[U-Boot] [PATCH v3 1/2] cmd: nvedit: env import can now import only variables passed as parameters
While the `env export` can take as parameters variables to be exported, `env import` does not have such a mechanism of variable selection.
Let's add the ability to add parameters at the end of the command for variables to be imported.
Every env variable from the env to be imported passed by parameter to this command will override the value of the variable in the current env.
If a variable exists in the current env but not in the imported env, if this variable is passed as a parameter to env import, the variable will be unset.
If a variable exists in the imported env, the variable in the current env will be set to the value of the one from the imported env.
All the remaining variables are left untouched.
As the size parameter of env import is positional but optional, let's add the possibility to use the sentinel '-' for when we don't want to give the size parameter (when the env is '\0' terminated) but we pass a list of variables at the end of the command.
env import addr env import addr - env import addr size env import addr - foo1 foo2 env import addr size foo1 foo2
are all valid.
env import -c addr env import -c addr - env import -c addr - foo1 foo2
are all invalid because they don't pass the size parameter required for checking, while the following are valid.
env import addr size env import addr size foo1 foo2
Nothing's changed for the other parameters or the overall behaviour.
One of its use case could be to load a secure environment from the signed U-Boot binary and load only a handful of variables from an other, unsecure, environment without completely losing control of U-Boot.
Signed-off-by: Quentin Schulz quentin.schulz@bootlin.com ---
v3: - migrate to env import addr size var... instead of env import -w addr size so that the list of variables to load is more explicit and the behaviour of env import is closer to the one of env export,
v2: - use strdup instead of malloc + strcpy, - NULL-check the result of strdup, - add common exit path for freeing memory in one unique place, - store token pointer from strtok within the char** array instead of strdup-ing token within elements of array,
cmd/nvedit.c | 22 ++++++++++++++++------ 1 file changed, 16 insertions(+), 6 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 11489b0..18cc4db 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -1001,7 +1001,7 @@ sep_err:
#ifdef CONFIG_CMD_IMPORTENV /* - * env import [-d] [-t [-r] | -b | -c] addr [size] + * env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] * -d: delete existing environment before importing; * otherwise overwrite / append to existing definitions * -t: assume text format; either "size" must be given or the @@ -1015,6 +1015,11 @@ sep_err: * addr: memory address to read from * size: length of input data; if missing, proper '\0' * termination is mandatory + * if var is set and size should be missing (i.e. '\0' + * termination), set size to '-' + * var... List of the names of the only variables that get imported from + * the environment at address 'addr'. Without arguments, the whole + * environment gets imported. */ static int do_env_import(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -1026,6 +1031,7 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, int fmt = 0; int del = 0; int crlf_is_lf = 0; + int wl = 0; size_t size;
cmd = *argv; @@ -1074,9 +1080,9 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, addr = simple_strtoul(argv[0], NULL, 16); ptr = map_sysmem(addr, 0);
- if (argc == 2) { + if (argc >= 2 && strcmp(argv[1], "-")) { size = simple_strtoul(argv[1], NULL, 16); - } else if (argc == 1 && chk) { + } else if (chk) { puts("## Error: external checksum format must pass size\n"); return CMD_RET_FAILURE; } else { @@ -1098,6 +1104,9 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, printf("## Info: input data size = %zu = 0x%zX\n", size, size); }
+ if (argc > 2) + wl = 1; + if (chk) { uint32_t crc; env_t *ep = (env_t *)ptr; @@ -1112,9 +1121,10 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, ptr = (char *)ep->data; }
- if (himport_r(&env_htab, ptr, size, sep, del ? 0 : H_NOCLEAR, - crlf_is_lf, 0, NULL) == 0) { + if (!himport_r(&env_htab, ptr, size, sep, del ? 0 : H_NOCLEAR, + crlf_is_lf, wl ? argc - 2 : 0, wl ? &argv[2] : NULL)) { pr_err("Environment import failed: errno = %d\n", errno); + return 1; } gd->flags |= GD_FLG_ENV_READY; @@ -1242,7 +1252,7 @@ static char env_help_text[] = #endif #endif #if defined(CONFIG_CMD_IMPORTENV) - "env import [-d] [-t [-r] | -b | -c] addr [size] - import environment\n" + "env import [-d] [-t [-r] | -b | -c] addr [size] [var ...] - import environment\n" #endif "env print [-a | name ...] - print environment\n" #if defined(CONFIG_CMD_RUN)
base-commit: 8a9dc16e4d07d29fff08b7caca36f0865065f7f7 -- git-series 0.9.1
This tests that the importing of an environment with a specified whitelist works as intended.
If there are variables passed as parameter to the env import command, those only should be imported in the current environment.
For each variable passed as parameter, if - foo is bar in current env and bar2 in exported env, after importing exported env, foo shall be bar2, - foo does not exist in current env and foo is bar2 in exported env, after importing exported env, foo shall be bar2, - foo is bar in current env and does not exist in exported env (but is passed as parameter), after importing exported env, foo shall be empty,
Any variable not passed as parameter should be left untouched.
Two other tests are made to test that size cannot be '-' if the checksum protection is enabled.
v3: - update whitelist test to reflect changes made in patch 1, - add two tests for no size parameter passed but checksum protection is enabled because I added the possibility to have a sentinel in place of size parameter, - I intentionally didn't put the Reviewed and Acked-by of Simon and Stephen since the code changed since v2,
added in v2
test/py/tests/test_env.py | 50 ++++++++++++++++++++++++++++++++++++++++- 1 file changed, 50 insertions(+)
diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index bfb5fc0..b83d2b1 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -5,6 +5,7 @@ # Test operation of shell commands relating to environment variables.
import pytest +import u_boot_utils
# FIXME: This might be useful for other tests; # perhaps refactor it into ConsoleBase or some other state object? @@ -239,3 +240,52 @@ def test_env_expansion_spaces(state_test_env): unset_var(state_test_env, var_space) if var_test: unset_var(state_test_env, var_test) + +def test_env_import_checksum_no_size(state_test_env): + """Test that omitted ('-') size parameter with checksum validation fails the + env import function. + """ + c = state_test_env.u_boot_console + ram_base = u_boot_utils.find_ram_base(state_test_env.u_boot_console) + addr = '%08x' % ram_base + + with c.disable_check('error_notification'): + response = c.run_command('env import -c %s -' % addr) + assert(response == '## Error: external checksum format must pass size') + +def test_env_import_whitelist_checksum_no_size(state_test_env): + """Test that omitted ('-') size parameter with checksum validation fails the + env import function when variables are passed as parameters. + """ + c = state_test_env.u_boot_console + ram_base = u_boot_utils.find_ram_base(state_test_env.u_boot_console) + addr = '%08x' % ram_base + + with c.disable_check('error_notification'): + response = c.run_command('env import -c %s - foo1 foo2 foo4' % addr) + assert(response == '## Error: external checksum format must pass size') + +def test_env_import_whitelist(state_test_env): + """Test importing only a handful of env variables from an environment.""" + c = state_test_env.u_boot_console + ram_base = u_boot_utils.find_ram_base(state_test_env.u_boot_console) + addr = '%08x' % ram_base + + set_var(state_test_env, "foo1", "bar1") + set_var(state_test_env, "foo2", "bar2") + set_var(state_test_env, "foo3", "bar3") + + c.run_command('env export %s' % addr) + + unset_var(state_test_env, "foo1") + set_var(state_test_env, "foo2", "test2") + set_var(state_test_env, "foo4", "bar4") + + #no foo1 in current env, foo2 overridden, foo3 should be of the value + #before exporting and foo4 should be deleted + c.run_command('env import %s - foo1 foo2 foo4' % addr) + + validate_set(state_test_env, "foo1", "bar1") + validate_set(state_test_env, "foo2", "bar2") + validate_set(state_test_env, "foo3", "bar3") + validate_empty(state_test_env, "foo4")
v3:
added in v2
Some nits below
- """Test that omitted ('-') size parameter with checksum validation fails the
- c = state_test_env.u_boot_console
- ram_base = u_boot_utils.find_ram_base(state_test_env.u_boot_console)
- addr = '%08x' % ram_base
- with c.disable_check('error_notification'):
- assert(response == '## Error: external checksum format must pass size')
- """Test importing only a handful of env variables from an environment."""
- set_var(state_test_env, "foo1", "bar1")
Please use ' for strings rather than ", except for the function/class comments
- set_var(state_test_env, "foo2", "bar2")
- set_var(state_test_env, "foo3", "bar3")
- c.run_command('env export %s' % addr)
- unset_var(state_test_env, "foo1")
- set_var(state_test_env, "foo2", "test2")
- set_var(state_test_env, "foo4", "bar4")
- #no foo1 in current env, foo2 overridden, foo3 should be of the value
- #before exporting and foo4 should be deleted
Spaces after each #
- c.run_command('env import %s - foo1 foo2 foo4' % addr)
- validate_set(state_test_env, "foo1", "bar1")
- validate_set(state_test_env, "foo2", "bar2")
- validate_set(state_test_env, "foo3", "bar3")
- validate_empty(state_test_env, "foo4")
-- git-series 0.9.1
On Fri, May 25, 2018 at 9:38 AM Quentin Schulz quentin.schulz@bootlin.com wrote:
are all valid.
v3:
v2:
- env import [-d] [-t [-r] | -b | -c] addr [size]
- env import [-d] [-t [-r] | -b | -c] addr [size] [var ...]
from
whole
cmd = *argv;
if (argc == 2) {
size\n");
size);
if (argc > 2)
wl = 1;
flag,
The addition of a '!' seems like an odd change, but looking at what himport_r() returns, I think you're correct and it's been broken forever.
NULL)) {
environment\n"
git-series 0.9.1
Tested-by: Alex Kiernan alex.kiernan@gmail.com
are all valid.
v3:
v2:
from
whole
cmd = *argv;
if (argc == 2) {
size\n");
size);
if (argc > 2)
wl = 1;
flag,
No. It was if (h_import_r() == 0) before! ^^^^
Lothar Waßmann
Hi Lothar and Alex,
are all valid.
v3:
v2:
from
whole
cmd = *argv;
if (argc == 2) {
size\n");
size);
if (argc > 2)
wl = 1;
flag,
Exactly, with the added ternary conditions, the line exceeds the 80 characters just for the opening bracket. I just replaced the == 0 with a ! to gain a few precious characters and avoid having to do a:
ret = himport_r(); if (!ret)
But I could do it if wanted.
If I had changed the behaviour of the function, I would have made a separate commit for it so it's not hidden in some unrelated code, so, that's just a cosmetic fix here :)
Quentin
On Fri, May 25, 2018 at 12:26 PM Lothar Waßmann LW@karo-electronics.de wrote:
On Fri, May 25, 2018 at 9:38 AM Quentin Schulz <
quentin.schulz@bootlin.com>
exported,
env.
if
will
be unset.
a
are all valid.
for
v3:
addr
v2:
of
the
imported
from
the
whole
flag,
cmd = *argv;
flag,
if (argc == 2) {
size\n");
flag,
size,
size);
if (argc > 2)
wl = 1;
flag,
forever.
I should learn to read properly... thanks and sorry for the noise.
Alex Kiernan
Lothar Waßmann
Quentin Schulz
