefile | 26 --------------------- board/nvidia/common/common.mk | 4 ++-- board/xilinx/ml507/Makefile | 2 +- board/xilinx/ppc405-generic/Makefile | 21 +---------------- board/xilinx/ppc440-generic/Makefile | 23 ++----------------- spl/Makefile | 25 ++++---------------- 14 files changed, 23 insertions(+), 230 deletions(-)
diff --git a/Makefile b/Makefile index 0d27b5b..b255733 100644 --- a/Makefile +++ b/Makefile @@ -558,32 +558,16 @@ ifeq ($(CONFIG_KALLSYMS),y) $(GEN_UBOOT) $(obj)common/system_map.o endif
-# Tentative step for Kbuild-style makefiles coexist with conventional U-Boot style makefiles -# U-Boot conventional sub makefiles always include some other makefiles. -# So, the build system searches a line beginning with "include" before entering into the sub makefile -# in order to distinguish which style it is. -# If the Makefile include a "include" line, we assume it is an U-Boot style makefile. -# Otherwise, it is treated as a Kbuild-style makefile. -select_makefile = \ - +if grep -q "^include" $1/Makefile; then \ - $(MAKE) -C $1; \ - else \ - $(MAKE) -C $1 -f $(TOPDIR)/scripts/Makefile.build; \ - mv $(dir $@)built-in.o $@; \ - fi - -# We do not need to build $(OBJS) explicitly. -# It is built while we are at $(CPUDIR)/lib$(CPU).o build. -$(OBJS): depend - if grep -q "^include" $(CPUDIR)/Makefile; then \ - $(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@)); \ - fi +$(OBJS): + @:
$(LIBS): depend $(SUBDIR_TOOLS) - +$(call select_makefile, $(dir $(subst $(obj),,$@))) + $(MAKE) $(build) $(dir $(subst $(obj),,$@)) + mv $(dir $@)built-in.o $@
$(LIBBOARD): depend $(LIBS) - +$(call select_makefile, $(dir $(subst $(obj),,$@))) + $(MAKE) $(build) $(dir $(subst $(obj),,$@)) + mv $(dir $@)built-in.o $@
$(SUBDIRS): depend $(MAKE) -C $@ all @@ -611,13 +595,6 @@ $(obj)tpl/u-boot-tpl.bin: $(SUBDIR_TOOLS) depend updater: $(MAKE) -C tools/updater all
-select_makefile2 = \ - if grep -q "^include" $1/Makefile; then \ - $(MAKE) -C $1 _depend; \ - else \ - $(MAKE) -C $1 -f $(TOPDIR)/scripts/Makefile.build _depend; \ - fi - # Explicitly make _depend in subdirs containing multiple targets to prevent # parallel sub-makes creating .depend files simultaneously. depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ @@ -626,9 +603,6 @@ depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ $(obj)include/autoconf.mk \ $(obj)include/generated/generic-asm-offsets.h \ $(obj)include/generated/asm-offsets.h - +for dir in $(SUBDIRS) $(CPUDIR) $(LDSCRIPT_MAKEFILE_DIR) ; do \ - $(call select_makefile2, $$dir); \ - done
TAG_SUBDIRS = $(SUBDIRS) TAG_SUBDIRS += $(dir $(__LIBS)) diff --git a/board/avionic-design/medcom-wide/Makefile b/board/avionic-design/medcom-wide/Makefile index 3077319..6c4ab64 100644 --- a/board/avionic-design/medcom-wide/Makefile +++ b/board/avionic-design/medcom-wide/Makefile @@ -7,28 +7,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(obj)../common $(obj)../../nvidia/common)
-LIB = $(obj)lib$(BOARD).o - -COBJS-y := ../common/tamonten.o +obj-y := ../common/tamonten.o
include ../../nvidia/common/common.mk - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/avionic-design/plutux/Makefile b/board/avionic-design/plutux/Makefile index 3077319..6c4ab64 100644 --- a/board/avionic-design/plutux/Makefile +++ b/board/avionic-design/plutux/Makefile @@ -7,28 +7,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
include ../../nvidia/common/common.mk - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/avionic-design/tec/Makefile b/board/avionic-design/tec/Makefile index 3077319..6c4ab64 100644 --- a/board/avionic-design/tec/Makefile +++ b/board/avionic-design/tec/Makefile @@ -7,28 +7,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
include ../../nvidia/common/common.mk - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/avnet/fx12mm/Makefile b/board/avnet/fx12mm/Makefile index 2dd48b6..37fb02f 100644 --- a/board/avnet/fx12mm/Makefile +++ b/board/avnet/fx12mm/Makefile @@ -6,6 +6,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += $(BOARD).o +obj-y += fx12mm.o
include $(SRCTREE)/board/xilinx/ppc405-generic/Makefile diff --git a/board/avnet/v5fx30teval/Makefile b/board/avnet/v5fx30teval/Makefile index 51b777c..f7d0417 100644 --- a/board/avnet/v5fx30teval/Makefile +++ b/board/avnet/v5fx30teval/Makefile @@ -6,6 +6,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += $(BOARD).o +obj-y += v5fx30teval.o
include $(SRCTREE)/board/xilinx/ppc440-generic/Makefile diff --git a/board/compal/paz00/Makefile b/board/compal/paz00/Makefile index fa5c510..824cd2e 100644 --- a/board/compal/paz00/Makefile +++ b/board/compal/paz00/Makefile @@ -14,28 +14,8 @@ # more details. #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(obj)../../nvidia/common)
-LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o +obj-y := paz00.o
include ../../nvidia/common/common.mk - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/compulab/trimslice/Makefile b/board/compulab/trimslice/Makefile index 3ce180c..0818673 100644 --- a/board/compulab/trimslice/Makefile +++ b/board/compulab/trimslice/Makefile @@ -5,28 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o +obj-y := trimslice.o
include ../../nvidia/common/common.mk - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/nvidia/common/Makefile b/board/nvidia/common/Makefile index 6215caf..e3fcf2b 100644 --- a/board/nvidia/common/Makefile +++ b/board/nvidia/common/Makefile @@ -1,30 +1,4 @@ # Copyright (c) 2011 The Chromium OS Authors. # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -ifneq ($(OBJTREE),$(SRCTREE)) -$(shell mkdir -p $(obj)board/$(VENDOR)/common) -endif - -LIB = $(obj)lib$(VENDOR).o - include common.mk - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/nvidia/common/common.mk b/board/nvidia/common/common.mk index d9bcb85..9a9b529 100644 --- a/board/nvidia/common/common.mk +++ b/board/nvidia/common/common.mk @@ -1,3 +1,3 @@ # common options for all tegra boards -COBJS-y += ../../nvidia/common/board.o -COBJS-$(CONFIG_TEGRA_CLOCK_SCALING) += ../../nvidia/common/emc.o +obj-y += ../../nvidia/common/board.o +obj-$(CONFIG_TEGRA_CLOCK_SCALING) += ../../nvidia/common/emc.o diff --git a/board/xilinx/ml507/Makefile b/board/xilinx/ml507/Makefile index 51b777c..3c84651 100644 --- a/board/xilinx/ml507/Makefile +++ b/board/xilinx/ml507/Makefile @@ -6,6 +6,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += $(BOARD).o +obj-y += ml507.o
include $(SRCTREE)/board/xilinx/ppc440-generic/Makefile diff --git a/board/xilinx/ppc405-generic/Makefile b/board/xilinx/ppc405-generic/Makefile index cc161ae..1562f17 100644 --- a/board/xilinx/ppc405-generic/Makefile +++ b/board/xilinx/ppc405-generic/Makefile @@ -9,27 +9,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../../xilinx/ppc405-generic) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS += ../../xilinx/ppc405-generic/xilinx_ppc405_generic.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += ../../xilinx/ppc405-generic/xilinx_ppc405_generic.o diff --git a/board/xilinx/ppc440-generic/Makefile b/board/xilinx/ppc440-generic/Makefile index 597afde..b2227c5 100644 --- a/board/xilinx/ppc440-generic/Makefile +++ b/board/xilinx/ppc440-generic/Makefile @@ -9,28 +9,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)../../xilinx/ppc440-generic) endif
-LIB = $(obj)lib$(BOARD).o - -COBJS += ../../xilinx/ppc440-generic/xilinx_ppc440_generic.o -SOBJS += ../../xilinx/ppc440-generic/init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += ../../xilinx/ppc440-generic/xilinx_ppc440_generic.o +extra-y += ../../xilinx/ppc440-generic/init.o diff --git a/spl/Makefile b/spl/Makefile index bf7271d..cbd3d27 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -190,29 +190,12 @@ GEN_UBOOT = \ $(obj)$(SPL_BIN): depend $(START) $(LIBS) $(obj)u-boot-spl.lds $(GEN_UBOOT)
-# Tentative step for Kbuild-style makefiles coexist with conventional U-Boot style makefiles -# U-Boot conventional sub makefiles always include some other makefiles. -# So, the build system searches a line beginning with "include" before entering into the sub makefile -# in order to distinguish which style it is. -# If the Makefile include a "include" line, we assume it is an U-Boot style makefile. -# Otherwise, it is treated as a Kbuild-style makefile. -select_makefile = \ - if grep -q "^include" $1/Makefile; then \ - $(MAKE) -C $1; \ - else \ - $(MAKE) -C $1 -f $(TOPDIR)/scripts/Makefile.build; \ - mv $(dir $@)built-in.o $@; \ - fi - -# We do not need to build $(START) explicitly. -# It is built while we are at $(CPUDIR)/lib$(CPU).o build. -$(START): depend - if grep -q "^include" $(SRCTREE)$(dir $(subst $(SPLTREE),,$@))Makefile; then \ - $(MAKE) -C $(SRCTREE)/$(START_PATH) $@; \ - fi +$(START): + @:
$(LIBS): depend - +$(call select_makefile, $(SRCTREE)$(dir $(subst $(SPLTREE),,$@))) + $(MAKE) $(build) $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)) + mv $(dir $@)built-in.o $@
$(obj)u-boot-spl.lds: $(LDSCRIPT) depend $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj). -ansi -D__ASSEMBLY__ -P - < $< > $@
Dear Masahiro Yamada,
This series uses the followings as prerequisites:
- First step towards Kbuild: Use Kbuild style makefiles (19 patch files)
- Second step towards Kbuild: Descend down like Kbuild (6 patch files)
In 'First step towards Kbuild' series, I changed more than 150 makefiles. And in this series, I have changed the remainders, more than 600 makefiles.
After applying first step thru third step, all makefiles under arch/, board/, drivers/, api/, common/, disk/, dts/, fs/, lib/, net/, post/, test/ are converted to Kbuild style.
( doc/, tools/, nand_spl/, example/ have not been changed yet. I'm planning to convert these directories. But I need something prepared before that: hostprogs-y, etc.)
Before converting makefiles to Kbuild style, I want to fix some makefile. This is done in 01/18 and 02/18.
01/18 fixes the link error of sparc architecture. Please see the snippet of arch/sparc/lib/Makefile:
LIB = $(obj)lib$(ARCH).o SOBJS = COBJS = board.o cache.o interrupts.o time.o COBJS-$(CONFIG_CMD_BOOTM) += bootm.o SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) $(LIB): $(obj).depend $(OBJS) $(call cmd_link_o_target, $(OBJS))
Both COBJS and COBJS-y are used. But this makefile missed to add $(COBJS-y) to OBJS. So, bootm.o is never compiled.
Here, you will notice the advantage of switching to Kbuild style.
Makefiles in sub-directories have very similar form. But there exists a slight difference for each Makefile.
For ex. some makefiles use COBJS and the others use COBJS-y. Some use both of them mixed, and sometimes a mistake like above happens. We should use consistently use obj-y, for both C and Assembler objects.
02/18 fixes arch/sh/cpu/{sh2,sh3,sh4}/Makefile. The snippet is as follows:
LIB = $(obj)lib$(CPU).o SOBJS = start.o COBJS = cpu.o interrupts.o watchdog.o SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) SOBJS := $(addprefix $(obj),$(SOBJS)) $(LIB): $(OBJS) $(SOBJS) $(call cmd_link_o_target, $(OBJS) $(SOBJS))
start.o is linked into lib$(CPU).o, but it shouldn't.
03/18 thru 15/18 convert arch-specific, board-specific makefiles.
16/18, 17/18 convert commonly used directories.
16/18 shows another big advantage of switching to Kbuild style. Check how simply post/Makefile was re-written by using obj-$(CONFIG-FOO) += foo/ systax.
18/18 convert the rest of makefiles and abolishes the support for U-Boot conventional makefile. After this commit, we cannot use U-Boot style makefiles any more. (exception: doc/, tools/, nand_spl/, example/ directory) Going forward, we must use only Kbuild style makefiles. Take care when you add a new makefile!
Of course, I tested carefully this series. I built as many boards as possible over all architectures.
Here is the site I downloaded the prebuilt crosstools from:
arm, avr32, m68k, mips, openrisc, powerpc, x86: ftp://ftp.kernel.org/pub/tools/crosstool/files/bin/x86_64/
blackfin, microblaze, nds32, nios2, sh, sparc: http://dev.gentoo.org/~vapier/u-boot/
I could not build some boards because the boards are already broken before this series or the crosstools are not suitable. But I could build more than 1100 target boards and I confirmed this series does no harm.
- 02 thru 18 did not break any boards.
- 02 thru 15 and 17, 18 did not change output ELF files at all. This was check by comparing md5sum.
- It was difficult to simply compare md5sum for patch 16 because it changes how the objects are linked under post/ directory. But I confirmed 16 did not change the section size.
Note: For comparing md5sum, there are some items you should take into account: Disabling time stamp, version, compiling in the same path, linking the objects in the same order... For detailed, refer to [U-Boot] [PATCH 00/19] First step towards Kbuild: Use Kbuild style makefiles Message-Id: 20130917093533.738A.AA925319@jp.panasonic.com
Note2: I confirmed this series can be applied on v2013.10 tag
Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com Cc: Wolfgang Denk wd@denx.de Cc: Gerhard Sittig gsi@denx.de
Dear Masahiro Yamada, Dear Tom Rini,
On 10/21/2013 04:53 AM, Masahiro Yamada wrote:
<snip cover letter for Kbuild introduction>
what is the time line for integrating Kbuild?
I have some changes which would also touch makefiles and wonder if I should wait for Kbuild integration.
Best regards
Andreas Bießmann
Masahiro Yamada (18): sparc: fix a link error sh: Do not include start.o in lib$(CPU).o sparc: convert makefiles to Kbuild style sh: convert makefiles to Kbuild style avr32: convert makefiles to Kbuild style openrisc: convert makefiles to Kbuild style microblaze: convert makefiles to Kbuild style mips: convert makefiles to Kbuild style nds32: convert makefiles to Kbuild style nios2: convert makefiles to Kbuild style x86: convert makefiles to Kbuild style m68k: convert makefiles to Kbuild style blackfin: convert makefiles to Kbuild style board: arm: convert makefiles to Kbuild style board: powerpc: convert makefiles to Kbuild style post: convert makefiles to Kbuild style dts,api,test: convert makefiles to Kbuild style Makefile: convert makefiles to Kbuild style and delete grep switch
Makefile | 40 +++---------- api/Makefile | 18 +----- arch/avr32/cpu/Makefile | 40 +++---------- arch/avr32/cpu/at32ap700x/Makefile | 22 +------ arch/avr32/lib/Makefile | 28 ++------- arch/blackfin/cpu/Makefile | 54 +++++------------ arch/blackfin/lib/Makefile | 52 +++++----------- arch/m68k/cpu/mcf5227x/Makefile | 25 +------- arch/m68k/cpu/mcf523x/Makefile | 25 +------- arch/m68k/cpu/mcf52x2/Makefile | 26 +------- arch/m68k/cpu/mcf532x/Makefile | 25 +------- arch/m68k/cpu/mcf5445x/Makefile | 25 +------- arch/m68k/cpu/mcf547x_8x/Makefile | 25 +------- arch/m68k/lib/Makefile | 33 ++-------- arch/microblaze/cpu/Makefile | 28 +-------- arch/microblaze/lib/Makefile | 27 +-------- arch/mips/cpu/mips32/Makefile | 28 +-------- arch/mips/cpu/mips32/au1x00/Makefile | 23 +------ arch/mips/cpu/mips32/incaip/Makefile | 25 +------- arch/mips/cpu/mips64/Makefile | 24 +------- arch/mips/cpu/xburst/Makefile | 30 +--------- arch/mips/lib/Makefile | 44 ++------------ arch/nds32/cpu/n1213/Makefile | 24 +------- arch/nds32/cpu/n1213/ag101/Makefile | 27 +-------- arch/nds32/cpu/n1213/ag102/Makefile | 27 +-------- arch/nds32/lib/Makefile | 27 ++------- arch/nios2/cpu/Makefile | 30 ++-------- arch/nios2/lib/Makefile | 30 ++-------- arch/openrisc/cpu/Makefile | 26 +------- arch/openrisc/lib/Makefile | 27 +-------- arch/sh/cpu/sh2/Makefile | 24 +------- arch/sh/cpu/sh3/Makefile | 24 +------- arch/sh/cpu/sh4/Makefile | 24 +------- arch/sh/lib/Makefile | 56 ++++------------- arch/sparc/cpu/leon2/Makefile | 27 +-------- arch/sparc/cpu/leon3/Makefile | 27 +-------- arch/sparc/lib/Makefile | 25 +------- arch/x86/config.mk | 2 +- arch/x86/cpu/Makefile | 28 +-------- arch/x86/cpu/coreboot/Makefile | 35 +++-------- arch/x86/lib/Makefile | 56 ++++++----------- board/8dtech/eco5pk/Makefile | 19 +----- board/AndesTech/adp-ag101/Makefile | 21 +------ board/AndesTech/adp-ag101p/Makefile | 21 +------ board/AndesTech/adp-ag102/Makefile | 21 +------ board/Barix/ipam390/Makefile | 21 +------ board/BuS/eb_cpu5282/Makefile | 22 +------ board/BuS/eb_cpux9k2/Makefile | 22 +------ board/BuS/vl_ma2sc/Makefile | 22 +------ board/CarMediaLab/flea3/Makefile | 30 +--------- board/LEOX/elpt860/Makefile | 22 +------ board/LaCie/edminiv2/Makefile | 20 +------ board/LaCie/net2big_v2/Makefile | 29 +-------- board/LaCie/netspace_v2/Makefile | 21 +------ board/LaCie/wireless_space/Makefile | 21 +------ board/Marvell/aspenite/Makefile | 22 +------ board/Marvell/db64360/Makefile | 25 +------- board/Marvell/db64460/Makefile | 25 +------- board/Marvell/dkb/Makefile | 22 +------ board/Marvell/dreamplug/Makefile | 28 +-------- board/Marvell/gplugd/Makefile | 22 +------ board/Marvell/guruplug/Makefile | 22 +------ board/Marvell/mv88f6281gtw_ge/Makefile | 22 +------ board/Marvell/openrd/Makefile | 22 +------ board/Marvell/rd6281a/Makefile | 22 +------ board/Marvell/sheevaplug/Makefile | 22 +------ board/RPXClassic/Makefile | 22 +------ board/RPXlite/Makefile | 22 +------ board/RPXlite_dw/Makefile | 22 +------ board/RRvision/Makefile | 22 +------ board/Seagate/dockstar/Makefile | 22 +------ board/Seagate/goflexhome/Makefile | 22 +------ board/a3000/Makefile | 22 +------ board/a3m071/Makefile | 22 +------ board/a4m072/Makefile | 22 +------ board/actux1/Makefile | 22 +------ board/actux2/Makefile | 22 +------ board/actux3/Makefile | 22 +------ board/actux4/Makefile | 22 +------ board/adder/Makefile | 22 +------ board/afeb9260/Makefile | 24 +------- board/ait/cam_enc_4xx/Makefile | 22 +------ board/alphaproject/ap_sh4a_4a/Makefile | 24 +------- board/altera/nios2-generic/Makefile | 30 ++-------- board/altera/socfpga/Makefile | 30 +--------- board/amcc/acadia/Makefile | 23 +------ board/amcc/bamboo/Makefile | 26 +------- board/amcc/bluestone/Makefile | 27 +-------- board/amcc/bubinga/Makefile | 22 +------ board/amcc/canyonlands/Makefile | 29 +-------- board/amcc/ebony/Makefile | 24 +------- board/amcc/katmai/Makefile | 27 +-------- board/amcc/kilauea/Makefile | 24 +------- board/amcc/luan/Makefile | 24 +------- board/amcc/makalu/Makefile | 23 +------ board/amcc/ocotea/Makefile | 24 +------- board/amcc/redwood/Makefile | 23 +------ board/amcc/sequoia/Makefile | 29 +-------- board/amcc/taihu/Makefile | 21 +------ board/amcc/taishan/Makefile | 24 +------- board/amcc/walnut/Makefile | 22 +------ board/amcc/yosemite/Makefile | 24 +------- board/amcc/yucca/Makefile | 24 +------- board/armadeus/apf27/Makefile | 27 +-------- board/armltd/integrator/Makefile | 28 ++------- board/armltd/versatile/Makefile | 24 +------- board/armltd/vexpress/Makefile | 21 +------ board/astro/mcf5373l/Makefile | 22 +------ board/atc/Makefile | 22 +------ board/atmark-techno/armadillo-800eva/Makefile | 27 +-------- board/atmel/at91rm9200ek/Makefile | 24 +------- board/atmel/at91sam9260ek/Makefile | 26 +------- board/atmel/at91sam9261ek/Makefile | 26 +------- board/atmel/at91sam9263ek/Makefile | 26 +------- board/atmel/at91sam9m10g45ek/Makefile | 24 +------- board/atmel/at91sam9n12ek/Makefile | 22 +------ board/atmel/at91sam9rlek/Makefile | 26 +------- board/atmel/at91sam9x5ek/Makefile | 22 +------ board/atmel/atngw100/Makefile | 21 +------ board/atmel/atngw100mkii/Makefile | 21 +------ board/atmel/atstk1000/Makefile | 21 +------ board/atmel/sama5d3xek/Makefile | 22 +------ board/avionic-design/medcom-wide/Makefile | 22 +------ board/avionic-design/plutux/Makefile | 22 +------ board/avionic-design/tec/Makefile | 22 +------ board/avnet/fx12mm/Makefile | 2 +- board/avnet/v5fx30teval/Makefile | 2 +- board/balloon3/Makefile | 21 +------ board/bc3450/Makefile | 22 +------ board/bct-brettl2/Makefile | 20 +------ board/bf506f-ezkit/Makefile | 22 +------ board/bf518f-ezbrd/Makefile | 22 +------ board/bf525-ucr2/Makefile | 22 +------ board/bf526-ezbrd/Makefile | 22 +------ board/bf527-ad7160-eval/Makefile | 22 +------ board/bf527-ezkit/Makefile | 24 +------- board/bf527-sdp/Makefile | 22 +------ board/bf533-ezkit/Makefile | 22 +------ board/bf533-stamp/Makefile | 26 +------- board/bf537-minotaur/Makefile | 22 +------ board/bf537-pnav/Makefile | 22 +------ board/bf537-srv1/Makefile | 22 +------ board/bf537-stamp/Makefile | 26 +------- board/bf538f-ezkit/Makefile | 22 +------ board/bf548-ezkit/Makefile | 24 +------- board/bf561-acvilon/Makefile | 22 +------ board/bf561-ezkit/Makefile | 22 +------ board/bf609-ezkit/Makefile | 30 +--------- board/blackstamp/Makefile | 22 +------ board/blackvme/Makefile | 22 +------ board/bluegiga/apx4devkit/Makefile | 23 +------ board/bluewater/snapper9260/Makefile | 22 +------ board/boundary/nitrogen6x/Makefile | 21 +------ board/br4/Makefile | 22 +------ board/buffalo/lsxl/Makefile | 22 +------ board/calao/sbc35_a9g20/Makefile | 24 +------- board/calao/tny_a9260/Makefile | 24 +------- board/canmb/Makefile | 25 +------- board/chromebook-x86/coreboot/Makefile | 21 +------ board/cloudengines/pogo_e02/Makefile | 22 +------ board/cm-bf527/Makefile | 22 +------ board/cm-bf533/Makefile | 22 +------ board/cm-bf537e/Makefile | 22 +------ board/cm-bf537u/Makefile | 22 +------ board/cm-bf548/Makefile | 24 +------- board/cm-bf561/Makefile | 22 +------ board/cm4008/Makefile | 22 +------ board/cm41xx/Makefile | 22 +------ board/cm5200/Makefile | 22 +------ board/cmi/Makefile | 22 +------ board/cobra5272/Makefile | 22 +------ board/cogent/Makefile | 22 +------ board/comelit/dig297/Makefile | 21 +------ board/compal/paz00/Makefile | 22 +------ board/compulab/cm_t35/Makefile | 25 +------- board/compulab/trimslice/Makefile | 22 +------ board/congatec/cgtqmx6eval/Makefile | 21 +------ board/corscience/tricorder/Makefile | 21 +------ board/cpc45/Makefile | 22 +------ board/cpu86/Makefile | 22 +------ board/cpu87/Makefile | 22 +------ board/cray/L1/Makefile | 30 +--------- board/creative/xfi3/Makefile | 23 +------ board/csb272/Makefile | 27 +-------- board/csb472/Makefile | 27 +-------- board/cu824/Makefile | 22 +------ board/d-link/dns325/Makefile | 22 +------ board/dave/PPChameleonEVB/Makefile | 22 +------ board/davedenx/aria/Makefile | 23 +------ board/davedenx/qong/Makefile | 24 +------- board/davinci/da8xxevm/Makefile | 27 +-------- board/davinci/dm355evm/Makefile | 22 +------ board/davinci/dm355leopard/Makefile | 22 +------ board/davinci/dm365evm/Makefile | 22 +------ board/davinci/dm6467evm/Makefile | 22 +------ board/davinci/dvevm/Makefile | 23 +------ board/davinci/ea20/Makefile | 23 +------ board/davinci/schmoogie/Makefile | 23 +------ board/davinci/sffsdr/Makefile | 23 +------ board/davinci/sonata/Makefile | 23 +------ board/dbau1x00/Makefile | 24 +------- board/denx/m28evk/Makefile | 23 +------ board/denx/m53evk/Makefile | 21 +------ board/dnp5370/Makefile | 22 +------ board/dvlhost/Makefile | 22 +------ board/eXalion/Makefile | 22 +------ board/earthlcd/favr-32-ezkit/Makefile | 21 +------ board/egnite/ethernut5/Makefile | 24 +------- board/eltec/elppc/Makefile | 25 +------- board/eltec/mhpc/Makefile | 22 +------ board/emk/top5200/Makefile | 21 +------ board/emk/top860/Makefile | 22 +------ board/emk/top9000/Makefile | 24 +------- board/enbw/enbw_cmc/Makefile | 21 +------ board/ep8248/Makefile | 22 +------ board/ep8260/Makefile | 22 +------ board/ep82xxm/Makefile | 21 +------ board/esd/adciop/Makefile | 21 +------ board/esd/apc405/Makefile | 21 +------ board/esd/ar405/Makefile | 21 +------ board/esd/ash405/Makefile | 21 +------ board/esd/cms700/Makefile | 21 +------ board/esd/cpci2dp/Makefile | 21 +------ board/esd/cpci405/Makefile | 23 +------ board/esd/cpci5200/Makefile | 23 +------ board/esd/cpci750/Makefile | 24 +------- board/esd/cpciiser4/Makefile | 21 +------ board/esd/dasa_sim/Makefile | 21 +------ board/esd/dp405/Makefile | 21 +------ board/esd/du405/Makefile | 21 +------ board/esd/du440/Makefile | 26 +------- board/esd/hh405/Makefile | 21 +------ board/esd/hub405/Makefile | 21 +------ board/esd/mecp5123/Makefile | 23 +------ board/esd/mecp5200/Makefile | 22 +------ board/esd/meesc/Makefile | 24 +------- board/esd/ocrtc/Makefile | 21 +------ board/esd/otc570/Makefile | 24 +------- board/esd/pci405/Makefile | 24 +------- board/esd/pf5200/Makefile | 23 +------ board/esd/plu405/Makefile | 21 +------ board/esd/pmc405/Makefile | 21 +------ board/esd/pmc405de/Makefile | 26 +------- board/esd/pmc440/Makefile | 26 +------- board/esd/tasreg/Makefile | 22 +------ board/esd/vme8349/Makefile | 25 +------- board/esd/voh405/Makefile | 21 +------ board/esd/vom405/Makefile | 21 +------ board/esd/wuh405/Makefile | 21 +------ board/esg/ima3-mx53/Makefile | 21 +------ board/espt/Makefile | 24 +------- board/esteem192e/Makefile | 22 +------ board/etin/debris/Makefile | 22 +------ board/etin/kvme080/Makefile | 22 +------ board/eukrea/cpu9260/Makefile | 24 +------- board/eukrea/cpuat91/Makefile | 22 +------ board/evb64260/Makefile | 24 +------- board/exmeritus/hww1u1a/Makefile | 28 ++------- board/fads/Makefile | 22 +------ board/faraday/a320evb/Makefile | 24 +------- board/flagadm/Makefile | 22 +------ board/freescale/b4860qds/Makefile | 38 ++---------- board/freescale/bsc9131rdb/Makefile | 38 ++---------- board/freescale/bsc9132qds/Makefile | 37 ++---------- board/freescale/c29xpcie/Makefile | 30 ++-------- board/freescale/common/Makefile | 86 +++++++++------------------ board/freescale/common/p_corenet/Makefile | 11 ++-- board/freescale/corenet_ds/Makefile | 40 ++++--------- board/freescale/m5208evbe/Makefile | 22 +------ board/freescale/m52277evb/Makefile | 22 +------ board/freescale/m5235evb/Makefile | 22 +------ board/freescale/m5249evb/Makefile | 22 +------ board/freescale/m5253demo/Makefile | 22 +------ board/freescale/m5253evbe/Makefile | 22 +------ board/freescale/m5271evb/Makefile | 22 +------ board/freescale/m5272c3/Makefile | 22 +------ board/freescale/m5275evb/Makefile | 22 +------ board/freescale/m5282evb/Makefile | 22 +------ board/freescale/m53017evb/Makefile | 22 +------ board/freescale/m5329evb/Makefile | 22 +------ board/freescale/m5373evb/Makefile | 22 +------ board/freescale/m54418twr/Makefile | 22 +------ board/freescale/m54451evb/Makefile | 22 +------ board/freescale/m54455evb/Makefile | 22 +------ board/freescale/m547xevb/Makefile | 22 +------ board/freescale/m548xevb/Makefile | 22 +------ board/freescale/mpc5121ads/Makefile | 25 +------- board/freescale/mpc7448hpc2/Makefile | 24 +------- board/freescale/mpc8260ads/Makefile | 22 +------ board/freescale/mpc8266ads/Makefile | 22 +------ board/freescale/mpc8308rdb/Makefile | 22 +------ board/freescale/mpc8313erdb/Makefile | 22 +------ board/freescale/mpc8315erdb/Makefile | 22 +------ board/freescale/mpc8323erdb/Makefile | 22 +------ board/freescale/mpc832xemds/Makefile | 25 +------- board/freescale/mpc8349emds/Makefile | 27 +-------- board/freescale/mpc8349itx/Makefile | 24 +------- board/freescale/mpc8360emds/Makefile | 25 +------- board/freescale/mpc8360erdk/Makefile | 25 +------- board/freescale/mpc837xemds/Makefile | 25 +------- board/freescale/mpc837xerdb/Makefile | 25 +------- board/freescale/mpc8536ds/Makefile | 28 ++------- board/freescale/mpc8540ads/Makefile | 28 ++------- board/freescale/mpc8541cds/Makefile | 28 ++------- board/freescale/mpc8544ds/Makefile | 28 ++------- board/freescale/mpc8548cds/Makefile | 28 ++------- board/freescale/mpc8555cds/Makefile | 28 ++------- board/freescale/mpc8560ads/Makefile | 28 ++------- board/freescale/mpc8568mds/Makefile | 30 ++-------- board/freescale/mpc8569mds/Makefile | 30 ++-------- board/freescale/mpc8572ds/Makefile | 28 ++------- board/freescale/mpc8610hpcd/Makefile | 29 ++------- board/freescale/mpc8641hpcn/Makefile | 26 +------- board/freescale/mx23evk/Makefile | 23 +------ board/freescale/mx25pdk/Makefile | 24 +------- board/freescale/mx28evk/Makefile | 23 +------ board/freescale/mx31ads/Makefile | 24 +------- board/freescale/mx31pdk/Makefile | 24 +------- board/freescale/mx35pdk/Makefile | 24 +------- board/freescale/mx51evk/Makefile | 24 +------- board/freescale/mx53ard/Makefile | 21 +------ board/freescale/mx53evk/Makefile | 21 +------ board/freescale/mx53loco/Makefile | 24 +------- board/freescale/mx53smd/Makefile | 21 +------ board/freescale/mx6qarm2/Makefile | 21 +------ board/freescale/mx6qsabreauto/Makefile | 21 +------ board/freescale/mx6sabresd/Makefile | 21 +------ board/freescale/mx6slevk/Makefile | 21 +------ board/freescale/p1010rdb/Makefile | 30 ++-------- board/freescale/p1022ds/Makefile | 34 +++-------- board/freescale/p1023rdb/Makefile | 28 ++------- board/freescale/p1023rds/Makefile | 26 +------- board/freescale/p1_p2_rdb/Makefile | 30 ++-------- board/freescale/p1_p2_rdb_pc/Makefile | 30 ++-------- board/freescale/p1_twr/Makefile | 34 ++--------- board/freescale/p2020come/Makefile | 28 ++------- board/freescale/p2020ds/Makefile | 28 ++------- board/freescale/p2041rdb/Makefile | 28 ++------- board/freescale/t4qds/Makefile | 40 +++---------- board/freescale/titanium/Makefile | 21 +------ board/freescale/vf610twr/Makefile | 21 +------ board/friendlyarm/mini2440/Makefile | 22 +------ board/funkwerk/vovpn-gw/Makefile | 22 +------ board/g2000/Makefile | 22 +------ board/gaisler/gr_cpci_ax2000/Makefile | 23 +------ board/gaisler/gr_ep2s60/Makefile | 23 +------ board/gaisler/gr_xc3s_1500/Makefile | 23 +------ board/gaisler/grsim/Makefile | 22 +------ board/gaisler/grsim_leon2/Makefile | 22 +------ board/galaxy5200/Makefile | 22 +------ board/gdsys/405ep/Makefile | 32 ++-------- board/gdsys/405ex/Makefile | 33 +--------- board/gdsys/common/Makefile | 40 ++----------- board/gdsys/dlvision/Makefile | 23 +------ board/gdsys/gdppc440etx/Makefile | 24 +------- board/gdsys/intip/Makefile | 29 +-------- board/gdsys/p1022/Makefile | 34 ++--------- board/gen860t/Makefile | 22 +------ board/genesi/mx51_efikamx/Makefile | 21 +------ board/genietv/Makefile | 22 +------ board/gw8260/Makefile | 23 +------ board/h2200/Makefile | 23 +------ board/hale/tt01/Makefile | 29 +-------- board/hermes/Makefile | 22 +------ board/hidden_dragon/Makefile | 22 +------ board/highbank/Makefile | 27 +-------- board/htkw/mcx/Makefile | 19 +----- board/hymod/Makefile | 22 +------ board/ibf-dsp561/Makefile | 22 +------ board/icecube/Makefile | 22 +------ board/icpdas/lp8x4x/Makefile | 21 +------ board/icu862/Makefile | 22 +------ board/idmr/Makefile | 22 +------ board/ids8247/Makefile | 22 +------ board/ifm/ac14xx/Makefile | 23 +------ board/ifm/o2dnt2/Makefile | 22 +------ board/imx31_phycore/Makefile | 24 +------- board/in-circuit/grasshopper/Makefile | 21 +------ board/incaip/Makefile | 24 +------- board/inka4x0/Makefile | 22 +------ board/intercontrol/digsy_mtc/Makefile | 24 +------- board/iomega/iconnect/Makefile | 22 +------ board/ip04/Makefile | 22 +------ board/ip860/Makefile | 22 +------ board/ipek01/Makefile | 22 +------ board/iphase4539/Makefile | 22 +------ board/isee/igep0033/Makefile | 29 +-------- board/isee/igep00x0/Makefile | 21 +------ board/ispan/Makefile | 22 +------ board/ivm/Makefile | 22 +------ board/jornada/Makefile | 24 +------- board/jse/Makefile | 24 +------- board/jupiter/Makefile | 22 +------ board/karo/tk71/Makefile | 22 +------ board/karo/tx25/Makefile | 23 +------ board/keymile/km82xx/Makefile | 22 +------ board/keymile/km83xx/Makefile | 21 +------ board/keymile/km_arm/Makefile | 23 +------ board/kmc/kzm9g/Makefile | 28 +-------- board/korat/Makefile | 26 +------- board/kup/kup4k/Makefile | 21 +------ board/kup/kup4x/Makefile | 21 +------ board/linkstation/Makefile | 21 +------ board/logicpd/am3517evm/Makefile | 19 +----- board/logicpd/imx27lite/Makefile | 23 +------ board/logicpd/imx31_litekit/Makefile | 24 +------- board/logicpd/omap3som/Makefile | 20 +------ board/logicpd/zoom1/Makefile | 21 +------ board/logicpd/zoom2/Makefile | 28 ++------- board/lubbock/Makefile | 21 +------ board/lwmon/Makefile | 22 +------ board/lwmon5/Makefile | 26 +------- board/manroland/hmi1001/Makefile | 22 +------ board/manroland/mucmc52/Makefile | 22 +------ board/manroland/uc100/Makefile | 23 +------ board/manroland/uc101/Makefile | 22 +------ board/matrix_vision/common/Makefile | 26 +------- board/matrix_vision/mergerbox/Makefile | 23 +------ board/matrix_vision/mvbc_p/Makefile | 19 +----- board/matrix_vision/mvblm7/Makefile | 23 ++----- board/matrix_vision/mvblx/Makefile | 24 +------- board/matrix_vision/mvsmr/Makefile | 21 ++----- board/mbx8xx/Makefile | 22 +------ board/mcc200/Makefile | 22 +------ board/micronas/vct/Makefile | 37 +++--------- board/mimc/mimc200/Makefile | 21 +------ board/miromico/hammerhead/Makefile | 21 +------ board/mosaixtech/icon/Makefile | 27 +-------- board/motionpro/Makefile | 22 +------ board/mousse/Makefile | 21 +------ board/mpc8308_p1m/Makefile | 22 +------ board/mpl/mip405/Makefile | 24 +------- board/mpl/pati/Makefile | 21 +------ board/mpl/pip405/Makefile | 24 +------- board/mpl/vcma9/Makefile | 25 +------- board/mpr2/Makefile | 24 +------- board/ms7720se/Makefile | 24 +------- board/ms7722se/Makefile | 24 +------- board/ms7750se/Makefile | 23 +------ board/muas3001/Makefile | 22 +------ board/munices/Makefile | 22 +------ board/musenki/Makefile | 22 +------ board/mvblue/Makefile | 22 +------ board/mx1ads/Makefile | 24 +------- board/netphone/Makefile | 22 +------ board/netta/Makefile | 22 +------ board/netta2/Makefile | 22 +------ board/netvia/Makefile | 22 +------ board/nokia/rx51/Makefile | 25 +------- board/nvidia/beaver/Makefile | 21 +------ board/nvidia/cardhu/Makefile | 21 +------ board/nvidia/common/Makefile | 26 -------- board/nvidia/common/common.mk | 4 +- board/nvidia/dalmore/Makefile | 21 +------ board/nvidia/harmony/Makefile | 21 +------ board/nvidia/seaboard/Makefile | 21 +------ board/nvidia/ventana/Makefile | 21 +------ board/nvidia/whistler/Makefile | 21 +------ board/nx823/Makefile | 22 +------ board/olimex/mx23_olinuxino/Makefile | 23 +------ board/omicron/calimain/Makefile | 21 +------ board/openrisc/openrisc-generic/Makefile | 21 +------ board/overo/Makefile | 20 +------ board/palmld/Makefile | 21 +------ board/palmtc/Makefile | 22 +------ board/palmtreo680/Makefile | 27 +-------- board/pandora/Makefile | 21 +------ board/pb1x00/Makefile | 24 +------- board/pcs440ep/Makefile | 24 +------- board/pdm360ng/Makefile | 23 +------ board/phytec/pcm030/Makefile | 22 +------ board/phytec/pcm051/Makefile | 29 +-------- board/pm520/Makefile | 22 +------ board/pm826/Makefile | 22 +------ board/pm828/Makefile | 22 +------ board/pn62/Makefile | 22 +------ board/ppmc7xx/Makefile | 25 +------- board/ppmc8260/Makefile | 22 +------ board/pr1/Makefile | 22 +------ board/prodrive/alpr/Makefile | 24 +------- board/prodrive/p3mx/Makefile | 23 +------ board/prodrive/p3p440/Makefile | 24 +------- board/prodrive/pdnb3/Makefile | 22 +------ board/psyent/pci5441/Makefile | 23 +------ board/psyent/pk1c20/Makefile | 23 +------ board/pxa255_idp/Makefile | 21 +------ board/qemu-malta/Makefile | 24 +------- board/qemu-mips/Makefile | 24 +------- board/quad100hd/Makefile | 23 +------ board/quantum/Makefile | 22 +------ board/r360mpi/Makefile | 22 +------ board/raidsonic/ib62x0/Makefile | 22 +------ board/raspberrypi/rpi_b/Makefile | 21 +------ board/rattler/Makefile | 22 +------ board/rbc823/Makefile | 22 +------ board/renesas/MigoR/Makefile | 24 +------- board/renesas/ap325rxa/Makefile | 24 +------- board/renesas/ecovec/Makefile | 25 +------- board/renesas/r0p7734/Makefile | 24 +------- board/renesas/r2dplus/Makefile | 23 +------ board/renesas/r7780mp/Makefile | 24 +------- board/renesas/rsk7203/Makefile | 24 +------- board/renesas/rsk7264/Makefile | 22 +------ board/renesas/rsk7269/Makefile | 22 +------ board/renesas/sh7752evb/Makefile | 20 +------ board/renesas/sh7757lcr/Makefile | 20 +------ board/renesas/sh7763rdp/Makefile | 24 +------- board/renesas/sh7785lcr/Makefile | 24 +------- board/ronetix/pm9261/Makefile | 26 +------- board/ronetix/pm9263/Makefile | 26 +------- board/ronetix/pm9g45/Makefile | 22 +------ board/rpxsuper/Makefile | 22 +------ board/rsdproto/Makefile | 24 +------- board/sacsng/Makefile | 22 +------ board/samsung/arndale/Makefile | 27 +-------- board/samsung/common/Makefile | 21 +------ board/samsung/goni/Makefile | 24 +------- board/samsung/origen/Makefile | 28 +-------- board/samsung/smdk2410/Makefile | 24 +------- board/samsung/smdk5250/Makefile | 29 +-------- board/samsung/smdkc100/Makefile | 26 +------- board/samsung/smdkv310/Makefile | 28 +-------- board/samsung/trats/Makefile | 21 +------ board/samsung/trats2/Makefile | 28 +-------- board/samsung/universal_c210/Makefile | 22 +------ board/sandburst/karef/Makefile | 27 +-------- board/sandburst/metrobox/Makefile | 26 +------- board/sandisk/sansa_fuze_plus/Makefile | 23 +------ board/sandpoint/Makefile | 22 +------ board/sbc405/Makefile | 22 +------ board/sbc8349/Makefile | 25 +------- board/sbc8548/Makefile | 28 ++------- board/sbc8641d/Makefile | 26 +------- board/sc3/Makefile | 24 +------- board/scb9328/Makefile | 24 +------- board/schulercontrol/sc_sps_1/Makefile | 23 +------ board/sheldon/simpc8313/Makefile | 22 +------ board/shmin/Makefile | 24 +------- board/siemens/dxr2/Makefile | 30 +--------- board/siemens/pxm2/Makefile | 30 +--------- board/siemens/rut/Makefile | 30 +--------- board/sixnet/Makefile | 22 +------ board/snmc/qs850/Makefile | 22 +------ board/snmc/qs860t/Makefile | 22 +------ board/socrates/Makefile | 33 ++-------- board/spc1920/Makefile | 22 +------ board/spd8xx/Makefile | 22 +------ board/spear/common/Makefile | 27 +-------- board/spear/spear300/Makefile | 23 +------ board/spear/spear310/Makefile | 23 +------ board/spear/spear320/Makefile | 23 +------ board/spear/spear600/Makefile | 23 +------ board/spear/x600/Makefile | 23 +------ board/st-ericsson/snowball/Makefile | 26 +------- board/st-ericsson/u8500/Makefile | 21 +------ board/st/nhk8815/Makefile | 23 +------ board/stx/stxgp3/Makefile | 30 ++-------- board/stx/stxssa/Makefile | 28 ++------- board/stx/stxxtc/Makefile | 22 +------ board/svm_sc8xx/Makefile | 22 +------ board/syteco/jadecpu/Makefile | 24 +------- board/syteco/zmx25/Makefile | 24 +------- board/t3corp/Makefile | 29 +-------- board/taskit/stamp9g20/Makefile | 24 +------- board/tcm-bf518/Makefile | 22 +------ board/tcm-bf537/Makefile | 22 +------ board/technexion/twister/Makefile | 19 +----- board/teejet/mt_ventoux/Makefile | 19 +----- board/timll/devkit3250/Makefile | 22 +------ board/timll/devkit8000/Makefile | 21 +------ board/toradex/colibri_pxa270/Makefile | 21 +------ board/toradex/colibri_t20_iris/Makefile | 25 +------- board/total5200/Makefile | 22 +------ board/tqc/tqm5200/Makefile | 24 +------- board/tqc/tqm8260/Makefile | 21 +------ board/tqc/tqm8272/Makefile | 21 +------ board/tqc/tqm834x/Makefile | 25 +------- board/tqc/tqm8xx/Makefile | 22 +------ board/trizepsiv/Makefile | 21 +------ board/ttcontrol/vision2/Makefile | 21 +------ board/utx8245/Makefile | 22 +------ board/v37/Makefile | 22 +------ board/v38b/Makefile | 22 +------ board/ve8313/Makefile | 22 +------ board/vpac270/Makefile | 23 +------ board/w7o/Makefile | 24 +------- board/wandboard/Makefile | 21 +------ board/woodburn/Makefile | 24 +------- board/xaeniax/Makefile | 21 +------ board/xes/common/Makefile | 38 +++--------- board/xes/xpedite1000/Makefile | 24 +------- board/xes/xpedite517x/Makefile | 26 +------- board/xes/xpedite520x/Makefile | 28 ++------- board/xes/xpedite537x/Makefile | 28 ++------- board/xes/xpedite550x/Makefile | 28 ++------- board/xilinx/microblaze-generic/Makefile | 22 +------ board/xilinx/ml507/Makefile | 2 +- board/xilinx/ppc405-generic/Makefile | 21 +------ board/xilinx/ppc440-generic/Makefile | 23 +------ board/xilinx/zynq/Makefile | 29 +-------- board/zeus/Makefile | 23 +------ board/zipitz2/Makefile | 21 +------ board/zpc1900/Makefile | 22 +------ dts/Makefile | 24 +------- post/Makefile | 65 ++++---------------- post/board/lwmon/Makefile | 7 +-- post/board/lwmon5/Makefile | 7 +-- post/board/netta/Makefile | 7 +-- post/board/pdm360ng/Makefile | 7 +-- post/cpu/mpc83xx/Makefile | 8 +-- post/cpu/mpc8xx/Makefile | 9 +-- post/cpu/ppc4xx/Makefile | 23 ++++--- post/drivers/Makefile | 7 +-- post/lib_powerpc/Makefile | 13 ++-- post/lib_powerpc/fpu/Makefile | 24 ++++---- post/rules.mk | 30 ---------- spl/Makefile | 25 ++------ test/Makefile | 26 +------- 618 files changed, 1209 insertions(+), 13474 deletions(-) delete mode 100644 post/rules.mk
For the series, applied to u-boot/master, thanks!
participants (5)
Andreas Bießmann
Masahiro Yamada
Sonic Zhang
