[U-Boot] [PATCH] ARM: tegra: implement WAR for Tegra114 CPU reset vector
A Tegra114 HW bug prevents the main CPU vector from being modified under certain circumstances. Tegra114 A01P and later with a patched boot ROM set the CPU reset vector to 0x4003fffc (end of IRAM). This allows placing an arbitrary jump instruction at that location, in order to redirect to the desired reset vector location. Modify Tegra114's start_cpu() to make use of this feature. This allows CPUs with the patched boot ROM to boot.
Based-on-work-by: Jimmy Zhang jimmzhang@nvidia.com. Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/cpu/arm720t/tegra114/cpu.c | 36 +++++++++++++++++++++++++++++++---- 1 file changed, 32 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/arm720t/tegra114/cpu.c b/arch/arm/cpu/arm720t/tegra114/cpu.c index 5962e15..429ac94 100644 --- a/arch/arm/cpu/arm720t/tegra114/cpu.c +++ b/arch/arm/cpu/arm720t/tegra114/cpu.c @@ -269,6 +269,8 @@ void powerup_cpus(void)
void start_cpu(u32 reset_vector) { + u32 imme, inst; + debug("start_cpu entry, reset_vector = %x\n", reset_vector);
t114_init_clocks(); @@ -285,12 +287,38 @@ void start_cpu(u32 reset_vector) /* Take CPU(s) out of reset */ remove_cpu_resets();
+ /* Set the entry point for CPU execution from reset */ + /* - * Set the entry point for CPU execution from reset, - * if it's a non-zero value. + * A01P with patched boot ROM; vector hard-coded to 0x4003fffc. + * See nvbug 1193357 for details. */ - if (reset_vector) - writel(reset_vector, EXCEP_VECTOR_CPU_RESET_VECTOR); + + /* mov r0, #lsb(reset_vector) */ + imme = reset_vector & 0xffff; + inst = imme & 0xfff; + inst |= ((imme >> 12) << 16); + inst |= 0xe3000000; + writel(inst, 0x4003fff0); + + /* movt r0, #msb(reset_vector) */ + imme = (reset_vector >> 16) & 0xffff; + inst = imme & 0xfff; + inst |= ((imme >> 12) << 16); + inst |= 0xe3400000; + writel(inst, 0x4003fff4); + + /* bx r0 */ + writel(0xe12fff10, 0x4003fff8); + + /* b -12 */ + imme = (u32)-20; + inst = (imme >> 2) & 0xffffff; + inst |= 0xea000000; + writel(inst, 0x4003fffc); + + /* Write to orignal location for compatibility */ + writel(reset_vector, EXCEP_VECTOR_CPU_RESET_VECTOR);
/* If the CPU(s) don't already have power, power 'em up */ powerup_cpus();
Stephen Warren
