[U-Boot] [PATCH] blackfin: gpio: Use proper mask for comparing function
The function return from P_FUNCT2MUX(per) takes 2 bits, however for BF537_FAMILY with offset != 1 the function is 1 bit.
Also has small refactor for better readability. In portmux_setup(), it looks odd having "muxreg &= ~(3 << 1);" while in current code we do muxreg |= (function << offset);.
Signed-off-by: Axel Lin axel.lin@ingics.com --- arch/blackfin/cpu/gpio.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/blackfin/cpu/gpio.c b/arch/blackfin/cpu/gpio.c index f74a0b7..c4cddaf 100644 --- a/arch/blackfin/cpu/gpio.c +++ b/arch/blackfin/cpu/gpio.c @@ -247,7 +247,7 @@ static struct {
static void portmux_setup(unsigned short per) { - u16 y, offset, muxreg; + u16 y, offset, muxreg, mask; u16 function = P_FUNCT2MUX(per);
for (y = 0; y < ARRAY_SIZE(port_mux_lut); y++) { @@ -258,12 +258,13 @@ static void portmux_setup(unsigned short per) offset = port_mux_lut[y].offset; muxreg = bfin_read_PORT_MUX();
- if (offset != 1) - muxreg &= ~(1 << offset); + if (offset == 1) + mask = 3; else - muxreg &= ~(3 << 1); + mask = 1;
- muxreg |= (function << offset); + muxreg &= ~(mask << offset); + muxreg |= ((function & mask) << offset); bfin_write_PORT_MUX(muxreg); } }
Acked-by: Sonic Zhang sonic.zhang@analog.com
u16 y, offset, muxreg, mask; u16 function = P_FUNCT2MUX(per); for (y = 0; y < ARRAY_SIZE(port_mux_lut); y++) {
if (offset != 1)
if (offset == 1)
mask = 3; else
mask = 1;
-- 1.8.1.2
Axel Lin
Sonic Zhang
