Re: [U-Boot] I want to a board(tiny4412) for exyno4412, but I can't get any output
sorry, I sent attach git format-patch directly, it cause the mistake mail, the patch is below. The SPL(bl2) is still the old one from manufacturer, as I don't know how to build a new one. I don't know much debug method, the how to use JTAG of it. Could anyone teach me some of it? Thanks. [PATCH] board: Fix mmc pins and remove some no use gpio.
In my board, the sdcard is in mmc2, and using sd2_cdn to detect. --- board/samsung/tiny4412/tiny4412.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/board/samsung/tiny4412/tiny4412.c b/board/samsung/tiny4412/tiny4412.c index 4f5bfbd..f969866 100644 --- a/board/samsung/tiny4412/tiny4412.c +++ b/board/samsung/tiny4412/tiny4412.c @@ -41,6 +41,8 @@ static void check_hw_revision(void) s5p_gpio_cfg_pin(&gpio2->m1, i, GPIO_INPUT);
/* GPM1[5:2]: HW_REV[3:0] */ + /*In my board, those pins are used for camera*/ + /* GMP0[0:7] and GPM1[0:3] */ for (i = 2; i < 6; i++) { s5p_gpio_cfg_pin(&gpio2->m1, i, GPIO_INPUT); s5p_gpio_set_pull(&gpio2->m1, i, GPIO_PULL_NONE); @@ -87,9 +89,7 @@ static void board_external_gpio_init(void) * if that pin set as input then that floated */
- s5p_gpio_set_pull(&gpio2->x1, 5, GPIO_PULL_NONE); /* IF_PMIC_IRQ*/ s5p_gpio_set_pull(&gpio2->x3, 5, GPIO_PULL_NONE); /* OK_KEY */ - s5p_gpio_set_pull(&gpio2->x3, 7, GPIO_PULL_NONE); /* HDMI_HPD */ }
#ifdef CONFIG_SYS_I2C_INIT_BOARD @@ -114,6 +114,7 @@ static void board_init_i2c(void)
int board_early_init_f(void) { + /*pull up led*/ gpio2 = (struct exynos4x12_gpio_part2 *)EXYNOS4X12_GPIO_PART2_BASE; s5p_gpio_cfg_pin(&gpio2->m4, 1, GPIO_INPUT); s5p_gpio_set_pull(&gpio2->m4, 1, GPIO_PULL_NONE); @@ -206,9 +207,9 @@ int board_mmc_init(bd_t *bis)
/* * Check the T-flash detect pin - * GPX3[4] T-flash detect pin + * GPK2[2] T-flash detect pin */ - if (!s5p_gpio_get_value(&gpio2->x3, 4)) { + if (!s5p_gpio_get_value(&gpio2->k2, 2)) { err2 = exynos_pinmux_config(PERIPH_ID_SDMMC2, PINMUX_FLAG_NONE); if (err2) debug("SDMMC2 not configured\n"); -- 1.8.4.rc3
randy
