[U-Boot] [PATCH 0/9] arm/km: bugfixes and small corrections
This patchseris extracts the bugfixes and minor adaptions of the already posted patchserie http://lists.denx.de/pipermail/u-boot/2012-May/124413.html as requested.
There are now changes in the patches compared to the previous serie.
cc: Prafulla Wadaskar prafulla@marvell.com cc: Holger Brunck holger.brunck@keymile.com cc: Valentin Longchamp valentin.longchamp@keymile.com
Holger Brunck (7): arm/km: add board type to boards.cfg arm/km: add piggy mac adress offset for mgcoge3un arm/km: rename CONFIG option CONFIG_KM_DEF_ENV_UPDATE arm/km: use ARRAY_SIZE macro arm/km: fix wrong comment in SDRAM config for mgcoge3un arm/km: change maintainer for mgcoge3un arm/km: remove CONFIG_RESET_PHY_R
Valentin Longchamp (2): arm/km: enable mii cmd km_arm: use filesize for erase in update command
MAINTAINERS | 2 +- board/keymile/km_arm/km_arm.c | 2 +- board/keymile/km_arm/kwbimage-memphis.cfg | 2 +- boards.cfg | 4 ++-- include/configs/km/km_arm.h | 8 ++++---- include/configs/km_kirkwood.h | 4 ++-- include/configs/mgcoge3un.h | 1 + 7 files changed, 12 insertions(+), 11 deletions(-)
Some other kirkwood boards from keymile will follow. They will have some small differences, but we want to use the km_kirkwood.h for all to distinguish them. This patch a preparation for this.
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- boards.cfg | 4 ++-- include/configs/km_kirkwood.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 0dee43f..b711e0d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -138,8 +138,8 @@ enbw_cmc arm arm926ejs enbw_cmc enbw calimain arm arm926ejs calimain omicron davinci pogo_e02 arm arm926ejs - cloudengines kirkwood dns325 arm arm926ejs - d-link kirkwood -km_kirkwood arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_DISABLE_PCI -km_kirkwood_pci arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_RECONFIG_XLX +km_kirkwood arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_KIRKWOOD,KM_DISABLE_PCI +km_kirkwood_pci arm arm926ejs km_arm keymile kirkwood km_kirkwood:KM_KIRKWOOD_PCI,KM_RECONFIG_XLX mgcoge3un arm arm926ejs km_arm keymile kirkwood portl2 arm arm926ejs km_arm keymile kirkwood inetspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood lacie_kw:INETSPACE_V2 diff --git a/include/configs/km_kirkwood.h b/include/configs/km_kirkwood.h index ed36124..f639edc 100644 --- a/include/configs/km_kirkwood.h +++ b/include/configs/km_kirkwood.h @@ -42,10 +42,10 @@ /* * Version number information */ -#ifdef CONFIG_KM_DISABLE_PCI +#if defined(CONFIG_KM_KIRKWOOD) #define CONFIG_IDENT_STRING "\nKeymile Kirkwood" #undef CONFIG_KIRKWOOD_PCIE_INIT -#else +#elif defined(CONFIG_KM_KIRKWOOD_PCI) #define CONFIG_IDENT_STRING "\nKeymile Kirkwood PCI" #endif
On mgcoge3un the piggy mac adress is at offset 3.
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- include/configs/mgcoge3un.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/mgcoge3un.h b/include/configs/mgcoge3un.h index 797b0df..156821c 100644 --- a/include/configs/mgcoge3un.h +++ b/include/configs/mgcoge3un.h @@ -77,6 +77,7 @@ MVGBE_SET_MII_SPEED_TO_100)
#define CONFIG_KM_BOARD_EXTRA_ENV "waitforne=true\0" +#define CONFIG_PIGGY_MAC_ADRESS_OFFSET 3
/* * PCIe port not used on mgcoge3un
This config option sounds like the it is responsible for the update of the environment, but it is the u-boot update handling. Therefore we adapt it to a more apropriate naming.
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- include/configs/km/km_arm.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index c73a10c..e46b510 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -81,7 +81,7 @@ "boot=bootm ${load_addr_r} - -\0" \ "cramfsloadfdt=true\0" \ "u-boot="xstr(CONFIG_HOSTNAME) "/u-boot.kwb\0" \ - CONFIG_KM_DEF_ENV_UPDATE \ + CONFIG_KM_UPDATE_UBOOT \ ""
#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ @@ -235,7 +235,7 @@ int get_scl(void); "orion_nand:" \ "-(" CONFIG_KM_UBI_PARTITION_NAME ")"
-#define CONFIG_KM_DEF_ENV_UPDATE \ +#define CONFIG_KM_UPDATE_UBOOT \ "update=" \ "spi on;sf probe 0;sf erase 0 50000;" \ "sf write ${load_addr_r} 0 ${filesize};" \
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- board/keymile/km_arm/km_arm.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index 9e9940c..c6c9a71 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -410,7 +410,7 @@ const ulong patterns[] = { 0x00000000, 0xFF00FF00, 0x0F0F0F0F, 0xF0F0F0F0}; -const ulong NBR_OF_PATTERNS = sizeof(patterns)/sizeof(*patterns); +const ulong NBR_OF_PATTERNS = ARRAY_SIZE(patterns); const ulong OFFS_PATTERN = 3; const ulong REPEAT_PATTERN = 1000;
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- board/keymile/km_arm/kwbimage-memphis.cfg | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/keymile/km_arm/kwbimage-memphis.cfg b/board/keymile/km_arm/kwbimage-memphis.cfg index 2faaf2b..6df2ad7 100644 --- a/board/keymile/km_arm/kwbimage-memphis.cfg +++ b/board/keymile/km_arm/kwbimage-memphis.cfg @@ -149,7 +149,7 @@ DATA 0xFFD01424 0x0000F17F # DDR Controller Control High DATA 0xFFD01428 0x00084520 # DDR2 SDRAM Timing Low # bit3-0 : 0000, required # bit7-4 : 0010, M_ODT assertion 2 cycles after read -# bit11-8 : 1001, M_ODT de-assertion 5 cycles after read +# bit11-8 : 0101, M_ODT de-assertion 5 cycles after read # bit15-12: 0100, internal ODT assertion 4 cycles after read # bit19-16: 1000, internal ODT de-assertion 8 cycles after read # bit31-20: 0 , required
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com Acked-By: Heiko Schocher hs@denx.de cc: Prafulla Wadaskar prafulla@marvell.com cc: Gerlando Falauto gerlando.falauto@keymile.com --- MAINTAINERS | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index f796872..0445539 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -738,6 +738,7 @@ Sergey Lapin slapin@ossfans.org Valentin Longchamp valentin.longchamp@keymile.com
km_kirkwood ARM926EJS (Kirkwood SoC) + mgcoge3un ARM926EJS (Kirkwood SoC) portl2 ARM926EJS (Kirkwood SoC)
Nishanth Menon nm@ti.com @@ -848,7 +849,6 @@ Heiko Schocher hs@denx.de
enbw_cmc ARM926EJS (AM1808 SoC) magnesium i.MX27 - mgcoge3un ARM926EJS (Kirkwood SoC)
Michael Schwingen michael@schwingen.org
This is already defined in the generic kirkwood header.
Signed-off-by: Holger Brunck holger.brunck@keymile.com Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- include/configs/km/km_arm.h | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index e46b510..76666ef 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -164,7 +164,6 @@ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0 #define CONFIG_ENV_OVERWRITE /* ethaddr can be reprogrammed */ -#define CONFIG_RESET_PHY_R /* use reset_phy() to init 88E1118 PHY */
/* * UBI related stuff
From: Valentin Longchamp valentin.longchamp@keymile.com
This is useful to debug the switch initialization
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- include/configs/km/km_arm.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 76666ef..36eb765 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -159,6 +159,7 @@ */ #define CONFIG_NETCONSOLE /* include NetConsole support */ #define CONFIG_MII /* expose smi ove miiphy interface */ +#define CONFIG_CMD_MII /* to debug mdio phy config */ #define CONFIG_MVGBE /* Enable Marvell Gbe Controller Driver */ #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN /* detect link using phy */ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */
We used to have an arbitrary value, which can be a problem if we have a u-boot image that is bigger than this value.
This patch is dependant on the whole km/arm series and will be included in the v3 of the series if there is one.
Signed-off-by: Valentin Longchamp valentin.longchamp@keymile.com cc: Holger Brunck holger.brunck@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com --- include/configs/km/km_arm.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index 36eb765..eb60d29 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -237,7 +237,7 @@ int get_scl(void);
#define CONFIG_KM_UPDATE_UBOOT \ "update=" \ - "spi on;sf probe 0;sf erase 0 50000;" \ + "spi on;sf probe 0;sf erase 0 +${filesize};" \ "sf write ${load_addr_r} 0 ${filesize};" \ "spi off\0"
-----Original Message----- From: Holger Brunck [mailto:holger.brunck@keymile.com] Sent: 25 May 2012 17:27 To: u-boot@lists.denx.de Cc: Holger Brunck; Prafulla Wadaskar; Valentin Longchamp Subject: [PATCH 0/9] arm/km: bugfixes and small corrections
This patchseris extracts the bugfixes and minor adaptions of the already posted patchserie http://lists.denx.de/pipermail/u-boot/2012- May/124413.html as requested.
Applied to u-boot-marvell.git master branch
Regards.. Prafulla . . .
Holger Brunck
Prafulla Wadaskar
